The "Bacon Race" Theater / Patio / Bar Project - Page 96 - AVS Forum | Home Theater Discussions And Reviews
 112Likes
post #2851 of 2873 Old 01-07-2016, 03:06 PM
Quoted: 2038 Post(s)
Liked: 1782
1) soffits inside drywall bunker allows recessed lights without backer boxes, improves sound attenuation of HVAC ductwork, and you can use as a chase for wiring. Bass traps is actually the last benefit.
2) I've done MDF, Drywall and Plywood. The secret to painting MDF is proper priming. It also resonates less than plywood. Use what you like. The cheapest route is probably drywall, see rawlinsway and lemonade
BIGmouthinDC is online now
post #2852 of 2873 Old 01-08-2016, 08:01 AM - Thread Starter
damelon's Avatar
Liked: 227
Originally Posted by frankabjr View Post
Damelon & Big,
I absolutely love the Bacon Race theater, and thank you for doing so much documentation of the build. Its great for the rest of us DIYers to get our courage and confidence up.
I do have a couple of questions for you as I am in the planning stages of converting a game room in my house into a theater, and am definitely a newbie at theaters & audio planning etc.
When you built your Soffits, I noticed that you built them inside the sound envelope as opposed to framing them up as part of your walls, and then covering them with drywall/GG/drywall(placing them outside the sound envelope).
1) I'm guessing you chose to put them on the inside of the soundproofing because of the decision to make the soffits bass traps. Now that the theater is done, how do you feel about that decision? In your opinion does using the soffit space as a bass trap work as well as you intended? Would you do it that way again?
2) When you built the soffit vertical panels(from ceiling nailer hanging down), and the light trays, you chose to make them out of MDF. Any particular reason for MDF choice? In my experience MDF can be difficult to paint and achieve a silky smooth look, plus it easily crumbles from trying to counter sink screw holes etc. I planned on borrowing some of your concepts for your guys soffits and light trays, but it was my intention to do the woodwork with finished plywood. I'm curious why that decision was made for MDF. I'm guessing material cost?
3) I don't have a requirement for a soffit in my space (No Pipes or ducts etc to hide), but I like the architectural look of it. I could get away with no soffit, just a light tray on the wall if I chose too. Having said that, my current plan is to create a soffit, based on your response to item#1 above. Plus, I think I would like to run all my romex and speaker wire in the soffit, and leave the light trays for nothing but LED strip lights, and possibly black UV flourescent tubes for a future painted star ceiling. I would love to hear your thoughts in regards to this?
Frank
Thank you so much for your compliments. It was a fun project to work on and I actually miss the work. It was a great time to be able to work on this project with BIG and be talking shop every day. It also moved at such a great pace that changes were consistently visible as we worked. We are happy to help!
1) You noted some of the primary reasons we did the soffit in my theater. It was the easy way to run HVAC ductwork based on the design of my ceiling beams. On top of that, mirror BIG's response. I couldn't really tell you if the bass traps in the soffit worked as expected (Since I can't really test it independently), but I will say that I love how my theater sounds. It did require a sub upgrade though. My old subs couldn't pump out enough bass for my theater initially. Once I changed, the result is some beautiful sounding bass!
2) We could have used Drywall. The primary reason of using MDF over plywood was both cost and how smooth it is. Since it was something that would be painted directly, any budget plywood would look terrible. You would have to use higher quality plywood to make painting easier. For the light tray, the MDF was needed due to the rounding of the edges. This could have been done with solid wood too, but would have been more costly. You are correct that it isn't the easiest to paint. Most of my MDF required several coats of paint (Especially the red color) to look decent. As BIG mentioned, Drywall would have been a cheaper option for just the parts that were vertical, but then we would have had to back it in places where we mounted the "L" wood pieces to connect the light try below it. All of the framing and "connector" pieces were wood. The MDF was only some of the paintable outward facing areas of the theater. (You can see we used this everywhere in the theater... columns, trim, etc) Could have used solid wood for the rest of it too but again, cost was a factor. Painting was a pain, even with primer. In the overall scope of the project though, it wasn't that much work.
3) So even without HVAC, a smaller light tray inside of the soundproofing means that all of your wiring and lighting would not require holes to be put into the shell. I did not have recessed lighting either. I used the soffit to run all of my cabling to the front, and there is a lot of room in there for some decently large conduit should you need to add wires in the future. I think even if I didn't need the soffit for HVAC I still would have made one. It just wouldn't have needed to be so big. Take for instance even the Fortress of Solitude/Curve Frenzy build. He had a very small light tray for the rope lights, and built his lights into his soffit itself. Where I had a large soffit and a much larger light tray. I've mentioned also before those micro-lights from de-kor. They are only about 1 cubic inch big and low voltage on top of that. You could run a ton of them in a tiny space to give accent lighting. They aren't super bright, but don't require any room. You can even recess them completely into a 2x4 with only the small wire pigtail sticking out the back. I love those little lights and have used them in multiple projects now. (Just not in my theater) If I used them in my theater though, I probably would have needed some primary recessed lights in the main ceiling area. Also, LED strip lights make the job a lot easier now too than old-school rope light in the light-tray.
3b) As far as UV lights, mine do charge my whole ceiling, but they are also a good distance closer to the center of the room due to the larger soffits. If you just ran a small light tray and then ran UV lights around the edges of your theater, it is possible that UV tubes won't charge the center of your room. I have tubes running the entire way around my theater at the moment, and they charge the edges very quickly, but it takes longer to charge the middle. In the case that I had a small conduit-sized soffit and smaller light tray, they would be further away from the center and the middle of the room might not get much charge. In that case you would need an additional UV Cannon light or a temporary floor light to charge the stars. OR... just use fiber-optic lights.
Good luck to you on your project!!!
damelon is offline
post #2853 of 2873 Old 01-11-2016, 10:33 AM - Thread Starter
damelon's Avatar
Liked: 227
Update: The Concrete company has started prep-work for the pool deck. Primarily where the pavilion goes, since it requires a small retaining wall and deep footers beneath it to support the weight of the fireplace and structure. Due to the rain, I haven't had a chance to take a picture of the work so far, but I'll try in the next day or two. The time-lapse camera doesn't have an angle on the area where they are doing the work so I can't really use that. Over the weekend I spent a lot of time refining the details of the plans. At least it is sunny, but it will be getting colder, so I still don't think it is likely that the patio itself will get poured until springtime. Who knows. I'll try to post pictures soon.
damelon is offline
post #2854 of 2873 Old 01-12-2016, 03:22 PM - Thread Starter
damelon's Avatar
Liked: 227
Some photos!
What the Pool tanning deck and interior steps look like
The circular table area taking shape (Formerly where the fire-pit would go)
The Pavilion fireplace starting to be built! Along with the concrete backing wall and footers
Picture of the pool next to the palm tree where the concrete patio currently ends
damelon is offline
post #2855 of 2873 Old 01-13-2016, 07:20 PM
NightSkyMurals's Avatar
Quoted: 45 Post(s)
Liked: 39
Night Sky on theater ceiling
Can't believe I am just seeing these pictures!! At least I think I'm just seeing them. Either way... you did an awesome job of capturing a difficult picture, and one I am usually too tired to get once I'm finished. If I don't have these yet... can I get copies, and would you mind if I used them? So nice!
Hope you are still enjoying the mural.
Jeff
Here are some of todays pictures. I have only adjusted the basics like sharpness, brightness, contrast but the Nikon program shows a different image than windows photo viewer so they end up a little darker. At least in these you begin to get some of that 3D effect
NightSkyMurals is offline
post #2856 of 2873 Old 01-13-2016, 08:26 PM
mike mcdaniel's Avatar
Quoted: 16 Post(s)
Are you installing a heater in your pool? You may have stated it but I missed it. I want to add one to ours. We love our outdoor pavilion area. Looking good!
mike mcdaniel is offline
post #2857 of 2873 Old 01-13-2016, 08:50 PM - Thread Starter
damelon's Avatar
Liked: 227
Jeff
Of course you can use them! I shared the album with you (Should be in your gmail inbox)
damelon is offline
post #2858 of 2873 Old 01-13-2016, 08:57 PM - Thread Starter
damelon's Avatar
Liked: 227
We are. It is something overkill too. Like 400,000 BTU. Not that we will be heating it that much, but maybe a few degrees here and there, but can allow us to keep it open longer. Gas line still needs to be hooked up. It isn't far. Maybe 15 feet, but it is right under where all the construction traffic is. I will worry about that once the concrete is finished.
Super excited about the pavilion area myself. Problem is that I have to work during the day when they are there, and the plans we got, while great, didn't have all the measurements on them. (It was a cad file... but it was free after all) And in the end, the measurements weren't quite right. So I feel like I am constantly having to look over their shoulder to fix mistakes before they happen. The mason guys are great, it's trying to get the walls in the right places that are picky.
The circular area where the fire pit was supposed to be had to be scaled down a little due to running out of room, and to where the electrical line was trenched behind it. Because of that, the wall from there to the staircase (to be built) was closer to the pool by a couple of feet. This was a cascading effect. The staircase needed 4'6" of space between the columns for the gate to fit, and the walkway down the stairs was supposed to be about 5' wide, but they trenched the footers to be 4'6" the whole way, before the stone was put on, so I need to adjust little things here and there. Would kill for a couple of days of working from home. This is really going to be the only rough part though, as once the walls are set it is all easy. Still, I also don't like them to work so hard in the wrong place. Wasted time and effort. I don't pay for the time due to mistakes, but I'm sure they don't want to be wasting their time.
damelon is offline
post #2859 of 2873 Old 01-13-2016, 09:17 PM
Quoted: 16 Post(s)
I understand completely about wanting to be there. Lucky enough we did a lot of work ourselves. Wife worked at home when they did a lot of work. I did a lot of video conference. Here's our little heaven. We spend more time in pavilion. I have full kitchen out there along with half bath and 75" tv.
post #2860 of 2873 Old 01-14-2016, 06:28 AM - Thread Starter
damelon's Avatar
Liked: 227
I understand completely about wanting to be there. Lucky enough we did a lot of work ourselves. Wife worked at home when they did a lot of work. I did a lot of video conference. Here's our little heaven. We spend more time in pavilion. I have full kitchen out there along with half bath and 75" tv.Attachment 1183394
Wow! Now THAT is a pavilion. You an house a whole party under that! We aren't doing anything that upscale, just a fireplace with a covered roof. Only going to be 18x20 or so. I would have liked to put in a half bath somewhere outside but we decided it was too much work. It's great that you were able to do a lot of work yourselves and that your wife was home during construction.
damelon is offline
post #2861 of 2873 Old 01-16-2016, 07:52 AM - Thread Starter
damelon's Avatar
Liked: 227
Some morning pictures. Fireplace and pavilion coming along quickly! Thing just keeps getting beefier lol. The back yard is like a dump right now due to construction. Can't wait for it to be finished.
Issue of the day. So on our plan we had a circular patio area butting up to the pool on the side opposite of the pavilion. Due to buried electrical conduit location, the radius of the circle had to be shortened, which is ok by me, but it does pose an issue. The wall doesn't connect to the place where the rock wall ends on the pool! Fortunately, the coping is not grouted yet or anything. I think the plan is to have the rock extended to meet the end of the wall. The other choice I would have would be to put a little piece of wall there. your thoughts?
damelon is offline
post #2862 of 2873 Old 01-16-2016, 08:37 AM
jkasanic's Avatar
Quoted: 276 Post(s)
Liked: 103
Personally, I'd extend the rock wall to make it look as intended. Looks great BTW!
jkasanic is offline
post #2863 of 2873 Old 01-16-2016, 08:57 AM - Thread Starter
damelon's Avatar
Liked: 227
I agree. The masons are working today so I asked them if they would be able to just do it for me. (Instead of calling the waterfall guy and scheduling) Fortunately, they are the best workers on the team, and said "no problem, we can hook you up!". Really like how it is taking shape! Still hard to visualize it when it is done, even with the 3d renders I had.
jkasanic likes this.
damelon is offline
post #2864 of 2873 Old 01-16-2016, 04:30 PM - Thread Starter
damelon's Avatar
Liked: 227
Some questions:
1) I want to mount hooks to the stone on the fireplace so that I can mount things like garlands in the winter, or something like a lantern at other times. In my head, I'd picture that they would sell iron hooks that just had a long flat piece of iron that you could just mortar into the wall while building. Like a 6" deep flat piece, instead of drilling into the wall when it is done. I want one on each side of the fireplace, and then maybe a decorative iron candle holder above the fireplace. What would you recommend I do? Just do it post-completion?
2) My pavilion has square stone bases on the columns, which are about 3' high, and then they are white vinyl which tapers from the size of the base and gets smaller as it gets to the ceiling soffit. So my question is, if I wanted to mount 2 sconce lights on the tapered portion, how would I do it? Most wall lights I see are fixed in place, so they would look like they are leaning back, unless I somehow un-tapered it under the back of the sconce. Thoughts?
damelon is offline
post #2865 of 2873 Old 01-16-2016, 09:11 PM
Liked: 1782
Consider rust when you think about those hooks. As for the lights you will need to find or make a tapered mounting block. They make blocks for homes with tapered siding so maybe there is something out there. You might have to make something.
post #2866 of 2873 Old 01-16-2016, 09:17 PM
RTROSE's Avatar
Quoted: 94 Post(s)
Liked: 97
Wow! Everything is coming together and you are going to have a fantastic space to enjoy. I'd second the extending of rock wall where the gap is.
Keep the pics coming!
RTROSE
RTROSE is offline
post #2867 of 2873 Old 01-17-2016, 06:47 AM - Thread Starter
damelon's Avatar
Liked: 227
Looks like we will be going to ElDorado stone again for our stone choice. Our fireplace is being modeled after one of their photos anyway. (See below) It will be a semi-irregular ledgestone. "Sequoia Rustic Ledge". Here are some sample photos of the stone, and another pic of the fireplace we're looking at. The masons will extend the rock wall for us.
Initially we thought we would go with the rustic ledgestone only for the fireplace, and then the "Warm Springs Top Rock" for the walls/Columns. I think it would blend with the rock wall behind the pool better, but not sure if I want to do both stone types
But the plan (at the moment) would be to use the Sequoia Rustic Ledgestone for everything, and just mix in some of the large beige stones from warm springs here and there.
Below, an example of the rustic ledge with some added large round rocks in random locations.
damelon is offline
post #2868 of 2873 Old 01-17-2016, 06:52 AM - Thread Starter
damelon's Avatar
Liked: 227
Yeah, I'll have to look for those blocks. Otherwise we'll just get someone to shop something for us. The siding ones I've seen have the grooves for siding, but it is usually a large sawtooth sort of design, not a single angled plane on the back.
I don't think rust should be an issue. They just need to be painted with that black they use for fences and such. Iron will rust to be sure... but just need to make sure we don't scrape the paint off anywhere so it isn't exposed to air directly. Of course black painted aluminum or stainless steel solves that problem too.
damelon is offline
post #2869 of 2873 Old 01-24-2016, 09:58 AM - Thread Starter
damelon's Avatar
Liked: 227
There was a slight delay in the pool project......
damelon is offline
post #2870 of 2873 Old 01-24-2016, 01:54 PM
RTROSE's Avatar
Quoted: 94 Post(s)
Liked: 97
Looks like it's time to turn that pool heater on!
RTROSE
FWIW I like the last pic where you show an example of the bigger stone mixed in. Has a very nice look to it.
RTROSE is offline
post #2871 of 2873 Old 01-25-2016, 06:44 AM - Thread Starter
damelon's Avatar
Liked: 227
RTROSE
Hah! I know right! (Except it isn't hooked up yet) A flamethrower would work!
I like the big stone mix in too, but that will be rare I think, because it would depend on finding large pieces that color match in another box. Hopefully we'll be able to do it here and there though, it breaks up the monotony a little.
damelon is offline
post #2872 of 2873 Old 01-25-2016, 08:50 AM
Mfusick's Avatar
Quoted: 554 Post(s)
Liked: 2255
Are you doing the Stone work yourself? Or a contractor?
"Too much is almost enough. Anything in life worth doing is worth overdoing. Moderation is for cowards."
Mfusick is offline
post #2873 of 2873 Old 01-25-2016, 11:06 AM - Thread Starter
damelon's Avatar
Liked: 227
The masonry company doing the patio is doing everything. I just tell them when they are doing it wrong and to start over. Currently, I have to do that with part of the fireplace. The center area where the fire would go is a little too narrow. Would like it wider, but haven't been able to tell them yet due to snow.
damelon is offline
Optoma Th1060p Projector , Oppo Bdp 93 Blu Ray Player , M80 V3 Floorstanding Speaker Boston Cherry , Sony Vpl Vw95es Full Hd 3d Home Cinema Projector , Seaton Sound Submersive H P
