DIY Custom-Printed Movie Poster Acoustic Panels - cheap! - Page 96 - AVS Forum | Home Theater Discussions And Reviews
 897Likes
post #2851 of 2874 Old 03-09-2017, 06:12 AM
xylem's Avatar
Quoted: 225 Post(s)
Liked: 117
Originally Posted by rflores2323 View Post
Hello. I have 4 Windows in my room that I want to cover up. I was thinking of making these panels there so that it would give it a great look and be functional aswell. Do you guys recommend doing the panels so large. Each window would be 46 w x 76 x h
See pic.
Sent from my SM-G930T using Tapatalk
That would be a great idea, they would be some pretty big panel! Make sure you measure, check twice.
Also keep in mind the light will bleed from the side, since the panels are rigid, so you might want to consider something under them.
Sony VPL-HW40ES / Silver Ticket 110"
Pioneer SC-97
Klipsch RP-450C / 2x RP-280F / 2x R-5650-S II / 2x F-30 / 2x CDT5800 II
Sub: Outlaw Ultra-X12
HTPC Windows 7 and Kodi (with custom Phenomenal skin) / Home Server for Media
Custom Acoustic Panels
xylem is online now
post #2852 of 2874 Old 03-09-2017, 07:03 AM
KB77Hell's Avatar
Quoted: 47 Post(s)
See pic.
I think they would look fantastic in that space!
KB77Hell is offline
post #2853 of 2874 Old 03-09-2017, 07:16 AM
rflores2323's Avatar
I would make the frame so that it would site inside the window frame to have it flush.. I was thinking of adding some molding around the panels so they wouldnt bleed light.
rflores2323 is offline
post #2854 of 2874 Old 03-09-2017, 07:16 AM
Quoted: 67 Post(s)
Liked: 36
See pic.
I blacked out a 45x54 inch window with a panel I made.
I used this to black out the window first...
Blackout EZ Window Cover - Large (45" x 66") Black/White https://www.amazon.com/dp/B006S65GAE..._-exWybF04GS9P (Same company makes custom sizes)
Then I covered the window with the panel and not one spec of light comes through. See attached.
ID:	2015401   Click image for larger version
KB77Hell and rflores2323 like this.
weboperations is offline
post #2855 of 2874 Old 03-09-2017, 07:18 AM
Good idea. So you put the panel over the window.. I was thinking of making it inside the frame to give it a flush look. Nice design and theater!!
post #2856 of 2874 Old 03-09-2017, 07:25 AM
handcuff's Avatar
Quoted: 24 Post(s)
Liked: 34
See pic.
I don't see a reason why not. The size would require multiple OC-703 boards to cover, but the fabric would cover that without issue (most of the fabric is at least 48 wide, some as wide as 58 inches). As an additional plus(or two) if you mounted to the room wall and set it 'over' the window box (rather than setting the panels inside the frame of the window box), you would have an air-gap between the panel and the window behind it. That air-gap will increase the efficiency of the panel significantly. Finally, it would also block the light.
You could even do a compression-style panel, that had some type of foam seal around the edge (like you have with an exterior door), so you could pop the panels in/out when needed, without any negative impact.
rflores2323 likes this.
New build: Cedar Creek Home Theater (working name) Construction Thread
Old Theater from previous home: Starting 'The Underground' Theater - My construction threads - Finishing 'The Underground' Theater
handcuff is online now
post #2857 of 2874 Old 03-09-2017, 08:08 AM
I like the idea of the compression style panel and covering the whole window idea. What are you using to hang the panels?
post #2858 of 2874 Old 03-09-2017, 03:47 PM
hdtvluvr's Avatar
Quoted: 33 Post(s)
Liked: 32
Be careful of potential moisture buildup between the glass and your compressed fitting panel. I'd black out the glass as a poster did above and then put the panel in front of the window with an air gap between wall and panel frame.
hdtvluvr is offline
post #2859 of 2874 Old 03-09-2017, 10:50 PM
Quoted: 67 Post(s)
Liked: 36
Yes I overlapped the window by 2 inches on the sides, and 6 inches top to bottom. The reason I overlapped the vertical measurement more is to allow for hanging the panel with zbars over the windows.
I've attached photos of the blackout ez attached to the window, and you can see the z bars attached above the window. Then the panel just hanged over it.
I've also attached photos of how I built the panel. Since it was so big I put a cross piece down the center of the panel. I also put fiber board on the back to help strengthen the panel.
ID:	2017201   Click image for larger version
ID:	2017209   Click image for larger version
ID:	2017217   Click image for larger version
nickbuol, NuDLP and rflores2323 like this.
post #2860 of 2874 Old 03-10-2017, 08:57 AM
Brent A's Avatar
Quoted: 51 Post(s)
Liked: 55
What do you guys think of these?
https://printgaze.com/
At the prices they are currently offering them at, I'm thinking it might be worth a try. Figured I could just build my frame for the insulation to fit them.
Brent A is offline
post #2861 of 2874 Old 03-10-2017, 09:05 AM
xylem's Avatar
Quoted: 225 Post(s)
Liked: 117
Potential issue: their "canvas" may not be "acoustically transparent", meaning the sound will bounce on them like on plain wall.
The idea of the acoustic panel is to "absorb", "attenuate" sound reverberation and reflection to obtain a cleaner sound.
"The purpose of an acoustical panel is to reduce reflected sound and dampen the echo and reverberation"
nickbuol and mushroommunk like this.
Pioneer SC-97
xylem is online now
post #2862 of 2874 Old 03-10-2017, 09:14 AM
Witchboard's Avatar
Quoted: 112 Post(s)
Liked: 64
Agreed that they are likely not acoustically transparent, but I'd love to get my hands on their art library.
Witchboard is online now
post #2863 of 2874 Old 03-10-2017, 09:15 AM
Brent A's Avatar
Quoted: 51 Post(s)
Liked: 55
That was what I was wondering. Probably better off saving the $65 and putting it toward the proven material.
Still might order one of these for my son's room. He would love the Batman one.
Brent A is offline
post #2864 of 2874 Old 03-10-2017, 09:24 AM
xylem's Avatar
Quoted: 225 Post(s)
Liked: 117
Some of us have master the mystical Art of Google-Fu ;-)
I am sure if you are looking for something special, one of the member can find it!
<< Cerca trova: Seek and Ye Shall Find! >> ("Vasari: The Battle of Marciano", ref: Dan Brown, Inferno. great book, very disappointing movie)
FYI, the below is a good start as well.
http://forum.blu-ray.com/showthread.php?t=220892
Pioneer SC-97
xylem is online now
post #2865 of 2874 Old 03-10-2017, 10:13 AM
Witchboard's Avatar
Quoted: 112 Post(s)
Liked: 64
post #2866 of 2874 Old 03-10-2017, 10:36 AM
KB77Hell's Avatar
Quoted: 47 Post(s)
Absolutely. I winder if they'd be willing to print onto the proper fabric for a panel?
KB77Hell is offline
post #2867 of 2874 Unread 03-10-2017, 08:17 PM
Liked: 0
hi, i am able to get some cheaper rockwool. I was wondering if that can be used for these panels?
ramsham is offline
post #2868 of 2874 Unread 03-10-2017, 08:31 PM
xylem's Avatar
Quoted: 225 Post(s)
Liked: 117
You need to make sure they are the "rigid" type. Roxul rockboard 40, 60, 80 for example.
most of the time they will be 2x4. (24x48inch).
Pioneer SC-97
xylem is online now
post #2869 of 2874 Unread 03-11-2017, 09:18 AM
Liked: 0
These ones have one shiny side and seems pretty rigid. Would they have same sound dampening properties or acoustic foams are special?
ramsham is offline
post #2870 of 2874 Unread 03-11-2017, 12:42 PM
xylem's Avatar
Quoted: 225 Post(s)
Liked: 117
I guess they are the one with the Aluminum side.
You can peel the aluminum away.
Pioneer SC-97
xylem is online now
post #2871 of 2874 Unread 03-11-2017, 01:16 PM
nickbuol's Avatar
Quoted: 574 Post(s)
Liked: 620
A few of those sites, like that one, grab images from anywhere on the internet and then sell the products using other people's artwork. It is one thing to borrow and print, and another to sell someone else's artwork.
One other thing, as already mentioned those canvases are many time very reflective as they almost always put a hard coating over the printed image making the canvas even more acoustically reflective.
That being said, I have an enlarged version of the original Batman image in 36" x 64" at 150dpi. It is freely available online for people to use, which is why I grabbed it, but can't be sold. I threw the original through my resize software, and it definitely has some blur and detail loss even using high quality software. Nothing that won't look good from 5 feet away, but my image is easily just as good as what they would sell you.
It is just a matter of splitting it up into a few panels.
If interested in the image as is, let me know, if you want me to cut and slice it, I can do that too. You just need to decide if the DIY price is worth it for your son's room vs the already done price.
nickbuol is online now
post #2872 of 2874 Unread 03-17-2017, 02:26 PM
NuDLP's Avatar
Quoted: 68 Post(s)
Liked: 26
Anyone order the Spoonflower in a plain fabric and attempt to do their own art on it, such as Batik? My wife wants to build these but do her own art design. We ruled out acrylic due to the resulting reflection on the hard painted surface, but Batik may retain the acoustic transparency. Or maybe there is another method of coloring the fabric that could be recommended? We don't want anything tye dyed though.
Living Room - Monitor Audio Gold 100, Monitor Audio CP-IW460X center, Monitor Audio CP-CT380IDC, SVS-SB2000 X 2, Samsung UN55F9000, Oppo BDP-93, Playstation 4, NAD M15HD2, NAD M27
Dedicated Theater in Process - KEF XQ20, KEF XQ50C Center, KEF Ci200QR, NAD M15Hd2, NAD M25, Sony Playstation 3, Samsung DLP TV - (future projector), Subs TBD -
NuDLP is online now
post #2873 of 2874 Unread 03-17-2017, 06:56 PM
Silva741's Avatar
Quoted: 80 Post(s)
Liked: 63
I've been trying to find a company in Europe that prints on acoustically transparent fabric, to make several acoustic panels, and it turns out that Spoonflower has a factory in Germany. I contacted them to ask if their printing process and methods there are exactly equal to the ones used in the US, and it seems they are, so the quality shouldn't be an issue.
I was planning to choose the Performance Knit fabric, based on the opinions posted on this thread by several users, but the reply I got from Spoonflower left to me wondering if it's the best option. Here's an excerpt ''The processes are equal to our US based operation. The results you would see would be the same as if that fabric were printed in our US facility. It may be worth noting that this fabric as a synthetic is not particularly acoustically transparent, and our most transparent fabric for permitting the movement of sound would be our Kona cotton.''
Are ''we'' sure Performance Knit is indeed a good option?
Silva741 is offline
post #2874 of 2874 Unread Today, 08:47 AM
nickbuol's Avatar
Quoted: 574 Post(s)
Liked: 620
I used Spoonflower's Performance Knit for my images. I didn't use poster or movie themes, but more of an artistic set of elements that spread across multiple panels. The "inspiration" was from the metal piece of artwork that is supposed to go behind the wet bar just outside of the home theater (if I EVER can scrounge the funds to build it). The art piece is a number of metal circles that are different sizes and metals. I basically recreated it digitally in Photoshop, added some background elements to blend with my room colors, and printed them. Turned out great.
I wouldn't use any fabric that has anything but the raw fabric and ink. Some art pieces are coated with waxes, paint, or other hardened materials that make it reflect sound, and you don't want that.
NuDLP likes this.
