It's not small...it's "intimate" - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 45 Old 02-14-2011, 06:42 PM - Thread Starter
Jon_B's Avatar
Quoted: 25 Post(s)
I use to wonder how someone could take years to finish their basement. Now I can see how time flies when life keeps you busy.
Not much progress to brag about. Insulation is 90% done in the entire basement. That is all to report for now.
Jon_B is offline
post #32 of 45 Old 02-15-2011, 02:56 AM
elmalloc's Avatar
Quoted: 28 Post(s)
Liked: 44
A person commented in my thread how it took them 5 years to finish their theater, because they are doing what I'm doing - every month you have X dollars of cash, and you use that - but you may only work during the winter (landscaping takes precedence in the summer).
I'm currently at 1 month so far and I think I'm about 65% done, have to finish by spring!
Current Projects:
ON HOLD - Building Home Gym.
elmalloc is online now
post #33 of 45 Old 02-16-2011, 02:11 AM - Thread Starter
Jon_B's Avatar
Quoted: 25 Post(s)
My wife would kill me if I even joked about it taking that long. I've been following your build and will continue to do so.
Jon_B is offline
post #34 of 45 Old 04-09-2011, 03:22 PM - Thread Starter
Jon_B's Avatar
Quoted: 25 Post(s)
Most of my clips are up on the ceiling. Just need to put some xps rigid foam to be used in the joist that faces the outside wall. After that I need to fix a few 2x4's that are askew from the others. Then I should be ready for drywall!
Sherwin-Williams had a discount going on, so I picked up some paint while it was cheaper.
Pictures will follow when more progress has been made.
Jon_B is offline
post #35 of 45 Old 04-04-2012, 08:33 AM - Thread Starter
Jon_B's Avatar
Quoted: 25 Post(s)
Progress...at least that's what these pictures are being used in an effort to claim progress.
Jon_B is offline
post #36 of 45 Old 04-04-2012, 08:34 AM - Thread Starter
Jon_B's Avatar
Quoted: 25 Post(s)
Jon_B is offline
post #37 of 45 Old 04-04-2012, 08:35 AM - Thread Starter
Jon_B's Avatar
Quoted: 25 Post(s)
Jon_B is offline
post #38 of 45 Old 04-04-2012, 08:36 AM - Thread Starter
Jon_B's Avatar
Quoted: 25 Post(s)
start of second layer
Jon_B is offline
post #39 of 45 Old 04-04-2012, 08:45 AM - Thread Starter
Jon_B's Avatar
Quoted: 25 Post(s)
I'm all about the "green"
Jon_B is offline
post #40 of 45 Old 04-09-2012, 08:15 AM - Thread Starter
Jon_B's Avatar
Quoted: 25 Post(s)
Looking back at my last posts, I realize how bad of picture my cell phone takes. I'll try not to use that again.
Jon_B is offline
post #41 of 45 Old 04-09-2012, 11:55 PM
Scopeguy's Avatar
Another option for the front of the room if you are planning on using an acoustically transparent screen is to go with on wall speakers. My theater is quite small and I didn't want to lose 3 feet behind a false wall. With my setup I only lose 7 inches. Just something to consider.
Drywall is looking good. Are you doing it yourself?
Greg
Scopeguy is offline
post #42 of 45 Old 04-10-2012, 02:26 PM
stockmonkey2000's Avatar
Your making good progress. Taping and Mudding seems to be the spot that slows down a lot of people. Keep up the pace during that and you'll be set.
stockmonkey2000 is offline
post #43 of 45 Old 04-11-2012, 06:16 PM - Thread Starter
Jon_B's Avatar
Quoted: 25 Post(s)
Greg
Thanks Greg. I am doing the drywall myself. I am still planning to hire out the taping and mudding.
I agree with your suggestion of on wall speakers. If I find one that is designed to be used that way, and I can afford them I will definitely look into it.
Jon_B is offline
post #44 of 45 Old 06-14-2012, 07:51 AM
Just add water and stir
zuluwalker's Avatar
Quoted: 46 Post(s)
Liked: 490
Jon great work!
Looks fabulous, all this hard work will be worth it. Your room is going well, and you will always know what went into it...so it sounds better as a result! wink.gif
zuluwalker is offline
post #45 of 45 Old 08-27-2012, 05:35 PM
Mr.Tim's Avatar
Quoted: 277 Post(s)
Liked: 180
Wow, you remind me so much.. of me!
I literally finished the drywall today.. and only because I had spackled everything else. So I had to finish. Those little pieces are such a PITA.
It's definitely a milestone when you can cross drywall off the list. The stuff that remains do be done is not so enormous as to be overwhelming. Drywall is definitely intimidating when you do it yourself.
Hang in there!!
Tim
Mr.Tim is offline
