Rich'z Nightmare Basement build - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 37 Old 03-10-2013, 07:33 PM
AaronN's Avatar
Progress looks great! If you ever have any leftovers that you don't need keep me in mind! I'm right down the road biggrin.gif
__________________________________________________ ______
http://www.avsforum.com/t/1415464/aa...sement-theater
AaronN is offline
post #32 of 37 Old 03-10-2013, 09:35 PM
domz777's Avatar
Quoted: 76 Post(s)
Liked: 76
Pfft! Those aren't windows! Those are walls of transparent aluminum!!
"I can't believe I've come millions of miles"
"Thousands!"
"...thousands of miles, and no one is prepared to greet me!"
domz777 is offline
post #33 of 37 Old 04-02-2013, 02:51 PM - Thread Starter
BIG RICH's Avatar
After pulling these wood partitions out
And installing the window units
BIG RICH is offline
post #34 of 37 Old 04-02-2013, 02:52 PM - Thread Starter
BIG RICH's Avatar
The insulation guy said "go ahead man, take as much as you need"
He never should have said that. . .
BIG RICH is offline
post #35 of 37 Old 04-02-2013, 04:30 PM
jbrehm's Avatar
Good thread - it's nice to see some builds where people had to do serious work to the infrastructure before tackling the theatre aspect! I can empathize since I ended up taking the entire pad out of my basement (90,000lbs of concrete broken via hammer and carried up the stairs eek.gif), steel-braced all the walls, and redid the entire electrical, plumbing, and HVAC. That sort of killed the theatre budget, and I've been on hold for a while.
Can you tell me exactly which Sakrete product you used? Was it self-levelling? We poured the new pad ourselves, and had a buddy power trowel it, but there's a couple of spots that I need to level out.
jbrehm is offline
post #36 of 37 Old 04-02-2013, 05:37 PM - Thread Starter
BIG RICH's Avatar
I used Sakrete's High Strength concrete mix, it wasn't self leveling.
BIG RICH is offline
post #37 of 37 Old 04-03-2013, 08:07 AM
AirBenji's Avatar
Quoted: 35 Post(s)
Liked: 83
Wow I'd say that's a pretty good deal on materials! Looking good Rich.
AirBenji is offline
