DIY Custom-Printed Movie Poster Acoustic Panels - cheap! - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 1044Likes
post #61 of 3115 Old 03-12-2011, 08:44 PM
cybrsage's Avatar
Liked: 154
Originally Posted by longshorejl View Post
If I scale my image to 24 x 36 do I then need to add a colored border around the image? I don't want the wrapped fabric to be white on the sides of the panel.
Jim
I would make the border of your image black.
What size border do people recommend?
cybrsage is offline
post #62 of 3115 Old 03-13-2011, 06:38 AM - Thread Starter
luma's Avatar
Liked: 35
In the art world this is known as gallery wrap. Typically, what you will do is extend the color of the outside border enough to wrap around the back. Alternately (depending on the source material), you might mirror the image or otherwise extend the lines of the artwork beyond the image frame in order to accommodate the wrap.
You need enough fabric to wrap around the depth of the frame, and I'd leave at least .5" (1" is better) to staple on the back. So if you're using 2" deep frames on a 36" wide image, you would ideally have a 42" wide print (36" + 2" + 2" + 1" + 1").
cholmes1 likes this.
luma is offline
post #63 of 3115 Old 03-14-2011, 10:19 AM
mtbdudex's Avatar
Quoted: 79 Post(s)
Liked: 771
Did you do the testing yet?
Samples just came Monday afternoon......
I did the subjective testing and posted those, the objective with mic/REW will be this weekend - I need to make a test fixture.
I'm getting new 1st row seats today (was supposed to be yesterday) and want to re-calibrate the HT with those, so doing double duty.
Did the objective testing this weekend, lots of charts/graphs here:
http://www.avsforum.com/avs-vb/showt...4#post20147694
Cliff notes
Spoonflower cotton cloth charts
Chart 2a Midrange with spoonflower cotton cloth, baseline and @ 0, 45, 60 degrees
Chart 2b Tweeter with spoonflower cotton cloth, baseline and @ 0, 45, 60 degrees
2a.......................................................... .................................2b
>>My conclusion from the midrange/tweeter charts: spoonflower cotton cloth is AT and good to go for acoustic absorber panels usage.
mtbdudex is offline
post #64 of 3115 Old 03-16-2011, 08:00 PM - Thread Starter
luma's Avatar
Liked: 35
This is seriously great work mtbdudex! Thanks for going through all this trouble, and I'm glad it verified my fantastically non-scientific breath test. I've updated the OP with a link to your results.
luma is offline
post #65 of 3115 Old 03-23-2011, 08:06 PM - Thread Starter
luma's Avatar
Liked: 35
Update: final pictures (finally) posted.
luma is offline
post #66 of 3115 Old 03-23-2011, 10:48 PM
xzener's Avatar
Quoted: 30 Post(s)
Liked: 38
Those completed posters came out great... I have a hunch I will be creating some acoustically transparent posters to hide my in-wall speakers. Thanks for the great tutorial.
Xzener
xzener is offline
post #67 of 3115 Old 04-04-2011, 11:44 AM
cybrsage's Avatar
Liked: 154
Awesome!
cybrsage is offline
post #68 of 3115 Old 04-04-2011, 11:45 AM
cybrsage's Avatar
Liked: 154
Does anyone know where I can find some high res images of Troy Palomalu and other Steelers' images?
cybrsage is offline
post #69 of 3115 Old 04-04-2011, 01:56 PM
dooomi's Avatar
I don't know the answer to your question, but you may run into copyright issues with images like that.
dooomi is offline
post #70 of 3115 Old 04-04-2011, 02:19 PM
cybrsage's Avatar
Liked: 154
Yeah, I know. I would contact the owner to cover my bases. I did a search (including on the NFL site and the Steelers site) and found none to even ask about!
cybrsage is offline
post #71 of 3115 Old 04-07-2011, 07:56 AM
localhost127's Avatar
Quoted: 25 Post(s)
Liked: 61
the freqency response isn't really necessary --- but does anyone have ETC graphs with this printed fabric? that will give a better indication of absorption (especially at grazing incident angles)
thanks you !
localhost127 is offline
post #72 of 3115 Old 04-08-2011, 08:24 AM - Thread Starter
luma's Avatar
Liked: 35
FWIW Spoonflower doesn't seem to care much about that sort of stuff. Use discretion as necessary. For images like that, they are almost always shot under contract for magazines/TV networks and can be difficult to license. If it's an independent photographer, you will often find that you can deal with them directly to get high-res images at a reasonable reproduction price.
luma is offline
post #73 of 3115 Old 04-08-2011, 10:34 AM
cybrsage's Avatar
Liked: 154
From what I understand, places such as Spoonflower require us to obtain the rights to the print, they make the assumption we have done so. Good idea for them, since otherwise they are open to a world of hurt.
As I find pictures, I attempt to find the picture taker and contact them, I assume the picture taker knows who has the rights to allow me to print. So far, no replies, but I expected this part to take time.
cybrsage is offline
post #74 of 3115 Old 04-08-2011, 11:12 AM
mtbdudex's Avatar
Quoted: 79 Post(s)
Liked: 771
thanks you !
I saved my measurements in rew5, so should be able to show this data for 0,45,60 degrees.
(driving home from WDW now, surfing AVS via my new ipad2 3G while my wife is driving her turn)
mtbdudex is offline
post #75 of 3115 Old 04-15-2011, 10:49 AM
spike9876's Avatar
Quoted: 42 Post(s)
Hello...
I'm planning on getting printed art on panels and since I'm not much of a DIY...
I know that it would be much cheaper to do it yourself... but I was thinking about getting panels and then order printed fabric. Then I would only need to staple then printed art cloth over a premade panel... OK to do this ?
Thanks in advance.
Fronts: Sanders Sound M10d, Sanders Magtech Amp. Surround: B&W CM1, 2x JL Audio F112, Integra DHC-80.3, Emotiva XPA-5, OPPO 93 & HTPC
spike9876 is offline
post #76 of 3115 Old 04-15-2011, 12:54 PM
Quoted: 25 Post(s)
Liked: 61
Originally Posted by spike9876 View Post
Hello...
Thanks in advance.
it's not recommended to double up the layer of fabric if the panel is to be used for broadband absorption to absorb first order specular reflections @ high angles of incident.
post #77 of 3115 Old 04-15-2011, 01:17 PM
HDvids4all's Avatar
In other words, replace existing fabric on the panels, don't just staple the new fabric over top of it.
Another option is to buy pre-made panel frames, along with the insulation that goes inside it. Your cost will be much much cheaper than buying full panels from the start, and you won't have to dissect anything.
Note: If you can find an insulation supply co. close by, you'll save a good amount on OC703 or equivalent instead of ordering online.
tank3467 likes this.
HDvids4all is offline
post #78 of 3115 Old 04-15-2011, 01:52 PM
dc_pilgrim's Avatar
^^^^ Nice resources.
dc_pilgrim is offline
post #79 of 3115 Old 04-15-2011, 01:59 PM
Quoted: 25 Post(s)
Liked: 61
correct. sorry i wasn't more clear. remove old fabric and re-staple the printed.
just my opinion, but id advise against those frames with hardwood backings, unless you're mounting directly up against the wall.
also ... depends on the use, but if they're for broadband panels for early reflections i'd advise against full frames that wrap around the sides as you can induce edge diffraction (all can be verified with an ETC).
post #80 of 3115 Old 04-15-2011, 04:39 PM
spike9876's Avatar
Quoted: 42 Post(s)
OK, so bad idea to cover panel with art cloth over existing panel cloth.
Next question, I have an irregular room and from research I was planning on placing 3 panels on wall behind my couch which sits flush with wall. I probably should be fine with two but have seen art panels across 3 panels and they look good. I had been planning on placing 4" bass panels but Im having doubt wether I really need 4" and if 2" would be fine on a non corner wall. I understand that 4" absorbs more but I'm a little confused which one to use.
Also, what about spacing when placing panels against wall ? Should it be flush against wall or I should have some inches from wall ?
Thanks in advance
post #81 of 3115 Old 04-15-2011, 10:43 PM
stepyourgameup's Avatar
Liked: 29
4" will absorb more of the lower frequencies than 2" but 2" should be fine for non-corners. If you can space the panels from the wall that will also help absorb more of the lower frequencies. So if you do go with 2" panels and can provide some space between them and the walls you will be doing good.
Alcohol. The cause of and solution to all of life's problems.
stepyourgameup is offline
post #82 of 3115 Old 04-16-2011, 06:23 AM
Quoted: 25 Post(s)
Liked: 61
i disagree.
for absorbing early reflections, at least 4" OC703 (or equiv) with 4" air gap. 6" OC703 with 4-6" air gap if you can afford losing a bit more real estate.
you can verify all specular reflections are destroyed with an ETC graph (measured one speaker at a time).
post #83 of 3115 Old 04-16-2011, 06:28 AM
Quoted: 25 Post(s)
Liked: 61
Thanks in advance
you need to add as much absorption (sq area covered) as you need depending on how large your sweet spot/listening position needs to be.
for destroying specular reflections (first order reflections), 4" OC703 with 4" air gap should do the job, but measurements will tell you for certain.
since the rear wall is also a LF issue (nulls off the rear wall), 6" OC703 with 4-6" air gap should perform nicely.
read this for an understanding of how porous absorption works:
http://www.ethanwiner.com/acoustics.html
read it - it will probably save you time and money in the long wrong to take the time and understand what's going on re: porous absorption before blindly applying treatments.
utilizing an air gap is about as close to a 'free lunch' as one can get in the real world. see the above link to understand why.
post #84 of 3115 Old 04-16-2011, 06:34 AM
cybrsage's Avatar
Liked: 154
Wow, a two feet of space (one foot per side) lost to absorption panels? Unless a person has a rather large room, the will look quite silly.
cybrsage is offline
post #85 of 3115 Old 04-16-2011, 07:51 AM
Quoted: 25 Post(s)
Liked: 61
is the design requirement to get the room to sound good or to look good?
if you have another solution, then by all means please fill us in.
absorption is surgically applied - it's not like you're coating your entire wall
post #86 of 3115 Old 04-16-2011, 09:08 AM
CruelInventions's Avatar
Quoted: 622 Post(s)
Liked: 761
Actually, it might be better to coat the entire wall, strictly from an aesthetic perspective. The appearance of random-looking giant rectangular lumps projecting far out from the walls and into the room has got to kill the chances for an Architectural Digest front cover.
Obviously, blanket coverage wouldn't work though (over-absorption, etc.).
It might help if we had some quick comparative reference numbers handy, contrasting the benefits of say, a 6" panel with 6" air gap vs. 4" panel with a 4" or a 2" air gap. Might help clarify for folks whether or not the greater loss of wall space depth would be worth the trade-off, knowing what their additional absorption gains would probably be.
CruelInventions is offline
post #87 of 3115 Old 04-16-2011, 09:27 AM
sdurani's Avatar
Quoted: 4971 Post(s)
Liked: 3431
You could coat the entire wall with cloth covered panel frames for a consistent look, but not put fiberglass in all of them to keep from over-absorbtion.
Sanjay
sdurani is offline
post #88 of 3115 Old 04-16-2011, 09:43 AM
Quoted: 622 Post(s)
Liked: 761
interesting idea - could be a viable solution for those with large enough rooms to pull it off and can afford to lose the wall depth (if they care that much about the aesthetics).
post #89 of 3115 Old 04-16-2011, 09:45 AM
Quoted: 622 Post(s)
Liked: 761
what do you mean by full frames "that wrap around the sides"?
post #90 of 3115 Old 04-16-2011, 09:46 AM
Quoted: 25 Post(s)
Liked: 61
it's quite simple - one can always measure via ETC and increase thickness or air-gap until all specular reflections above -20dB within 20ms of original source are destroyed.
macboyrules likes this.
