TV Stand That Accommodates Center Speaker - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 08-28-2011, 09:10 PM - Thread Starter
lilfleck's Avatar
Hey Guys,
I am looking for a speaker stand that will accommodate a large center speaker and won't block my view of the tv. I have a LG 50" and a KEF C6 (soon) center channel. I am looking for something that will work with this setup.
Any help would be great!
lilfleck is offline
post #2 of 10 Old 08-28-2011, 09:40 PM
tezster's Avatar
Quoted: 410 Post(s)
Liked: 282
Did you have a specific type of stand you're looking for? There should be a number of different stands that will accommodate your needs. In my case, the center channel sits on the top shelf of a 3-shelf hybrid TV stand/mount directly below the TV.
Depending on your needs, something like this may or may not work for you.
With my 55" LCD installed at the maximum height, the top shelf has 9" of clearance. With a 50" TV, there would be more than enough room for a KEF C6.
biznus97 likes this.
tezster is online now
post #3 of 10 Old 08-29-2011, 07:43 AM
Kal Rubinson's Avatar
Quoted: 673 Post(s)
Liked: 460
Is that stable? Does not look it.
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #4 of 10 Old 08-29-2011, 08:12 AM
tezster's Avatar
Quoted: 410 Post(s)
Liked: 282
I admit the setup looks top-heavy, but it's stable (or at least, stable enough for me).
post #5 of 10 Old 09-05-2011, 08:31 AM
biske's Avatar
Ikea Besta with a B&W HTM 61 inside (H 7.8 in x W 21.5 in X D 13.4 in)
Looks and works great IMO.
biske is offline
post #6 of 10 Old 11-19-2011, 01:04 PM
goodwad's Avatar
Had this same problem (needed a large center channel shelf) and I wanted a stand that was "bomb proof", so I had no other choice than to build one. There's a nice "Build your own TV stand" thread on AVS and my project is below:
http://www.avsforum.com/avs-vb/showt...4#post21232794
goodwad is offline
post #7 of 10 Old 09-24-2014, 06:05 AM
whokilledkaji's Avatar
Sorry for reviving a dormant thread, but I have a question...
Does anybody know how big the actual shelves are in an IKEA besta TV unit?
I am getting an Infinity PC351 center channel and I need to know if it'll fit on a Besta shelf. I can't find the actual shelf dimensions anywhere!
(There are no IKEA locations near me, so I can't easily check myself.)
Any other suggestions for a low and long console that can fit the PC351?
whokilledkaji is offline
post #8 of 10 Old 11-08-2014, 10:56 PM
bruzer79's Avatar
Quoted: 22 Post(s)
Ever get an answer to this? I have been digging around the internet and striking out?
bruzer79 is offline
post #9 of 10 Old 11-10-2014, 09:37 AM
I finally came back to the States and went to Ikea two days ago. The PC351 does not fit in any of the Besta units at all.
post #10 of 10 Old 11-11-2014, 09:26 AM
B&W_Elit3's Avatar
Did you happen to measure the stand's dimensions? I need to know the amount of space there i inside each shelf .
B&W_Elit3 is offline
