DIY Custom-Printed Movie Poster Acoustic Panels - cheap! - Page 101 - AVS Forum | Home Theater Discussions And Reviews
 953Likes
post #3001 of 3005 Old Today, 07:12 AM
Jase25's Avatar
Quoted: 18 Post(s)
Originally Posted by Charlie Anderson View Post
Finished my first batch of DIY posters. 6 down, 6 to go.
https://imgur.com/gallery/W3G6f
Those turned out great, well done! Looks like you used 1x3's and the Owens Corning 703 insulation. Did you just set the insulation in the frame of did you use some hot glue(or similar)? Also, are the frames setting flush against the wall?
Jase25 is offline
post #3002 of 3005 Old Today, 07:59 AM
Charlie Anderson's Avatar
Quoted: 18 Post(s)
Liked: 5
Correct! I used spray adhesive on the inside of the frames to keep the insulation in. Had to cut it EXACTLY to size as there is no give in the material. I might try to use Roxul if I make more than 6 for he next batch.
The frames are sitting about 1/2" away from the wall, maybe less. I used a Monkey Hook, heavy duty one, for the panels and they just sit a bit away from the wall. Worked great!
Director of Photography | Digital Imaging Technician
www.charlieandersondp.com | www.dorkinatent.com | http://imdb.to/1iVaUAZ
Charlie Anderson is offline
post #3003 of 3005 Old Today, 09:38 AM
KB77Hell's Avatar
Quoted: 156 Post(s)
Liked: 74
Looking GOOOOOOD!
LG OLED65C6P ~ MARANTZ SR6011~ OPPO UDP-203
PS4 PRO ~ XBOX ONE-S ~ PS3 ~ BELL FIBE ~ Monitor Audio Silver Series Speakers in 5.1
KB77Hell is online now
post #3004 of 3005 Old Today, 10:30 AM
Quoted: 149 Post(s)
Liked: 26
My great room has dark grey walls and dark grey furniture, but the carpet is light colored and the ceiling is white. I have a light canon of a projector too. I'd like to build panels this summer and am curious as to how much I should worry about reflections should I go with family pictures or the like.
My initial thoughts are to go with either a darker or lighter shade of grey on the walls and my wife isn't ready to decorate that part of the house (the room is finished, but we want to do a bar before adding further decor).
HarpNinja is offline
post #3005 of 3005 Old Today, 08:32 PM
xylem's Avatar
Quoted: 246 Post(s)
Liked: 151
Looks great! Which Printer and fabric did you end up using?
Sony VPL-HW40ES / Silver Ticket 110"
Pioneer SC-97
Klipsch RP-450C / 2x RP-280F / 2x R-5650-S II / 2x F-30 / 2x CDT5800 II
Sub: Outlaw Ultra-X12
HTPC Windows 7 and Kodi (with custom Phenomenal skin) / Home Server for Media
My personal take on Acoustic Panels and Posters
xylem is online now
