The Plains Theater - Page 85 - AVS Forum | Home Theater Discussions And Reviews
 281Likes
post #2521 of 2661 Old 07-31-2015, 08:39 AM - Thread Starter
J_P_A's Avatar
Quoted: 599 Post(s)
Liked: 451
Way back when I set my server and media streamer up, ISOs were one of the few ways that could provide menus and lossless audio (IIRC). I don't remember the details anymore, but there were some issues with MKV that pushed me in the direction of ISOs. To begin with I did 1:1 transfers of the entire disc. I've moved away from that over the years, but I haven't taken the step to convert everything to MKV.
The Plains Theater Has Begun
J_P_A is online now
post #2522 of 2661 Old 07-31-2015, 08:57 AM
doublewing11's Avatar
Quoted: 229 Post(s)
Liked: 954
I've been lost the last page and one-half...............with all these tech acronymns...........starting to feel like an ole' fuddy-duddy!
J_P_A and ambesolman like this.
doublewing11 is offline
post #2523 of 2661 Old 07-31-2015, 09:36 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2693
If the shoe fits.....
@ JPA just convert them man.
Use MakeMKV and run it right off the ISO you have.
I use ISO too. That's the duplicitous part of my server. I keep some around for menus and special effects or 3D. But everything is MKV first, and honestly I use MKV like 99.9% of the time.
Just rip the ISO to MKV, you can do it the same as if you rip a disc. I use MakeMKV program.
Then you should be ok.
Mediabrowser Theater (EMBY THEATER) does ISO btw, but you need a window build I think to set it up. KODI I don't know. I've always generally disliked KODI and XBMC, it's too blocky.
EMBY server + a ROKU with EMBY app. Simple. DONE.
That is what wife uses. It basically replaced the HTPC. (no ISO support though)
If I go the route of HTPC and installing OS and stuff, it better fly faster than superman. I also never got the forced subs figured out in XBMC, but it seemed to work pretty well with MB. I think at this point if I'm honest- I have not given the new KODI a fair shot. I never give it the time and learning curve it should get, so I never like it.
doublewing11 likes this.
Mfusick is offline
post #2524 of 2661 Old 07-31-2015, 09:56 AM - Thread Starter
J_P_A's Avatar
Quoted: 599 Post(s)
Liked: 451
I feel your pain!
Oh boy, here we go! What happened to I'll ditch my Dune player once I get this setup?
I've tried at least one mkv, and I got the same error. So I think I've got an issue somewhere else. I'd like to get this working before I change anything else.
J_P_A is online now
post #2525 of 2661 Old 07-31-2015, 10:34 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2693
Start from scratch. Make a folder on your server. Call it EMBY. Put in there a couple MKV's and a couple ISO's. Set EMBY server to use that library and scan it. Give it a day or so to do it's thing, test it out. What happens?
Mfusick is offline
post #2526 of 2661 Old 07-31-2015, 10:56 AM
BllDo's Avatar
Quoted: 595 Post(s)
Liked: 394
This. If you are not using MadVR, SVP or doing other processing that would require a real computer horsepower a Roku 3 is perfect for just playing back movies. I had a small pc in my family room that has since been replaced by a Roku. It's cheap, easy to use and really never fails except for an occasional need to power cycle.
In my theater, I'm using JRiver on a dedicated PC with a video card to process MadVR, SVP and some of the other features in JRiver. It took some effort to get it set up, but has been running more or less untouched for a couple years now.
BllDo is offline
post #2527 of 2661 Old 07-31-2015, 12:27 PM
kmhvball's Avatar
Quoted: 526 Post(s)
Liked: 294
So far I am liking Plex Server/ Plex Player, but I haven’t built much of a library up yet, so don't know if the User Interface gets a lot worse with tons more data.
The primary thing I have liked is how 'easy' it has been to set up through-out my house. I have 6 tvs + 1 projector, and all but one so far (haven’t checked the blu-ray player on that one), have had the Plex App available, so, it has been super easy to get set up and using through-out my home. Also, setting up our 3 cell phones and 4 ipads was similarly easy. We just bought a 65" Vizio tv last Wednesday, and when I turned it on, I connected to wifi (I haven't terminated my LAN cable yet)... download the plex app and I could stream from it with as much ease as a Netflix account, according to my wife's assessment. All other server/client programs may be the same, but this is the only one I have tried and I like it so far.
I have a ton of old DVDs already ripped to a hard drive, which I saved to a had drive as backups of my DVDs. I started converting those to .mkv, one at a time using makemkv, and figured out that was going to take a long time. Then a friend told me of this fancy knew tool on the World Wide Web, if I remember right it is called Google :-), so, I typed in ‘batch process mkv files', and on a makemkv forum found this tool:
http://www.makemkvbatch.com
I installed this yesterday and did two 'test runs' of about 20 files at a time, and those worked super easy. If you check the box of 'name file based on folder', it will name the .mkv file for you and this has worked pretty well for me so far. You can also choose if you keep the source file, or delete it after processing. My first two individual files, I added to the interface one at a time, and then processed... and processed both. I then tried making a "Test" folder, and putting the ~ 20 DVD file folders inside that one... then selected that folder, and all the DVD files came up - so, that was much easier.
I have found Plex fairly easy so far (other than trying to figure out my remote access through two routers... can't figure out the bridge on the first router yet... although, only tried for about 20 minutes). I have had a couple of metadata type issues, 6 Bullets is pulling up 6 Bullets to Hell, but I also named my file for this with a wrong year... and it happened to be the year 6 Bullets to Hell came out, so, partly user error.
I am not particularly tech savvy, so, part of my decision was based on my perception of 'commercially packaged' being easier to use, vs the more flexible Open Source type programs.
kmhvball is online now
post #2528 of 2661 Old 07-31-2015, 02:09 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2693
I like plex. Use it too.
Mfusick is offline
post #2529 of 2661 Old 07-31-2015, 04:47 PM - Thread Starter
J_P_A's Avatar
Quoted: 599 Post(s)
Liked: 451
Thanks, guys!
I'm getting there..... slowly.
I've managed to get videos playing. I had to change my path substitutions as follows
from /mnt/user
to smb://MyServer/
I should have realized that was necessary to begin with.
Now, unfortunately, I have another problem. The video is stuttering and buffering badly! It's buffering more than it's playing at this point. Does anyone know how I can tell if emby is trying to transcode my files? I'd like for them to play directly from the ISOs rather than having my server (try to) transcode the files. It's way underpowered for that. Looking at my resource monitor it doesn't look like it's transcoding, but emby server doesn't seem to have much in the way of diagnostic tools.
J_P_A is online now
post #2530 of 2661 Old 07-31-2015, 05:08 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2693
What is the speed of your stuff? 10/100 or 10/100/1000 ?
I would not be surprised to see if you are stuck in slow poke land on your network.
Test it.
Try this:
https://www.dropbox.com/s/vru9i8m663...dTest.exe?dl=0
What you get? If it's 80/90/100MB per second you good. If it's 11.5MB per sec, you got problems.
Mfusick is offline
post #2531 of 2661 Old 08-02-2015, 07:29 PM
Quoted: 229 Post(s)
Liked: 954
Off topic of Tech acronyms!
JPA, how much bracing does your volts have? What material thickness is used? I'm trying to get design of backer box to friend who has a CNC machine. Hoping to get away with 9ply Russian Baltic Birch.
post #2532 of 2661 Old 08-03-2015, 04:53 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2693
On a box that size you'd probably have little to worry about. Bracing becomes serious concern every 10" or more span. I'd assume you'd have a new corner or boundary there on your box anyways. Just cut some basic strips out of the scraps and glue them in. You'll be fine. MDF makes better boxes becuase it's got less issues with resonance and it's consisently damped, some has to do with it being homogenous and manufactured. With ply there is less consistency and that can lead to problems acoustically if you are unlucky. But then again it might work out ok. I hate cabinet resonances becuase you can't EQ them, and your ears are extremely adept at hearing them.
I could hear a cabinet resonance over a same power or even louder room issue like a bad reflection much easier. You brain can to some extent ignore some things, but resonances it can't.
Mfusick is offline
post #2533 of 2661 Old 08-03-2015, 06:04 AM - Thread Starter
J_P_A's Avatar
Quoted: 599 Post(s)
Liked: 451
Yep, like MFusik said, no bracing. Just a box.
Mfusick and doublewing11 like this.
J_P_A is online now
post #2534 of 2661 Old 08-03-2015, 06:54 AM
Tedd's Avatar
Quoted: 1039 Post(s)
Liked: 395
You could use dowels as bracing. Or double up cabinet walls.
This (old) NHT 1250 sub project, covered all the angles.
Name:	sub internal bracing.jpg
Tedd is offline
post #2535 of 2661 Old 08-03-2015, 08:58 AM
Quoted: 229 Post(s)
Liked: 954
Thanks! are they using 1/2" as Mike has suggested?
Weight is HUGE concern since attachment will be done directly to ceiling which already has Alder framing attached along with 50+ lb projector.......but thanks, great suggestion.
post #2536 of 2661 Old 08-03-2015, 09:13 AM
Tedd's Avatar
Liked: 395
I guess you missed the 250 lb+ crt days....
Mfusick, doublewing11 and BllDo like this.
Tedd is offline
post #2537 of 2661 Old 08-03-2015, 09:19 AM
BllDo's Avatar
Quoted: 595 Post(s)
Liked: 394
I still miss my Runco. At the end I had to calibrate the stupid thing about once a month, but oh what a picture. When that thing died, I had a line a NOS G90. Almost pulled the trigger, but my better half got wind of my plans and put an end to that. Oh well.
BllDo is offline
post #2538 of 2661 Old 08-03-2015, 09:22 AM
Quoted: 229 Post(s)
Liked: 954
Thanks......
Dimension as of now is 15x15x8" or smaller........that's most likely 15-20 lbs ofs MDF!
I'm scared.....really scared! 25 lb driver and box!
Will make wearing hardhat mandatory in theater room!
post #2539 of 2661 Old 08-03-2015, 09:38 AM - Thread Starter
J_P_A's Avatar
Quoted: 599 Post(s)
Liked: 451
Nope. 3/4" MDF.
J_P_A is online now
post #2540 of 2661 Old 08-03-2015, 10:03 AM
Quoted: 229 Post(s)
Liked: 954
Nope. 3/4" MDF.
What's the dimensions and estimated weight? My size enclosure using 3/4" MDF could be 30lbs with driver!
post #2541 of 2661 Old 08-03-2015, 10:10 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2693
Thanks......
What are you attaching it to? and with?
Use some construction adhesive as extra safety. A dab of PL will hold like 1000 pounds or something. It all matters what you are screw into, or attach directly to.
They use poly construction adhesive to glue up tiles on ceilings in public areas FYI.
Mfusick is offline
post #2542 of 2661 Old 08-03-2015, 10:16 AM - Thread Starter
J_P_A's Avatar
Quoted: 599 Post(s)
Liked: 451
19.8 pounds according to my scales.
Dimensions are 11" wide x 15" tall x 9.25" (top) and 5.5" (bottom)
J_P_A is online now
post #2543 of 2661 Old 08-03-2015, 10:18 AM - Thread Starter
J_P_A's Avatar
Quoted: 599 Post(s)
Liked: 451
If you're clever, you might be able to seal the sides of the box to the ceiling and eliminate the back panel all-together to save a little weight.
J_P_A is online now
post #2544 of 2661 Old 08-03-2015, 10:40 AM
HopefulFred's Avatar
Quoted: 508 Post(s)
Liked: 443
I'm not sure about the engineering of your ceiling, but it would seem to me that if you are in a position where 150lbs of speakers would put you over the limit, then you probably are already on borrowed margin. No?
HopefulFred is online now
post #2545 of 2661 Old 08-03-2015, 06:15 PM
Quoted: 229 Post(s)
Liked: 954
Clip and channel spec is for three layers.......I have two layers plus trim work on ceiling. I'd be adding approximately 80-88 lbs total........similar to one more sheet of 5/8th's drywall. Since I'm not too experienced with clip and channel engineering.........I'm playing it safe.
There's no better way to go though.........Watching heavy bass movie while ceiling comes crashing down on your head!
post #2546 of 2661 Old 08-03-2015, 06:20 PM
Quoted: 229 Post(s)
Liked: 954
IB-3 clips directly to ceiling which is OSB.......hoping to get one or two clips into channel.
But then again, ceiling is already dampened........maybe directly to ceiling with construction glue would be better........problem is, no way to move it later.
post #2547 of 2661 Old 08-04-2015, 10:09 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2693
You'll be fine.
Back to the HTPC talk
Mfusick is offline
post #2548 of 2661 Old 08-04-2015, 10:58 AM
LeBon's Avatar
Quoted: 184 Post(s)
Liked: 87
I think your OCD is getting in the way. I agree you'll be fine. Not to worry.
LeBon is offline
post #2549 of 2661 Old 08-04-2015, 12:26 PM
Quoted: 229 Post(s)
Liked: 954
You'll be fine.
Yeah, you're both probably right......
Best to have a plan for all contingencies.......
post #2550 of 2661 Old 08-04-2015, 08:06 PM - Thread Starter
J_P_A's Avatar
Quoted: 599 Post(s)
Liked: 451
Have you looked at the span tables for your hat channel? You should be able to figure out where you're at as far as loading and deflection. You may have to weigh a few scraps of your alder to get an accurate estimate.
On the HTPC front, I finally have my new streamer working. I ended rebooting all my networking equipment. My server was stuck at 10 Mbs for some reason. I watched inception with no stuttering. Now I just need to find a skin to make it look nice
J_P_A is online now
