Black & Gold Theatre Build - Page 8 - AVS Forum | Home Theater Discussions And Reviews
post #211 of 226 Old 05-20-2013, 07:16 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
Mfusick is offline
post #212 of 226 Old 05-20-2013, 09:42 AM - Thread Starter
cybrsage's Avatar
Liked: 154
I KNEW I did not like you for some reason - just could not figure out what it was! Now I know. wink.gif
cybrsage is offline
post #213 of 226 Old 06-19-2013, 08:18 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
Lol.
Where is the HTPC and server located ?
Mfusick is offline
post #214 of 226 Old 06-19-2013, 11:54 AM - Thread Starter
cybrsage's Avatar
Liked: 154
It is outside the theater room, to the left of the entrance door. It is a mess right now since the bathroom is not yet complete, but I put up some shelving that can hold the weight of all my gear and it is sitting on the shelves. I run an IR Extender to get the IR signal out of the room to the HTPC. Keeps the light, heat, and the sound out of the room.
cybrsage is offline
post #215 of 226 Old 06-19-2013, 02:38 PM
kevinwoodward's Avatar
Quoted: 22 Post(s)
Can you send a link on the IR Extender you are using and what you think of it?
I need a replacement from my RF logitech clicker...
thanks.
kevinwoodward is offline
post #216 of 226 Old 06-20-2013, 05:55 AM - Thread Starter
cybrsage's Avatar
Liked: 154
I used this as the repeater box. It is there you connect the receiver(s) and the transmitter(s)
http://www.buffaloelectronics.com/infrared/ir100.htm
I used this IR Receiver. I installed it in the front of the stage:
http://www.buffaloelectronics.com/infrared/ir350.htm
After everything was done, I realized I did not have a direct line of sight to that IR receiver from the back row because the chairs in the front row were blocking it! I fix that, I added this to the soffit above the screen. The cover comes off easily so I removed it and painted it black.
http://www.buffaloelectronics.com/infrared/ir250.htm
I used this IR Transmitter Eyebud to transmit the signal to the Windows MCE IR Receiver plugged into the HTPC. I had tried one of the IR Eyebuds I already had, but they did not work. Luckily, I had ordered a kit and had one of these to use. No idea why my other Eyebud did not work. It was old so it might just have been broken.
http://www.buffaloelectronics.com/infrared/ire1.htm
I ran a non-terminated CAT5e cable between each of the receivers and the repeater, then plugged an IR Transmitter eyebud into the receiver and stuck it on the HTPC IR receiver. I also plugged two mono 2.5mm (I think) mini-connector cables into the repeater. One was a male - male cable and was run to the IR Input on the AVR, the other was a male - female calbe and one to the projector. At the projector side I used another Eyebud, connected into the extension cable and stuck over the IR Input of the projector. I think I bought my kit here:
http://www.smarthome.com/81704/Buffalo-Electronics-Home-Theater-IR-Kit-includes-part-numbers-IR-350-IR-100-IR-E1-DV9-500/p.aspx
The IR Repeater box does NOT come with a power supply, so buying a kit is a great idea.
cybrsage is offline
post #217 of 226 Old 08-17-2013, 10:43 PM
jbcain's Avatar
Liked: 64
nice build thread and final outcome.
jbcain is offline
post #218 of 226 Old 09-11-2013, 09:29 AM - Thread Starter
cybrsage's Avatar
Liked: 154
After a brief hiatus that involved the fact that some people actually have a life (not me, Chris my friend and builder), we are starting the basement bathroom. The only thing left in the theater room itself is the blackout window blind that I just received and have to put up and the end cap for the plasma track on the ceiling that needs to be fabricated. The end is in sight!
cybrsage is offline
post #219 of 226 Old 09-12-2013, 08:38 AM
iamjason's Avatar
Quoted: 31 Post(s)
Looks great...you should send a pic to the steelers and espn mag
iamjason is offline
post #220 of 226 Old 09-12-2013, 01:14 PM - Thread Starter
cybrsage's Avatar
Liked: 154
Most likely they would send me a bill for the royalties on the pictures I have on the walls. wink.gif
cybrsage is offline
post #221 of 226 Old 09-18-2013, 04:58 PM
kopkiwi's Avatar
Quoted: 113 Post(s)
Liked: 72
Great thread mate. Have enjoyed reading it back from start to finish. Don't realize how long it takes.
kopkiwi is offline
post #222 of 226 Old 09-23-2013, 07:05 PM - Thread Starter
cybrsage's Avatar
Liked: 154
I only worked when I both had money to buy things and time to work - so it takes a bit longer that way. Of course, it is 100% paid for so far, so that is nice.
More pics, this time of the bathroom being installed outside the theater room. Once done I will no longer have to run up a flight of steps just to pee. smile.gif It is a pressure assisted, wall mounted, low volume toilet. Yes, I will have to move that light.
cybrsage is offline
post #223 of 226 Old 09-24-2013, 08:52 AM
GWCR's Avatar
Quoted: 17 Post(s)
Liked: 39
eek.gif Good grief! Would make me a bit nervous using that thing. Looks like it could suck you in! tongue.gif
BTW, I don't think you need to worry about the Steelers hunting you down for royalties...they have more pressing issues this year...
GWCR is offline
post #224 of 226 Old 09-24-2013, 12:22 PM - Thread Starter
cybrsage's Avatar
Liked: 154
Their plan is to ensure they end the season with 6 Superbowl championships! wink.gif
cybrsage is offline
post #225 of 226 Old 09-24-2013, 12:35 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
It's not looking good so far ...
Mfusick is offline
post #226 of 226 Old 09-24-2013, 12:45 PM - Thread Starter
cybrsage's Avatar
Liked: 154
They already have 6 of them and it appears they want to keep it that way. frown.gif
cybrsage is offline
