The Monkey_Man Home Theater Build - Page 3 - AVS Forum
Old 05-27-2013, 08:23 PM
NGiovas's Avatar
Liked: 36
Glad you were able to get the results you were looking for. I know how frustrating it can be trying to get things just the way you want them.
NGiovas is offline
Old 05-28-2013, 01:30 PM
majek 60's Avatar
Quoted: 27 Post(s)
Liked: 46
I am also glad that you are able to move on!
My roller marks for the most parts will be covered by my ceiling acoustical panels.......
Now that the HT has been functional for 2 weeks, I am not as upset with the ceiling as I was 2 weeks ago.
Best decisions ever was to paint that screen wall flat black with the Rosco Off Broadway Black. There appears to be nothing on that wall except for the projected image............
Good Luck!
majek 60 is offline
Old 07-14-2013, 08:28 AM - Thread Starter
Monkey_Man's Avatar
Quoted: 25 Post(s)
Liked: 29
Time to update this thread. Things have been moving along slowly, but moving.
Here is a shot of the stage skinned with two layers of 3/4" OSB with a layer of roofing felt in the middle. Sorry about the mess, I struggle with cleaning as I build.
Here I started to build my columns. Mine are primarily decorative. My surround speakers will be mounted on the outside of the column like a traditional big box theater. The main reason I did this was my back row will be 5 seats across I didn't have the room to make the columns any deeper than 4.5" to mount my surrounds inside them, way to big. I made my columns out of 3/4" MDF Some with mitered edges and some without. Here is the process I used to finish:
1. Sand down to 220 with orbital sander until the edges of MDF are very smooth.
2. Skimmed with 1 or 2 coats of MH Ready Patch to fill in the joints then sanded to 220 each time.
3. Rounded corners, taking off sharp edge of corner, with 220 sanding sponge
4. Primed all surfaces of the MDF with Zinsser BIN Primer
5. Sanded primer smooth with 220 sanding sponge
In the pic below the column on the right is mitered and the column on the isn't. The non-mitered columns were a lot more difficult to finish since the edge of the MDF was rough. This was the way Cinemar did his columns. The reason I did this was that my track saw was kinda hard to do 45 degree angles on such a long cut and the cuts weren't coming out perfect.
Here I painted the can light bezels flat black. I used a rattle can high temp black used for grills. This paint comes out dark grey and not very black. Since the cans are halogen I didn't want to used low temp paint. In other threads I read that some people have used low temp paint without issue.
Below are some shots of my wall cleats. I started with building a frame then I just used used spare 2x10s and 2x12's I had left over.
I filled the columns with insulation, because that's what we do, empty space, fill with insulation wink.gif
Column installed with crown molding.
In total, I have 7 columns. I'll get some better shots as I get closer to the end so you can see the layout.
At this point I changed gears and worked on the LED lighting tray. I installed vertical 3/4" plywood to the lighting channel to attach trim and then the crown molding. Biggest mistake of this build was that I mounted the HVAC reg on the ceiling and not in the soffit. In beginning I didn't think I was going to do a lighting tray. Looks bad with the LED light on, all well... moving on...
This pic illustrates the way I did my LED channel to hide the wires and power packs.
I copied Cinemar's lighting channel trim arrangement.
I couldn't help but to mount the LEDS before the crown.
Darn registers...
Here is a shot of the first piece of the 5.25" crown molding, I likey!!!
Next I need to mount the crown molding to the rest of the columns. Then it's on to the custom wainscoting and all the trim that involves.
Monkey_Man is offline
Old 07-14-2013, 08:59 AM
ScAndal's Avatar
Liked: 26
Looking great! Quick question: I'm about to prime all my mdf with zinnser. Did you paint outside the room or in? I need to paint in the room and I'm wonderering about ventilation with that primer.
ScAndal is offline
Old 07-14-2013, 09:13 AM - Thread Starter
Monkey_Man's Avatar
Quoted: 25 Post(s)
Liked: 29
I did paint outside. It wasn't as bad as I thought it would be as far as smell. The Zin also dries super fast. However, I'm not sure how bad it will be in an enclosed space. I painted in my garage with the door open. I also had the paint store add 2 oz's of black to the Zin. I think I will try it in the basement without too much concern.
Old 10-14-2013, 07:14 PM - Thread Starter
Monkey_Man's Avatar
Quoted: 25 Post(s)
Liked: 29
Time for an update. Little 360 of the room.
Time to start the wainscoting...
Some BIN
Magnetic gang locator
Time to install the bull nose
Time to brush on the BJ Aura eggshell on the wainscoting and trim. This paint is awesome. I added BM extender to increase open time and to level brush strokes. The pics below are just the first coat!
First coat came out great, with a little effort it could be done with one coat of the BM Aura. The pics above show the paint wet. Mario recommended eggshell to make the trim pop. On my setup the speakers are exposed on the columns. I'm using 4 Klipsch RS-52II for the surrounds http://www.klipsch.com/rs-52-ii-surround-speaker/details. The trim height on the columns reflect clearance for the speakers. Now if the darn door would come in I could finish the trim. There was an epic amount of caulking, I caulked every piece of the trim. Way over kill.
Old 10-14-2013, 10:19 PM
nickbuol's Avatar
Quoted: 90 Post(s)
Liked: 237
nickbuol is offline
Old 03-08-2014, 02:54 PM - Thread Starter
Monkey_Man's Avatar
Quoted: 25 Post(s)
Liked: 29
Update time!
I ended up ditching the purple paint (sorry wifey) and went with a red BM Aura. Much better pop with the black trim. I cannot say enough for this paint. just awsome to roll
Painted the screen wall with Rasco Black scene paint. Off broadway I think.
Seats arrived!!! That was an ordeal, can't wait to install them. 8 seats total.
Arrival of the 1st of 2 UXL-18's!!!! What a beast!!!! http://www.istonline.ca/mach5_uxl_18.html
iNuke 6000DSP to push the UXL's. This amp has tons of power for the price. Also has a great built in DSP
1 of 2 Marty subs http://www.avsforum.com/t/1489541/large-ported-dayton-ho18s/0_20#post_23711347
All clamps on deck!!! Triple layer baffle.
I'll have better pics soon, the wife just picked up a DSRL Canon
Old 03-22-2014, 12:03 PM - Thread Starter
Monkey_Man's Avatar
Quoted: 25 Post(s)
Liked: 29
Flush bit to trim any panels not lined up perfectly. 3/8" round over on the ports, 1/2" round over on the edge, 1/8" round over on the bottom edge, 45 degree bit on the top edge
Hung first of 4 surround speakers. Klipsch RS-52II
john171 likes this.
Old 03-22-2014, 11:00 PM
morgbug's Avatar
I'm a bit slow on the uptake but this looks stunning.
morgbug is offline
Old 03-23-2014, 06:57 AM
john171's Avatar
The choice to go with red walls looks very nice, smart choice, hopefully your WAF has not suffered too much. Overall you are creating a wonderful HT!
Though I have to say, your use of so much trim/molding would drive me crazy, the cutting and fitting, not the finished look, that is such amazing detail!
What are the plans for your first movie night?
john171 is offline
Old 03-23-2014, 07:16 AM - Thread Starter
Monkey_Man's Avatar
Quoted: 25 Post(s)
Liked: 29
Thanks! I'm happy with the red over the purple by a long shot. Wife wishes the red was a bit toned down. I reminded her the lights are on full power, but once I get the Grafik eye installed, the lights will dimmed most of the time when on, which will tone the red down. I will have a few days and nights of calibration but the first movie day/night event is going to be a Star Wars marathon party with a group of friends (Star Wars geeks). Haha the trim... Was outrage amounts of work cutting and precision. I have so much detail on the back wall I was telling the wife I'm kind of sad the back row is going to hide all the work. For space reason I didn't go with an AT wall so all the speakers and subs are going to be exposed (refrigerator size subs). I knew the exposed speakers were going to be ugly so I tried to spruce up the rest of the room to make up for that. I guess my motto was function over form, but then I decided to put more form in the room wink.gif
Old 03-23-2014, 05:12 PM
Jonny5nz's Avatar
Quoted: 25 Post(s)
Liked: 84
I see that the Cinemar HT was a big influence. And it looks fantastic. I will be using your HT for future reference also.
Jonny5nz is offline
Old 03-23-2014, 05:18 PM - Thread Starter
Monkey_Man's Avatar
Quoted: 25 Post(s)
Liked: 29
You know it! Mario is the man. Let me know if you have any questions, I'm happy to assist.
Old 03-23-2014, 07:40 PM
Jonny5nz's Avatar
Quoted: 25 Post(s)
Liked: 84
Considering Mario's Home Theater won
Electronic House 2013 Gold Award Winner
Best Home Theater $25,000 - $75,000
You can' really go wrong copying anything he did.
I'm not gonna be building my HT for some time, but I've started my plans, which continue to evolve. But I will try to replicate as much of yours and Mario's as possible. They just look so good.
Jonny5nz is offline
Old 08-23-2014, 10:23 AM - Thread Starter
Monkey_Man's Avatar
Quoted: 25 Post(s)
Liked: 29
Six zone grafic eye
Old 08-23-2014, 11:01 AM
g_bartman's Avatar
Quoted: 51 Post(s)
Liked: 62
I really admire guys who have the time, patience and skill to design and build a room like yours. I have none of those things! Very well done.
g_bartman is offline
Old 08-23-2014, 11:32 AM - Thread Starter
Monkey_Man's Avatar
Quoted: 25 Post(s)
Liked: 29
Thanks g_Bartman! it was a lot more work then I thought it would be. Thus why it took me like 3.75 years. Initial tests are amazing! Audio and video are a monster. The subs never run out of volume.
I'm going to wrap the subs with black velvet, a little too much reflected light on the sides of subs.
Old 08-23-2014, 09:10 PM
john171's Avatar
Thumbs up
Might want to do all the cabinets while your at it, from your photos it appears they all are a bit reflective.
Great looking HT, amazing workmanship. I'd go crazy if it took 3.75 years, I'd be hanging the screen and watching movies!
john171 is offline
Old 08-23-2014, 10:33 PM - Thread Starter
Monkey_Man's Avatar
Quoted: 25 Post(s)
Liked: 29
Only the top of the LCR reflect but not much with a movie, It's the subs that really reflect. Watched a move tonight and in the front row reflection is a non-issue, it's the back row that I notice it.
With the cost of the AV equipment, building supplies, tools, and time I really don't think I could have done it much faster. But I hear ya, it was an exercise in restraint not to hook stuff up during the build to preview.
Old 08-23-2014, 10:36 PM
panino's Avatar
Quoted: 27 Post(s)
Liked: 39
I just perused through your theater build. Wonderful theater you have built! Excellent craftsmanship.
I was originally planning on going the exact same color scheme with mine, then started thinking the red with black would be too dark and got the idea of switching to a tan and black. You may have me convinced to switch back to red.
panino is offline
Old 08-23-2014, 10:51 PM - Thread Starter
Monkey_Man's Avatar
Quoted: 25 Post(s)
Liked: 29
Thank you, I really appreciate it. The color of the wall didn't translate well with in the pics. I have much better shots with a SLR. But for what ever reason the color looks too orange or pink. The color of the walls is Benjamin Moore Caliente. I love this combination, looks old school theater to me.
Old 08-24-2014, 12:01 PM
avtexan's Avatar
Quoted: 31 Post(s)
Liked: 72
That looks sweeeet! Nice job and I am glad to see all of your hard work pay off.
The Moving Pictures Theater Construction Thread:
http://www.avsforum.com/t/1462881/th...ruction-thread
Houston GTG - Summer 2014
http://www.avsforum.com/forum/61-are...l#post26079610
avtexan is offline
Old 08-24-2014, 12:25 PM
Frohlich's Avatar
Quoted: 326 Post(s)
Liked: 320
Very nice!!!!
Frohlich is online now
Old 09-02-2014, 03:07 PM
panino's Avatar
Quoted: 27 Post(s)
Liked: 39
I was looking back at your wainscoting. Nice work! I'm planning something similar for my build. Did you use MDF and if so, 1/2"? Also, did you attach with liquid nails?
Thanks in advance.
panino is offline
Old 09-02-2014, 08:20 PM - Thread Starter
Monkey_Man's Avatar
Quoted: 25 Post(s)
Liked: 29
Thanks in advance.
Hey thanks! Yes 1/2" MDF panels that were glued with liquid nails panel glue. I put one screw at the top and bottom of the panel per stud. I made sure the screw would be hidden by chair rail and baseboard. For good measure I attached each panel to the columns via pocket screws again hidden by the chair rail and base board. All the trim was attached with 18" gauge nails to the panels. I caulked every inch of the wainscoting. If you do black paint I really think caulking is overkill.
