Help with Isolating sound/rumble from Buttkicker in an upstairs apt? - AVS Forum | Home Theater Discussions And Reviews
Old 10-12-2011, 01:48 PM - Thread Starter
holyindian's Avatar
Quoted: 83 Post(s)
Liked: 44
Hi all,
Currently my HT setup is on the first floor.. its another 2 years before i build my dedicated HT in the basement, cos of this my family complains of rumbling sound from above (the HT room) when i turn on the buttkicker. I have these mounted to my Recliners, and the rubber isolation feet is not much help.
I was wondering if i cud mount the entire recliner on a plywood/mdf/mass loaded vinyl/auralex platfoam kit... etc.. or anything else, to reduce the sound for people downstairs. Please guide... whats the best option for me. Right now i have a carpet, but within few months we will install hardwood floor. I dont have a problem mounting the entire recliner on any kind of riser or a platform.
I was looking at Auralex Platfoam Kit, the prices are pretty steep high, not sure if there is something else in the market and if i cud use something more efficient for relatively cheaper.
Any suggestion guys?
holyindian is offline
Old 10-13-2011, 01:16 PM
stockmonkey2000's Avatar
Tell them that you will remove the buttkickers and install giant subwoofers instead - That should quiet them down
The rubber isolation feet that come with the buttkickers are actually a pretty hard rubber and probably do not isolate the chairs from the floor much. I think if you used a different (softer) product like sorbothane or something you would get much better results. Sorbothane would be quite expensive for that application though. One negative of the Sorbothane is that it is squishy and the chairs might move around a bit on the sorbothane.
The auralex would probably give good results but not sure how the cost would compare to something like sorbothane. Using too much sorbothane would also end up allowing the platform to move around a bit.
stockmonkey2000 is offline
Old 10-13-2011, 05:29 PM - Thread Starter
holyindian's Avatar
Quoted: 83 Post(s)
Liked: 44
sorbothane is 10 times more expensive as compared to Auraflex i guess.
