Nick's Homebrew Bar and Entertainment Area - Page 33 - AVS Forum | Home Theater Discussions And Reviews
post #961 of 1241 Old 05-14-2013, 10:30 AM - Thread Starter
NGiovas's Avatar
Liked: 43
Originally Posted by vikgrao View Post
Everything looking super neat!! are you going to stain the door also?
Thanks Vik.  No, I will have acoustic treatments on the doors that match the walls.
NGiovas is offline
post #962 of 1241 Old 05-14-2013, 11:45 AM
AirBenji's Avatar
Quoted: 35 Post(s)
Liked: 83
Just catching up on the pictures - looking great Nick! Nice work!!
AirBenji is offline
post #963 of 1241 Old 05-14-2013, 01:41 PM - Thread Starter
NGiovas's Avatar
Liked: 43
Thanks Ben.  I am just jealous that you are sitting back enjoying movies in your theater while I am still not done.wink.gif
NGiovas is offline
post #964 of 1241 Old 05-14-2013, 02:31 PM - Thread Starter
NGiovas's Avatar
Liked: 43
Fred and Mike,
I can say with certainty that all of the acoustic theories are above my skill level.  I am going to have to rely on measurements before deviating from the plan.
NGiovas is offline
post #965 of 1241 Old 05-14-2013, 02:40 PM
damelon's Avatar
Liked: 270
Originally Posted by NGiovas View Post
After my last post about the trim - time seemed to slip by with no progress.  I had a stomach flu that following weekend and was really busy the next week.  I decided to finally kick things into gear again and make some progress.  Fortunately, I got several things done.  things are finally coming together.
I finally wired the outlets on the back of my columns.  It makes it much easier to be able to plug things in inside the room rather than having extension cords running under the door.  I debated how high to make the outlets, but decided to make them a bit higher since they are hidden on the back side of the columns.
Before working on the trim any further, I decided to finish painting the ceiling so that I wouldn't have to worry about over spray.  The first step was finally installing my diffusers on the air inlets.  I finished caulking the small gap between the top of the drywall and the HVAC boot.  I then fabricated some small sheet metal lips for the register brackets to hook onto.  Once the registers  were installed, I finally was able to finish painting the ceiling.  All I can say is - the light levels plummeted with the flat black ceiling.  I'm actually worried that I may need to find some brighter bulbs.
After painting the ceiling, I cut all of the OC 703 for my corner base traps.  I still need to build some sort of frame so I can wrap in in fabric.
Next, I cut all of the wooden plates for my column speaker grills.  I am using a design similar to what BIG used on the Bacon Race build.  I am cutting black pipe for the corner supports and will use wooden supports in the rear of the grill.  The first one was a bit tight and will need to be adjusted so that it can easily slide in and out with the fabric attached.
HAH wow I thought I was looking at my own theater for a minute! Red, Yellow corners, black wall, same stage shape, curved soffit over the stage... Awesome! I had to do a double take! You even got the outlets on the side of the columns! smile.gif
Great job on the columns and soffit ! I definitely chickened out on the veneer, even though that's what I wanted to do originally. Your write-up of the process was also excellent. I might have done it if I had some more details from Sandman's build when I did mine. Kudos! Looking great Nick!!
Since you are using the same column idea, I'll remind you of the issue we had. Our "Inserts" were a little too tight in the end, mostly because we measured once and copied the heights all around, but if you fit in the "Speaker Cover" before putting on the fabric, remember that there will be fabric there later, so it will be thicker on the top and bottom. You want it to have friction, but not to be so tight that you scratch your columns later. If I did them again I'd make them a little more loose and find a way to make them hinge open or "Snap" into place. I could have used the front ones for some sort of super secret storage!
damelon is offline
post #966 of 1241 Old 05-14-2013, 02:56 PM - Thread Starter
NGiovas's Avatar
Liked: 43
Thanks Damelon.  I definitely got lots of inspiration from your build.  I started out years ago drooling over Sandman's theater and then incorporated several of your improvements.  Just to save you the shock later - I will be doing red and black fabric on the walls (surprise, surprise).  Of course I had to do the veneer so that something was different than yours wink.gif.  I just hope my theater turns out half as nice as yours did.
Thanks for the tip on the fabric.  I noticed the first column I mocked up was tight even without the fabric.  I am trying to figure out how much space is right.
NGiovas is offline
post #967 of 1241 Old 05-14-2013, 03:06 PM
damelon's Avatar
Liked: 270
I still love his theater. It was his veneers and curvy columns that really stood out. Both of which I sort of axed. I still do love the Red and Black!!!
Since then, I've seen things like Mario's build and again it was the woodwork that caught me. It really ups the classy in a theater! You're doing an excellent job, I have no doubt you'll love the end result. You are almost there!!
Have you decided on lighting? I've really liked the LED tape lights people have put in. I'd probably put that under a lip of the riser instead of step lights now. Hard to do once the carpet is up, but it's a cool effect. I even saw someone put LED lighting behind the edges of their columns to make them "Light up". That was a cool effect. I am starting to forget who did what now.
Are you building your own frames? How about the sizes/shapes? Are you doing those different? I think I noticed that you did some veneer mid-wall trim as well as baseboard in the same general locations I have them. What about your panels? It has been a little over 1.5 years since my frames were up. There have been paint scuffs on the columns in some places (Something some nice lacquer will help you with) and the frames have a few places where you can see the frame borders now through the cloth, or that the fabric bunches up very slightly. Of course only I notice, but I'm not about to rip anything down for something so small.
damelon is offline
post #968 of 1241 Old 05-15-2013, 01:03 PM - Thread Starter
NGiovas's Avatar
Liked: 43
Sandman's theater is still one of the top home theaters out there.  Especially if you consider that it was DIY (with the help of friends).  I love the round columns and really wanted to do something similar, but trying to find the right curved plywood was costly.  Plus, the speakers I am building wouldn't fit in them well.  It was a worthwhile compromise.  The other compromise I made was not having the star ceiling.  My ceiling height is too low to even consider it.
Mario's theater is stunning.  Nothing over the top design wise - just perfectly executed.  The fit and finish appears to be top notch.
I have 4 zones of can lights - behind the screen, screen wash, sides and rear.  I also wired for step lights, but really like the LED strips people have put under the lip.  Lastly, I will have an LED rope light in a lip around the perimeter of the soffit.  I wanted color changing 120V LEDs, but that isn't cost effective at this point, so I will likely just go with red dimmable LEDs.
I am building my own frames.  I am layering plywood and MDF so that I can chamfer the edges.  I am looking at a similar pattern to you and Sandman for the panels.  I will have one narrow black horizontal panel above the top trim.  There will be side-by-side vertical red panels above the chair rail.  Lastly, I am going to do a couple of horizontal black panels at the bottom above the base trim.  I was wondering how the fabric would hold up over time.  I am debating painting the frames to help hide them behind the fabric.  I'm not sure if it is worth the effort.  I am hoping the panel building goes quickly.  I feel like I am finally getting close.  I would love to knock a bunch of the panels out over Memorial Day weekend.
NGiovas is offline
post #969 of 1241 Old 05-15-2013, 01:33 PM
damelon's Avatar
Liked: 270
You should paint the frames black, even if it's just a quick and dirty on the front edge. I did that, but it's not the color that is standing out, it's just the tension itself. it's pulled over the wood and over time it is slightly more obvious where the wood on the frame ends, that's all. It would be less obvious if I angled the can light a little. Again, it's something only I notice really.... all of my guests seem to have the same reaction to the panels too, they want to stick their hands on them and feel the squish of the panels in the center. At least they don't touch the screen!
damelon is offline
post #970 of 1241 Old 05-15-2013, 01:38 PM - Thread Starter
NGiovas's Avatar
Liked: 43
I am working on a way to electrify my screen - kind of like a bug zapper.  That way if someone touches it, they get shocked eek.gif.  I will keep you posted on my progress biggrin.gif.
NGiovas is offline
post #971 of 1241 Old 05-15-2013, 05:16 PM
psychdoc's Avatar
Quoted: 121 Post(s)
Liked: 197
It's actually pretty easy. Go buy a cheap tesla coil and run a wire around the perimeter of your screen. You'll only get zapped when you touch the wire but you can turn it up where that would be quite unpleasant. Kinda funny, but your dog and kids won't think so. Have fun... biggrin.gif
psychdoc is offline
post #972 of 1241 Old 05-15-2013, 08:04 PM
damelon's Avatar
Liked: 270
And thus, the Tesla theater was born!
damelon is offline
post #973 of 1241 Old 05-15-2013, 09:38 PM
Peter M's Avatar
Quoted: 162 Post(s)
Liked: 177
I get this as well ... drives me nuts !
Cheers,
Peter M is offline
post #974 of 1241 Old 05-16-2013, 05:24 AM - Thread Starter
NGiovas's Avatar
Liked: 43
Cheers,
Because of my low ceiling height, I am more worried about people reaching up to touch the black ceiling while standing on the riser.  I can see the fingerprints already.
NGiovas is offline
post #975 of 1241 Old 05-16-2013, 12:33 PM - Thread Starter
NGiovas's Avatar
Liked: 43
Nick on your corner bass traps you putting a reflective cover on the face before the fabric or just fabric?
Possible uncovered may contribute to over dampen room.
Measurement time.
Nice progress, keep at it.
Sent from my 32GB iPhone4 using Tapatalk
Mike,
I confirmed with Bryan that I do not want to put paper on the front bass traps.  He said that you want 100% absorption on the front wall and only want to reflect highs in the rear of the theater.  I am going to stick with the original plan unless measurements show otherwise.
NGiovas is offline
post #976 of 1241 Old 05-17-2013, 11:04 AM
mtbdudex's Avatar
Quoted: 78 Post(s)
Liked: 689
Measurement time.
Mike,
Is there a reason why OC703 for the corner vs Pink Fluffy?
I made mine from OC ridgid before the gas flow resistivity equations were put into usage and results shared with the DIY community.
I'm sure Bryan is aware that, so I'd like to know his rationale for sticking with OC703 in corners superchunk.
http://www.bobgolds.com/AbsorptionCoefficients.htm
There are several types of absorbers
a) thin porous most of wall
b) thick porous entire ceiling full
c) corner porous panel (corner chunk)
d) corner porous full (superchunk)
e) parallel out from surface porous (e.g. 4" out, acoustic ceiling tiles)
f) covered porous (FRK, leather couch)
g) constant slat/slot helmholtz (traditional formuals)
h) variable slat/slot helmholtz (John Sayers example)
i) port helmholtz (e.g. helmholtz riser)
j) constant perforated/microperforated helmholtz
k) variable perforated helmholtz
l) membrane, panel, diaphramatic (cupboards, bad risers)
m) polycylindrical {membrane,slat,port,perforated} absorbers
n) active noise suppression
porous includes
1) fiberglass (fluffy pink, rigid)
2) rockwool (semi rigid SafeNSound, rigid)
3) cotton
4) polyester batting (WalMart fabric department ish)
5) foam (often available in shapes like wedges)
Any absorber may be placed in a checkerboard or separated baffles.
In all cases if you have less than 4" you use rigid, if you have 8" or more you use fluffy, unless you need rigid for structure.
Porous absorbers are always broadband.
mtbdudex is offline
post #977 of 1241 Old 05-17-2013, 12:14 PM
HopefulFred's Avatar
Quoted: 490 Post(s)
Liked: 422
I wouldn't want to speak for Bryan, but it seems to me that the only place the loose batts offer significantly better absorption is in the lowest two octaves or so. Corner treatment for the first order modal interactions that dominate those ranges will be largely ineffective. For the lowest octaves, placement and eq are much better solutions, so the 703 makes good sense to me.
HopefulFred is online now
post #978 of 1241 Old 05-17-2013, 06:53 PM - Thread Starter
NGiovas's Avatar
Liked: 43
Honestly Mike, Bryan specified triangle dimensions and height, but I'm the one who selected OC 703. I had enough available and had seen that others had used it with good results. I figured it would be really easy to swap out later if I choose to.
NGiovas is offline
post #979 of 1241 Old 05-19-2013, 06:30 PM - Thread Starter
NGiovas's Avatar
Liked: 43
I continued to make some progress this week.  I finished up the frames for the speaker/column grills.  I have 4 of them covered in fabric.  The columns look great with the grills in place.  I am really glad I took the time to put the black dividing stripes between the trim.  It really ties the column together.
The four rear columns are deeper because they will house my surround speakers.  I wanted room to angle them if necessary.
The front columns are "false columns".  They really are only there to balance out the look of the room, so they are only half as deep.
Since there is a false column right inside the door, I decide that would be a great place to mount my scene selector to control the lights in the room (besides using a remote).  I had to develop a bracket to mount the electrical box so that it could be hidden behind the fabric on the column.
This is one of the two columns I still need to put the fabric on.  I have it cut for both, so hopefully I can finish up during the week.
I had previously cut a bunch of strips of MDF for my acoustic panels.  I finally picked up the plywood for the frames today and cut all of the strips.  Now I have everything I need to finish the panels.  I glued up the first two today.  Once the glue is completely dry, I will chamfer the edges before wrapping them with fabric.  I hope to take advantage of the long weekend and knock several panels out.
It may be time to start calling carpet installers to discuss pricing and measuring...
NGiovas is offline
post #980 of 1241 Old 05-19-2013, 10:39 PM
cdika17's Avatar
Liked: 27
Slow Down!! Ha, looking great, keep it up.
Chase "Fetch"
Old Theater Build
New House Build
cdika17 is offline
post #981 of 1241 Old 05-20-2013, 02:56 AM - Thread Starter
NGiovas's Avatar
Liked: 43
Thanks Chase.  In my mind, I want it to be done so bad - it seems like it couldn't go any slower.
NGiovas is offline
post #982 of 1241 Old 05-27-2013, 06:40 PM - Thread Starter
NGiovas's Avatar
Liked: 43
Another weekend is gone, but the good news is that I am continuing to make some progress.  Now I definitely feel like I am over the hump.
Earlier in the week I ordered my z-wave switches for the theater.  Unfortunately, they are on back order until mid June.  I did get my scene selector switch and got it installed this weekend.  Of course, I can't really do anything with it without the other switches.
Once everything is complete.  I plan to order some custom buttons for the switch.  Leviton will custom laser etch them for you..
The big project for the weekend was working on the acoustic panels.  I glued up several panels during the week and got several installed this weekend.  It totally changes the look of the room.  I can now really see what the room is going to look like.  I am extremely happy with the look of the panels.  I finished several vertical red panels and one of the horizontal black panels at the top of the room.
One of my biggest worries was that the GOM fabric was that it would look too much like burlap.  That isn't the case at all.  On a larger scale, you don't focus on the pattern/weave of the fabric at all.  Just the color.  It looks great.  I cut some of the wood for more panels.  I hope to glue up several more during the week.  If I can finish up the trim on the rear wall, I may go ahead and call to have the room measured for carpet.
NGiovas is offline
post #983 of 1241 Old 05-27-2013, 07:19 PM
rmajor55's Avatar
Looking great, keep up the good work!
Robin Major
I never know what to put here.<---- Soon to be build thread.
rmajor55 is offline
post #984 of 1241 Old 05-27-2013, 07:59 PM - Thread Starter
NGiovas's Avatar
Liked: 43
Thanks Robin.  There is no stopping me now wink.gif.
NGiovas is offline
post #985 of 1241 Old 05-27-2013, 08:16 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Looks great !
Mfusick is offline
post #986 of 1241 Old 05-28-2013, 03:40 AM
Mr.Tim's Avatar
Quoted: 277 Post(s)
Liked: 180
Wow, Nick. You made a lot of progress!
Is that Red or Claret? Do all the panel have OC703 in them, or only in certain areas? How are you attaching them?
Tim
Mr.Tim is offline
post #987 of 1241 Old 05-28-2013, 05:33 AM - Thread Starter
NGiovas's Avatar
Liked: 43
Thanks Mfusick and Tim.
The red fabric is 418 Claret Accent.  There is OC 703 behind portions of the panels based on my acoustic plan.  I put batting behind the open areas.  Each panel has a drop of construction adhesive in each corner and one in the middle of each long side to ensure they don't pop off.  I held them in place with pin nails in each corner to allow the adhesive to dry.  The pins have no head, so you can't see them at all.
I was a little worried about the frames showing through the fabric, but it isn't an issue at all.  You can only slightly see them with the work light shined directly on them.  With the normal room lighting there is no issue.
A suggestion for anyone getting ready to make fabric panels - stock up on staples smile.gif.
farkem likes this.
NGiovas is offline
post #988 of 1241 Old 05-28-2013, 08:53 AM
NickTheGreat's Avatar
Quoted: 381 Post(s)
Liked: 255
How are you going to integrate the Z-Wave? I really wish there was a good way to be able to do SOMETHING Z-wave with my Harmony Remote mad.gif
NickTheGreat is offline
post #989 of 1241 Old 05-28-2013, 09:06 AM - Thread Starter
NGiovas's Avatar
Liked: 43
I already have 36 z-wave switches/dimmers/controllers in my house, so I will be integrating with my existing network.  The theater will have 6 different lighting areas (behind screen, screen wash, sides, rear, steps and rope lights).  Everything will be integrated through my HAI system which will house all of the code.  Currently I have a series of rules that adjust lighting throughout the house.
At one point I was playing with CQC and touch panels.  I really like the ability to customize my system, but it was costly and the touch panels were bulky and required a full pc to power them.  I have since switched to iRule.  It still allows for full customization and I will be able to integrate my lighting controls directly with other theater functions.  If you have an iPhone, iPad or Android device, it really isn't that costly and allows for full customization.
I have a Harmony remote in my family room.  It was really nice when all of my components needed to be controlled separately.  My wife and kids could simply hit one button and have everything turn on and switch to the correct input.  For simple installs, it works great.  Unfortunately, as you have figured out, it has its limitations.  The battery is starting to have issues on mine.  I think I am going to swap it for an old iPod touch with iRule when the time comes.
NGiovas is offline
post #990 of 1241 Old 05-28-2013, 12:17 PM
vanice's Avatar
Quoted: 32 Post(s)
Liked: 53
I see you "borrowed" the design for the center section of your columns from BIG and Damelon's build. I plan to "borrow" it as well. Any building tips you care to share or were they fairly straight forward to construct? I was thinking that these might be one of the last things that I do but I'm kinda changing my mind. Might move them up to next on the list after completing my one wall section of panels.
vanice is offline
Lcd Hdtv , Led Hdtv , Basement Bar
