Second Floor Theater - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 66 Old 06-07-2012, 12:22 PM
wraunch's Avatar
Quoted: 122 Post(s)
Liked: 39
so what's the verdict on the floor soundproofing you did? Was it enough? Wish you did more, less?
wraunch is offline
post #62 of 66 Old 06-07-2012, 04:46 PM - Thread Starter
Edge540's Avatar
Hi Wraunch,
What i did, did make a difference. Foot steps are quieter downstairs while in the theater room for sure. Im afraid i wont know the full story for a while. We had a baby boy a couple months ago and i have not been working on the project for a couple weeks before that. Im figuring i wont know how well any of my isolation efforts worked until i get a door installed on the theater. Hopfully this weekend i get time to start work again. My next step will be columns. The soffit is finished with light tray 75%. The lights and rope light are installed and working, however. Once i get a start on columns i will take more photos.
Edge540 is offline
post #63 of 66 Old 06-08-2012, 07:57 AM
calimark's Avatar
Curious- did you do any re-inforcements for your floor joists for the added dead load?
calimark is offline
post #64 of 66 Old 06-08-2012, 08:12 AM - Thread Starter
Edge540's Avatar
Calimark,
I didn’t do anything additional as the second floor was built in anticipation of the upstairs. The upstairs floor joists are laminated wood “I” beam, 16” depth on 16” centers with 1-1/8” Advantech subfloor. Longest span is something like 20’. I was the contractor on my house build which was finished in 2009.
Edge540 is offline
post #65 of 66 Old 08-13-2012, 10:42 AM
wraunch's Avatar
Quoted: 122 Post(s)
Liked: 39
Any update on the sound deadening results?
wraunch is offline
post #66 of 66 Old 08-20-2012, 06:53 AM - Thread Starter
Edge540's Avatar
wraunch
unfortunately with summer and baby here still have not made much progress since my last post.
i hope to get the upstairs finished this winter. i knew it would be a long project but didnt anticipate so much time off of it.
eric
Edge540 is offline
