The "Bacon Race" Theater / Patio / Bar Project - Page 22 - AVS Forum | Home Theater Discussions And Reviews
 175Likes
post #631 of 3017 Old 10-20-2011, 12:02 PM
Dinoco's Avatar
the soffit started with a 10 inch piece of MDF hanging from 2x2s that were 16 inches from the wall so the soffit started as 10x 16 3/4.
the light tray is made of a 5 1/2 bottom and a 6 inch tall piece fastened to the edge
that was fastened with 1 1/2 overlapping the bottom of the soffit so the total width of every thing is
16 3/4 +4 +3/4 = 21 1/2
of course then their was the decorative molding which added another inch.
Thanks much.
Dinoco is offline
post #632 of 3017 Old 10-21-2011, 07:08 AM - Thread Starter
damelon's Avatar
Liked: 274
Second coat of paint is done on the Light Tray and Columns.
The oppo player showed up yesterday! Once the projector part is done I'm going to have to take the obligatory stack of electronics boxes picture!
Went and looked at more carpet yesterday. I think I will make a decision on that as soon as today, if not then by Monday. I think a dark gray color is the way I am going to go. I've checked a few examples and it goes well with the column color and will offset the black as well.
Gearing up for the big weekend. I've been plagued with migraines my whole life and both yesterday and today they have been going strong. I'm going to have to take some injections if this keeps up over the weekend. The plan for Saturday/Sunday is to finish.... well, to FINISH! Other than the carpet (Which means no chairs yet) We are hoping to get all of our panels made and mounted by the end of Sunday! (Cross your fingers people!)
damelon is online now
post #633 of 3017 Old 10-21-2011, 09:31 AM
BeerParty's Avatar
Drinks cooling in the fridge.
Popcorn strategically stashed by the microwave.
Fresh cover on the comfy chair.
Laptop charging.
Sunday evening schedule cleared.
I think I'm ready, bring it!
Chris
--Despair, Inc. "Regret"
My AviaTrix TM Build
BeerParty is offline
post #634 of 3017 Old 10-21-2011, 09:39 AM - Thread Starter
damelon's Avatar
Liked: 274
A couple of people have asked me about why I never posted photos of my original theater.... well at the time, I wasn't really a user here and had no idea what I was doing. But it was a quick budget job. So I have some old photos I found, and they are a little blurry, but here is a few pics of my old theater I made with my roomate's help back in 2007
Entrance
Front
Back
And my little bar I had outside of the movie room
post #635 of 3017 Old 10-21-2011, 09:55 AM
Quoted: 3350 Post(s)
Liked: 2825
What was the purpose of that extra level on the left of the riser?
post #636 of 3017 Old 10-21-2011, 10:00 AM
Iusteve's Avatar
I'm glad I wasn't the only one to notice that....
XBOX Live: Zz NiNj4 D4D zZ
Iusteve is offline
post #637 of 3017 Old 10-21-2011, 10:11 AM - Thread Starter
damelon's Avatar
Liked: 274
There is no extra level. It's only one level with steps. The riser is sort of shaped like a U. It goes from wall to wall on the sides, with steps on the front edge, and then back down behind the rear seats.
See? Not only are my photos blurry, they present an optical illusion!
post #638 of 3017 Old 10-21-2011, 10:23 AM
Brad Horstkotte's Avatar
Liked: 68
I think they're referring to the area just right of the rear row of seats, where the baseboard jogs up apparently to a higher elevation on the right side of the platform? Looks like its just that you step up onto the riser from the rear.
Brad Horstkotte is offline
post #639 of 3017 Old 10-21-2011, 10:27 AM - Thread Starter
damelon's Avatar
Liked: 274
So behind the rear row of seats, the floor is the same height as the floor in front of the riser. There are steps on each side of the front of the riser, half height, to step down to the front of the room. The Riser extended back to the rear wall, except behind the seats. So you step down towards the door from each side behind the rear seats. All 4 steps go all of the way to the wall, so thats why the baseboard follows them down.
Yeah, it's a little bit of a goofy design. In fact at one time I was considering making a wall even behind the seats to block any direct light from the doors being open, but I thought it would make my surround sound setup wonky so I didn't. It is also a really wide room. It was like 19' x 21.5'. So there was a lot of extra space on the sides. I could have made it narrower, but the space on the side of the room would have still been unusable, unless I made it some odd hallway. It would have been a great building space to do a "room in a room". In fact, I would have LOVED to use that same space for my current theater... but I didn't, so there. Now that I've done all of my research and have done it again, I would have never made any of the same decisions I did. Still, in all fairness, the soundproofing was excellent. It cancelled out almost all of the noise, and I really didn't know what I was doing. But it needed some work in the wall treatments for sure. I still do own the house, and am renting it out (hopefully until I pay off the mortgage!!!) so who knows, maybe I'll get a chance to re-do it someday.
post #640 of 3017 Old 10-21-2011, 02:58 PM
Unacceptable's Avatar
Most indoor doors are 30". A lot of bathroom/powder room doors are 28".
Stupid question. If you're putting in a framed 28" door like you'd buy from Lowes, how large do you leave the opening? Is there a rule of thumb for that like an inch on either side for the door frame and shims so you'd leave a 30" opening for a 28" door. Does that make sense?
Unacceptable is offline
post #641 of 3017 Old 10-21-2011, 03:14 PM
jimim's Avatar
Quoted: 484 Post(s)
Liked: 142
2inch larger rough opening.
jimim is offline
post #642 of 3017 Old 10-21-2011, 03:16 PM
Liked: 2825
A general rule of thumb is to add two inches to the width, and two to the top, Now if you are going to have a double wall and a custom jamb they may use thicker material so leave 2 1/2 inches width and top.
For a double door, you should leave 3 on the width so for a 48 inch double leave 51, unfortunately I learned this lesson the hard way.
post #643 of 3017 Old 10-22-2011, 03:24 PM - Thread Starter
damelon's Avatar
Liked: 274
Round 1... FIGHT!
After staying up until almost 2am finishing all of the trim painting last night, this is what I ended up with!
Also, for those interested, this is what the bottom of the door seal looked like...
post #644 of 3017 Old 10-22-2011, 03:27 PM - Thread Starter
damelon's Avatar
Liked: 274
So here was the first panel we created today. If you would like to see how we do the fabric process, here it is.
Step one. Align one the fabric up on one corner of the panel and staple.
Then pull the far corner (lengthwise) tight, but make sure the seam is even along the frame so that the fibers aren't wonky, and staple!
Line up the center of that side with the edge of the fabric to make sure it is straight and throw a staple there to hold it in place.
Then you can just quickly staple that entire side along the edge.
post #645 of 3017 Old 10-22-2011, 03:31 PM - Thread Starter
damelon's Avatar
Liked: 274
Then on the opposite side (lengthwise) pull the fabric tight across the face of the panel in the center, and put a few staples in to hold the fabric tight.
Although there aren't more photos of the rest. Starting at the middle next to the staples you just made, pull small sections tight across the face, while at the same time slightly pulling it away from the staples you made, to make it tight in both directions. Do this in sections of 6-8" or so, and run a line of 5-6 staples. Then continue doing this toward the corner until you reach it.
Once you reach the corner, go back to the center and work the other direction.
Once both sides (lengthwise) are stapled, go to the top, wrap the fabric around the top edge, and staple a few times in the center.
Then go the opposite side (the bottom) and pull the fabric tight across the face, and put another three staples in the bottom center. Now work from the center staples on both the top and the bottom towards the corners like your did the sides. Make sure that you don't staple too close to the corner itself, as you will need to fold over and staple the remaining fabric like wrapping paper corners.
Cut off the excess fabric (from the staples) and you have a completed panel!
post #646 of 3017 Old 10-22-2011, 03:33 PM - Thread Starter
damelon's Avatar
Liked: 274
Here is an example of building a wall!
BEFORE:
Now the top black panel is inserted...
Another Angle
4AlexF likes this.
post #647 of 3017 Old 10-22-2011, 03:34 PM - Thread Starter
damelon's Avatar
Liked: 274
Now we insert a piece of 2" red trim below the black panel
Another angle
Now the 3 red center panels are installed. Outsides first and then the middle.
4AlexF likes this.
post #648 of 3017 Old 10-22-2011, 03:35 PM - Thread Starter
damelon's Avatar
Liked: 274
Now we add another piece of 2" red trim below the red panels.
Now we add the first of two black panels below the red trim.
Another Angle
4AlexF likes this.
post #649 of 3017 Old 10-22-2011, 03:36 PM - Thread Starter
damelon's Avatar
Liked: 274
Now the second black panel is added below that.
Followed by the baseboard
4AlexF likes this.
post #650 of 3017 Old 10-22-2011, 03:37 PM - Thread Starter
damelon's Avatar
Liked: 274
Then move on a couple of hours and a few more wall sections start to fill in...
With the rope light on...
4AlexF likes this.
post #651 of 3017 Old 10-22-2011, 03:38 PM - Thread Starter
damelon's Avatar
Liked: 274
Hate to end the photo shoot this way, but here is where we began some work with the panels around the rack unit
More to come tomorrow!
4AlexF likes this.
post #652 of 3017 Old 10-22-2011, 03:57 PM
ADDUpstate's Avatar
Does that rack have a glass door with a lock?
What kind of neighborhood do you live in?
ADDUpstate is offline
post #653 of 3017 Old 10-22-2011, 04:12 PM
tbraden32's Avatar
Looking amazing.....!!!
tbraden32 is offline
post #654 of 3017 Old 10-22-2011, 04:34 PM
queendvd2's Avatar
Wow, those are some amazing pics. Those measurements had to be perfect with all the frames. Are those just friction fit or velcro?
If this doesn't get BIG another gig then I'll be a monkey's uncle. Great work by both of you guys!
queendvd2 is offline
post #655 of 3017 Old 10-22-2011, 05:01 PM
Amazing work.
I spent half of today framing my room (got about 1/3 done) and stopped only for beer and to check this thread for replies. I'm hooked and your build is a major motivator to me so please keep posting the pics even though I'm sure it's a pain in the butt and slows you down. I only take two pictures AFTER I get done each day... I work slow enough as it is. ;-)
post #656 of 3017 Old 10-22-2011, 05:18 PM
calimark's Avatar
Damn impressive guys. Been followig this thread for weeks now.
And echoing the quesion above...velcro? Finish nail? Friction fit?
calimark is offline
post #657 of 3017 Old 10-22-2011, 05:18 PM
Liked: 68
Fabric panels look great, congratulations on the result of your long night.
post #658 of 3017 Old 10-22-2011, 05:20 PM
And what, if anything, is behind the fabric on top, middle and bottom? Any acoustical treatment?
post #659 of 3017 Old 10-22-2011, 05:37 PM
Liked: 2825
Yes, acoustical treatment, is was documented earlier in the thread with pictures and description. Either one inch acoustical cotton or two inch OC703 depending on location.
We glued and shot some finishing nails up through the fabric frames and through the painted molding (need to be filled and touched up)
this is the glue:
4AlexF likes this.
post #660 of 3017 Old 10-22-2011, 05:44 PM
Liked: 2825
Damelon and the Misses entertain a lot. D thought it a good idea to have a little defense to keep inappropriate hands from messing with his settings. Particularly the kids that come over. No peanut butter allowed in his Oppo Bluray player. It also provides some sound isolation of the equipment.
Optoma Th1060p Projector , Oppo Bdp 93 Blu Ray Player , M80 V3 Floorstanding Speaker Boston Cherry , Sony Vpl Vw95es Full Hd 3d Home Cinema Projector , Seaton Sound Submersive H P
