Desert Sunset Theater Build - Page 25 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #721 of 1112 Old 03-13-2012, 08:12 AM
J_P_A's Avatar
Quoted: 651 Post(s)
Liked: 484
I don't have any first hand experience with this, but I know a lot of people just use regular carbide router bits since aluminum is so soft. I think if you're just cutting out the openings with the router, then I'd try to cut out most of it with a jig saw leaving maybe 1/16". Then come back with the router to clean it up. Seems like I've read using a larger bit is a good idea as well to help keep the bit cooler and limit clogging. Unfortunately, that means more cleanup to do at the corners.
The Plains Theater Has Begun
J_P_A is offline
post #722 of 1112 Old 03-13-2012, 11:02 AM
dwightp's Avatar
What router bit would be the best for cutting aluminum?
If you use a router for this, please wear eye protection. You might want to wear long sleeves, too. There will be lots and lots of little sharp aluminum chips flying around at high speed. If your router has variable speed, dial it back to the slowest speed. Even so, your router will be running 10X faster than the mill that a machine shop would use to do this work.
My first choice for a router bit for this work would be a solid carbide down-cut spiral bit. They are rather expensive and can be hard to find (easily available on the internet, though). If you want more info about this kind of bit, let me know. You would need to use a guide bushing and a template, as petew suggested.
If you don't use a spiral bit, I would probably suggest a bearing-guided flush trim bit like this:
Link: http://www.amazon.com/Freud-50-102-2...1660562&sr=8-1
This kind of bit with the bearing on top lets you put the template on top of the workpiece -- the router actually rides on top of the template -- which is how I prefer to work with this kind of thing. You would make a template as described by petew, except that you would not need to calculate an offset. Use the template to mark the cutline and, as J_P_A suggests, cut out the bulk of the material using a jig saw.
dwightp is offline
post #723 of 1112 Old 03-13-2012, 11:41 AM - Thread Starter
stockmonkey2000's Avatar
Liked: 30
Will definitely wear eye protection. When I cut out the rough plates on the table saw I had short sleeves on and one arm ended up taking the brunt of the shavings. It still looks like I have a rash.
stockmonkey2000 is offline
post #724 of 1112 Old 03-13-2012, 12:45 PM
petew's Avatar
Quoted: 27 Post(s)
Liked: 68
I use a solid carbide spiral up cut bit sized the same as your collet. I usually use a 1/4" bit with good results.
With a guide bushing mounted to the router.
Eye protection
Hearing protection
Tight fitting long sleeve tee shirt
Helper with the same safety gear
Have the helper flood the cut with WD-40 (with the straw) to flush and cool.
Fresh air - the WD-40 will smoke.
Building Bass - Subs
Surrounds - Easy as Pi
Storage - unRAID unDELL
Mains - Another piece of Pi
petew is offline
post #725 of 1112 Old 03-13-2012, 12:52 PM
J_P_A's Avatar
Quoted: 651 Post(s)
Liked: 484
I can't keep the two straight, but does an upcut bit throw the shavings out the bottom? Seems like that would be desired in this situation, right?
J_P_A is offline
post #726 of 1112 Old 03-13-2012, 01:57 PM
dwightp's Avatar
Up-cut throws the chips up, toward the router. Down-cut pushes the chips down, away from the router.
dwightp is offline
post #727 of 1112 Old 03-13-2012, 02:21 PM
J_P_A's Avatar
Quoted: 651 Post(s)
Liked: 484
Since he's cutting through the metal, would a down-cut help keep the shavings off of him?
J_P_A is offline
post #728 of 1112 Old 03-13-2012, 04:26 PM
dwightp's Avatar
Yep. Chips will still go everywhere, of course, but a down-cut bit will throw more of them away from the user.
dwightp is offline
post #729 of 1112 Old 03-13-2012, 07:54 PM - Thread Starter
Liked: 30
I extended the doorknob so it would fit the thicker door. To extend the knob I cut off an inch or so of the hollow center post. I ground down a steel square rod so that it would fit inside the hollow post. Then I put the hollow post that was cut off on the end.
post #730 of 1112 Old 03-13-2012, 07:57 PM - Thread Starter
Liked: 30
Since the two halves do not connect together I created a wood plug that would keep the two halves from spinning independently from each other.
post #731 of 1112 Old 03-14-2012, 05:05 AM
Larry M's Avatar
Quoted: 29 Post(s)
Liked: 46
Holy crap...is that 2 doors sandwhiched together
Larry M is offline
post #732 of 1112 Old 03-14-2012, 06:36 AM - Thread Starter
Liked: 30
Its a solid core door with 2 layers of 1/2 inch MDF. Green Glue between layers.
post #733 of 1112 Old 03-14-2012, 11:43 AM
LeBon's Avatar
Quoted: 184 Post(s)
Liked: 88
That is a serious door!
LeBon is offline
post #734 of 1112 Old 03-14-2012, 01:36 PM
FOH
FOH's Avatar
Quoted: 39 Post(s)
Liked: 236
That is a serious VAULT door!
Sweet, keep it coming.
Active 16.8kw, 7.3 system
(2)Seaton SubM-HP, (4)18" IB
FOH is offline
post #735 of 1112 Old 03-14-2012, 05:32 PM
misugrad's Avatar
I want to see a pic of you actually picking up that beast of a door and setting it on hinges...or did the drywall lift come in handy again?!
Mike
Started the build...Theater With A View
misugrad is offline
post #736 of 1112 Old 03-15-2012, 03:48 AM
chinadog's Avatar
Quoted: 77 Post(s)
Liked: 284
Lifting that door and putting on the hinges is going to be fun.
Bud
chinadog is offline
post #737 of 1112 Old 03-15-2012, 06:41 AM - Thread Starter
Liked: 30
That's an old picture. The door was installed a long time ago. Hanging the door itself was not that difficult. It was reinforcing the door jamb that was the hardest part. I could not use double drywall near the jamb because the screws would go into the drywall. I replaced the drywall on the hinge side with an inch of wood with a thin 1/4" layer of drywall over it.
post #738 of 1112 Old 03-15-2012, 07:37 AM
bob2229's Avatar
I put the rest of the lights in the columns. I was able to do a little cleaner job this time with the parts I received today. I used the rope light channels to keep things nice and straight and even out the light output.
Stockmonkey, how are your columns wired? It looks like the rope lights are plugged into an outlet. Are they all wired to a switch? Are they dimable?
bob2229 is offline
post #739 of 1112 Old 03-15-2012, 07:43 AM - Thread Starter
Liked: 30
Yes the outlets in the columns are wired to a Grafik eye light controller. The rope lights are dimmable. The rope lights in the columns are incandescent.
post #740 of 1112 Old 03-15-2012, 08:13 AM
NicksHitachi's Avatar
Quoted: 182 Post(s)
Liked: 192
Hi SM2K,
Your theater is really nice looking and ALL DIY!! That is the impressive part IMO. Maybe change your sig hyperlink to reference "Desert Sunset Theater Build"? I clicked to check out your IB build and found your build thread by pleasant mistake. Might help others find ya, if that matters, IDK.
Off to finish going through it......
Nicholas
NicksHitachi is offline
post #741 of 1112 Old 03-15-2012, 10:51 AM
donjuanwater's Avatar
Are "Incandescent" Rope Lights different than regular rope lights and LED rope lights? What defines a rope light as being "Incandescent"?
donjuanwater is offline
post #742 of 1112 Old 03-15-2012, 12:05 PM - Thread Starter
Liked: 30
They are the rope lights with a traditional incandescent bulb instead of an LED bulb. Incandescent lights are always dimmable. Some LED's can be dimmed and some cannot. LED's are more efficient. Incandescent rope lights are cheaper than the LED rope lights and generally have a warmer color.
post #743 of 1112 Old 03-15-2012, 12:16 PM - Thread Starter
Liked: 30
Hi SM2K,
Nicholas
Thanks - It has been pretty much DIY and by DIY I mean for the most part it has been just me. The other help I've had - other than my wife painting the soffit woodwork, probably totals less than 1/2 hour of work. The only thing I really will be paying someone else to do is the carpet installation.
I've remodeled 4 homes now with significant help from others, but it has been really fun to do a sort of no compromise type of build. I think I have learned more on this room than all my other projects put together. I learned a lot from just trying to overcome various challenges on my own whether it be hanging a 12' sheet of drywall by myself or devising some sort of bracket to hold something above my head. In the past I would have waited for help for various things, but on this project I really wanted to see if I could do it on my own.
post #744 of 1112 Old 03-21-2012, 11:30 AM
JVoth's Avatar
Quoted: 304 Post(s)
Liked: 152
It seems like updating a build thread is a full time job in itself, so thanks for the ideas and hard work. However, it does look like we're slacking on said updates. Whatcha got for us?
JVoth is offline
post #745 of 1112 Old 03-21-2012, 11:54 AM - Thread Starter
Liked: 30
Unfortunately not much in the way of progress the last few weeks. Haven't had much time to put in to the theater lately. Big delay right now is waiting for the screen. I did start working on my acoustic panels - might be able to get a bit more done tonight.
post #746 of 1112 Old 03-21-2012, 12:49 PM
cdika17's Avatar
I also started work on the door. Started by hanging the door first.
Then removed the door from the hinges and cut 2 layers of 1/2" MDF. This was a dry fit. I used 2 layers of 1/2" so it would come close to matching the width of the automatic door bottom. I'll have to shim the door bottom out 1/8"
What is the width of your door?
Chase "Fetch"
Old Theater Build
New House Build
cdika17 is offline
post #747 of 1112 Old 03-21-2012, 12:57 PM - Thread Starter
Liked: 30
what is the width of your door?
2.75"
post #748 of 1112 Old 03-21-2012, 01:36 PM
cdika17's Avatar
2.75"
Width, not depth,
Chase "Fetch"
Old Theater Build
New House Build
cdika17 is offline
post #749 of 1112 Old 03-21-2012, 01:37 PM - Thread Starter
Liked: 30
width, not depth,
32"
post #750 of 1112 Old 03-23-2012, 04:43 PM - Thread Starter
Liked: 30
Finished up a few of the panels today. Ended up running out of staples so called it a day.
Fiberglass insulation
Fabric stretched on frame
Behringer Europower Ep4000 Professional Amplifier , infininte baffle , Integra , Jvc Dla Rs45 Home Theater Projector 1080p Hdmi , Oppo Bdp 93 Blu Ray Player
