I used the darkest color brown I could find at Home Depot - Behr "Espresso Bean" - lights off, it might as well be black - lights on, you can barely tell its brown. My wife actually commented "ooh, I like that color" when she saw it up on the ceiling - rare that she actually notices anything going on in my build.
Also be aware that if the Mrs. doesn't allow a full dark ceiling, the next best option is to go dark on the ceiling just around the screen.
Depending on the layout/aesthetics of your room, it might actually look good (my wife wouldn't have allowed for a two tone ceiling, but luckily she OKed the black ceiling to begin with.)
I had a flat black room (all walls and ceiling) from 2000 ~ 2005 and it was a nightmare to maintain. If dust settled on the walls, it was visible and when I wiped it off, it left a marks. If I used a touch up paint, it dried slightly different shade and looked worse. In the end, it was either repaint the entire wall each time or change the colour. I elected to move rooms and use a different colour.
I've used Pompeii Ash for the last two rooms and it can have a high WAF.
The key is light reflectiveness........Ralph Lauren Suede paint is very unusual--textured, hardly any sheen at all........besides its looks GREAT! The look of suede really gives that "high end" look..........soft with very low light reflection
Google the paint color..............and yes, the color sample on line looks nothing like what it looks like on the wall. Very deep, chocolate brown.............a much better alternative to flat black IMHO.
The paint is expensive, and you need to roll and then use an X pattern to bring out subtle patterns of the suede look. Don't discount colors from online source..........see for your self. I believe Home Depot distributes the paint...............
two things - First, I'm not sure I like that muted color. Sorry, just my opinion of course (and it's your room so only you and the wife needed to like it anyway). A lot will depend on if you're using crown molding and what color that will be though. I find that white strip there now very distracting. See my thoughts about color in the next paragraph.
The other thing, I like the accent lights you have in the soffit. Very nice effect. Would you be willing to share what type, size, and wattage they are? Where did you pick them up? I am embarking on (planning) my own project and I would like to do something similar. Okay, back to the color. As great as PS it leaves a lot to be desired for choosing color in the real world. I once painted a ceiling a color that looked great in PS but what happened in the real world was very different. That color reflected downwards and shifted the color of the rest of room including the wall color that I liked previously. I was not a nice effect. Anyway, notice how much the color changes on your walls where it is lit by those cans vs in the shadowed area and non direct light area. It can make the same color coming out of the can look like a different color. Have you thought about going monochromatic and using the wall color on the ceiling? With those accent lights on the walls they will look lighter than the ceiling does simply because of the lighting. Obviously it will match well too because it will all just be varied shades and brigtnesses of the same color. Depending on how often those lights will be on and what other ones will be used it can change quite a bit. Anyway, just a thought.
To go along with this thread (sort of), I used flat black on my ceiling, but my projector (which is ceiling mounted and picture angled to the floor) still reflects a decent amount of light on the ceiling and lights up the first half of it.
is velvet better than paint to not reflect any light?
the recessed lights i picked up at home depot for about $10 each. they are cheap and serve the purpose. however, they are very HOT and have high defect ratios. i must have returned at least 4 defected units.
we wanted the room to also be a family area, and a place where we can entertain guess as well, so we opted for a more neutral look, rather than an all out dark room.
currently, i leaned toward a darker brown/gold on the ceiling so it would complement the wall. but obviously, i am open to ideas/suggestions.
Velvet is a good choice, but installation will be tough and it's rather expensive. I used the Ralph Lauren Suede paint and it has worked out very, very well for us. Info on my build thread.
Thanks. I used RL Suede Paint upstairs, but home depot will not sell it anymore (and it's like 40 a gallon).
My questin to you will be is it really possible a brown (or dark) suede paint will work better than flat black? Flat black works fairly well but you can still see it light up the first few feet of the ceiling above the screen.
I hope I'm not infringing on this thread, just enlightening all that even flat black isn't good enough.
smokarz, very nice room. Take a look at the walls and ceiling in my theater and see what you think.
As you can see, next to the black trim, the color is very dark gray. If you like, the color is called "lincoln kettle black" and it is a Valspar brand (lowes)
@elmalloc - I found the hard way that some "flat" paints are more flat than others - in my case, Valspar (Lowes) had quite a bit more sheen than Behr (Home Depot). You might try a couple flat paint samples on a board or scrap drywall to test, before investing in fabric for the ceiling.
I really like those color combinations (dark purple carpet).
Related Threads
AVS Forum
34M posts
1.5M members
Since 1999
