Bethesda Build - Page 20 - AVS Forum | Home Theater Discussions And Reviews
 44Likes
post #571 of 589 Old 10-10-2013, 12:05 PM
Quoted: 3899 Post(s)
Liked: 3333
An all too familiar story.
Jesto races to get the theater done "enough" to show a movie for a large party, makes some babies, gets promotion at work with more responsibilities. The theater suffers.
post #572 of 589 Old 10-10-2013, 12:23 PM
Daniel Chaves's Avatar
Quoted: 436 Post(s)
Liked: 343
oooh okay well thats a reasonable excuse, guess I will sit tight until then smile.gif
Projector: BenQ w1500 + ES Sable 135" Screen AVR: Marantz SR6011 ATMOS/DTSX + Darbee 5000s
Speakers: Polk Audio TSX550t (FL/FR), CS2 Series II (C), Monitor40 Series II (RL/RR),
Polk Audio TSx110B (Ceiling FL/FR RL/RR), (2) JL Audio 12" Subs + (2) Dayton 15" Subs + (2) ButtKicker LFE
Arrangement: 5.1.4 Source: OPPO UDP-203 4k Bluray Player, Roku 4, HTPC, Nexus Player
Daniel Chaves is offline
post #573 of 589 Old 10-10-2013, 02:21 PM
Reddig's Avatar
Quoted: 252 Post(s)
Liked: 521
Thanks Big. Aw yes that can easily happen. Excited to see it in its completed state.
JBL Pro Cinema-JTR subwoofers-Sony SXRD projection-Elite AT screen-Denon AVR-Oppo BD player-Acoustimac panels-SeatCraft HT seating
MANCHESTER UNITED!!
Reddig is offline
post #574 of 589 Old 10-10-2013, 02:55 PM
Liked: 3333
This is what we wanted to do when life got in the way.
post #575 of 589 Old 10-10-2013, 09:00 PM
cdika17's Avatar
Stupid life...
Chase "Fetch"
Old Theater Build
New House Build
cdika17 is offline
post #576 of 589 Old 01-16-2014, 05:37 PM
jimmyk36's Avatar
Quoted: 90 Post(s)
Liked: 45
SPECIAL MIDWEEK REPORT
Hey Big - So when you do the soffits with Non-IC rated lights like the ones from Lowes, are you still putting insulation in the soffits but leaving the area around the lights open?
I bought the ones from Lowes that you have used in other builds but I haven't installed them yet
This is the light I bought:
jimmyk36 is offline
post #577 of 589 Old 01-16-2014, 05:55 PM
Liked: 3333
use insulation keep it away from the lights. and just a FYI those lights do not get hot enough to burn your hand on the back side after an hour on. Toasty yes, damage no.
There are alternatives that are IC rated but after buying the trims and bulbs it is probably about twice as much. Still affordable: just google sources.
post #578 of 589 Old 01-16-2014, 06:05 PM
jimmyk36's Avatar
Quoted: 90 Post(s)
Liked: 45
jimmyk36 is offline
post #579 of 589 Old 01-17-2014, 11:33 PM
jimmyk36's Avatar
Quoted: 90 Post(s)
Liked: 45
use insulation.
Any particular kind or weight insulation or just anything fluffy?
jimmyk36 is offline
post #580 of 589 Old 01-18-2014, 04:35 AM
Liked: 3333
post #581 of 589 Old 01-24-2014, 08:26 PM
jimmyk36's Avatar
Quoted: 90 Post(s)
Liked: 45
Hey Big - Is it OK to have these lights touch DMD or GOM fabric covered soffits?
jimmyk36 is offline
post #582 of 589 Old 01-24-2014, 08:48 PM
Liked: 3333
yes it shouldn't be a prombem the trims don't get that hot, but if there is a problem you may want to switch the bulbs from 50 to 30 watt. Also if it is going to keep you up at night, they now sell LED MR 16 bulbs with a GU10 base, which should fit.
post #583 of 589 Old 01-27-2014, 09:34 PM
Reddig's Avatar
Quoted: 252 Post(s)
Liked: 521
Hey Big any recommendations on a remote light I can install above a high mounted movie poster in my stairwell then it's switch could be easily adhesived or mounted by my light switch? Seen a few but some look cheap. Thanks
MANCHESTER UNITED!!
Reddig is offline
post #584 of 589 Old 01-28-2014, 06:13 AM
Liked: 3333
time to practice your drywall patching skills, just snake a wire to the switch add a double switch, as for the light fixture, take your pick:
http://www.lampsplus.com/products/picture-lights/
I do see they have a remote controlled battery powered LED picture light:
http://www.lampsplus.com/products/concept-cordless-polished-brass-led-picture-light__t0335.html
post #585 of 589 Old 01-28-2014, 10:01 AM
Reddig's Avatar
Quoted: 252 Post(s)
Liked: 521
Right i would definilty prefer to do it that way. Problem is it's about 15 feet high above the stairwell and having both ankles fused and having just had back surgery I'm so useless so I may need to hire an electrician. That stairwell has always needed a light. Great suggestions thanks Big!
MANCHESTER UNITED!!
Reddig is offline
post #586 of 589 Old 02-18-2014, 08:45 AM
Dan Rankin's Avatar
Getting ready to start a new room within a room build. Have been admiring all of Big's recent work, including this theatre. Was some kind of acoustical treatment for the side walls originally planned? Were you going to build it into the panels illustrated here?
thank you
dan
Dan Rankin is offline
post #587 of 589 Old 02-18-2014, 09:48 AM
Liked: 3333
post #588 of 589 Old 03-23-2015, 08:04 PM
marlon1925's Avatar
Quoted: 62 Post(s)
Smile Help: Soundproofing/Acoustic Treatment
Sir,
I hope someone can share an illustration with layer labels for your soundproofing/acoustic treatment. I am presently building my own HT and am greatly inspired by this build.
Thanks a lot.
marlon1925 is offline
post #589 of 589 Old 03-24-2015, 04:31 AM
Liked: 3333
as far as I know this room is flying naked. once the screen and projector were hung for a party all work stopped.
