Show me your Soffit - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 16Likes
post #61 of 66 Old 05-05-2016, 01:26 PM
Liked: 0
Thank you for your reply. Existing soffits are 2ft wide and 1ft height. Ceiling is 8ft height.
raghumvs is offline
post #62 of 66 Old 07-10-2016, 06:36 AM
Liked: 7
I attempted to build the soffits from 2X3 pine & after 2 attempts with what I thought was straight lumber, they were not straight so I stopped & looked for another solution.
After talking to an electrician friend, he said I should look into buying I-joists for the facia & tie them to the walls with 2X3's. Bought them from Menards, they were inexpensive & worked perfectly.
Here are few pics:
ID:	1538377   Click image for larger version
ID:	1538385   Click image for larger version
dlinsley likes this.
macplants is offline
post #63 of 66 Old 09-12-2016, 11:42 AM
Ladeback's Avatar
Quoted: 559 Post(s)
Liked: 183
Send a message via MSN to Ladeback
I started looking into building a soffit in my HT after this weekend when I noticed that I have coax and Cat 6 running down along a beam that I have a wall under. MY HT is under part of my living room and kitchen so will building bass traps into the soffit help a lot? I not to worried about some sound getting upstairs, just trying to slow it down and muffle if I can. I cam going to use Roxul for sound in the joist and my use resilient channel for the drywall where there isn't any soffit. Do I need to put drywall up before I build the soffit or can I just leave it open? Here is a rough photo of what I have so far. The room is 14'x26'x9'. I was thinking of going with a 8" drop for my soffit all the way around with rope lighting, I want to keep the top of my screen as close to 8' as I can.
Ladeback is offline
post #64 of 66 Old 09-12-2016, 02:03 PM
VTstang's Avatar
Quoted: 174 Post(s)
Liked: 112
I don't think adding a soffit just as a place to cram additional insulation will help with soundproofing. My understanding is that soffits are stuffed with insulation to help in-room response/decay rates.
VTstang is offline
post #65 of 66 Old 10-14-2017, 11:44 AM
pwlong's Avatar
Impressive setups -- the creativity showcased in this thread is really cool to see.
Here's a few pics of the soffit in our theater:
It's purpose was to hide HVAC runs and some lighting conduits, but I also incorporated it into some custom cabinetry used to mount the screen, and hide the speakers behind an AT screen:
I've got a few blog posts with more details, and the full build journal linked in my sig.
http://havingfunalongtheway.com/base...ng-the-soffit/
http://havingfunalongtheway.com/base...ater-lighting/
pwlong is offline
post #66 of 66 Old 10-14-2017, 12:35 PM
tanman's Avatar
Quoted: 175 Post(s)
Liked: 134
^^ Very cool!
tanman is offline
