Soundproofing Conduit? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 06-17-2011, 07:40 AM - Thread Starter
cybrsage's Avatar
Liked: 154
I did a search, but found nothing...
I am going to be running conduit from the underside of my stage where my electronics will be located, up through the front wall (behind the screen), across the ceiling, and stopping where the projector will be located (at about 18 feet from the screen). How do I prevent this hole in my ceiling from transmitting sound to the other side of my ceiling?
I am using hat channel, whisper clips, and double drywall with green glue on the ceiling...then I am cutting a two inch hole in that ceiling and running a conduit through it! That ceiling is the floor of the living room. I will put the conduit underneath the insulation to help remove the sound..but what else can I do? I was thinking of plugging both ends of the conduit with acoustic sealant after I ran my cables. I can always cut it away if I need to run more cables or such.
What else can I do to minimize the sound transfer?
cybrsage is offline
post #2 of 15 Old 06-17-2011, 07:53 AM
Ted White's Avatar
Quoted: 12 Post(s)
Liked: 44
The 2" diameter hole isn't such a hazard. Have the insulation positioned as you described. Rigid conduit will transmit more vibration out via conduction, so consider flexible conduit when possible.
__________________
Ted
The Soundproofing Company
Ted White is offline
post #3 of 15 Old 06-17-2011, 07:56 AM - Thread Starter
cybrsage's Avatar
Liked: 154
Thanks, I am using flexible, low voltage conduit. Should I even bother sealing the ends like I described? Should I just shove a little insulation into the hole instead?
I feel a bit better now.
cybrsage is offline
post #4 of 15 Old 06-17-2011, 07:58 AM
Ted White's Avatar
Quoted: 12 Post(s)
Liked: 44
There is removeable caulk available. A bit brittle, but it works. Some insulation is also OK as you suggested.
__________________
Ted
post #5 of 15 Old 06-17-2011, 10:01 AM
Quoted: 3255 Post(s)
Liked: 2743
Kill two birds with one stone. Add a piece of 5/8 plywood in the projector mount location instead of the first layer of drywall and then add backer boxes for the outlet and conduit connections.
see this discussion:
http://www.avsforum.com/avs-vb/showt...2#post20234072
post #6 of 15 Old 06-17-2011, 10:05 AM
Ted White's Avatar
Quoted: 12 Post(s)
Liked: 44
For a 2" hole, the backer box is a bit overkill. I like overkill as much as the next guy, however, and it certainly won't hurt anything at all.
__________________
Ted
post #7 of 15 Old 06-17-2011, 11:08 AM
npc2396's Avatar
I just did this for the projector mount and it worked out great. I used the zip style metal anchors with 1/4" bolts that seemed more secure than lag bolting.
npc2396 is offline
post #8 of 15 Old 06-17-2011, 12:09 PM - Thread Starter
cybrsage's Avatar
Liked: 154
I am going to just nail up a bunch of 2x4 chunks between the ceiling joists to screw the projector onto. Is this bad?
cybrsage is offline
post #9 of 15 Old 06-17-2011, 12:11 PM
Ted White's Avatar
Quoted: 12 Post(s)
Liked: 44
It will couple the ceiling to the joists. Not advised
__________________
Ted
post #10 of 15 Old 06-17-2011, 01:16 PM - Thread Starter
cybrsage's Avatar
Liked: 154
Ah, did not think of that...makes the whisper clips worthless then. Plywood it is!
cybrsage is offline
post #11 of 15 Old 06-17-2011, 03:36 PM
michaelstrunk's Avatar
What about vibration attaching the projector as part of the decoupled ceiling? Or does that not really matter.
I love it when someone else starts the exact same thread question I was about to start.
Mike
michaelstrunk is offline
post #12 of 15 Old 06-17-2011, 04:31 PM
Liked: 2743
There are a few sources of projector vibration.
First if the projector is secured to the ceiling framing anyone walking over the area will shake projector.
If the projector is attached to the decoupled ceiling enough bass might shake the projector. But if you use two layers of 5/8 it will be pretty hard to shake.
Some projectors have been reported to experience vibration of the front lens from intense base.
You can mount the projector to the ceiling framing and still keep the drywall decoupled if you pass steel rods through the drywall in holes bigger than the rods and fill the gaps with flexible caulk. You then need to fashion some kind of plate floating below the ceiling to attach the mount.
post #13 of 15 Old 06-17-2011, 05:30 PM
uscmatt99's Avatar
I'm running into projector shaking with heavy bass scenes. My room has totally decoupling of the walls and ceiling. I can only assume that the walls/ceiling are flexing with bass pressurization since the room is fairly well sealed. Has anyone tried decoupling some blocking from the drywall and room framing, within the room, using DC-04 clips? I was thinking this could at least dampen the vibrations to the PJ somewhat.
uscmatt99 is offline
post #14 of 15 Old 06-18-2011, 08:21 AM - Thread Starter
cybrsage's Avatar
Liked: 154
That is a thought! I might try it.
cybrsage is offline
post #15 of 15 Old 06-20-2011, 02:06 PM
kromkamp's Avatar
Quoted: 88 Post(s)
Liked: 70
I ran 2 new staggered joists across the decoupled stud walls so that I could mount plywood directly to them. (I also did the same for my screen).
kromkamp is offline
