Desert Sunset Theater Build - Page 34 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
Old 08-10-2012, 08:02 AM
NicksHitachi's Avatar
Quoted: 182 Post(s)
Liked: 191
Originally Posted by stockmonkey2000 View Post
Yes the projector is mounted in the hushbox. It is about 20' from lens to screen. I'll try to get a photo up of the PJ in place.
Hi SM2K,.
What type of ventilation and how much did you use for your hush box?  Could you link me to the build?
Nick
NicksHitachi is offline
Old 08-10-2012, 08:11 AM - Thread Starter
stockmonkey2000's Avatar
Liked: 30
I used a Panasonic whisper quiet fan for my hushbox (amazon link below). It is installed in the adjacent equipment room. I have a thermostat in the hushbox that will turn the fan on, however with my current setup, it never kicks on because the JVC projector has intake on the right side of the front of the unit and blows hot air out of the left side front of the unit, so the hushbox itself has never gotten hot. I could re-route the fan duct but it has not been an issue so far. The PJ is quiet and the heat from the projector has not been an issue so far. I used 4" duct but if I had to do it over I'd probably increase to a 5" duct at the hushbox to keep it a bit quieter.
http://www.amazon.com/gp/product/B003TJAGPS/ref=oh_details_o00_s00_i00
stockmonkey2000 is offline
Old 08-10-2012, 08:12 AM - Thread Starter
Liked: 30
There are more details of the fan and thermostat for the hushbox in post #336.
Old 08-10-2012, 09:13 PM
cw5billwade's Avatar
Quoted: 328 Post(s)
Liked: 184
thanks I am having a house built in GA and will be putting my HT on second floor looking at 24x18x9 with 2 ft screen wall, AT screen from Jamestown like yours. Just trying to plan everything now so that the sound plan can be built into the room. It will be unfinished and I plan to finish it but need a projector that will throw the same distance as you.
cw5billwade is offline
Old 08-16-2012, 11:26 AM
BllDo's Avatar
Quoted: 595 Post(s)
Liked: 393
I think with a 2 ft screen wall, your pj choices are going to be a little limited.
BllDo is offline
Old 08-17-2012, 12:59 PM
Quoted: 328 Post(s)
Liked: 184
No what I meant was a false wall of 2 feet with a 133" or larger 240.1 scope AT screen. That would give me 22 ft to the rear wall with maybe 20 ft to the soffit like Stockmonkey200
Old 08-17-2012, 06:43 PM
nickbuol's Avatar
Quoted: 602 Post(s)
Liked: 638
I've got a 2 foot deep false wall with Seymour XD (AT material) screen. The lens of my projector (JVC RS45) is about 18 feet from the screen. I could have gone closer of further back based off of specs, but the placement is perfect for me. The screen is 138" 1.78:1 format and just FYI that this DOES push the size limits quite a bit for AT screen usability in regards to picture quality with a lower gain screen (vs something a lot higher gain that isn't AT).
I can easily see myself having to mask down the 138" screen at some point to keep the image looking great.
Just a bit of advice so that you are prepared for a long throw, "low" gain, large screen setup.
nickbuol is offline
Old 08-25-2012, 01:30 PM
cdika17's Avatar
I also did some work on the hush box. Ran the fan duct and conduit and installed the electrical box for the powerbridge. All the initial wiring will be run outside the conduit leaving the conduit open for future expansion.
Did you account for all this weight on ceiling with extra clips and channel?
Chase "Fetch"
Old Theater Build
New House Build
cdika17 is offline
cdika17's Avatar
Also I want to do star ceiling eventually, what do I need to run for wires? Just 12/2 romex to my grafik eye?
And what is the list of parts/components you need?
Chase "Fetch"
Old Theater Build
New House Build
cdika17 is offline
Old 08-28-2012, 06:56 PM - Thread Starter
Liked: 30
Yes I did use extra channel and clips on the ceiling. I used the triple layer of drywall formula from the soundproofing company and then added some additional clips. With the star ceiling I actually have 4 layers with one layer being OSB. Most of the weight of the soffits are supported by the side walls which are standard stud construction with a layer of OSB which gave me plenty to attach the soffits to.
For the star ceiling I ran 2 romex (14/2). One is for the lamp and one for the motor. The motor is wired separately so it will not be dimmed by the grafik eye. My motor is hooked to an occupancy sensor.
The parts you need for the star ceiling depend a lot on how you install. The basic components are the illuminator and the fibers. You also need things like 1mm drill bits, a hot wire cutter to cut off the wires (this is necessary if you use the FOSI illuminator like I used but can be obtained from FOSI with a refundable deposit) and a template for your stars. I created my own template. You would also need painted or fabric covered panels and a method to attach them. I have lots of details in the thread about how I created the panels and attached them.
Old 08-29-2012, 06:20 PM
chinadog's Avatar
Quoted: 61 Post(s)
Liked: 236
How are you liking the JVC RS45? I think the throw distance on the Panny AE7000 is a little too far for the distance I need and the screen size. Any dislikes?
Bud
chinadog is online now
Old 08-30-2012, 05:53 AM
nickbuol's Avatar
Quoted: 602 Post(s)
Liked: 638
chinadog, not sure if you were asking me, but I'll answer anyway. I REALLY like the RS45. As it is well noted, it is not the best 3D projector, and I don't plan to ever use it for 3D, so that works for me. The inky blacks, great *real* contrast is wonderful too. Makes for a lot more detail in the dark areas of movies where other projectors lose out. It has been argued to be the best 2D projector (under $5000 MSRP) for 2012.
nickbuol is offline
Old 08-30-2012, 07:25 AM - Thread Starter
Liked: 30
I agree its a great projector. It produces a great picture with great detail in the blacks. The only minor nitpick I have is some motion blur on fast moving scenes. I think part of that is due to the huge screen. I would be interested in trying a different screen at some point because I did not notice the motion blur as much when I was just using a sheet while waiting for the screen. Of course the image size on the sheet was smaller too so that could be a factor.
Old 08-30-2012, 12:25 PM
nickbuol's Avatar
Quoted: 602 Post(s)
Liked: 638
Just use the zoom to make the image smaller... wink.gif Just for testing of course, and then crank it back up! cool.gif
nickbuol is offline
Old 09-08-2012, 11:21 AM - Thread Starter
Liked: 30
Still not much additional progress to show - I have started finishing up the rest of the basement but have not done much on the equipment room yet. I did pick up a new beverage center which will end up in the equipment room.
Old 09-08-2012, 10:36 PM
Jon_B's Avatar
Quoted: 25 Post(s)
Nice selection!
Jon_B is offline
Old 09-11-2012, 01:54 PM
Quoted: 328 Post(s)
Liked: 184
I just ordered a couple pairs of 3D glasses to check out the RS45 in 3D. Anyone have recommendations on 3D blu rays? Only thing I currently have is Hubble 3D.
I have about 20 or so 3D blue rays by far the best IMHO is Parrots of the Carrabin or any other Disney film. They do 3D right
Old 09-11-2012, 01:59 PM - Thread Starter
Liked: 30
I have since bought a few other 3d blu rays and have not even tried them out. I did watch Hubble and did not care for the 3D at all, so I have not really spent time watching anything else in 3d. Have Cars 2 in 3d and its still in the wrapper.
Old 09-24-2012, 05:59 PM
wadepoe's Avatar
Hey SM2K, I found your build on the IB cult and was so impressed I read through all 1021 posts. Love everything about your build including the crappy set backs, makes me feel like even I could do this.
I do have one question, could we see some more pics of the rack, front/back. What circuit size did you go with for the rack set up (15/20/30A)?
Keep up the good work!
wadepoe is offline
Old 09-25-2012, 11:54 AM - Thread Starter
Liked: 30
I'll try to get some pictures of my rack up. I still have work to do on the equipment room and some wire management to do. I have 2 20A dedicated outlets in the rack for the amps and I also have a 15A dedicated circuit that the rest of the equipment and projector are on. Probably overkill but I do have 4 2 channel amps and will be adding another. One of the amps (sierra audio) is pretty heavily biased in Class A and would sometimes trip a 15A breaker on its own when flipping the switch. The bigger sierras have 2 power switches one to charge up the capacitors and then another to power up the amp. My sierra is the smallest one and the power supply has 200,000uf of capacitance. The projector is plugged into a UPS which runs on the 15A circuit.
Old 10-08-2012, 07:01 AM
vanice's Avatar
Quoted: 32 Post(s)
Liked: 53
SM2k - Can you help me out with a sub wiring question? Is this how you wired up your IB subs?
I'm working on installing mine now and wanted to verify this before going much further.
vanice is offline
Old 10-08-2012, 07:12 AM - Thread Starter
Liked: 30
Yes that is exactly how I wired them. What amp are you using?
Old 10-08-2012, 07:14 AM
vanice's Avatar
Quoted: 32 Post(s)
Liked: 53
vanice is offline
Old 10-08-2012, 07:20 AM - Thread Starter
Liked: 30
The wiring above would give you around 350 watts per driver with that amp which is plenty. I've never pushed my IB to the limit yet.
Old 10-08-2012, 07:48 AM
vanice's Avatar
Quoted: 32 Post(s)
Liked: 53
Thanks for the confirmation. I started to wire it up differently but remembered that they are 2 ohm speakers and not 4 ohm. I just hope that my wire run wasn't too exact since I'll have to stretch the run a little bit to the next speaker. rolleyes.gif
Has the IB lived up to what you thought it might be?
vanice is offline
Old 10-08-2012, 09:15 AM - Thread Starter
Liked: 30
They do sell the speakers in 4 ohm models - just make sure that you ordered the 2ohm. Its not possible to get 4 ohm load for 2 channels with the 4 ohm drivers. The IB sub has been really great. The only thing that I was a bit disappointed in was that the subs do naturally roll off at 20hz or so (your experience may be different). I have EQ'd them for deeper response, but I did expect the response to go deeper naturally. In real world use though there is plenty of deep bass. The nice thing is never having to worry about the bottoming out the drivers. I've never come close to doing that.
Old 10-08-2012, 09:25 AM
TMcG's Avatar
Quoted: 1140 Post(s)
Liked: 970
SM2K - is that rolloff a function of any kind of equalization / DSP / room correction you have or is that a function of the speaker? Have you had the room professionally calibrated so that you could see / hear that super low-end response with the sub-sonic roll off?
TMcG is offline
Old 10-08-2012, 09:47 AM
vanice's Avatar
Quoted: 32 Post(s)
Liked: 53
Thanks stock, I did get the 2 ohm version. I still need to get something to eq. What are you using?
vanice is offline
Old 10-08-2012, 12:21 PM
damelon's Avatar
Liked: 274
Pretty much all of the Animated 3D movies are decent in 3D. The IMAX "Under the Sea" is a good one. You get both amazing depth underwater and some great pop-outs. Also, the Avengers had some good 3D in it, though most of it is the Avatar-ish depth 3D. I'd much rather a movie come in scope than be 3D. All of these epic movies coming out in 16:9 due to 3D is pissing me off.
damelon is offline
Old 10-08-2012, 12:51 PM
Quoted: 328 Post(s)
Liked: 184
guess I will have to unwrap my avengers and watch it then. Still on 55" Panasonic plasma GT30. No where near as fun as you all. On my TV there is bars on top and bottom of most 3D are you saying that avengers is 16x9?
Behringer Europower Ep4000 Professional Amplifier , infininte baffle , Integra , Jvc Dla Rs45 Home Theater Projector 1080p Hdmi , Oppo Bdp 93 Blu Ray Player
