Theater Build: Mike's Money Pit - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 14Likes
post #181 of 266 Old 08-06-2013, 10:50 AM
dvmiller's Avatar
That is a very cool looking wood stage Mike! The craftsmanship of your build and detail are wonderful. Great job!
dvmiller is offline
post #182 of 266 Old 08-06-2013, 01:22 PM - Thread Starter
JustMike's Avatar
Quoted: 61 Post(s)
Liked: 66
Thanks! Yes, I've been very lucky to work with some wonderful craftsmen. smile.gif
Mike Kobb
(Formerly "ReplayMike". These opinions are mine alone, and in no way reflect the opinions of employers past or present!)
"Mike's Money Pit" Build Thread
JustMike is offline
post #183 of 266 Old 08-08-2013, 09:16 AM
trek737's Avatar
Mike,
Your theater is coming down the final stretch on being completed and it is looking great. Looks like we have a few things in common with a love for Aerial speakers and the same Sony projector. Those Aerial 9's look very nice on the wood stage.
trek737 is offline
post #184 of 266 Old 08-08-2013, 09:52 AM - Thread Starter
JustMike's Avatar
Quoted: 61 Post(s)
Liked: 66
Thank you! I'm tickled pink with how the speakers ended up looking on the stage. We didn't set out to try to really match colors or anything, but it turns out that Sapele woodwork, when finished with Osmo (which is an oil/wax finish -- no stain!) is very compatible with the Aerial rosewood veneer. And the Tanoak flooring has enough reds in it that it works well too.
The Sony sat in a box for basically a year, because the theater is so far behind schedule and I bought it according to when the theater was supposed to be finished. It's very very quiet, but I do hear a couple of subtle things from it that I wonder about -- whether they're normal or if the projector needs service. There's a very very quiet constant tone from the fan on low lamp. And in 3D, when the fan goes to high, there's a quiet sound that I swear sounds like a film projector gate/shutter operating. I'm not sure if it's in the fan or if it's something to do with the 1080p/24 3D projection.
Mike Kobb
JustMike is offline
post #185 of 266 Old 08-08-2013, 10:08 AM
sonofthesun's Avatar
This is beautiful. It's very classy and tastefully done. I'm especially impressed that you took your vision and put it to work with both the pit and all of the moving components. This thing turned out gorgeous with no expense spared. Impressive Rack. Very nice build!!
Pro-Am
Theater
Pioneer Elite VSX-94TXH
Definitive Technology BP-2002TLs
Definitive Technology BP2X Speakers
Definitive Technology C/L/R 2500
Mirage BPS-400
Sharp AQUOS 70" 1080p LED HDTV
Living Room
Aperion Intimus 5 series
Denon AVR-1913
sonofthesun is offline
post #186 of 266 Old 08-08-2013, 11:07 AM - Thread Starter
JustMike's Avatar
Quoted: 61 Post(s)
Liked: 66
Thank you very much! :-)
Mike Kobb
JustMike is offline
post #187 of 266 Old 08-15-2013, 12:49 AM - Thread Starter
JustMike's Avatar
Quoted: 61 Post(s)
Liked: 66
Can you hear me now? How about now? Good.
Last Friday, one of the engineers from KYDG came by the house to do the preliminary checkout of the room, so that we could find any issues that might need to be addressed before the fabric is installed on the walls.
We got started at about 10am, and finished about 5, with a break for lunch, so it was quite a long day. His car was positively bursting with gear, some of which you can see in these photos.
First up was a check of the room's reverberation characteristics, and the sound isolation performance of the walls and ceiling. This was accomplished with a Brüel & Kjær dodecahedral speaker and measurement equipment.
He also performed a tap test (using a positively crazy mechanized tapping machine) to check out the characteristics of sound transfer from the floor above to the room.
Then, we measured ambient sound levels in the room using an ultra-sensitive low noise floor microphone. These measurements were done with everything off, then with various combinations of equipment operating, including the HVAC, the audio amplifiers, and the projector in both low and high lamp. I was very pleased to see that all the noise mitigation work that we've done on the room has paid off. The only area that I really think could be improved is isolation from outside (environmental) sounds. Perhaps some day, but honestly my neighborhood is pretty quiet, especially in the evening, so it may not be an issue.
We broke for lunch, and afterwards he set up microphones in each of the seating locations, and then played tone sweeps through all fourteen speakers (seven speakers, seven subwoofers) to measure the frequency responses.
When all was said and done, all the speakers are functioning properly, and it seems that the room's frequency response characteristics are as expected. We didn't find any issues that will prevent fabric installation. We did find that the two big Seaton subs up front needed to be moved a bit farther forward because they were too close to the back of the cabinet, and this was constricting the air movement from the rear woofer. And, we found that the Seatons pressurize the room effectively enough to make the picture window in the rear of the room flex visibly, which in turn causes it to make some noise as it moves in its mount. We're working on figuring out how to address this, but the good news is that it's a Marvin window, and they are designed so that the glass can be replaced from outside if need be.
Just as we completed testing of the last pair of Velodyne subs, the power went out. This was actually a great test, because I was able to confirm that the big UPSes in the rack continue to power all of the media equipment except for the amplifiers, and that they also kept the projector running so that I could shut it down cleanly. We had the Lutron blackout shades down, though, so once the projector was off, the room became utterly dark. We ended up packing up his gear by flashlight. I think I will see if we can power the blackout shades from the UPS as well. I probably should also look into some kind of emergency lighting that comes on when power fails.
superleo likes this.
Mike Kobb
JustMike is offline
post #188 of 266 Old 08-15-2013, 12:57 AM
jetforme's Avatar
Video of Mike doing his audio tests.
JustMike likes this.
jetforme is offline
post #189 of 266 Old 08-15-2013, 08:12 AM - Thread Starter
JustMike's Avatar
Quoted: 61 Post(s)
Liked: 66
Mike Kobb
JustMike is offline
post #190 of 266 Old 08-15-2013, 10:19 AM
jfn111's Avatar
That was great.
jfn111 is offline
post #191 of 266 Old 08-15-2013, 10:27 AM
superleo's Avatar
Quoted: 83 Post(s)
Liked: 312
Funny, that is exactly how I find the perfect listening position... smile.gif
RPCRT-TV Overscan Reduction
Reference Blu-Ray Demo Disc
superleo is offline
post #192 of 266 Old 08-15-2013, 11:53 AM - Thread Starter
JustMike's Avatar
Quoted: 61 Post(s)
Liked: 66
I have that scene bookmarked on the Kaleidescape system. I plan to use it before movies, along with the Simpsons THX "Turn it Up!" clip. smile.gif
Mike Kobb
JustMike is offline
post #193 of 266 Old 08-16-2013, 12:19 AM - Thread Starter
JustMike's Avatar
Quoted: 61 Post(s)
Liked: 66
Tonight, for the first time, I hooked up the three Seaton SubMersive HPs, put the Classé in triple mono sub mode (how cool that it has that!), did a very rough level set, and played a few clips from various movies like The Incredibles, War of the Worlds, Prometheus and Lord of the Rings.
eek.gifeek.gifeek.gifeek.gifeek.gifeek.gifeek.gifeek.gifeek.gifeek.gifeek.gifeek.gifeek.gifeek.gifeek.gifeek.gifeek.gifeek.gifeek.gifeek.gifeek.gifeek.gifeek.gifeek.gifeek.gifeek.gif
Holy smokes.
I did find a new rattle or two. Still nothing that will affect fabric, but I definitely plan to do tone sweeps this weekend to make sure that I identify and squash them. On the plus side, I only heard the rattles during the pink noise level setting. I didn't hear anything during the clips I played. But of course they may be frequency specific and just not excited by what I played.
Mike Kobb
JustMike is offline
post #194 of 266 Old 09-12-2013, 11:52 AM - Thread Starter
JustMike's Avatar
Quoted: 61 Post(s)
Liked: 66
It's a tiny little update, but a momentous one. The fabric installation is underway! :-)
Mike Kobb
JustMike is offline
post #195 of 266 Old 09-12-2013, 12:06 PM
Nightlord's Avatar
Quoted: 760 Post(s)
Liked: 264
Oh, what a lovely colour combo! Speaks of Rotel Michi to me. Wonderful!!!
Codename - the Larch theater
Nightlord is offline
post #196 of 266 Old 09-12-2013, 05:16 PM
petew's Avatar
Quoted: 27 Post(s)
Liked: 68
That-Just-Looks-Great!
I love the reveal around the perimeter of the fabric, which ties into the reveal between the panels.
Simply excellent.
Building Bass - Subs
Surrounds - Easy as Pi
Storage - unRAID unDELL
Mains - Another piece of Pi
petew is offline
post #197 of 266 Old 09-12-2013, 05:35 PM - Thread Starter
JustMike's Avatar
Quoted: 61 Post(s)
Liked: 66
Simply excellent.
Thanks! That really turned out even better than I hoped.
Mike Kobb
JustMike is offline
post #198 of 266 Old 09-12-2013, 07:23 PM
Elill's Avatar
Quoted: 109 Post(s)
Liked: 91
Looks great!
What is the fabric make/type? sorry if you've covered that elsewhere, I couldn't seem to find it.
Peter the Greek
Downunder Theatre MkII
List of Pro Designers
Elill is offline
post #199 of 266 Old 09-12-2013, 08:33 PM
Peter M's Avatar
Quoted: 182 Post(s)
Liked: 209
Beautiful !!!
Cheers,
Peter M is offline
post #200 of 266 Old 09-13-2013, 06:04 AM
iamjason's Avatar
Quoted: 31 Post(s)
Great build the bookshelves gave me an idea for my buid....nothing like yours but bug inspiration for functionality
iamjason is offline
post #201 of 266 Old 09-13-2013, 11:32 AM - Thread Starter
JustMike's Avatar
Quoted: 61 Post(s)
Liked: 66
Thanks! I haven't seen the Michi in person, but I think the fabric is a bit more warm/gold than the Michi is. It's very hard to get a good photo with a simple camera. I will have to bring in a "real" camera and a grey card to white balance properly.
Mike Kobb
JustMike is offline
post #202 of 266 Old 09-13-2013, 12:03 PM
Nightlord's Avatar
Quoted: 760 Post(s)
Liked: 264
Oh, don't bother on my behalf, It's still lovely even if the colour temperature is shifted a fraction. smile.gif might be prettier than the Michi even.
post #203 of 266 Old 09-13-2013, 12:05 PM - Thread Starter
JustMike's Avatar
Quoted: 61 Post(s)
Liked: 66
I do want to get some nice photos once everything is really done -- light fixtures up etc, so I will post those once they're done. I will probably get a pro to come shoot it.
Mike Kobb
JustMike is offline
post #204 of 266 Old 09-17-2013, 09:01 AM - Thread Starter
JustMike's Avatar
Quoted: 61 Post(s)
Liked: 66
Howdy all,
I'll do better pictures shortly with better lighting and a better camera etc. Waiting for a few odds and ends are completed. But, this frame from my time lapse camera turned out so nicely that I thought I should just go ahead and share it. This shows the theater in "library/music" mode -- screen retracted. Suitable for 2-channel listening and giving access to the books. smile.gif
Mike Kobb
JustMike is offline
post #205 of 266 Old 09-17-2013, 09:30 AM
dRwOOD73's Avatar
Quoted: 20 Post(s)
Wow eek.gif, very nice - that wood plank stage is beautiful..
dRwOOD73 is offline
post #206 of 266 Old 09-17-2013, 12:38 PM
Nightlord's Avatar
Quoted: 760 Post(s)
Liked: 264
That's lovely in so many ways...
post #207 of 266 Old 09-17-2013, 02:29 PM
HFGuy's Avatar
Quoted: 202 Post(s)
Liked: 179
Does it feel any different to watch in the pit vs the back row ?
HFGuy is offline
post #208 of 266 Old 09-17-2013, 02:29 PM
Elill's Avatar
Quoted: 109 Post(s)
Liked: 91
Peter the Greek
Elill is offline
post #209 of 266 Old 09-17-2013, 04:32 PM - Thread Starter
JustMike's Avatar
Quoted: 61 Post(s)
Liked: 66
Well, the image is obviously bigger if you sit in the front row, but I find the back row image size still very satisfying and comfortable to watch. One thing that is not set up yet is the Lumagen scaler, which will be used to take a 2.35:1 image and shift it to the bottom of the screen, so that the front row viewers don't have to look up at it. I think this will be nicer, although I've watched a couple of movies in the current configuration, and it's not bad at all as is. But my masking is designed for the image to be pinned to the bottom, so I need to get this done.
The other news, and I'll write more about this soon, is that Keith Yates and his team have performed the audio calibration of the room!! biggrin.gif:D Holy crap! It's pretty amazing. I've never heard a system with a subwoofer (much less seven!) that is so well integrated. Based on all of my prior experience, I was worried that the music experience would suffer, with bass that didn't feel like it was really coming from the main speakers. But that is not the case at all. And the level of detail evident in the music is remarkable.
I have to say, the Trinnov processor is pretty jaw dropping. Between the science of that processor and the art of the "sweetening" that Keith does as part of the calibration, the results are dramatic. I'm looking forward to doing more detailed listening. Unfortunately, I've had evening engagements both days since the calibration was completed, so I've not been able to sit and enjoy!
For those of you who don't know the Trinnov, one of the things that it does is to take measurements from each seating location, and then you assign a weight/priority to each of those locations, and supply it with a desired output response curve. It will calculate the necessary processing to try to deliver that curve at every seat, but giving priority to the higher-weighted locations.
I am very interested to try a configuration in which my seat is the only one factored in. In other words, this would be purely for solo listening. I would like to know whether such a configuration is noticeably different than my current 7-seat configuration, so I know how much (if any) compromise there is.
Mike Kobb
JustMike is offline
post #210 of 266 Old 09-17-2013, 04:34 PM - Thread Starter
JustMike's Avatar
Quoted: 61 Post(s)
Liked: 66
Originally Posted by Elill View Post
Thanks, me too! I have a few odds and ends to do, like getting the wall sconces up, the side masking system installed and tested, and then the masking/screen compartment covers installed and painted. Once that's done, I have a line on a top-notch professional photographer and I'm excited to get some really good shots done. In particular, I plan to ask him to shoot from the same locations as KYDG's renderings, so we can compare the final product to the concepts. I can tell you right now, it's pretty damned close! smile.gif
Mike Kobb
JustMike is offline
