The Plains Theater - Page 75 - AVS | Home Theater Discussions And Reviews
 151Likes
post #2221 of 2249 Old 03-28-2015, 08:20 PM - Thread Starter
J_P_A's Avatar
Quoted: 372 Post(s)
Liked: 300
You guys got any suggestions for wall mounts for Volt 8 surrounds? I'm not sure what they way, but it's certainly more than a Bose bookshelf I've been thinking it would be nice to be able to adjust the downward angle without worrying about the top-heavy slanted enclosure falling off a shelf. That and I'm kinda tired of sanding MDF
The Plains Theater Has Begun
J_P_A is online now
post #2222 of 2249 Old 03-29-2015, 06:14 AM
TMcG's Avatar
Quoted: 656 Post(s)
Liked: 480
When I was originally thinking of going the DIY route with these speakers, I was thinking about the same thing. The best I could come up with was to use a piano hinge on the bottom, cut to the width of the speaker, to function as a hinged support bracket. Then attach some screw eyes to both the back (or side) of the speaker and the wall. Then you could use standard picture hanger wire through the screw eyes and wound back on itself to get the exact downward angle you need. Plus it is cheap and very easy to adjust.
I hope this description makes sense. I'd render it in TMcGoogle Sketchup for you, but I am not near anywhere I can do it.
TMcG is offline
post #2223 of 2249 Old 03-29-2015, 08:13 AM
HopefulFred's Avatar
Quoted: 283 Post(s)
Liked: 259
This is one of the reasons I don't want flat packs. It's a bespoke theater - give it custom speakers.
HopefulFred is offline
post #2224 of 2249 Old 03-30-2015, 09:05 AM - Thread Starter
J_P_A's Avatar
Quoted: 372 Post(s)
Liked: 300
Thanks, Tim! I'm hoping for something with as little DIY as possible. I'm planning for this to be a pseudo-temporary solution. So I don't want to invest a lot of time into it if possible.
@HopefulFred , this sort of goes along with the above, but I'm trying to ease myself into the speaker building business. Since I've never built a speaker before, the flat packs seemed like a good way to get going. I'm glad I did because I would have certainly made some rookie mistakes otherwise. I'd like to custom build a full set of speakers at some point. I might even look into my own crossover design if I can't get one of the guys that visit the DIY thread to take on the challenge. I think it would be fun, but I just don't have the knowledge or experience at this point.
The other thing about the brackets is I'm coming to realize that I don't mind the naughty bits showing in my theater. Speaker wires don't bother me as long as they are made to look like they are a professionally terminated. Seeing the speakers doesn't bother me either. Most of the theaters I've been in have the speakers right out in the open anyway. If I can figure out a way to make it look clean, I may still leave my treatments out for everyone to see. I've been going back and forth on that for a while, and I only have a few nagging issues that I would need to get worked out.
J_P_A is online now
post #2225 of 2249 Old 03-30-2015, 09:12 AM
Mfusick's Avatar
Quoted: 347 Post(s)
Liked: 1457
Treatments visable for the win...
Mfusick is online now
post #2226 of 2249 Old 03-30-2015, 09:26 AM
BllDo's Avatar
Quoted: 202 Post(s)
Liked: 146
Especially if it looks like this, which I'm sure it will...
Mfusick and dlbeck like this.
Is it solipsistic in here, or is it just me?
BllDo is offline
post #2227 of 2249 Old 03-30-2015, 09:35 AM
Mfusick's Avatar
Quoted: 347 Post(s)
Liked: 1457
That actually looks pretty ^
"Too much is almost enough. Anything in life worth doing is worth overdoing. Moderation is for cowards."
post #2228 of 2249 Old 03-30-2015, 09:54 AM - Thread Starter
J_P_A's Avatar
Quoted: 372 Post(s)
Liked: 300
Well thanks for setting the bar so high Bildo! That's not exactly what I have in mind. Nyal may veto it anyway.
J_P_A is online now
post #2229 of 2249 Old 03-30-2015, 10:02 AM
BllDo's Avatar
Quoted: 202 Post(s)
Liked: 146
Ah, sorry. Forgot you had Nyal working his magic in your space. He does seem to like the Auralex panels up a little higher than that photo shows. So forget that one. I think this one would definitly be Nyal approved.
BllDo is offline
post #2230 of 2249 Old 03-30-2015, 10:41 AM - Thread Starter
J_P_A's Avatar
Quoted: 372 Post(s)
Liked: 300
Yeah.... That's better......
Careful or I will revoke your image posting privileges in my thread
I'm struggling with the aesthetics issue. The Auralex panels are plastic, and I'm not sure if they will look like cheap plastic after they are painted. I like the look of them, but I don't want it to look cheap when it's all done. There's no way way it will look as nice as either of those two posts, but I think it would be nice to do something different than the other theaters on the boards. I'm not very good at this sort aesthetics business
J_P_A is online now
post #2231 of 2249 Old 03-30-2015, 11:00 AM
TMcG's Avatar
Quoted: 656 Post(s)
Liked: 480
I've been in 24 Changer's theater which has painted Auralex plastic diffusers. They don't look bad at all....in fact, they look bad a$$.
Creekside Stone Cinema
Mfusick likes this.
TMcG is offline
post #2232 of 2249 Old 03-30-2015, 11:24 AM
jimim's Avatar
Quoted: 116 Post(s)
Liked: 29
Those two pics look awesome with everything exposed. I so don't have the balls to do that. Lol. I really would like to but I would be shaking at the end of the day with my ocd if it didn't look perfect.
jimim is online now
post #2233 of 2249 Old 03-30-2015, 11:29 AM
Mfusick's Avatar
Quoted: 347 Post(s)
Liked: 1457
Exposed !
post #2234 of 2249 Old 03-30-2015, 02:29 PM - Thread Starter
J_P_A's Avatar
Quoted: 372 Post(s)
Liked: 300
BTW, there has been progress! But I came up about two gallons short, and I need another coat...... I did have help, though! My lovely wife likes to paint And my dog likes to eat paint Most of what you see in this picture is just primer.
J_P_A is online now
post #2235 of 2249 Old 03-30-2015, 05:14 PM
lpnaz480's Avatar
Quoted: 29 Post(s)
I'm struggling with the aesthetics issue. The Auralex panels are plastic, and I'm not sure if they will look like cheap plastic after they are painted. I like the look of them, but I don't want it to look cheap when it's all done. ...
i did 3 or 4 coats of black spray paint, then painted the ceiling black. they dont look like the wood ones, but they dont look cheap either. grant it, mine are on the ceiling, i think you'll be able to achieve a nice cohesive between wall color and quadfusors. that is if you go w/ paint and exposed
J_P_A likes this.
lpnaz480 is offline
post #2236 of 2249 Old 04-10-2015, 07:24 PM - Thread Starter
J_P_A's Avatar
Quoted: 372 Post(s)
Liked: 300
Today I passed another major milestone. I passed both my final electrical and my final building inspection. I was expecting to have to schedule another final room inspection after the electrical, but my inspector remembered my room and what I was doing. He went ahead and looked at everything while he was here. The only thing that nearly caused a hiccup was the LV transformer for my LED rope lighting. It's wired up on HV side, but I've just capped the LV side with wire nuts. Once I explained it was only 12 V out, he was fine with it.
I know a lot of builders on here have had issues with their local codes enforcement, but I've got to say that my local department has been great to work with. They've always been willing to answer my questions and listen to what I was doing and offer helpful advice.
So, to celebrate, I decided to pull an old friend out of storage
After carrying that thing down two flights of stairs, I was seriously questioning my idea of a "celebration!" Any suggestions on how many rack spaces to leave open between this one and the next one?
J_P_A is online now
post #2237 of 2249 Old 04-10-2015, 07:39 PM
auburnu008's Avatar
Quoted: 76 Post(s)
Liked: 74
Was it "Red Tag" Jim that did the inspection?
auburnu008 is online now
post #2238 of 2249 Old 04-10-2015, 07:44 PM - Thread Starter
J_P_A's Avatar
Quoted: 372 Post(s)
Liked: 300
Haha! No. Not 'ol "Red Tag"
Did you have issues with your electrical inspection? From what I understand, Michael Allen has a good relationship with the inspectors in town.
J_P_A is online now
post #2239 of 2249 Old 04-10-2015, 07:55 PM
auburnu008's Avatar
Quoted: 76 Post(s)
Liked: 74
No issues here. Luckily Jim was apparently in a good mood that day. I believe Michael has a good relationship with everyone. lol
J_P_A likes this.
post #2240 of 2249 Old 04-11-2015, 07:04 AM
doublewing11's Avatar
Quoted: 140 Post(s)
Liked: 450
Wow...........................
Your misses has no paint in her hair..................face............clothes..... .....................
Mine would be covered in paint...........................I tend to keep her away from the stuff!
BTW....................GET HER A STEP LADDER!!!!!!
doublewing11 is offline
post #2241 of 2249 Old 04-11-2015, 07:14 AM
dlbeck's Avatar
Quoted: 207 Post(s)
Liked: 255
Coming along very nicely! Glad to see you went with Nyal on the acoustic design
dlbeck is online now
post #2242 of 2249 Old 04-11-2015, 09:12 AM
BllDo's Avatar
Quoted: 202 Post(s)
Liked: 146
Very nice! Sherbourn recomends two spaces above and one below.
BllDo is offline
post #2243 of 2249 Old 04-11-2015, 11:33 AM
TMcG's Avatar
Quoted: 656 Post(s)
Liked: 480
Sherbourn recommends just one rack U above the amplifier. Underneath, the feet height of 3/4" is the recommended minimum if you're just sitting it on a rack shelf. If you've removed the feet for rack mounting, then 1U underneath is what you need. Page 4 of the manual HERE. But if you have the additional rack space, then give it a bit more room.
Congrats on passing all of your inspections! That is a huge milestone.
TMcG is offline
post #2244 of 2249 Old 04-12-2015, 07:37 AM
jimim's Avatar
Quoted: 116 Post(s)
Liked: 29
it's always nice passing inspections. inspections in our town are always interesting. my plumber had his pass stickers on my site when we built before he did the work. i remember i got my occupancy permit with all the tails still in the garage cause we "just didn't get to it yet". but then i did my back porch and he was suddenly an engineer who wanted a thicker LVL for the spans I was doing and wanted to see larger lags to hold the weight going through the brick into the house. It was all very amusing. Funny it's been 5 years and he still hasn't come back to make sure it was done properly.
good luck moving along. that amp looks like a beast.
jimi
jimim is online now
post #2245 of 2249 Old Today, 05:46 AM - Thread Starter
J_P_A's Avatar
Quoted: 372 Post(s)
Liked: 300
A question for you guys. I ordered these for mounting my surrounds
Any suggestions for how to mount them to the walls? Now that I'm eliminating the columns, at least for now, I'll need to mount my speakers to the drywall. For those of you just tuning in, it's clips+channel+DDW+GG. The chances of a channel being where I need it is slim to none.
I've thought about using a 12"x12" square of 3/4 MDF glued and screwed to the wall and then attaching the speaker mount to that. I still haven't decided what to use for fasteners, though.
J_P_A is online now
post #2246 of 2249 Old Today, 05:54 AM
Mr.Tim's Avatar
Quoted: 113 Post(s)
Liked: 99
Toggle bolts are going to have the highest ultimate pullout strength. With that much GWB a 1/4" bolt will have well over 400 lbs of capacity.
I am not sure a screw through the bracket into a piece of MDF would have that much capacity.
Tim
Mr.Tim is online now
post #2247 of 2249 Old Today, 06:36 AM - Thread Starter
J_P_A's Avatar
Quoted: 372 Post(s)
Liked: 300
Toggle bolts.... I haven't used those in quite a while. That certainly seems like the most obvious choice (now that you mention it)
I'll have to layout my speaker mounting positions and see how it will work. Thanks for the suggestion!
J_P_A is online now
post #2248 of 2249 Old Today, 06:55 AM
AVS Club Gold
Clarence's Avatar
Quoted: 42 Post(s)
Liked: 36
Togglers... snaptoggles. Easier and stronger than the classic toggle bolts.
See Hanging projector - resilient bars, no backer plate
Clarence is online now
post #2249 of 2249 Old Today, 07:47 AM - Thread Starter
J_P_A's Avatar
Quoted: 372 Post(s)
Liked: 300
Interesting. I've seen those things, but never used them. They look to be quick and easier than using a regular toggle. I'll have to take a look at their ratings.
J_P_A is online now
