Soffits with MDF? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 12-17-2010, 10:21 AM - Thread Starter
WannaTheater's Avatar
Hi all,
I will soon need to cover my framed soffit (2x2s) with MDF. The soffit was built after the room was drywalled. Soffit will eventually be covered with fabric.
How is everyone attaching MDF to their soffits? I am inclined to use course thread wood screws, but wondering if there is a better way. Also is predrilling necessary to prevent splitting?
WannaTheater is offline
post #2 of 14 Old 12-17-2010, 10:29 AM
fotto's Avatar
Quoted: 21 Post(s)
Originally Posted by WannaTheater View Post
Hi all,
I just used coarse thread drywall screws. I don't recall drilling first (don't think I did).
fotto is offline
post #3 of 14 Old 12-17-2010, 10:44 AM
premiertrussman's Avatar
Quoted: 17 Post(s)
Hi all,
They actually make screws specifically for MDF, but can use drywall screws if you wish. Pre drilling will make it easier, but probably isnt necessary except for any places you are very near the edge...you might want to pre drill in those spots.
The screws wont sink into the MDF very well, so if your fabric is going to lay flat against the MDF you may consider using a counter sink so the screws will be more flush.
_____________________________________
Shades of Grey Theater
Currently Playing: Overwatch/WoW - Legion
premiertrussman is offline
post #4 of 14 Old 12-17-2010, 10:47 AM
Ted White's Avatar
Quoted: 12 Post(s)
Liked: 44
Excellent advice
__________________
Ted
The Soundproofing Company
Ted White is offline
post #5 of 14 Old 12-17-2010, 10:49 AM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 284
I always use a pilot counter sink bit with mdf it makes the job much cleaner.
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is online now
post #6 of 14 Old 12-17-2010, 11:01 AM - Thread Starter
Thanks guys! Pilot hole, countersink and drywall screws it is.
post #7 of 14 Old 12-17-2010, 11:19 AM
Sands_at_Pier147's Avatar
Or liquid nails and a 16 ga nail gun ...
It appears my hypocrisy knows no bounds.
Brian
The Cinema Rouge Home Theater
Sands_at_Pier147 is offline
post #8 of 14 Old 12-17-2010, 11:30 AM
Brad Horstkotte's Avatar
Liked: 68
If its going to be covered with fabric, why not fill with some fiberglass and cover with fabric (no MDF), to get some bass trapping out of it?
Brad Horstkotte is offline
post #9 of 14 Old 12-17-2010, 11:52 AM - Thread Starter
I thought about that... But would need to figure out a way to incorporate can lights and a rope-light tray.... Any ideas?
post #10 of 14 Old 12-17-2010, 11:57 AM
Liked: 68
Check the last page of my build thread, I'm doing something like that - the bottom is open and filled with insulation (added a layer of rigid insulation since those pics), and I have a rope light tray and recessed lights. Also check Moggie's thread, and Sandman's.
post #11 of 14 Old 12-17-2010, 12:19 PM
SierraMikeBravo's Avatar
Quoted: 335 Post(s)
Liked: 214
Adding the MDF will act just fine as a bass trap. The MDF won't add up to a hill of beans compared to most low frequency wave lengths, and the addition of the MDF will actually enhance the bass trapping characteristics. A wavelength that passes through the MDF will be attenuated, and it will be attenuated even further when a portion of it is reflected back through the MDF making for reduced SPL. Keep in mind as well, your whole room is one big bass trap. Brad is correct in that you should put some insulation in there. Hope this helps! Best wishes!
Shawn Byrne
CEDIA Certified Professional EST II - HAA, THX.
Theater Design Information and Examples
skbyrne@sbcglobal.net
shawn@questai.com
SierraMikeBravo is offline
post #12 of 14 Old 12-17-2010, 10:34 PM
James L's Avatar
You can counter sink the drywall screws on MDF without going through the effort of pre-drilling. Just make sure that you are not screwing it in close to the edge or it will crumble it. People have been doing this in the car audio business for years and it just takes practice.
Check out my build - The Den
James L is offline
post #13 of 14 Old 12-18-2010, 07:49 AM
Dennis Erskine's Avatar
Quoted: 64 Post(s)
Liked: 100
The typical method is to install 2x2's on the wall and ceiling using screws and a construction adhesive. The screws through the 2x2's should anchor into your HAT channel (if that's what you are using). The soffits (preconstructed) are then raised into place and screwed into the 2x2 runners without construction adhesive. This provides a more secure anchorage and allows for easy future removal of the soffit if required.
Dennis Erskine CFI, CFII, MEI
Architectural Acoustics
Subject Matter Expert
CEDIA Board of Directors
www.erskine-group.com
Dennis Erskine is offline
post #14 of 14 Old 12-18-2010, 08:16 AM - Thread Starter
Thanks all for the feedback. My soffits are up... without construction adhesive. I did build a full "box" soffit out of 2x2s, then lifted it into place, and screwed through into hat channel. I also screwed horizontally into studs on sides. I did shim around the bottom to make sure the front part of the soffit was truly "vertical." I have found that my theater walls taper near the top, I assume from the extra tape and mud from the drywallers.
{after re-reading last post} Dennis - Fantastic idea... I wish I knew that earlier.
