Window Vibration Buzz HELP! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 19 Old 01-02-2011, 10:02 PM - Thread Starter
soberparty's Avatar
Hey all,
I have an issue with my windows vibrating when the subwoofer kicks in or it vibrates all the time if were watching an action/sp effects movie.
Without replacing the windows, and without removing the glass panes and putting clay or putty on it and re mounting windows again, what if anything can be done?
They are single pane wooden windows from the 1980's. Please feel free to PM me because this thread will likely dissappear due to lack of responses. I am cool with that.
thanks guys
xblgt: soberparty
soberparty is offline
post #2 of 19 Old 01-03-2011, 04:10 AM
Dennis Erskine's Avatar
Quoted: 64 Post(s)
Liked: 100
I have a flat tire. How can I fix it without buying a new tire, filling it with air, fixing the leak or changing the tire?
That's kind of where you are at.
Dennis Erskine CFI, CFII, MEI
Architectural Acoustics
Subject Matter Expert
CEDIA Board of Directors
www.erskine-group.com
Dennis Erskine is offline
post #3 of 19 Old 01-03-2011, 06:03 AM - Thread Starter
soberparty's Avatar
alright them man, im hosed huh.
xblgt: soberparty
post #4 of 19 Old 01-03-2011, 06:16 AM
CatBrat's Avatar
Busting them out with a rock might work.
CatBrat is offline
post #5 of 19 Old 01-03-2011, 06:52 AM
tlogan6797's Avatar
Quoted: 105 Post(s)
Liked: 131
Are they wood?
You might be able to re-glaze from the outside with actually removing the panes. Just add new caulk over the old, although removing the old is the way to go. Also, if wood, you might be able to insert a few glazier points in the right places to fix it.
I would say, if they are not wood framed, you ARE hosed.
Tom Logan
Need motivation? Get LOGANED
tlogan6797 is offline
post #6 of 19 Old 01-03-2011, 07:33 AM - Thread Starter
soberparty's Avatar
Are they wood?
do you mean "without" removing the panes?
Yes, they are single pane wooden windows from the 1980's.
xblgt: soberparty
post #7 of 19 Old 01-03-2011, 10:04 AM
tlogan6797's Avatar
Quoted: 105 Post(s)
Liked: 131
Yes, sorry. WITHOUT removing the pane. I'm suggesting laying another layer of the glazing compound over top of the existing. But removing the old would be better. It still means getting up on a ladder on the outside, though.
Tom Logan
post #8 of 19 Old 01-04-2011, 03:44 PM - Thread Starter
soberparty's Avatar
alright thanks. So liquid nails on the window where it connects with the wodden frame at the pane? Will silicone be a better option?
xblgt: soberparty
post #9 of 19 Old 01-05-2011, 07:00 AM
tlogan6797's Avatar
Quoted: 105 Post(s)
Liked: 131
Not what I had in mind but it might work. I wouldn NOT use liquid nails. If you ever break a pane and have to replace it, it will be VERY difficult. There is "window glazing compound." It comes in a rope form. you peel some off, rub it in your hands to the correct length and width (OK,OK, ELEVATE YOUR MIND! I know what you guys are thinking....) and then press it into the frame to hold the glass pane in, like caulk. You could just overlay the existing, but I would recommend removing it first. Then paint.
Tom Logan
post #10 of 19 Old 01-05-2011, 07:40 AM
AndreasMergner's Avatar
There is a removable silicone if you really want to do it that way, but glazing compound is easy and better. It is just like clay and you can "work it" just like Tom says.
Where are you located? I'm in Albany.
Current HT: HTPC-->Epson 5010 projector-->135" screen, BFM TLAHs x7 & THT
Build log: DIY rotary sub for contemporary HT in 100 year old house?
Andreas' Slow Rotary Sub build
AndreasMergner is offline
post #11 of 19 Old 01-05-2011, 07:54 AM
Quoted: 3255 Post(s)
Liked: 2743
Build soundproofing window plugs, panels that totally cover the windows.
post #12 of 19 Old 01-05-2011, 10:33 PM - Thread Starter
soberparty's Avatar
maybe I am not following but...
I want to keep the windows just as they are (theyre 30 year old living room windows) and try to stop the window from vibrating in its slot. So if I were able to run silicone along the seam where the 2 toutch(kinda like cauking tile) has anyone had success with that technique?
xblgt: soberparty
post #13 of 19 Old 01-06-2011, 01:44 AM
contentedbloke's Avatar
I have the same problem. My wooden windows are pretty old and are single pane and they vibrate whenever a bass heavy piece is played. Also, I am told that if I need to add another round of glazing, I need to replace the shutters themselves as they are too old to bear further modifications.
So what I did was buy some good quality sealant and applied it to the edge of the glass all round the windows (where the glass meets wood). It cut down vibrations by atleast 75% and i can now atleast watch my movies in peace even though its nowhere near soundproof quality.
contentedbloke is offline
post #14 of 19 Old 01-06-2011, 06:53 AM
thebland's Avatar
Quoted: 1490 Post(s)
Liked: 842
+1.
You're ****ed
It's back!! Wine of the Week! Clos Martinet Tinto, Priorat DOCa, Spain ~$60. If you've not had a good Priorat, you've not truly tried Spain's smallest, yet most unique terroir.
My Home Theater of the Month- Le Petit Trianon
thebland is online now
post #15 of 19 Old 01-06-2011, 07:41 AM
tlogan6797's Avatar
Quoted: 105 Post(s)
Liked: 131
OK, not to get TOO far OT....
What do the shutters have to do with the glass panes?
Tom Logan
post #16 of 19 Old 01-08-2011, 02:31 AM - Thread Starter
soberparty's Avatar
I am doing this today. thank you
xblgt: soberparty
post #17 of 19 Old 01-08-2011, 08:35 AM
barhoram's Avatar
Quoted: 125 Post(s)
Liked: 34
Not certain that you are ****ed, or have a flat-tire that can't be fixed......??
have you tried a subdude? Worked to stop some unwanted vibrations from my subs.
They are like $40 bucks...and simply help decouple the sub from floor--->wall--->window.
One of these + the caulking mentioned above will probably make a huge difference.
http://www.auralex.com/sound_isolati...de/subdude.asp
barhoram is offline
post #18 of 19 Old 01-08-2011, 06:43 PM
ivflight's Avatar
There is really no reason this can't be fixed. I have windows a hundred years older than yours and have been able to fix vibration issues. It sounds like you've concluded that the glass pane is vibrating in the sash. To properly fix this you should reglaze the pane from the outside using glazing compound like Dap 33. You can also just use caulk to do this, but Bob Vila would not be too happy about this.
If it is too cold to work outside you could consider caulking from the inside and either make it really pretty or plan to scrape it off later.
Are you sure the sash isn't vibrating in the window casing?
ivflight is offline
post #19 of 19 Old 01-09-2011, 04:57 AM
Quoted: 64 Post(s)
Liked: 100
No one said it couldn't be fixed. The original post, however, included a list of constraints, which by implication eliminated reglazing, caulking, etc. The list did not include turning off his amplifier however.
