My New Home Theater 2.0, Staggered Wall HT. - Page 17 - AVS Forum | Home Theater Discussions And Reviews
 8Likes
post #481 of 538 Old 03-21-2014, 01:41 PM - Thread Starter
landshark1's Avatar
Quoted: 18 Post(s)
Liked: 62
Quick question guys!
I'm about to start building an gym room in the basement. I'm planning to run a conduit to the TV location for HDMI & power cable. I'm having a hard time to find a decent diameter conduit at the local HD. The thickest I saw there is only 3/4" ID (those blue one that most use for wiring). Where can I find something like 1.5-2" ID flexible conduit? I'll probably need about <25' long.
landshark1 is offline
post #482 of 538 Old 03-21-2014, 02:11 PM
Pain Infliction's Avatar
Quoted: 978 Post(s)
Liked: 506
Try PVC.
The Thompson Theater
RIP William Alexander
Pain Infliction is offline
post #483 of 538 Old 03-21-2014, 02:11 PM
Quoted: 3439 Post(s)
Liked: 2897
If you can handle rigid conduit with sweeping bends you can save some money and use the gray PVC electrical conduit and HD stocks that. You want the big orange stuff you will pay dearly and you will need to find someone willing to sell it by the foot instead of the roll. I used to have some leftovers but I've used that up. No need to buy a roll in the near future.
If you call an electrical supply shop ask for Carlon resi-gard. There are some on-line vendors that sell small quantities.
post #484 of 538 Old 03-21-2014, 02:21 PM - Thread Starter
landshark1's Avatar
Quoted: 18 Post(s)
Liked: 62
Thanks for the advice guys.
I'll go to HD on Sunday and check again. In the worst case, I'll just use PVC pipe since I could modify it to a pretty straight run to the mechanical room (right next to it) where the A/V equipment will be hidden from the room.
2nd question, when you run the conduit through the stud, how do you bend it 90 degree so it face the drywall when using non flexible tube? Do you attach it to a 90 degree PVC elbow or something like that?
post #485 of 538 Old 03-21-2014, 03:23 PM
Liked: 2897
Plumbing elbows are too tight of a radius, they have sweeping turns next to the gray PVC conduit, stay away from the plumbing section, these will be over in electrical supply
For the wall you can actually have the conduit enter the side of an electrical box recessed in the wall no turns required. I don't think you could make a 90 degree turn inside a 2x4 wall with 1 1/2 inch rigid conduit.
post #486 of 538 Old 03-21-2014, 03:36 PM - Thread Starter
landshark1's Avatar
Quoted: 18 Post(s)
Liked: 62
post #488 of 538 Old 03-23-2014, 07:20 PM
Liked: 2897
why are you running power cable in conduit, if you can run conduit, can't you just run Romex?
post #489 of 538 Old 03-23-2014, 08:13 PM - Thread Starter
landshark1's Avatar
Quoted: 18 Post(s)
Liked: 62
I was thinking when mounting the TV flat on the wall, the power plug will get in the way as most of those plug are plugged straight to the outlet at 90 degree. On my other TVs, I just ran them inside the wall and out to the bottom outlet. But this one (where the TV wall) will have a full wall floor to ceiling mirror, so no bottom electrical outlet available. And if I put a regular outlet right behind the TV, is the power plug (at 90 degree) will get into the way to mount it flat? So I thought run the power cable via conduit (it's there for HDMI and other cables anyway) to the bare mechanical room would be the cleanest installation. I could be very wrong tho.... confused.gif
post #490 of 538 Old 03-23-2014, 08:48 PM
Liked: 2897
post #491 of 538 Old 03-24-2014, 04:51 PM - Thread Starter
landshark1's Avatar
Quoted: 18 Post(s)
Liked: 62
post #492 of 538 Old 04-22-2014, 07:20 AM
rfolkes's Avatar
Liked: 94
OK can someone help me... I have french doors and trying to think of what to do with mine. Saw these here but having trouble finding any details on this build thread... Of course I haven't looked at every page YET! ... I have scanned around a bit and find glass doors then next page is solid doors... Is there info in here on the door.
rfolkes is offline
post #493 of 538 Old 04-22-2014, 09:23 AM
Liked: 2897
The secret sauce is that we made panels for the door, filled them with linacoustic. Then screwed them to the door from the other side, patched and painted the screw holes. I think we put something on the glass to make it uniformly black from the outside, I can't remember what.
ellisr63 likes this.
post #494 of 538 Old 04-22-2014, 04:32 PM
rfolkes's Avatar
Liked: 94
What was done to seal the gap in the middle of the doors? How effective was this? What about the bottom of the doors. Did you use the automatic door seal or is that not possible with french doors?
rfolkes is offline
post #495 of 538 Old 04-22-2014, 05:17 PM
Liked: 2897
this room is a single layer of DW (Builders special) , we didn't treat the gap or the bottoms of the door for obvious reasons.
post #496 of 538 Old 04-22-2014, 09:22 PM
rfolkes's Avatar
Liked: 94
Big
Maybe you can call be captain unobvious but I don't understand why you wouldn't do the gap in the door or the bottoms.
Thanks for all the insight. Appreciate it.
rfolkes is offline
post #497 of 538 Old 04-22-2014, 10:30 PM
ellisr63's Avatar
Quoted: 991 Post(s)
Liked: 413
Originally Posted by rfolkes View Post
Big
I believe it is because the door gap is not the weak link with single drywall walls... Or that it is not worth the expense to seal the door opening with french doors , glass, and single drywall wall.
Yamaha CX-A5100, (3) JBL 2360As/EV DHA-1s, (3) 1/4 Pie bass bins, 4 JBL 8340As, 4 JBL 8320s, PS3, XBoxOne, 2 Intel NUCs, Monoprice speaker wire, and XLR cables, Redmere HDMI cables, Monster HTPS7000, 2 Furman filters, 2 DTS-10 subs, Panasonic AE8000, SeymourAV 195" diagonal scope screen, Panamorph UH-480, Darbee Darcet, Yamaha P7000s, (2) Crest Audio CM2208s, Yamaha XM-4080, (2) MiniDSP DDRC-88.
The Ellis Family Go Big or go Home HT
ellisr63 is offline
post #498 of 538 Old 04-23-2014, 04:42 AM
Liked: 2897
Correct, there was no reason to make the door superior to the rest of the soundproofing in place.
post #499 of 538 Old 06-18-2014, 01:30 PM - Thread Starter
landshark1's Avatar
Quoted: 18 Post(s)
Liked: 62
Been busy finishing the basement home gym the last couple of months. But finally have some time to do a little update on the HT front.
I wall mounted an old 24" Dell monitor that I have laying around in the rack room. And programmed the new Harmony Ultimate remote (moved the original Harmony 900 for the gym room) so it'll just turn on the AVR, set the input to Popcorn Hour, for any update (movie library or firmware) work without turning on the projector.
S_IMG_7356 by Gary Ngo | Photography, on Flickr
S_IMG_7352 by Gary Ngo | Photography, on Flickr
S_IMG_7357 by Gary Ngo | Photography, on Flickr
post #500 of 538 Old 06-18-2014, 01:59 PM
NickTheGreat's Avatar
Quoted: 395 Post(s)
Liked: 266
I've only had my Ultimate for a few weeks, but I really like it. Especially for movie watching.
NickTheGreat is online now
post #501 of 538 Old 06-20-2014, 04:09 AM
cw5billwade's Avatar
Quoted: 328 Post(s)
Liked: 184
Does it work through Insteon or can I use it independently? RF or just IR?
cw5billwade is offline
post #502 of 538 Old 06-21-2014, 07:47 AM - Thread Starter
landshark1's Avatar
Quoted: 18 Post(s)
Liked: 62
Yes, it works the same as the older 900 with Insteon, and it support both RF & IR. Plus this supports macro while the older 900 doesn't.
post #503 of 538 Old 07-25-2014, 11:52 PM
jimmyk36's Avatar
Quoted: 80 Post(s)
Liked: 35
Originally Posted by landshark1 View Post
OK, finally had my garage done this past weekend.
So here's the pics for you guys.
Before:
After:
Looks great! What color did you paint the walls?
jimmyk36 is offline
post #504 of 538 Old 07-26-2014, 12:23 PM
Nightlord's Avatar
Quoted: 735 Post(s)
Liked: 255
Wow!
Codename - the Larch theater
Nightlord is online now
post #505 of 538 Old 07-27-2014, 07:12 AM - Thread Starter
landshark1's Avatar
Quoted: 18 Post(s)
Liked: 62
I'm sorry the garage is one of the room that I didn't keep the color swap.... I think I got the paint from Benjamin Moore tho. I'm about to paint the lower half of the wall in a darker shade of grey to give it a bit more contrast too. And about to change out the 2 little light bulbs to some proper shop lights for my car detailing work.
post #506 of 538 Old 07-27-2014, 09:31 AM
ClemsonJeeper's Avatar
Quoted: 228 Post(s)
Liked: 140
Looks awesome. I'm a big fan of the gladiator line of products. Pricey, but well worth it!
November 2015 HT of the Month: The Vortex Theater
My Home Theater Build: The Vortex Theater Build
ClemsonJeeper is offline
post #507 of 538 Old 07-31-2014, 10:43 AM
hanesian's Avatar
Quoted: 36 Post(s)
Liked: 84
Dude.
Dat garage!
Wow!
Double wow!
The Un-Theater Un-Build
hanesian is offline
post #508 of 538 Old 07-31-2014, 05:44 PM
Liked: 2897
You can't drive a dirty car into a garage like that.
post #509 of 538 Old 08-01-2014, 06:11 AM
EMAGDNIM's Avatar
Race Deck flooring? That's what I'm talking about! That garage space looks great!
EMAGDNIM is offline
post #510 of 538 Old 08-04-2014, 12:32 AM
Myriad_Rocker's Avatar
Quoted: 63 Post(s)
That HT is amazing! I'm actually in the process of trying to finalize my house plans for building and I will say, without shame, that I am stealing most of your ideas. Maybe even all of them!
For my treatment material, though, I think I'll go either OC703 or this stuff Roxul makes called Safe n Sound. The Roxul stuff is only $50 per bag.
Myriad_Rocker is offline
Harmony 900 Remote , Oppo Bdp 93 Blu Ray Player , Directv , Sonos , Wii U , Xbox 360 250gb Console With Kinect
