Show me your Soffit - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 9Likes
post #31 of 58 Old 11-25-2011, 11:14 PM
petew's Avatar
Quoted: 20 Post(s)
Liked: 55
Bacon Race was the final kick in the ass I needed to get started.
Building Bass - Subs
Surrounds - Easy as Pi
Storage - unRAID unDELL
petew is offline
post #32 of 58 Old 01-16-2012, 04:11 PM
cdika17's Avatar
Liked: 26
Lets keep this thread a going!
Chase "Fetch"
Old Theater Build
New House Build
cdika17 is offline
post #33 of 58 Old 01-16-2012, 09:55 PM
blazar's Avatar
Quoted: 711 Post(s)
Liked: 514
The exposed yellow is OC703 Fiberglass. The frames in front of the fiberglass will be covered with GOM fabric with the color of our choice.
I know that the soffit is not exposed in every direction for bass trapping BUT there are so many geometric surfaces comprising the soffit that it should add to the diffusive properties, if not bass trapping.
Jaurhead likes this.
Blazar!
blazar is offline
post #34 of 58 Old 01-16-2012, 10:59 PM
profpatel's Avatar
Love the curves - as I see my house going up and I get to see the cabinet shop do it's thing, I realize just how difficult it is to make curves like that.
Originally Posted by TJ7 View Post
profpatel is offline
post #35 of 58 Old 02-07-2012, 07:52 AM
pyro383's Avatar
all fired up
pyro383 is offline
post #36 of 58 Old 02-07-2012, 08:27 AM
stockmonkey2000's Avatar
My room is not finished yet but I just finished my soffit recently. It was a lot of work but I'm very pleased with how it turned out.
dabsabre and banzaiibc like this.
stockmonkey2000 is offline
post #37 of 58 Old 02-07-2012, 12:09 PM
Roger Dressler's Avatar
Quoted: 1440 Post(s)
Liked: 646
Beautiful design, excellent craftsmanship on the soffits, lighting, and star sky.
The black parts of the soffit look like cloth on frames (maybe stretchy grill cloth)? How are the gray frames made? Wood, then paint? Very impressive. I hope visitors take a moment to look at the screen when you play movies! I'd be looking up.
Deadwood Atmos theater [HTOM]
AV7702 Atmos 7.4.4, SSP-800 PLIIx 7.4
Aerial Acoustics 7B/CC3B fronts, B&W CWM8180 surrounds, Tannoy Di6 DC heights, Hsu ULS-15 subs
Roger Dressler is online now
post #38 of 58 Old 02-07-2012, 01:03 PM
They are frames covered in cloth. The cloth is guilford of maine broadcast fabric in the color Mink. At the rear of the room they are frames made of 3" MDF covered in the fabric. The rear soffit is filled with insulation to act as a bass trap. The panels at the sides of the room are plywood covered with fabric. I made these solid so that it would provide additional isolation of some of the HVAC stuff in the soffit. The panels are held in place with velcro so they can be removed for wiring retrofit later if needed. There are more details in my full build thread.
By the way Roger - Love your theater - I have lots of photos from that bookmarked. Love your combination of gear. I'm also planning on going against the grain here and having floorstanding speakers out in front of the screen and audio is a high priority for me. The center will be behind the screen along with the infinite baffle subs.
post #39 of 58 Old 04-25-2012, 10:23 AM
Here's another update on my soffit.
post #40 of 58 Old 04-25-2012, 12:59 PM
Liked: 42
Wow!!
Ted White is offline
post #41 of 58 Old 01-28-2013, 01:49 PM
CEO FALCON SCREENS
snickers1's Avatar
Quoted: 75 Post(s)
Liked: 116
a borrowed design with small twist
combination of 3/4 mdf and 1/2 mdf for the profile with 2 5/8 crown above and below the soffit .
snickers1 is offline
post #42 of 58 Old 04-15-2014, 06:48 AM
thxonly's Avatar
looks awesome
thxonly is offline
post #43 of 58 Unread 11-04-2014, 02:00 PM
pilla75's Avatar
Wow!! Looks really nice.
pilla75 is offline
post #44 of 58 Unread 01-22-2015, 10:02 AM
DrBabs's Avatar
Quoted: 61 Post(s)
can anyone tell me where the soffits are with the metal channel? I thought I marked it but cant find it anywhere. the metal channel is a drywall strip or a metal stud or something like that. just trying to get the dimensions correct for special order.
DrBabs is offline
post #45 of 58 Unread 01-22-2015, 10:29 AM
Jon_B's Avatar
Quoted: 25 Post(s)
http://www.menards.com/main/mobile/b...127-c-5695.htm
Jon_B is offline
post #46 of 58 Unread 01-22-2015, 01:29 PM
DrBabs's Avatar
Quoted: 61 Post(s)
Originally Posted by Jon_B View Post
thanks J!
thats the one!
** has anyone ever attempted to install soffits using an ibeam, or floor joist? seems like it would be much simpler than cutting dozens of 2x4 and fixing them all individually. especially since the joist is the perfect dimension.
like this http://hostedmedia.reimanpub.com/TFH..._FRABMT_14.JPG
DrBabs is offline
post #47 of 58 Unread 01-22-2015, 05:32 PM
doublewing11's Avatar
Quoted: 223 Post(s)
Liked: 726
ID:	495898   Click image for larger version
ID:	495906   Click image for larger version
Boomassiv likes this.
doublewing11 is offline
post #48 of 58 Unread 01-22-2015, 06:17 PM
Boomassiv's Avatar
Quoted: 118 Post(s)
Liked: 48
Good revive of this thread. Some nice looking builds.
Boomassiv is offline
post #49 of 58 Unread 01-22-2015, 06:27 PM
Jon_B's Avatar
Quoted: 25 Post(s)
Originally Posted by doublewing11 View Post
Wow!!! Very nice work!
Jon_B is offline
post #50 of 58 Unread 01-22-2015, 07:24 PM
Stridulent's Avatar
Quoted: 18 Post(s)
Is an 8 ft ceiling too low for a soffit?
Stridulent is offline
post #51 of 58 Unread 01-22-2015, 08:29 PM
DrBabs's Avatar
Quoted: 61 Post(s)
like this http://hostedmedia.reimanpub.com/TFH..._FRABMT_14.JPG[/QUOTE]
DrBabs is offline
post #52 of 58 Unread 01-26-2015, 11:05 PM
DrBabs's Avatar
Quoted: 61 Post(s)
Ah heck, nm. Im just going for it . Ha !
DrBabs is offline
post #53 of 58 Unread 02-13-2015, 02:55 PM
sillywilly's Avatar
DrBabs:
Interesting approach that I had never thought of.
Did it turn out the way you expected? Did you hang the joist first and then fill in with the support 2x4 or the other way around? Do you just affix the drywall to the joist's furring-type strip?
Do you think you could use the gap between the joist/soffit face and the drywall as a thin cable run?
My Home Theater and Game Room Build -- IN PROGRESS
THE SPUD CELLAR
sillywilly is offline
post #54 of 58 Unread 06-28-2015, 06:35 PM
Invictus1911's Avatar
looking for the 25-Gauge Metal Track soffit builds. Can anyone link a few of the newer builds
Invictus1911 is offline
post #55 of 58 Unread 06-28-2015, 08:27 PM
KanosWRX's Avatar
Quoted: 123 Post(s)
Liked: 37
Here are some from my build, showing various stages.
ID:	801154   Click image for larger version
ID:	801170   Click image for larger version
ID:	801178   Click image for larger version
ID:	801186   Click image for larger version
ID:	801202   Click image for larger version
ID:	801218   Click image for larger version
ID:	801226   Click image for larger version
ID:	801234   Click image for larger version
KanosWRX is offline
post #56 of 58 Unread 01-04-2016, 04:30 PM
jmd1982's Avatar
Quoted: 42 Post(s)
will a sophet work on a room that isnt a perfect square/rectangle? what i mean by this is the room iam using has a wall thats about 11 feet wide, 8 feet is slanted and then bout 3 feet is straight but the 3 feet which is a straight wall is pushed back behind the slanted wall by about 2 feet.
i hope this makes sense if not iam going to have to take some pics.
trying to figure out how i can make this work
jmd1982 is offline
post #57 of 58 Unread 01-30-2016, 10:03 AM
sigma722's Avatar
Quoted: 93 Post(s)
Liked: 29
Kind of a late reply, but pics would probably be helpful if you haven't posted them elsewhere.
Also just kinda wanted to bump this thread for more contribution
sigma722 is offline
post #58 of 58 Unread 01-30-2016, 10:39 AM
schmidtwi's Avatar
Quoted: 71 Post(s)
Liked: 65
Not at all. I'd venture to say that the majority of HT's here have 8' ceilings or less. 9+' is much better, obviously, but we all have to make due with what we have.
The Schmidt Haus Theater - WIP (or not) since 2010
schmidtwi is offline
