Need Help On design my theater room - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 04-13-2011, 10:01 PM - Thread Starter
hackgiz's Avatar
need some Ideas on
Placement of screen
Projector Distances From The Screen
the Walls are 9' tall
Screen 106 or 120
Surround sound 5.1 or 7.1
Projector will be a Epson 8350
Any Input form the Experts Thanks
hackgiz is offline
post #2 of 2 Old 04-13-2011, 11:03 PM
stockmonkey2000's Avatar
Liked: 29
You can check out the throw distance for your projector at projectorcentral.com. Many good projectors work with an 18' throw distance on a 10' wide screen. You could put the projector in the garage and fire through a port hole if you wanted to avoid noise.
If you go with a 10 foot screen you will probably want to do an acoustically transparent screen with speakers behind the screen. Otherwise your speakers are going to be crammed in the corners.
stockmonkey2000 is offline
