few question to finish my accoustic panels - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-28-2010, 07:15 PM - Thread Starter
montrealht's Avatar
now i understand i have to treat the screen wall, do i have to treat it behind too? or just side of it. should i use 1 or 2 inches thick? and finally what kind of fabric should i use? what is the breath test? its been few months i'm reading and reading, i have come to understand a few things here and there. where should i use diffuser?
montrealht is offline
post #2 of 3 Old 08-28-2010, 07:22 PM - Thread Starter
montrealht's Avatar
what is GOM? batting and insushield? english is not my first language and would like to understand what fabric should i use!
post #3 of 3 Old 08-29-2010, 04:19 AM
Dennis Erskine's Avatar
Quoted: 64 Post(s)
Liked: 100
Derrière le mur d'écran:
- Deux 1 "couches de revêtement InsulShield Noire. Installer 3mil feuilles en poly (plastique) entre les couches.
- GOM est Guilford du Maine. Typiquement Guilford of Maine FR701 type de tissu.
- «batting» fait référence Ã* ouate de polyester, généralement vous trouverez cette utilisés pour faire des courtepointes.
- InsulShield est un produit isolants Johns Manville, qui est (a) noir et (b) revêtu pour lui permettre d'être exposés Ã* l'air libre.
Votre anglais est meilleur que mon français.
Behind the screen wall:
- Two 1" layers of coated InsulShield Black. Install 3mil poly sheeting between the layers.
- GOM is Guilford of Maine. Typically Guilford of Maine FR701 type fabric.
- "batting" refers to polyester batting, typically you'll find this used to make quilts.
- InsulShield is a Johns Manville insulation product which is (a) black and (b) coated to allow it to be exposed to free air.
Dennis Erskine CFI, CFII, MEI
Architectural Acoustics
Subject Matter Expert
CEDIA Board of Directors
www.erskine-group.com
Dennis Erskine is offline
