Fetch's Theater Build - 95% complete!!! - Page 6 - AVS Forum | Home Theater Discussions And Reviews
post #151 of 176 Old 09-09-2013, 07:30 AM
Spaceman's Avatar
Quoted: 45 Post(s)
Liked: 150
Like Vanice, my front wall treatment was already black so I didn't need to cover it. But I did cover my back wall since it had the shiny FSK facing. This stuff is pretty cheap and comes in a wide roll should you decide to cover everything before building your false wall.
Spaceman is offline
post #152 of 176 Old 09-09-2013, 07:31 AM - Thread Starter
cdika17's Avatar
All true. Just friction fit panels around screen. Big's minimalist screen wall design.
Chase "Fetch"
Old Theater Build
New House Build
cdika17 is offline
post #153 of 176 Old 09-10-2013, 03:00 PM - Thread Starter
cdika17's Avatar
I have some of that stuff!! Was going to save it for new house but ill just order more!!
Whoever is gonna buy my house better appreciate this room!!!
Cover OC703, ✔
Chase "Fetch"
Old Theater Build
New House Build
cdika17 is offline
post #154 of 176 Old 09-14-2013, 10:52 PM - Thread Starter
cdika17's Avatar
Update, also for my reference
Paint ceiling and soffits/light tray - 3 coats
paint light gimble trims and vent covers, then install
Build panel door
install both doors
install OC703 on wall, bass traps and cover with fabric
Install auto door stop and bottom
Paint walls a blue/grey
Build screen wall, install screen and make friction fit frames
Carpet riser and floor (HD's Platinum Plus Wondrous , Color -Yorktown, 286 sq ft)
Install theater seating
Build Columns, wrap in fabric, install
Install trim around room
Build acoustic panels
Install speakers and projector
Party
Chase "Fetch"
Old Theater Build
New House Build
cdika17 is offline
post #155 of 176 Old 09-21-2013, 07:28 PM - Thread Starter
cdika17's Avatar
Goal posts up and 110" 1.78 Carada screen. Looks good me thinks!! I'll pull screen down and paint everything black, re hang and build surrounding panels.
And now the wait for carpet, 2-3 weeks!! Stupid HD. In the mean time I'll build the columns and fabric frames. Then once carpet is in, I'll add the trim, install columns, do the final wiring, hang acoustic frames, install speakers/projector, calibrate and boom, Bobs your uncle.
Chase "Fetch"
Old Theater Build
New House Build
cdika17 is offline
post #156 of 176 Old 09-26-2013, 09:59 PM - Thread Starter
cdika17's Avatar
Cleaned up the room.
Chase "Fetch"
Old Theater Build
New House Build
cdika17 is offline
post #157 of 176 Old 09-27-2013, 08:36 AM
dvmiller's Avatar
Looking good Fetch. It was frustrating waiting for HD on my carpet install too. They did do a good job on the install though. Hope yours goes well too. It will transform your room dramatically.
dvmiller is offline
post #158 of 176 Old 09-29-2013, 06:09 AM
GWCR's Avatar
Quoted: 17 Post(s)
Liked: 39
Looks like your heading down the home stretch! Great looking room. Keep up the good work!
GWCR is offline
post #159 of 176 Old 09-29-2013, 07:22 AM - Thread Starter
cdika17's Avatar
Thanks for stoppn in! Yah can't believe it took me this long to get to this point. Still have a bit to go, hopefully get it finished by Halloween.
Chase "Fetch"
Old Theater Build
New House Build
cdika17 is offline
post #160 of 176 Old 09-29-2013, 12:23 PM
doublewing11's Avatar
Quoted: 229 Post(s)
Liked: 968
Wow.............almost done! After two years bet you're ready for a cold one while sitting back watching a movie!!
doublewing11 is offline
post #161 of 176 Old 09-29-2013, 12:52 PM - Thread Starter
cdika17's Avatar
More pumped for NFL and NHL, go 49's and Leafs!!!
Chase "Fetch"
Old Theater Build
New House Build
cdika17 is offline
post #162 of 176 Old 10-08-2013, 11:18 AM - Thread Starter
cdika17's Avatar
Installed surrounds.
Actually found an amazing deal on some Niles Stagefront Pro770fx, gonna leave these installed when I sell the house next year and keep my eD slants for new house.
Sides will be in bipole mode and rears in dipole mode.
Chase "Fetch"
Old Theater Build
New House Build
cdika17 is offline
post #163 of 176 Old 10-08-2013, 09:02 PM - Thread Starter
cdika17's Avatar
Build panel door
install both doors
Carpet riser and floor (HD's Platinum Plus Wondrous , Color -Yorktown, 286 sq ft) Hopefully carpet will be in this week.
Install theater seating - out of recommended order but need room in garage to muscle 4 x 8 sheets of 3/4" mdf around for columns, very tight quarters.
Install speakers Did this out of order too just to clear up space in spare room
Install Projector
Calibrate
Party
Chase "Fetch"
Old Theater Build
New House Build
cdika17 is offline
post #164 of 176 Old 10-17-2013, 09:06 PM - Thread Starter
cdika17's Avatar
Shameless bump, Carpet will be installed Wednesday!!
And thank you, yes you, for stopping by. If it were possible, id offer popcorn while you poke around and check out my thread. Also go to my other thread where i start to plan the next house and theater room.
http://www.avsforum.com/t/1471872/the-hillside-estates-house-theater-build-by-fetch/0_100
Chase "Fetch"
Old Theater Build
New House Build
cdika17 is offline
post #165 of 176 Old 10-21-2013, 08:42 AM
GWCR's Avatar
Quoted: 17 Post(s)
Liked: 39
GWCR is offline
post #166 of 176 Old 10-23-2013, 09:52 PM - Thread Starter
cdika17's Avatar
Sneak peek of carpet and seats!!!!
Chase "Fetch"
Old Theater Build
New House Build
cdika17 is offline
post #167 of 176 Old 12-06-2013, 06:38 PM - Thread Starter
cdika17's Avatar
Seeing that it was -40 degrees C today, I got a few things finished in the room.
Tomorrow I hope to have screen wall panels wrapped and trim painted and installed. Then I think I deserve to hang the projector and wire up my racks and then crack a cold one and watch some hockey. Then start the acoustical treatments.
Build panel door
install both doors
Install speakers
Install Projector
Setup racks and install all components
Calibrate
Party
Chase "Fetch"
Old Theater Build
New House Build
cdika17 is offline
post #168 of 176 Old 12-07-2013, 04:12 AM
NGiovas's Avatar
Quoted: 16 Post(s)
Liked: 44
Wow, things are really coming along.  Looks great.
NGiovas is offline
post #169 of 176 Old 12-07-2013, 09:02 AM
Claybe's Avatar
Quoted: 214 Post(s)
Liked: 81
Here are some dimensions:
Seating is basically 12' and 17' from screen wall on sketchup.
I only got 18" of space for a false wall because on my electrical panel, now i don't know the specifics, but i i don't know if that will be sufficient.
I've heard of Infinite Baffle, any links to how to's, threads or users known?
Heard of REW, haven't read to much on it.
Adding a layer of drywall could eventually be a possibility, wonder how that would work for a textured ceiling?
I believe that rattling is in the ceiling somewheres.
Can you tell me what program you used to draw this up? Thanks
Claybe is offline
post #170 of 176 Old 12-07-2013, 09:36 AM - Thread Starter
cdika17's Avatar
http://www.sketchup.com
Chase "Fetch"
Old Theater Build
New House Build
cdika17 is offline
post #171 of 176 Old 12-07-2013, 09:28 PM - Thread Starter
cdika17's Avatar
Craptastic iphone pano.
On to trim tomorrow!
Chase "Fetch"
Old Theater Build
New House Build
cdika17 is offline
post #172 of 176 Old 12-08-2013, 05:44 AM
GWCR's Avatar
Quoted: 17 Post(s)
Liked: 39
GWCR is offline
post #173 of 176 Old 01-06-2014, 12:05 PM - Thread Starter
cdika17's Avatar
95% done!! Just need to do acoustic frames. And get a real camera.
Chase "Fetch"
Old Theater Build
New House Build
cdika17 is offline
post #174 of 176 Old 01-06-2014, 12:38 PM
NGiovas's Avatar
Quoted: 16 Post(s)
Liked: 44
NGiovas is offline
post #175 of 176 Old 01-15-2014, 02:55 PM
jtlong's Avatar
Hi Chase (Fetch),
Fantastic looking theater. How do you like your Fusion 1019 Escape seating?
Did you get the leather or bonded leather? Did you purchase them from Rtheaters (Roman)? How was the shipping costs?
Lots of questions. I am looking at purchasing 4 of the curved chairs.
Any info would be appreciated. Thanks in advance
Joey
jtlong is offline
post #176 of 176 Old 01-15-2014, 09:27 PM - Thread Starter
cdika17's Avatar
Originally Posted by jtlong View Post
Hi Chase (Fetch),
Joey
Bonded leather, from Roman yes. Shipping was ok. Remember to always record any damage to boxes with the person who delivers.
Love the chairs, would buy again.
Chase "Fetch"
Old Theater Build
New House Build
cdika17 is offline
