My New Home Theater 2.0, Staggered Wall HT. - Page 16 - AVS Forum | Home Theater Discussions And Reviews
 8Likes
post #451 of 537 Old 01-03-2014, 01:29 PM
ckgolf's Avatar
Quoted: 63 Post(s)
Liked: 61
I am going to use your design as inspiration for my theater. I showed my wife your theater and told her I want to do something similar. She absolutely loves it. That's half the battle won right there! smile.gif
My question to you is... do you have any regrets about not doing more soundproofing? I have an end unit town home that's being built right now, I will put the theater in the basement on the far end. My only concern is annoying the neighbors with my duel 18" subs. I feel like you in that I don't need absolute sound isolation. Was it ever a concern at all in your last theater or even this one? Should I opt to spend a little extra to at least decouple the room? (double walls and clips on ceiling)
ckgolf is online now
post #452 of 537 Old 01-03-2014, 02:08 PM
Quoted: 3255 Post(s)
Liked: 2743
Landshark1 will have his opinion but from my point of view you are buying a unit in a multi family structure, if you want to enjoy your dual 18 inch subs you need to soundproof. You should check with the builder and gain an appreciation for how the units are separated and soundproofing is achieved, maybe you will be lucky and they went above and beyond code. You might also win the lottery.
post #453 of 537 Old 01-04-2014, 09:09 AM - Thread Starter
landshark1's Avatar
Quoted: 18 Post(s)
Liked: 62
Sound proofing wasn't my first priority in both builds and my family is totally fine with it. The only time that I'll need to be conservative of the volume (e.g. -15db vs -10db MV) is when my wife is working at home and having a conference call. Even when I crank it to -10db MV, we don't hear a thing at the 2nd floor bedrooms, especially my daughter's room. A separated HVAC system for the 2nd floor really helps to limit the sound travel upstair.
I was fine in my 1st HT as well, end unit townhouse like you. May be I had a nice neighbor? But I didn't have a dual 18s to play with tho (I had a DefTech Supercube1 back then) and listen at <-20db MV. Also there's a laundry/mechanical room sandwiched between the HT space & the common wall helps too. But I could tell you I can hear everything in the 2nd floor bedrooms in my old townhouse tho.
As Big said, if you want to fully enjoy your dual 18s, you do need to really consider totally soundproofing the HT area especially in a townhouse. But I think it's not easy since most modern design townhouse has a fully open space basement area. So you'll have to either closed up the HT area and build a isolated room inside, or you'll have to soundproof "the whole" basement. I could tell you the deep bass is much much harder to contain vs high frequency.
landshark1 is offline
post #454 of 537 Old 01-05-2014, 12:29 PM
robc1976's Avatar
Quoted: 137 Post(s)
Liked: 87
Love this entire thing....really interested how you did the front faceplates on your gear...looks so smooth and perfect. Did you make a face plate then cover with fabric or something?
Klipsch RF82II Fronts & Wides
Klipsch RC64II Center
Klipsch RB61II Heights & Surrounds
2X Elemental design 15" subs W/ O-audio amps
Denon 4311ci
2X Emotiva XPA-5
Samsung D8000 64"
Denon 3313 UBD
Full GIK treatments
New theater under construction!
robc1976 is offline
post #455 of 537 Old 01-05-2014, 01:21 PM
Liked: 2743
I believe Landshark got out his checkbook and:
http://www.middleatlantic.com/rsh/rshcus2.htm
robc1976 likes this.
post #456 of 537 Old 01-05-2014, 03:17 PM
robc1976's Avatar
Quoted: 137 Post(s)
Liked: 87
you're the man!
Denon 4311ci
2X Emotiva XPA-5
Samsung D8000 64"
Denon 3313 UBD
Full GIK treatments
robc1976 is offline
post #457 of 537 Old 01-05-2014, 03:26 PM
CEO FALCON SCREENS
snickers1's Avatar
Quoted: 81 Post(s)
Liked: 126
snickers1 is offline
post #458 of 537 Old 01-05-2014, 04:50 PM
Pain Infliction's Avatar
Quoted: 978 Post(s)
Liked: 506
Originally Posted by snickers1 View Post
you may also want to check here you will safe some $$
http://www.customavrack.com/category/20-middle-atlantic-custom-rack-shelves.aspx
+1 This is where I get mine too.
The Thompson Theater
RIP William Alexander
Pain Infliction is offline
post #459 of 537 Old 01-05-2014, 06:16 PM
robc1976's Avatar
Quoted: 137 Post(s)
Liked: 87
awesome!
Denon 4311ci
2X Emotiva XPA-5
Samsung D8000 64"
Denon 3313 UBD
Full GIK treatments
robc1976 is offline
post #460 of 537 Old 01-06-2014, 08:08 AM - Thread Starter
landshark1's Avatar
Quoted: 18 Post(s)
Liked: 62
post #461 of 537 Old 01-06-2014, 05:25 PM
robc1976's Avatar
Quoted: 137 Post(s)
Liked: 87
Originally Posted by landshark1 View Post
Yes, that's where I got the rack from included the custom faceplates.
ordered faceplates today (using them a bit different).
Denon 4311ci
2X Emotiva XPA-5
Samsung D8000 64"
Denon 3313 UBD
Full GIK treatments
robc1976 is offline
post #462 of 537 Old 02-04-2014, 07:44 AM
jollyguy23's Avatar
HI Gary,
Excellent home threater!. Your thread has been a HUGE inspiration for me since I am srating my home theater as well with very very similar dimensions as your room. Also 90% same equipment as you and same screen size. So this thread is all the more useful for me.
I have read through all the posts and you had mentioned that you had to install about 6" of OC 703 to the rear wall to get the bass smoothed out. If you dont mind and when you find time can you please post some pictures of how you did this and the finished rear wall? As i mentioned your thread is my guide and since I am going for a dual PB 12 plus it would be hugh help to see what you did in terms of bass trap.
Congrats and Thanks in advance!
jollyguy23 is offline
post #463 of 537 Old 02-04-2014, 07:49 AM - Thread Starter
landshark1's Avatar
Quoted: 18 Post(s)
Liked: 62
Originally Posted by jollyguy23 View Post
HI Gary,
At the moment, I'm just stacking 2-3 2" thick of OC703 and lean them on the back wall. I'm still waiting for Big/Jeff to come over to redo the whole rear wall panels to hide those OC703 inside. To get to the smooth bass across all seats, I put the 2 SVS in the opposite corner too. And moved the 1st row 6" forward towards the screen.
post #464 of 537 Old 02-04-2014, 08:03 AM
jollyguy23's Avatar
Thanks for the reply. A follow up question. Are you going to put the OC 703 as a corner bass trap or fill in the rear wall panels with it just like you did with Linacoustic?
post #465 of 537 Old 02-04-2014, 01:49 PM - Thread Starter
landshark1's Avatar
Quoted: 18 Post(s)
Liked: 62
I'm going to fill them in the rear wall panels in place of all Auralex diffusers. Probably in alternated column of the panels.
If you are building from scratch and have the room/design to accommodate some real corner bass trap at the back of the room, do it! I couldn't due to the design & the equipment rack location.
post #466 of 537 Old 02-04-2014, 02:12 PM
jollyguy23's Avatar
Thanks for the details and the tips. I am definitely looking in to corner traps.
post #467 of 537 Old 02-11-2014, 05:09 PM
jimmyk36's Avatar
Quoted: 80 Post(s)
Liked: 35
Can you post a picture? Not sure I follow?
By stacking do you mean you are making the panels 4-6" thick and then leaning against the wall or are you stacking the floor to ceiling?
jimmyk36 is offline
post #468 of 537 Old 02-17-2014, 09:41 AM - Thread Starter
landshark1's Avatar
Quoted: 18 Post(s)
Liked: 62
Here you go. They are just leaning against the wall and wait for Big to modify the rear wall to fit them inside. Not the prettiest way, but surely the way to go (to get rid of the null at my MLP from the rear wall).
post #469 of 537 Old 02-17-2014, 07:37 PM
trmoore2's Avatar
Quoted: 107 Post(s)
Liked: 48
Gary,
I'm starting a HT in next few months and my room is the same size as yours. I have a few questions:
1. Is the 12" platform worth it? (compared to 7")
2. Are you happy with your screen size?
3. Are Cat-6 cables fine for future technology?
4. Do you know if IR repeaters are fine for gaming (if the box is in another room) or do you have your Xbox/PS in the room?
5. How many air vents and returns do you have and have your encountered any problems or overkill?
Tom
Main Speakers: Revel F208's. Center: C208
SUB#1: Rhythmik F15HP. SUB#2: Stereo Integrity HST18 w/ Crown XLS2502
Marantz SR7009, Emotiva XPA-5
Projector: Sony HW55-ES, Carada 134" screen
trmoore2 is offline
post #470 of 537 Old 02-17-2014, 10:13 PM
HDLife's Avatar
My goodness, I thought you would be done by now when I first follow your HT thread. Congrats on a great build. I just got into my new place here in NoVA and have been planning on building one in the basement. Thank you for helping us Newbies by documenting your work. Hopefully, you fanatics here can help me out on setting mine up too.
HDLife is offline
post #471 of 537 Old 02-18-2014, 06:02 AM
Liked: 2743
Guilty as charged. He wanted me over a long time ago to help out with that back wall.
post #472 of 537 Old 02-20-2014, 09:56 AM - Thread Starter
landshark1's Avatar
Quoted: 18 Post(s)
Liked: 62
Originally Posted by trmoore2 View Post
Gary,
Tom
1. The platform height was depend on the view angle and was from the online riser calculator.
2. Yes, we are very happy with the screen size to our viewing distance. Just perfect for us.
3. Yes, Cat6 should last you for a long time into the future IMO.
4. I hooked up a IR extender from the Harmony base directly to all the equipments included the Xbox360 (front IR sensor). It works fine.
5. I totally have 4 air vents, but no return vent. It does get hot when I have more than 4 people in the room with no A/C running. I'm thinking when Big come over to redo the rear wall, I might have him to retro fit an exhaust vent/fan somewhere in the room to have the air circulation.
No problem Big. I know you are pretty tide up with another project. Just let me know whenever you are available. I already have the HT version 2.1 in mind. wink.gif
post #473 of 537 Old 02-25-2014, 03:20 PM
Yukichon's Avatar
Quoted: 145 Post(s)
Liked: 59
Wow, wow and wow again......amazing build thread. Some great inspiration, detail and lessons to learn.
My family and I are moving to the States in a couple of months and we have bought a lovely new home where I will be adding a dedicated theatre during the remodel. I've already built a cinema room in 2008 and recorded it on this forums UK sister site AV Forums http://www.avforums.com/threads/yukis-new-media-room-project.822998/
Your build has given me lots of new ideas and I congratulate you on a fantastic project.
Yukichon is offline
post #474 of 537 Old 02-25-2014, 04:34 PM
ellisr63's Avatar
Quoted: 990 Post(s)
Liked: 412
I like the way you did the walls with fabric covered cubes. Are all of them with acoustic absorbers behind them or are some with difusers?
Yamaha CX-A5100, (3) JBL 2360As/EV DHA-1s, (3) 1/4 Pie bass bins, 4 JBL 8340As, 4 JBL 8320s, PS3, XBoxOne, 2 Intel NUCs, Monoprice speaker wire, and XLR cables, Redmere HDMI cables, Monster HTPS7000, 2 Furman filters, 2 DTS-10 subs, Panasonic AE8000, SeymourAV 195" diagonal scope screen, Panamorph UH-480, Darbee Darcet, Yamaha P7000s, (2) Crest Audio CM2208s, Yamaha XM-4080, (2) MiniDSP DDRC-88.
The Ellis Family Go Big or go Home HT
ellisr63 is online now
post #475 of 537 Old 03-02-2014, 08:07 AM - Thread Starter
landshark1's Avatar
Quoted: 18 Post(s)
Liked: 62
There's some diffuser behind the panel at the back wall too.
ellisr63 likes this.
post #476 of 537 Old 03-02-2014, 09:01 AM
jimmyk36's Avatar
Quoted: 80 Post(s)
Liked: 35
Any plans to cover the OC703 with Kraft Paper or Scrim?
jimmyk36 is offline
post #477 of 537 Old 03-02-2014, 09:07 AM - Thread Starter
landshark1's Avatar
Quoted: 18 Post(s)
Liked: 62
Not at the moment as I'm very happy to how the room sounds. Even the surround channels.
post #478 of 537 Old 03-03-2014, 05:20 PM
bassmaniac69's Avatar
Man, I am loving this room Gary! I've just read through the thread in one sitting... so many ideas, my head is spinning!
I love the built out wall with the screen, it's something I have been considering for my room but haven't started yet, the pics give me a bit of confidence on giving it a go!
bassmaniac69 is offline
post #479 of 537 Old 03-03-2014, 07:02 PM
IwantmyTHX's Avatar
Awesome job Landshark1 and Big!
How do you like the layout of your seating? I Plan to do the same front row and 2 love seats in the rear row.
Even thought it would be to sit in the center love seat with my wife it would probably be me and 2 kids LOL
IwantmyTHX is offline
post #480 of 537 Old 03-06-2014, 01:40 PM - Thread Starter
landshark1's Avatar
Quoted: 18 Post(s)
Liked: 62
The love seats are for me & my wife, and we love it. Sometimes we sit there along with our 2 yrs old in the middle when watching a kids movie too.
Harmony 900 Remote , Oppo Bdp 93 Blu Ray Player , Directv , Sonos , Wii U , Xbox 360 250gb Console With Kinect
