Home Theater Demo Disc - Version 2.0 - Page 22 - AVS Forum | Home Theater Discussions And Reviews
post #631 of 1695 Old 08-21-2011, 06:49 PM
mpivovar's Avatar
Using Bitcomet I am getting slow download rates of the torrent. Also only says 3 seeds connected. At this rate should be another week untill I have it.
mpivovar is offline
post #632 of 1695 Old 08-21-2011, 07:40 PM
StrikeOne33's Avatar
Sounds like you have the old torrent, go to the disc's page and download the "new" torrent.
StrikeOne33 is offline
post #633 of 1695 Old 08-21-2011, 10:02 PM
mpivovar's Avatar
Taking off now... all I did was shut down torrent and restart it.... now tons of seeders and much faster download.
mpivovar is offline
post #634 of 1695 Old 08-22-2011, 12:48 AM
Taxi's Avatar
Liked: 24
[Sorry, the question was already answered. Deleted.]
Taxi is offline
post #635 of 1695 Old 08-22-2011, 06:24 AM
Vinculum's Avatar
Quoted: 13 Post(s)
I'd like to thank Scubasteve for putting together this demo disc and helping with burning instructions. Thanx man! I'll be seeding this for awhile yet..
Dr V
Vinculum is offline
post #636 of 1695 Old 08-22-2011, 07:54 AM
shadowcaster's Avatar
Originally Posted by FraggleRock View Post
I did use Steve's suggestion of 1300 ms off the front to address the pixelization. I only got length errors on three files - 27, 32, and 39 (eliminating the nudity on Baraka) and I just clicked the Fix Length button to correct them. After that, I browsed through every clpi file using the tool and nothing else headers or otherwise) came up in red with errors on any of the files. This was all done on the files Steve provided afterwards minus the streams directory.
I've got 25 minutes left on the burn (2x BD-RE media) and then I'll be able to test it
UPDATE: Well, trimming 00027, 00032, and 00039 all seemed to work fine using the modified cpli files by CLIPINF Editor v0.05. I did notice that if I fast-forward through one of the modified clips at more than 1.5X speed that the video won't sync until I push play again whereas it does just fine on the unmodified clips. I'm going to try the 00027 and 00032 files that Steve just uploaded (thanks) and see if they make a difference on the fast-forward/reverse syncing of the picture beyond 1.5X on when played back on the PS3. I also noticed that now on 00039 (the Baraka clip) that the video just stays freeze framed from 132 seconds until the 4 minute mark. This works for me as my goal was to eliminate the nudity. It would be nice to figure out how to just make the clips stop playing and return to the menu but I'm happy regardless. What file indicates the total clip runtime for 00039? I was thinking updating the length using that CLIPINF Editor v0.05 tool would have done it but either isn't doing it fulling as Steve indicated may happen or that info is coming from somewhere else like the .mpls file, etc.
Clipinf editor is a beta program that hasn't been updated in 2 years. I don't always trust it. BTW, the header info isn't in red but the "Fix Header" button is active, which is the indication. Steve expalined why and it makes perfect sense.
The files that indicate the total runtime are the playlist files, *.mpls, in the case of Baraka, 00064.mpls. There is an easy, all in one solution, to fix the FF and return to menu issues. I'll use Baraka as the example (one drawback is that the Popup menu will no longer be available for this clip-due to the mpls file):
1. Using Tsmuxer, drag 00039.m2ts into the "input" window.
2. Set the output to "Blu-ray disc" and browse to a destination folder of your choice. ( I just create a temp folder on the hd)
3. On the "Blu-ray" tab, under "options", set the "First MPLS file" to 64 and the "First M2TS file" to 39.
4. On the Split & cut tab, check "enable cutting". As Steve stated, leave "start" at zero and "end" @ 132 sec.
5. Then "Start muxing", only takes a min or two.
6. Navigate to the Home Theater BDMV, Clipinf folder. Then rename 00039.clpi to some other extension, such as "bak".
7. Next, go to the Playlist folder and rename 00064.mpls, as above.
8. Next, go to the Stream folder and rename 00039.m2ts as well.
9. Final steps are to copy the same 3 files, from the Blu-ray folders that you created, into the Home Theater folders.
10. You will now have a fully functional Baraka clip that will FF and return to menu normally. All timestamps are correct, just no popup menu.
____________________________________________________________ _______________________
Follow similiar steps for Master and Commander and iRobot. (although Steve used 1300 ms, I used 1 sec as the cut point and pixelation was completely eliminated.) However, in this case do not replace the mpls files. (this will keep the pop up menu option)
Master and Commander: 00027.clpi, 00027.m2ts,
iRobot : 00032.clipi, 00032.m2ts,
Edit: Steve, obviously feel free to use any of this to update page 1, if you wish.
"Talk to me Goose"
shadowcaster is offline
post #637 of 1695 Old 08-22-2011, 08:06 AM
Mpray1983's Avatar
Hey I'm not trying to be a punk or anything I was just wondering about the legality of this because I have seen other threads where people talk about downloading movies and the mods shut them down. Granted these were entire movies and not clips. This is purely out of curiosity.
Mpray1983 is offline
post #638 of 1695 Old 08-22-2011, 08:52 AM
antbatt13's Avatar
If I order this disc from you Steve, will it come with a printed image on the actual disc? Also, will the jacket be blank or be "labeled?"
If not, can somehere here get that done for me?
Thank you for all the time and effort you put into this!
antbatt13 is offline
post #639 of 1695 Old 08-22-2011, 09:05 AM - Thread Starter
scubasteve2365's Avatar
Quoted: 262 Post(s)
Liked: 356
The files that indicate the total runtime are the playlist files, *.mpls, in the case of Baraka, 00064.mpls. There is an easy, all in one solution, to fix the FF and return to menu issues. I'll use Baraka as the example (one drawback is that the Popup menu will no longer be available for these clips):
10. You will now have a fully functional Baraka clip that will FF and return to menu normally. All timestamps are correct.
Follow the same steps for Master and Commander and iRobot. (although Steve used 1300 ms, I used 1 sec as the cut point and pixelation was completely eliminated.)
Master and Commander: 00027.clpi, 00027.m2ts, 00030.mpls
iRobot : 00032.clipi, 00032.m2ts, 00035.mpls
This is good information but you should understand the each clip is in 6 different playlists. For example Baraka is in:
1) wide visuals baraka
2) wide visuals play all
3) wide play all
4) scope visuals baraka
5) scope visuals play all
6) scope play all
"The Scuba Tank" thread here
PSN/XBL/Steam : ScubaSteve2365 - PC = i7-4790k, GTX 1080Ti, 32GB Ram, 500G SSD, 14TB HDDs
My VR Podcast on Youtube - VR Roundtable - Vive, Playstation VR, and Rift Owner
scubasteve2365 is offline
post #640 of 1695 Old 08-22-2011, 09:06 AM - Thread Starter
Quoted: 262 Post(s)
Liked: 356
I don't include any prints but the files are made available if you want to print them out yourself.
post #641 of 1695 Old 08-22-2011, 09:09 AM - Thread Starter
Quoted: 262 Post(s)
Liked: 356
This is obviously different than a thread regarding movie piracy but probably a thin line regardless. I'd say that it's best not to bring attention to it. I've asked that the torrent link not be directly posted for this reason.
post #642 of 1695 Old 08-22-2011, 09:25 AM
3) wide play all
6) scope play all
Ooops, yes, I missed that. Was addressing your's and Fragglerock's post and it didn't even occur to me re the other locations, because you hadn't mentioned it.
"Talk to me Goose"
post #643 of 1695 Old 08-22-2011, 10:33 AM
AirBenji's Avatar
Quoted: 35 Post(s)
Liked: 84
Just received my disc in the mail today from Steve and wanted to say thanks publicly. Super-fast delivery - just in time for my mini-meetup tonight! Thanks Steve!
AirBenji is offline
post #644 of 1695 Old 08-22-2011, 10:44 AM
marky301067's Avatar
Quoted: 61 Post(s)
Liked: 55
Hi Steve, I just finished downloading your demo disc this morning, I am loving all the content that you have out on it especially War of the Worlds, I have not felt bass like that since the tank scene in Saving Private Ryan One question: I run most of these files from my OPPO 93 from a hard drive, I would like to try burn a copy to disc to use when I do not want to use my drive, my files are showing at 46.1 gig! I started downloading when you first released the torrent then downloaded the 2nd torrent, are there extra files in there somewhere that i have to remove?
An amazing job once again
Mark
Dali: Epicon / Paradigm: Sub 1 / Plinius: Tautoro / SB301 / Toko / Anthem: MRX1120 / Oppo: 205 / JVC Dila: 950 / Apple: IpadProd 12.9 V2
marky301067 is offline
post #645 of 1695 Old 08-22-2011, 11:06 AM
canuckerfan's Avatar
3) wide play all
6) scope play all
is there anyway all the files could be updated so that the trimmed clips won't act fussy during fast forward?
canuckerfan is offline
post #646 of 1695 Old 08-22-2011, 11:19 AM
smakovits's Avatar
Quoted: 33 Post(s)
What is the easiest way to get a bdmv folder to play on a PCH A-210? I try to point right to it and it says unable to play...
I know the files work cause they play on the computer.
smakovits is offline
post #647 of 1695 Old 08-22-2011, 11:23 AM - Thread Starter
Quoted: 262 Post(s)
Liked: 356
The play all playlists would be better suited by re-authoring in scenarist because otherwise someone would have to know what items are in the playlist. The are 3 playlists per "play all". One playlist as the 264 video, another playlist has the VC1 video and another with the Mpeg Video. Scenarist won't let you (perhaps it's a BD spec issue) create one playlist that has multiple video types. The play all button then jumps to an HDMV Title that calls those 3 playlists in order (and then a 4th main menu playlist so as to return to the menu.)
This would mean that those three stream files would then have to be shared again which then means a new torrent.
I'll look into it when I get a chance.
post #648 of 1695 Old 08-22-2011, 11:25 AM - Thread Starter
Quoted: 262 Post(s)
Liked: 356
I don't think the A-210 support Full Bluray Discs, it only does what is referred to as a BD-Lite, which means that it won't be able to read the disc menu.
My C-200 plays it flawlessly.
post #649 of 1695 Old 08-22-2011, 11:32 AM
antbatt13's Avatar
I don't have the capability to print on a disc
post #650 of 1695 Old 08-22-2011, 11:37 AM - Thread Starter
Quoted: 262 Post(s)
Liked: 356
Neither do I.
You can also print to a label and apply it.
The case cover can be printed by any regular printer. I find that to be good enough in my opinion.
post #651 of 1695 Old 08-22-2011, 11:59 AM
Kalani's Avatar
Quoted: 110 Post(s)
Liked: 26
Neither do I.
Avery sells adhesive disc labels should suffice for those who don't have disc-printing-capable inkjets (and printable discs). (something like this, which you should be able to find at any Staples, Office Depot, etc., or online)
Printing the actual case cover is super easy, just print the JPG included in the torrent as large as you can (landscape, on standard 8.5x11 paper) within the normal limits of the printer margin capabilities (meaning, max that the printer will let you, no 1" margins or anything like that), and then cut it out with scissors, seems to work great. I've used MS Paint, PhotoShop and ACDsee on three different color printers (two HP color laserjets and a massive Konica color copier) and they all seem to print it just fine without any tweaking.
Kalani is offline
post #652 of 1695 Old 08-22-2011, 12:02 PM
I've just been playing around with this some more and, interestingly enough, the FF issue doesn't appear in the "scope" mode or the "play all" in the sub menu. Haven't tried the main "play all" yet as there are a lot of scenes to scan through to find those 2 (I didn't modify Baraka permanently).
Steve, note I've edited my post #641 to reflect no mpls change for M&C and iRobot. This keeps the pop up menu option and allows normal fast forwarding at multiple speeds.
"Talk to me Goose"
post #653 of 1695 Old 08-22-2011, 02:36 PM
smakovits's Avatar
Quoted: 33 Post(s)
Think I found it, will report tonight.
the latest A-210 firmware was updated to support full menus, I guess what I am missing is the setting to enable the use of these...should know more tonight and will report back.
post #654 of 1695 Old 08-22-2011, 05:48 PM
The yeti's Avatar
Anyway someone can post up the cover and disc label? I bought the disc and really don't want too download the whole thing just for these two images.
Thank you
The yeti is offline
post #655 of 1695 Old 08-22-2011, 05:55 PM
globalgreg's Avatar
Liked: 29
Thank you
With uTorrent (and I assume most torrent clients) you can select what files you download.
globalgreg is offline
post #656 of 1695 Old 08-22-2011, 05:59 PM
HopefulFred's Avatar
Quoted: 521 Post(s)
Liked: 484
I imagine someone can, and that may be the simplest for you, but be aware that you can load whatever folders you want. If you already had a torrent client, you'd probably know this, but maybe not...
Download the torrent file from Steve's website. When you open it in your torrent client, the dialog will allow you to select/deselect which ever folders/files you want, and it will only download those you've requested. You'll be finished in about 30 seconds.
On the other hand if doing that means downloading and installing software you won't use again... maybe someone can help you out.
Fred
Edit: I see below that Steve is going to post them, but check out post 380 in this thread, where Stew4msu posted his.
HopefulFred is offline
post #657 of 1695 Old 08-22-2011, 06:05 PM - Thread Starter
Quoted: 262 Post(s)
Liked: 356
Thank you
I'm going to get them posted for you. I'm on my mobile right now. I keep forgetting to it but I'll get them up soon.
post #658 of 1695 Old 08-22-2011, 06:55 PM
dfergie's Avatar
Quoted: 30 Post(s)
Liked: 35
The cool thing about the popcorn is you can make the play a disc image bigger than an actual DL disc... (authoring a 56 gig image now for later)
dfergie is offline
post #659 of 1695 Old 08-22-2011, 08:47 PM
The yeti's Avatar
Thank you very much
The yeti is offline
post #660 of 1695 Old 08-22-2011, 09:38 PM
the_abbot's Avatar
Quoted: 228 Post(s)
Liked: 38
Thanks for all of your hard work Steve! The disc is awesome!!!
Current setup: JVC RS55 - Marantz 7008 - Dune Solo 4K - Kodi/Chromebox - Cinema 10's LCR - Volt 10 Surrounds - Polk in wall rear & ceiling - eD A7-450
the_abbot is offline
