"Reel Time" Build Log-14' Scope, 9.7 17,000W Transducer Audio, Dedicated Stadium Room - Page 13 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #361 of 368 Old 08-09-2013, 08:00 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
Originally Posted by cowger View Post
Indeed. This build plus Mario's were the two that truy inspired me...
I think we have similiar tastes. For me I can add yours to the list biggrin.gif
Mfusick is offline
post #362 of 368 Old 08-11-2013, 12:59 PM
deafking's Avatar
The theater looks awesome and most likely sounds outrageous as well. It gives me ideas on what to do in mine. What speakers did you use? I saw in your previous build thread you talked about using the transducers, but from what I saw, transducers are only for bass. I could be wrong though. Consider me subscribed though late in the game.
deafking is offline
post #363 of 368 Old 08-12-2013, 05:07 AM - Thread Starter
RedTopDown's Avatar
The whole system is transducers, so the only "standard" audio are the four subs, one in each corner. You might be thinking about tactiles, which are for bass and a little shake. I have three rows of four of those, a row under each seating area.
Here are some links in the thread:
Tactile Installation Under Floor: LINK
Actual Transducer (Hidden Audio Systems) Close-Up: LINK
Start Of Transducer Install (56 of them!): LINK
RedTopDown is offline
post #364 of 368 Old 08-23-2013, 06:46 PM
TSHA222's Avatar
Liked: 71
Love the detail in your theater. I have a fairly advanced mildew issue ( theater sits above slab ) so I'm about to begin a "re-build" theater project.....fun!! I was particularly impressed with your custom screen. My screen is a 16 foot wide 2.35 from Harkness Hall but since my bright enough 3 chip from Digital Projection went and failed on me, I'm going with a projector that's not nearly as bright. Because of this, I'm going to do a painted screen too. It's nice to see fellow members achieve such large images with some relatively modestly priced projectors.
I don't have the patience or skill to get as detailed in my trim and finish as you but you give me something to aspire to for sure. Great work!
TSHA222 is offline
post #365 of 368 Old 10-13-2013, 07:52 AM
mtbdudex's Avatar
Quoted: 79 Post(s)
Liked: 790
I come back to this thread looking for acoustic measurements, like to learn about all the wall mounted transducer performance.
I'm looking for waterfall for below 250hz and gated ETC for above 250hz, did not see them posted.
Also, you are not using Audyssey EQ at all?
( I can't recall reading if you did or not).
Specifically what acoustic calibration was done?
I love how this HT turned out!
How is the love seat usage?
mtbdudex is online now
post #366 of 368 Old 10-14-2013, 04:46 AM - Thread Starter
RedTopDown's Avatar
Thanks and good luck with your re-build!
post #367 of 368 Old 10-14-2013, 04:49 AM - Thread Starter
RedTopDown's Avatar
I wish I could give you those details, but I don't have anything like that at all. MMan might be able to go that technical. I have never been able to get through Audyssey EQ without issues. I think I have something wrong with the mic and have never had the time to resolve. I've not done any kind of acoustic calibration.
Love seat is a great feature in my opinion!
post #368 of 368 Old 10-14-2013, 01:08 PM
cowger's Avatar
Quoted: 23 Post(s)
Liked: 79
I have an extra mic if you're interested in trying it out.
cowger is offline
