i need a GOLD PAINT..?????????? - AVS Forum | Home Theater Discussions And Reviews
Old 05-28-2011, 08:47 AM - Thread Starter
petetwinofpat's Avatar
Did any body use a gold paint,,and if so what color and brand,, i need to paint somme trim...my room right now is black w maroon right now.........
petetwinofpat is offline
Old 05-28-2011, 09:07 AM
carboranadum's Avatar
Quoted: 21 Post(s)
CurtisG did his DE designed theater in red/back and gold molding.
Turned out beautiful. I need to tell you though that it helps to paint the molding first then hang and just touch up the nail holes.
http://www.avsforum.com/avs-vb/showt...hlight=curtisg
I think he discusses the type of paint that he used and the painting technique in his thread.
carboranadum is offline
Old 05-28-2011, 09:54 AM
Brad Horstkotte's Avatar
Liked: 68
Might also want to check in sathya's build thread
Brad Horstkotte is offline
Old 05-28-2011, 11:22 AM - Thread Starter
do u have a build name for "sathys" cant find it.Thanks
Old 05-28-2011, 12:46 PM
Liked: 68
Sure, here you go:
http://www.avsforum.com/avs-vb/showthread.php?t=1245539
Old 05-28-2011, 06:19 PM
MysticalJet's Avatar
Quoted: 81 Post(s)
Liked: 151
Behr sells a gold paint. Check out my "previous theater" link. I am sure I have a picture of the Behr paint bottle.
MysticalJet is offline
Old 05-30-2011, 06:02 AM
dc_pilgrim's Avatar
I used gold paint, then added a glaze over it. Let me check my thread for a couple pix. We used Benjamin Moore.
Here is a couple quotes:
We also scouted some paint for the the crown. We tried a couple different combo's, but the one we like is a base coat of Benjamin Moore's "Stuart Gold" with their [expensive] metallic gold glaze on top. We are going to do the crown and most likely the curved soffit in the front in this color. The rest of the colors will be dazian expocloth (aka exposure) - black for the screen wall, under soffits and columns, and royal blue for the fabric frames.
On this shot you can see we ran out of the ones my wife pre-painted with the glaze, and part of it isn't glazed yet. The glaze really adds IMHO.
There is also a fancy gold paint that some people have bought (Old Masters or something?) Run some searches in the archives.
EDIT 2 - Here it is:
Originally Posted by makeit57 View Post
It's Modern Masters Olympic Gold
Well. it's been a while but we're finally getting things wrapped up. The last phases of this project have been taking the longest and they involved finishing the theater lounge and choosing the medallions for the ceiling. I'm still waiting on my anamorphic lens from DPI and now they're telling me it will be available at the end of this week, but I've been hearing that since January so I'm not holding my breath.
Here are the latest photos.
The medallions from the Medallion Factory.
Spraying on the primer.
Priming the trim rings for the 4" can lights.
Painted medallions
Finished trim rings.
Close up of ceiling medallion installed.
Entire ceiling shots.
dc_pilgrim is offline
Old 05-30-2011, 03:41 PM
FuzzyZipperbaum's Avatar
The tough part in trying to gague colors on many of our HTs is that we design the rooms to be dark. Most photography does not accuratly reflect the colors of our HTs....
The easiest thing for me is that I watch a TON of college football. So when I went with colors, in this case GOLD, I liked Florida State's. Glidden makes matches for all college and pro teams. So if you like a certain gold, say FSU, ND, etc.... just get the glidden match.
FuzzyZipperbaum is offline
Old 05-30-2011, 07:33 PM
MrBobb's Avatar
Quoted: 164 Post(s)
Liked: 63
"dc_pilgrim"
Holly crap. Not my taste but very nice indeed.
MrBobb is offline
Old 05-30-2011, 08:00 PM
cybrsage's Avatar
Liked: 154
Anyone know where to get Steelers Yellow/Gold?
cybrsage is offline
Old 05-30-2011, 09:23 PM
sathyakamaraj's Avatar
I used Valspar Metallic Gold Spray Paint. If you are going wit this route...read da below
Mistakes I did (like always trying to hurry up and then feel 4 it)
1. Not spraying evenly
2. Not giving enough time to dry and try to lift it - finger prints
3. Use painter Mask tape around da area where u r spraying on wall
Advise - Spray 2 coat minimum
Live till die
sathyakamaraj is offline
Old 05-30-2011, 09:24 PM
I like this GOLD better dan mine....... Clean finish, may be you should select this type
Live till die
Old 05-31-2011, 04:48 AM
dc_pilgrim's Avatar
Originally Posted by MrBobb View Post
"dc_pilgrim"
I assume your talking about the second theater. Not mine, but the one I think of when I think of gold paint. He is one of those guys who came in, posted a thread for a few months, doing some serious work and then disappeared. Search Makeit57 for his full thread. I am glad his pics still load.
Old 05-31-2011, 07:09 AM
I used Pitt Gold on a workout room project. Go to HD as they have all the team color codes and ask them for Pitt Gold.... if for some reason you cant get it let me know and I will go find my can and pull the codes for you.
