JapanDave dedicated theater build. - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 5Likes
post #91 of 615 Old 11-04-2010, 09:48 AM - Thread Starter
JapanDave's Avatar
Quoted: 160 Post(s)
Liked: 116
Originally Posted by Dixon View Post
That makes sense to me. If the room is sealed concrete, including the ceiling, I suspect the only leakage concern (apart from any holes you cut in it) would be something clicking/banging on the concrete. That doesn't appear to be an issue for you.
Thx. Cool space.
No worries, like I said I am no expert and it good to be kept on my toes.
My build thread
My 8 x RE XXX 18" Subwoofers, IB build
Couldn't pour water out of a boot with instructions on the heel.
Do you know what Nemesis means?
JapanDave is offline
post #92 of 615 Old 11-04-2010, 10:06 AM
Hughman's Avatar
Thanks for all the pics, great detail on the building methods.
When the acoustic plan for the room was being developed was your input sought when determining a target RT60 for the room or was it left completely with the designer? I find it impressive and speaks highly of the skill of the desginer that a complete arms length acoustical plan can be developed to achieve set goals including satisfactory RT60 plot. To that end is specific seating and carpeting also outlined in the HT plan? Also, are there provisions when the build is complete for an acoustic testing phase which would identify any areas which may require a few wiggle changes for the ratio of aborption/reflection/diffusion?
Anyways, outstanding build and design.
Hughman is offline
post #93 of 615 Old 11-04-2010, 04:20 PM - Thread Starter
JapanDave's Avatar
Quoted: 160 Post(s)
Liked: 116
Hey Hughman, thanks for stopping by.
The acoustics were left completely up to the designer, I am just assuming that the desirable RT60 is within a certain range and Dennis made the plans accordingly. Something that I have not thought about, but Dennis has said that there is a lot of absorption in the room and I should not have a problem with the very low frequencies. I know that is open for interpretation, but I plan on taking measurements(This is not included in the agreement, but if changes or adjustments are needed I am sure I will have Dennis's help in one way or another.)
As for the carpet, specific carpet and underlay are part of the initial designs. Seating type was not talked about except the number of seats that was going to be used.
Thanks for the words of encouragement
My build thread
post #94 of 615 Old 11-04-2010, 05:26 PM
Dennis Erskine's Avatar
Quoted: 64 Post(s)
Liked: 100
It is very difficult to ever consider seating within the context of acoustics in a residential sized room. The biggest single show stopper is that none of the available home theater seats or recliners have been measured under various conditions...yet
Dennis Erskine CFI, CFII, MEI
Architectural Acoustics
Subject Matter Expert
CEDIA Board of Directors
www.erskine-group.com
Dennis Erskine is offline
post #95 of 615 Old 11-04-2010, 06:23 PM - Thread Starter
JapanDave's Avatar
Quoted: 160 Post(s)
Liked: 116
Dennis , very good point, especially since my room is not considered big.
Edit: I also wanted to add, that it would be pretty difficult for Dennis to make appropriate measurements when I am here in Japan, especially not knowing what equipment I have.
My build thread
post #96 of 615 Old 11-04-2010, 06:42 PM
Mike_WI's Avatar
Quoted: 123 Post(s)
Liked: 76
Yet.
Mike
HT: Oppo UDP-203 -> Lumagen RadiancePro 4446 {18 GHz input x2 & output x1 cards} - parallel outs to --> [Audio: Denon 5308CI] --> [Video: JVC RS520]
HT Details: link
Mike_WI is online now
post #97 of 615 Old 11-04-2010, 07:12 PM
Hughman's Avatar
Great information, thanks. Regarding the post build acoustic analysis I was thinking along the lines of what you are planning to do. Do the measurements yourself following explicit instructions from the designer and he/she would interpret the results and outline any necessary tweaks if required.
"and I should not have a problem with the very low frequencies"
Seeing what subs you're installing the only problem I would anticipate is your eardrums exploding and lodging malleus shrapnel in your brain, other than that you should be fine.
Hughman is offline
post #98 of 615 Old 11-04-2010, 07:36 PM - Thread Starter
JapanDave's Avatar
Quoted: 160 Post(s)
Liked: 116
That sounds like a great plan. Of coarse I recommend Dennis to do you designs, very professional and his responses to any queries I had were answered very quickly. I really did have piece of mind when finalizing everything from the designs to payment, considering I am here in Japan. Something I have not actually thanked Dennis for yet. Of I understand it is entirely up to you, just wanted to share my experiences.
I forgot to mention these 2 of these dual firing 15" Submersives will also be incorporated into the room, so I will have 4 sub enclosures in room. The Submersives will be going at the back of the room.
My build thread
post #99 of 615 Old 11-04-2010, 08:00 PM
Hughman's Avatar
Yes, that arrangement should suffice. Has sub placement also been predetermined?
Hughman is offline
post #100 of 615 Old 11-04-2010, 08:10 PM - Thread Starter
JapanDave's Avatar
Quoted: 160 Post(s)
Liked: 116
Only the front two behemoths. The two submersives are going to go somewhere in the region of 24" to 50" from the back wall as close to the side wals as they are allowed to go. Mark (Seaton) is expecting a dip in the 35-50hz region at the seating postion and they will be there to cover that.
We have discussed crossing the Terraforms XL'S around that frequency and allowing the submersives to handle the upper bass in the LFE. I don't really have anything set in stone yet , as I want to hear the system set up and measure it to see what needs to be done.
My build thread
post #101 of 615 Old 11-04-2010, 08:23 PM
Hughman's Avatar
Good plan, very similar to how I ended up utilizing my subs.
On another note, the word "Malleus" (inner ear hammer) would be a great speaker company name, speaker name, subwoofer name or theater name. Should anyone reading this decide to use this name I would expect certain considerations.
Hughman is offline
post #102 of 615 Old 11-04-2010, 08:39 PM - Thread Starter
JapanDave's Avatar
Quoted: 160 Post(s)
Liked: 116
I just hope I have the smarts to implement this plan!
Now you mention it, I still have not named my theater. Maybe I should let my 6 year old son decide.
My build thread
post #103 of 615 Old 11-04-2010, 09:04 PM
Moggie's Avatar
Quoted: 23 Post(s)
Liked: 33
That's an interesting setup. I have immovable IB subs at the front and slightly movable sealed subs at the rear -- both subs are close to the center line of the room. I'm not ready to perform final calibration but recently I purchased a Berhinger DCX2946 to allow messing with time/phase alignment and equalization of the pairs of subs whilst using REW's RTA monitor to watch the effects. It's fascinating stuff and I would be interested on more details on how you approach this.
BTW As somebody who is 18 months into my HT I'm having fun watching the speed of your build!
Cheers!
My "Old Vic" Theater Build | Screen Build | HT of the Month | Contest Win
My 8 year old daughter: "are contractors the people that mess up your house for money?"
Moggie is offline
post #104 of 615 Old 11-04-2010, 09:18 PM - Thread Starter
JapanDave's Avatar
Quoted: 160 Post(s)
Liked: 116
Cheers!
Just want to say again that your build is amazing!
I will do my best to post everything I end up doing when crossing these subs. I know it is going to take a long time to get the right position of the subs and crossover. By then I hope I will have enough knowledge to give some good advise.
It is moving fast, but preparations for it nearly total one year and that includes getting materials and making them.
My build thread
post #105 of 615 Old 11-05-2010, 02:33 AM
DavidinCT's Avatar
Quoted: 243 Post(s)
Liked: 67
Cool, Gota see how this one comes out...Subbed !!!!
Looks good so far....
-Dave
MCSE 2003
Windows Media Center specialist - MVP and Certified Home Theater specialist
Avid gamer and home theater junkie..
DavidinCT is offline
post #106 of 615 Old 11-05-2010, 04:44 AM
Quoted: 64 Post(s)
Liked: 100
Yet.
The "fix" is underway but I'll say nothing beyond that.
...always up for a trip to Japan.
post #107 of 615 Old 11-05-2010, 05:36 AM - Thread Starter
JapanDave's Avatar
Quoted: 160 Post(s)
Liked: 116
If that is the case, I am always up to have a guest. Maybe we can talk about this some more.
My build thread
post #108 of 615 Old 11-05-2010, 05:44 AM - Thread Starter
JapanDave's Avatar
Quoted: 160 Post(s)
Liked: 116
More updates.
The screen wall is done, minus the black acoustically transparent fabric. Also if you look at previous pics there were orange conduits. Finally got them cleaned up and out of site.
A shot from the side, sorry for all the junk.
A shot above the screen with the acoustic treatments and fabric in place. Forgive the plastic, the room is still really dusty.
The original lights removed and ready to have covers placed on them.
All the sofits acoustic treatments are complete with the fabric in place. Just have to get the wood trim sorted and attached and they will be done, minus the lights.
Apic of the material I used for the sofits,
My build thread
post #109 of 615 Old 11-05-2010, 09:27 AM
Mike_WI's Avatar
Quoted: 123 Post(s)
Liked: 76
Wow!
I can hardly wait to here about the (?) Dennis visit and graphs of FR curves.
Mike
HT Details: link
post #110 of 615 Old 11-05-2010, 05:14 PM - Thread Starter
JapanDave's Avatar
Quoted: 160 Post(s)
Liked: 116
Originally Posted by Mike_WI View Post
Wow!
Mike
I just hope Dennis likes beer, b/c nothing beats Japanese beer IMO.
BTW, the painters are in today the paint the sound proof doors and anything else that needs it.
My build thread
post #111 of 615 Old 11-05-2010, 05:34 PM
Elill's Avatar
Quoted: 98 Post(s)
Liked: 89
Is the door as narrow as it looks in the photo?
Peter the Greek
Downunder Theatre MkII
List of Pro Designers
Elill is offline
post #112 of 615 Old 11-05-2010, 06:57 PM - Thread Starter
JapanDave's Avatar
Quoted: 160 Post(s)
Liked: 116
It certainly is. Would you like me to take a pic of what is behind there? BTW, that is not the entrance, it is an access door for a room full of filters for my 2000g fish tank upstairs.
I will post a pic of the tank in the living room.
My build thread
post #113 of 615 Old 11-05-2010, 06:58 PM - Thread Starter
JapanDave's Avatar
Quoted: 160 Post(s)
Liked: 116
Dave
Looking good
How is your HT space in relation with the rest of the house it looks like a bunker but all the better to crank up those Subs.
The rest of the house is a bunker too! A bunker with windows!
My build thread
post #114 of 615 Old 11-05-2010, 08:26 PM
Elill's Avatar
Quoted: 98 Post(s)
Liked: 89
Please do!
Ah ok, I thought that was the entry door
Peter the Greek
Elill is offline
post #115 of 615 Old 11-05-2010, 10:05 PM - Thread Starter
JapanDave's Avatar
Quoted: 160 Post(s)
Liked: 116
Here is a close up pic of the 2000g tank. The biggest fish on the left is about 3' long for size reference.
Balbolito likes this.
My build thread
post #116 of 615 Old 11-05-2010, 10:57 PM
Anthony A.'s Avatar
you obviously havent been to germany then!
Anthony A. is offline
post #117 of 615 Old 11-05-2010, 11:16 PM
FusionRx's Avatar
Or Belgium then...
FusionRx is offline
post #118 of 615 Old 11-05-2010, 11:47 PM
theWalkinator's Avatar
No beer, Japanese is all about sake, sushi and geisha ...
theWalkinator is offline
post #119 of 615 Old 11-05-2010, 11:52 PM
Anthony A.'s Avatar
Originally Posted by FusionRx View Post
Or Belgium then...
thats my second favorite!!!!!
too much choice though in belgium, apparently they have the most variety in the world. thank all the monks for that.
post #120 of 615 Old 11-06-2010, 03:08 AM
Elill's Avatar
Quoted: 98 Post(s)
Liked: 89
That is totally cool.......how much time do you spend cleaning it? or does the filtration system look after it?
Peter the Greek
Elill is offline
