DIY construction methods of hang-able acoustic panels & moveable Corner traps (not fixed frames) - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 11Likes
post #181 of 191 Old 02-26-2015, 09:04 AM - Thread Starter
mtbdudex's Avatar
Quoted: 79 Post(s)
Liked: 788
^^^ ok - 1st row.
measure and post your ETC, then build the first row ceiling cloud, install it, measure, subjective listen.
>>How does your soundstage/imaging sound now?
mtbdudex is offline
post #182 of 191 Old 02-26-2015, 09:13 AM
toofast68's Avatar
Quoted: 485 Post(s)
Liked: 130
^^^ ok - 1st row.
Soundstage and imaging sound really good to my "untrained" ears.
Only question I have left, is SHOULD I make the 1st row cloud larger than 2' - since it looks like the 1st ceiling reelection is RIGHT at 2'. Will making it bigger help with the sound NOT BOUNCING off the edges of the wood frame ?
Would going 2 1/2 foot wide cause any negative effects ?
toofast68 is offline
post #183 of 191 Old 02-26-2015, 09:33 AM - Thread Starter
mtbdudex's Avatar
Quoted: 79 Post(s)
Liked: 788
2' was/is a "nice" size simply because sheets came in 2' x 4' size, it worked for me.
If you need 2.5 ft wide than do that, I remember reading in one of these hundereds of threads that while people have touted the advantages of having the sides of acoustic panels "open" to catch specular reflections, the testing has shown it's really neutral, ie, both framed sides and opened sides performed similar enough in real world. So, don't sweat it too much....
(either Ethan W site or at Gearslutz, I can't recall)
mtbdudex is offline
post #184 of 191 Old 02-26-2015, 10:11 AM
toofast68's Avatar
Quoted: 485 Post(s)
Liked: 130
Cool...yeah my stuff is 16" wide, so I am going length dimension and cutting.
Oh, I did have one more questions (sorry I have two threads that are similar, but I am trying to focus this on the building of the cloud vs. 1st reflection)...but I will ask here if that is ok.
Do you (or anybody) have any idea what tilting UP the center channel has on 1st reflection on ceiling. The software most likely does not account for that, and I know testing would, but I have no way of holding my entire cloud at that height to test.
My gut tells me it MUST move 1st ceiling reflection closer to the front ??
post #185 of 191 Old 02-26-2015, 01:05 PM - Thread Starter
mtbdudex's Avatar
Quoted: 79 Post(s)
Liked: 788
DIY construction methods of hang-able acoustic panels & moveable Corner traps...
^^^acousticians give sound fancy names, like modal waves and spectular Rays. I'll simplify, mathematically sound below what's called Fs, the translation frequency behaves like a sine wave, and wave theory can be used for its modeling and visualization. Sound above Fs behaves like spectular Rays, that is fancy way of saying like many straight lines starting from the same source and leaving it into 3D space. Fs is typically 250hz or so in common small room sizes.
What that means from your case of pointing the center channel upward vs straight? That means the reflected angle analysis is correct, but the strength of those reflections may be more because most speakers are strongest on axis and have some db fall off pattern off axis. Some speaker companies publish this info. It won't affect placement of your acoustic cloud, well technically maybe a nudge more foreword but starting with the Ray tracing as baseline is a good start. Best is having measurement mic to exactly place it.
Via Mikes brain/thumb interface, LLAP
mtbdudex is offline
post #186 of 191 Old 03-15-2015, 04:36 PM
toofast68's Avatar
Quoted: 485 Post(s)
Liked: 130
Yeah, finished by rear traps, 3.5 " Roxul Mineral Wool plus 3" air gap. Looks great too and it helps a ton...it really cut down on the echoes coming off the "close" ceiling in the back wall
Cloud is finished as well, just have to hang it and take pics.
mtbdudex likes this.
post #187 of 191 Old 02-15-2016, 09:53 AM - Thread Starter
mtbdudex's Avatar
Quoted: 79 Post(s)
Liked: 788
Been a while since I've posted here.
I've added a big 4 foot wide solid core door, that changed the balance of acoustics in the HT, so finally over past few weeks I've made a frame and nearly complete...
Hi tech sketch - grid paper
Inside view .................................................. ..... Outside view
Frame hung up without OC703 to confirm all "ok" with swing clearance, hand to know clearance, etc
2" air gap with 2" OC703 ................................ .... detail of router inside 1 x 4 pine to "hold" the 2" OC703
Temp hanging, as I'm going to do the spoonflower AT cover here, with Nick's help
This image I took Jul 14, 2015 I'd like to have as AT cover.
mtbdudex is offline
post #188 of 191 Old 02-16-2016, 08:44 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
Mike what speakers are you using?
Did you take any side wall reflection measurements?
Mfusick is offline
post #189 of 191 Old 02-17-2016, 08:34 AM - Thread Starter
mtbdudex's Avatar
Quoted: 79 Post(s)
Liked: 788
Took measurements years ago, then no door so RH side went thru curtains.
Now since added the door Reflections same as left side due to symmetry - can't change physics , so this was on my bucket list
mtbdudex is offline
post #190 of 191 Old 02-17-2016, 08:43 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
I have not totally followed this thread but wondering where you stand on the good vs bad reflections thing, and the reflect/diffuse versus absorb argument.
I know you talk with Ethan a lot on FB, and he is a big proponent of absorption at the first reflection, and at generally making the room more dead. But I also know you value Toole, his book, and the work he's done showing that some reflections are good and add spaciousness and envelopement and a wider sound stage. Just wondering where you fall with that, and what experiences you've had with it? Have you changed your treatment strategy over time because of it? And- did you new speakers change anything from the old ones? (or did you not get them up and running yet?)
Mfusick is offline
post #191 of 191 Old 10-05-2017, 06:50 PM
1Myke's Avatar
Don’t know if anyone follows this thread but when the insulation was wrapped how did you work out the bumps that push against the speaker fabric?
I’m using roxul 3” safe and sound and it has small pieces that are visibly pushing on the speaker fabric. Trying to make it look smooth, obviously. Was thinking of wrapping the face of the frame in screen then speaker fabric? Any suggestions?
RTi A7's, CSI A6, FXi A4's | Emotive XPA-5 | JVC DLA RS46 | Panamax M5300 PM | Pioneer Elite | Seymour Screen
1Myke is offline
