DIY Custom-Printed Movie Poster Acoustic Panels - cheap! - Page 34 - AVS Forum | Home Theater Discussions And Reviews
 898Likes
Old 03-17-2014, 12:42 PM
nickbuol's Avatar
Quoted: 574 Post(s)
Liked: 620
Originally Posted by ambesolman View Post
For those who've gotten the fabric samples, is the silky faille similar in the thickness and texture of the pk?
They are both what I would call a "fine thread knit" meaning that from just a short distance away, the weave just disappears (which is good). This finer weave also allows for a crisper image. Keep in mind that this is still "printing" on fabric, and not a smooth piece of glossy photo paper, but it looks really good.
They are also both pretty thin in feel, which means less bulk to have to deal with vs. other products. You won't be able to see through them once placed against solid color objects like your frame/acoustic insulation even though they are thin.
The PK stretches more than the SF.
The SF takes a little more "pull" to get wrinkles to go flat, which actually can distort the image sharply where you pull it, but the solution is easy... Just don't pull it THAT hard, and use a wrinkle release spray (per Soupy. I haven't tried that myself). The PK can distort more easily, but it takes less effort to get rid of wrinkles (again, not really an issue with wrinkle release spray).
nickbuol is offline
Old 03-17-2014, 01:24 PM
ambesolman's Avatar
Quoted: 1080 Post(s)
Liked: 909
Thanks nick!
ambesolman is online now
Old 03-17-2014, 05:32 PM
Dodobirdy's Avatar
Gravity isn't complete, i have more stretching/stapling to do tomorrow, but here it is. I still want to do a pixar theme but cant find high res images that stand out. These 2 were fun, but aren't my favorites pictures.
To reiterate, i spent more time messing with warped wood than anything else - Don't use furring strips.
PK works great, easy to stretch to get it where you want.
nickbuol likes this.
Dodobirdy is offline
Old 03-17-2014, 08:29 PM
nickbuol's Avatar
Quoted: 574 Post(s)
Liked: 620
Looks good. Glad that the images worked out for you as did the PK.
nickbuol is offline
Old 03-18-2014, 11:13 AM
purbeast's Avatar
Quoted: 14 Post(s)
Liked: 27
Looking good.
Just FYI, I still have the hi-res Finding Nemo picture I used for mine if you are interested in that for a Pixar theme one. It's my favorite out of the 6 I made.
purbeast is offline
Old 03-18-2014, 12:26 PM
Bacon13's Avatar
Quoted: 14 Post(s)
Liked: 39
Ordered my Roxul 60 from ATS acoustics and my poster fabric from Spoonflower last night. I picked up 2" insulation and I would like to do 3" panels. What are you guys using for frames? I was thinking of 1x poplar. I don't really feel like ripping all the boards down to 3" so I'll either go with 1x4 and leave it or go with 1x3.
Bacon13 is offline
Old 03-18-2014, 01:28 PM
nickbuol's Avatar
Quoted: 574 Post(s)
Liked: 620
I went with 1x4 so that I have 2" of insulation and a 1.5" air gap. The air gap really helps with the acoustical performance of the panel, so it was a win-win... Better performance AND didn't have to rip boards.
Poplar is nice since is starts and stays pretty straight.
nickbuol is offline
Old 03-18-2014, 03:33 PM
Waterbird's Avatar
Liked: 51
I went with poplar also, but 1x3. I hand picked each stick to make sure they were the straightest of the lot. Rethinking I maybe should have done 1x4, but frames are made now. If I really want 1/2" more air gap I'll hang the frames further from the wall. My Roxul arrived today and I continue to wait on Spoonflower. Finally got a solicited message from them that my order has been printed and will ship soon. I think it will be here Thursday.
Waterbird is offline
Old 03-18-2014, 05:35 PM
Dodobirdy's Avatar
Goodluck Waterbird, post pics. Did poplar work well?
Old 03-18-2014, 06:38 PM
Waterbird's Avatar
Liked: 51
Will do. Size and squareness came our very nicely with poplar. Just looking at the pine in the store made me cringe. Some of the poplar was bowed as well. I highly recommend hand picking the straightest ones you can.
Old 03-18-2014, 08:22 PM
ambesolman's Avatar
Liked: 909
Mind posting some pics of your frame?
Old 03-18-2014, 08:30 PM
Deep Sea Sound
dgage's Avatar
Quoted: 1571 Post(s)
Liked: 1368
By the way, I think the big box stores have nice cut lumber of different species in different lengths. It would cost more but I might recommend you look in that section and see if they have oak. It is stronger than poplar and more likely to stay as a straight frame. I have this bad thought of you guys using the 1x3 poplar lumber, which has a quite high moisture content and could twist and wrap once it dries out in your house, even on the wall. You really want some kiln dried wood as it will be less likely to move, or more accurately, it will already have done most of it's moving before you pick it out.
ambesolman likes this.
David Gage
Deep Sea Sound
"You don't listen to our subs, you EXPERIENCE them!"
dgage is offline
Old 03-19-2014, 09:10 AM
outlanderbz's Avatar
Quoted: 14 Post(s)
Thank you - its 24" x 36"s
W - 3375 pixels
H - 5000 pixels
DPI - 150
Do you add in a black or colored edge to the original image? If yes, would the size you mention include that edge? I am confused on how you get the images to fit the frame and if making multiple, to make sure they are all the same size. Perhaps I need to read this thread more?
So say I want to make 4 of these and have them be 24" wide. The height can be whatever a standard movie poster would make it, I am not worried about that and obviously can't have the image distort. How do I go about making a movie poster picture include the black edge to frame it out and wrap the wood?
From reading this thread it sounds like most people use 1x3 poplar to create the frame, paint the frame front black and then fill it with Roxul Rockboard 60 24x48 panels cut to fit.
outlanderbz is offline
Old 03-19-2014, 09:24 AM
Bacon13's Avatar
Quoted: 14 Post(s)
Liked: 39
I can't speak for anyone else, but I used Gimp to resize my pictures. I got the images from google and they were around 1900pix x 2900pix. Gimp has a resize feature that lets you independently set DPI and size. I set the DPI to 150, then set the size to 26.875" x 40.875". I did this for the two posters I wanted and saved them independently as .xcf files (each poster was around 250 MB.) I then imported both images onto one canvas. Once I had them aligned with 8" between them, I created a solid black second layer that was 4" larger on each side. From there I exported the image to a jpg and uploaded to Spoonflower. I think my final .jpg for two posters was 31 MB.
It figured this out by trial and error and it sounds a lot more complicated than it is. Took me about an hour to do it all.
outlanderbz likes this.
Bacon13 is offline
Old 03-19-2014, 09:32 AM
Quoted: 14 Post(s)
So you left 4" of black to wrap them around a 1x3 frame? You were able to fit 2 on one print from spoonflower? In the end this gave you an image to wrap on a frame that was made of 1x3 and about 23" by 37"? sorry for all the questions, I am very interested in doing this and am not worried about making the frames but the image part I am having a tough time wrapping my head around. thanks for your time!
Old 03-19-2014, 10:02 AM
Bacon13's Avatar
Quoted: 14 Post(s)
Liked: 39
No not 23x37. The finished product will be 27x41 or standard movie poster size. The images were resized to that size (-1/8" for fabric stretch), THEN the 4" of black was added to wrap around the 3" frame. So the whole image with two posters and 4" around each ended up being 49" x 70". The performance knit fabric has a printable width of 56" so my image fit sideways on two yards of fabric.
Most of the people here that are doing them are making them 24x36 so you can squeeze two side by side on the fabric, but that's a pretty tight fit and you can only have a 2" thick panel.
I'll add a pic when I get home tonight.
Bacon13 is offline
Old 03-19-2014, 04:26 PM
Waterbird's Avatar
Liked: 51
Here are a few pics of my frames. I used 1x3 kiln dried poplar. Made a nice little jig to screw them together to get them square. Spoonflower delivery tomorrow!
Old 03-19-2014, 06:07 PM
ambesolman's Avatar
Liked: 909
Those look good, thanks! Can't believe I didn't even think about sanding a little😒
Thinking I'm going to need a support brace in the middle of mine since it'll be 8'. Should be shipped in the next 6 days.
Waterbird likes this.
Old 03-19-2014, 06:08 PM
Dodobirdy's Avatar
I get my movie posters from http://www.movieposterdb.com/. And send the images to a member of this forum who adds a few inches of black to each pic (or whatever color necessary).
I used 1x3" furring strips, they sucked. Poplar is better but may warp over time. On a brighter note, Waterbirds frames are much nicer/straighter than mine.
For all black panels; yes, i would recommend painting the wood depending on where you got the acoustic material from.
outlanderbz and Waterbird like this.
Old 03-19-2014, 06:54 PM
nickbuol's Avatar
Quoted: 574 Post(s)
Liked: 620
...send the images to a member of this forum who adds a few inches of black to each pic (or whatever color necessary).
nickbuol is offline
Old 03-19-2014, 09:55 PM
Bacon13's Avatar
Quoted: 14 Post(s)
Liked: 39
Here is what I just sent to spoonflower. They guarantee delivery on 3/25.
Bacon13 is offline
Old 03-20-2014, 09:49 AM
Waterbird's Avatar
Liked: 51
One thing I did with my prints was to put a single 1-pixel wide line between the two prints to aid when I cut them into individual pieces. We'll see how well it works/looks with my order. Great trick I read about earlier in this thread.
Bacon13 - I will be very interested to see if you get your order by 3/25. I was told 13 days and today is day 20 - supposed to be at the house when I get home today. Maybe these guys just got some huge temporary spike in demand.
Old 03-20-2014, 10:04 AM
Bacon13's Avatar
Quoted: 14 Post(s)
Liked: 39
It better be here on the 25th. I paid extra for the guaranteed delivery date.
I thought about the 1pix line between the prints, but after an hour of getting everything lined up, I was done and didn't want to try to figure that out for the next hour. haha. Also, I'd be curious to see if a 1pix line is visible at 150 dpi between two black bars.
Bacon13 is offline
Old 03-20-2014, 10:18 AM
Quoted: 14 Post(s)
Originally Posted by nickbuol View Post
if I decide to do this, I take it you're the guy that I need to bribe with something... hah
Old 03-20-2014, 12:48 PM
nickbuol's Avatar
Quoted: 574 Post(s)
Liked: 620
No bribe needed...
outlanderbz and Dodobirdy like this.
nickbuol is offline
Old 03-20-2014, 03:19 PM
Waterbird's Avatar
Liked: 51
Finally.... more to follow.... they look fantastic. You can see 1 pixel to cut by.
Old 03-20-2014, 03:32 PM
Bacon13's Avatar
Quoted: 14 Post(s)
Liked: 39
They look good. What size are those?
Bacon13 is offline
Old 03-20-2014, 04:08 PM
Soupy1970's Avatar
Quoted: 264 Post(s)
Liked: 269
Those are huge. I'm really surprised the print turn out so great with such large prints. They look Awesome!
Denon X6200W - Klipsch KLF-10 Fronts - Klipsch KLF-C7 Center - Klipsch KLF-C7 X 2 Surrounds - Klipsch RB-61 II Back surround -OSD ACE850 ceiling x 4 Atmos - Dual HSU VTF-3 MK4 Subs - 4 Dayton Audio BST-1 Bass Shakers with SA230 Amp - BenQ W1070 projector - 106" Antra fixed Screen
Soupy1970 is offline
Old 03-20-2014, 04:36 PM
ambesolman's Avatar
Liked: 909
Those look great. That gives me hope mine will be as nice.
Old 03-20-2014, 04:59 PM
Waterbird's Avatar
Liked: 51
Thanks for the comments everyone, so far I'm pleased. Frames I made are 27" x 40.5", so I made the graphic 1/8" smaller and added black out to the width of the material... I can't find my exact calculations now, but I added enough black so I could staple on the inside of the frame on the back, so the staples wouldn'y scratch the walls. With the added border from Spoonflower I will probably have more than I need. Flash on the camera washed the blacks out a little. Can't wait to get them framed up!
