Chinadog's Tennessee Theater! - Page 19 - AVS Forum | Home Theater Discussions And Reviews
 305Likes
post #541 of 1329 Old 02-19-2013, 04:13 AM - Thread Starter
chinadog's Avatar
Quoted: 77 Post(s)
Liked: 284
Strange indeed.. Maybe you should have your water tested. It's uncommon to have copper tube fail on city water. Even in the case of galvanic corrosion it's usually not the copper that fails. I wonder if you have some stray current going through the piping.
It's also weird that you have two failures so close together. The question is: What's changed?
Tim
The plumber said the same thing. Maybe I will have the water tested. Nothing has changed as far as I know. It's strange.
Bud
chinadog is online now
post #542 of 1329 Old 02-19-2013, 04:46 AM
RTROSE's Avatar
Quoted: 195 Post(s)
Liked: 169
Hey Bud,
Great score on the score board (no pun intended). I know how frustrating it can be to deal with HVAC as I went though three or four contractors all with varying ideas and prices. Can be very frustrating for sure. Glad you are getting it sorted out. That is strange on the water leaks. I have had my fair share of water issues, they make me very uneasy. I would definitely find out what is going on there.
On the thermostat, it may be 4k res, but what's the screen size? LOL
RTROSE
RTROSE is offline
post #543 of 1329 Old 02-19-2013, 08:58 AM
jikkjack's Avatar
How much for the Golden Tee that the scoreboard is leaning on...???
jikkjack is offline
post #544 of 1329 Old 02-19-2013, 12:33 PM
farkem's Avatar
Originally Posted by chinadog View Post
Good news though, I scored a scoreboard on ebay for the basement. It's a little rough, but I should be able to get it to work. It came out of a sports bar in Cromwell, CT called "Rookies Sports Bar and Grille", apparently they got bought out or something. A consignment place had it (looks like they've got some other stuff too) and had it in the "scrapbooking" section on ebay. Got it for a steal using esnipe. It has the controller with it as well. I called a friend of my brother's who picked it up for me today. He'll bring it to my brother (also in CT) who will give it to my father-in-law (also in CT) who will haul it down to KnoxVegas this summer. smile.gif
Looking forward to cleaning it up and hanging it. Boy, I hope the buzzer works, that'll scare the crap out of my guests that sleep in the guest room in the basement, huh? tongue.gif
Bud
I think you should hang it over the headboard in the master bedroom.
farkem is offline
post #545 of 1329 Old 02-19-2013, 03:14 PM - Thread Starter
chinadog's Avatar
Quoted: 77 Post(s)
Liked: 284
Jason -
Here you go. Golden Tee info
Bud
post #546 of 1329 Old 02-19-2013, 03:15 PM - Thread Starter
chinadog's Avatar
Quoted: 77 Post(s)
Liked: 284
That's hilarious! I really, really, really doubt I could get away with that. tongue.gif
Bud
post #547 of 1329 Old 02-19-2013, 03:58 PM
farkem's Avatar
Bud
It'd give a whole new meaning to sudden death overtime...
farkem is offline
post #548 of 1329 Old 02-19-2013, 04:59 PM
Brad Horstkotte's Avatar
Liked: 72
Haha, good one - how about adding the hockey game air horn too?
Brad Horstkotte is offline
post #549 of 1329 Old 02-19-2013, 05:58 PM
J_P_A's Avatar
Quoted: 650 Post(s)
Liked: 483
The Plains Theater Has Begun
J_P_A is online now
post #550 of 1329 Old 02-19-2013, 06:01 PM - Thread Starter
chinadog's Avatar
Quoted: 77 Post(s)
Liked: 284
Maybe I should have gotten the one with the 30 second shot clock instead. wink.gif
Bud
post #551 of 1329 Old 02-19-2013, 06:45 PM
Intricate1's Avatar
To chime in on pinhole leaks and copper failing. I did not read all of the thread but If I recall it first happened on a recirculating line. Actually this is a very common issue. the circ pump is a run 24 hour a day seven day a week pump i am assuming, that is 8 times or more the amount of water flow through your water heater and through the piping than with no recirculating line. Get an aquastat for the circ pump and then you may want to test the chlorine level of your water. this will obviously not reverse the damage already done it will however slow the rate of further damage.
Intricate1 is offline
post #552 of 1329 Old 02-19-2013, 06:51 PM
J_P_A's Avatar
Quoted: 650 Post(s)
Liked: 483
Bud
LOL!!!!!
J_P_A is online now
post #553 of 1329 Old 02-20-2013, 04:12 AM - Thread Starter
chinadog's Avatar
Quoted: 77 Post(s)
Liked: 284
Thanks for chiming in. I'll look into it.
Bud
post #554 of 1329 Old 02-20-2013, 06:58 AM
design1stcode2nd's Avatar
Quoted: 31 Post(s)
Liked: 44
Bud
The houses in our neighborhood (at least 3 that I know of not including mine) have had a bunch of pinhole leaks on the cold water lines. We all feel it’s something the county was or was not doing to the water but we can’t prove that. In the end after a number of repairs I decided to re-pipe the entire house with CPVC, no issues since then. Hopefully you are not having a similar issue.
Play like a Raven
design1stcode2nd is offline
post #555 of 1329 Old 02-20-2013, 07:21 AM - Thread Starter
chinadog's Avatar
Quoted: 77 Post(s)
Liked: 284
The house has the red/blue supplies (is that CPVC?) throughout the house in the walls, where to comes to the fixtures (I could be wrong), I think they connect it to copper. The hot water recycler has (one one side) the plastic pipe coming in the copper joint that connects to it. The other side if all plastic pipe, including the joint. I'll have to go under some sinks and take some pictures. I assume the plastic pipe comes to copper for the controls behind the shower walls, but don't know without ripping out some drywall.
Bud
post #556 of 1329 Old 02-20-2013, 07:52 AM
J_P_A's Avatar
Quoted: 650 Post(s)
Liked: 483
Sounds like PEX. In our house they plumbed everything with PEX and stubbed out with a copper line to anything that needed to be "sturdy" like the hose bibs outside or anything that needed to be "pretty" like the exposed lines under a vanity. I think the water heaters also have a short copper line as well.
J_P_A is online now
post #557 of 1329 Old 02-20-2013, 07:57 AM
HopefulFred's Avatar
Quoted: 521 Post(s)
Liked: 484
HopefulFred is online now
post #558 of 1329 Old 02-20-2013, 08:02 AM
Quoted: 31 Post(s)
Liked: 44
My house was built in the late 70’s so the entire thing was copper. Where it met faucets and toilets it’s flex line but the “bones” were all copper. We would see sagging drywall and a drip forming and we’d know we had another leak. We’d cut out the drywall re-pipe that section and patch/paint. After about 6 of those I replaced all of it. Luckily for me there was a main wetwall and we wanted to remodel a bathroom anyway so we just rolled it all together.
It sounds like yours may not be the same issue I had. I would have a pin hole surround be green corrosion in the middle of a 8’ run of pipe, the another section in a completely different spot then another 5’ down from the first. Didn’t seem to be a rhyme or reason to where they sprung up. Some far from the a faucet, some just before, but it always seemed to be in the cold water lines if I remember correctly, it’s been about 7-8 years now.
Play like a Raven
post #559 of 1329 Old 02-20-2013, 08:05 AM - Thread Starter
chinadog's Avatar
Quoted: 77 Post(s)
Liked: 284
Yup, that's the stuff.
J_P_A - sounds like my house - what about the showers?
Bud
post #560 of 1329 Old 02-20-2013, 08:21 AM
J_P_A's Avatar
Quoted: 650 Post(s)
Liked: 483
In my house they connected PEX supplies directly to the mixing valve and up to the head in the shower. Same for the tub/showers but they ran copper for the spout.
You didn't ask for pictures, but here they are anyway smile.gif I had to zoom way in on the shower pic, so it's a little fuzzy.
J_P_A is online now
post #561 of 1329 Old 02-20-2013, 09:10 AM - Thread Starter
chinadog's Avatar
Quoted: 77 Post(s)
Liked: 284
Cool. Thanks for the pictures. I have one of those scopes that plumbers use (kinda - not on a reel, only a few feet long). I may poke a few holes in my walls to see how they connected the PEX to the shower.
Bud
post #562 of 1329 Old 02-20-2013, 03:52 PM - Thread Starter
chinadog's Avatar
Quoted: 77 Post(s)
Liked: 284
So I own the Facebook group for our subdivision. Yeah, its small and I'm a geek. Go figure. Anyway, I posted about having two pinhole leaks in the last month and asked has anyone else had a pinhole leak recently? I got a response from one person who said she had a pinhole leak about a month ago. I asked her what builder it was, it was the same. I asked when the house was built, it was the same. I asked where it was, she said on the copper piece coming from the HW heater (the same - the second time). It was probably the same plumber as well.
Thought I'd share.
Bud
post #563 of 1329 Old 02-20-2013, 06:24 PM
Neurorad's Avatar
Quoted: 231 Post(s)
Liked: 145
Call that plumber? Maybe he has more info.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #564 of 1329 Old 02-20-2013, 07:23 PM
Intricate1's Avatar
If you have pex in all of your walls and only copper at the circulation lines and out of the hot water heater then it is not likely a source for galvanic action. There are a few reasons pinholes can occur in copper. Electrolysis, turbulence/cavitation, low ph in water, other water quality issues, and good old father time. Since copper in Tennessee has been used a LONG time and if I recall you are in/ near knoxville I am going to rule out father time. Testing the ph of your water is easy but fixing low ph not so easy.
Turbulence and cavitation from the recirc system are going to be my bet. If you do not deburr copper turbulence can form and cause excessive wear.
Also a pump can cavitate and cause excessive wear.
Some linking to water softeners causing early failure on copper is evident.
Reverse osmosis treatment will destroy copper in a very short time frame.
PM me i will gladly take a phone call from you on this subject. I am a professional plumber in Nashville. I left management to being in the service industry because it is what I love to do.
post #565 of 1329 Old 02-21-2013, 01:52 AM
TMcG's Avatar
Quoted: 1177 Post(s)
Liked: 997
Bud
It would be really "trick" if you could devise a way to interface this thing with an RSS feed from the game of your choice! Nice find.
TMcG is offline
post #566 of 1329 Old 02-21-2013, 05:54 AM - Thread Starter
chinadog's Avatar
Quoted: 77 Post(s)
Liked: 284
Unfortunately, I don't know who the plumber is - we bought the house less than two years ago.
Bud
post #567 of 1329 Old 02-21-2013, 07:01 AM - Thread Starter
chinadog's Avatar
Quoted: 77 Post(s)
Liked: 284
I may take you up on that, thank you very much. I'm not familiar with cavitation. What is that?
Bud
post #568 of 1329 Old 02-21-2013, 12:00 PM
cuzed2's Avatar
Quoted: 200 Post(s)
Liked: 256
I can also speak to water quality / turbulence contributing to leaks in copper.
We sell and install scientific equipment that utilizes water chillers. Our installations are in all 50 states.
Some of these water chillers run 24x7 and utilize water-cooled condensers where city water flows 24x7 to cool the chiller and is dumped down the drain (I know extremely wasteful).
In some locations with poor quality well water; we are overhauling these chillers every few years.
In locations with higher quality water (Chicago area is on lake Michigan water), we rarely have water cooled condenser failures.
A recent failure analysis by the chiller Mfr. showed that a high mineral content combined with higher than normal incoming water pressure actually caused abrasion on the internal surfaces of the cooling lines (especially where the copper bends or is at a junction (or tee). Lowering the water pressure and/or using large capacity particulate filters on the incoming lines can sometimes help.
In extreme cases "marine grade" stainless steel components are built into our chillers.
Cuzed2
CuznEddy Cinema
cuzed2 is offline
post #569 of 1329 Old 02-21-2013, 04:44 PM
Intricate1's Avatar
cavitation is when a pump is spinning and churning air which happens when a low pressure event occurs feeding the pump. IE the pump impeller is spinning faster than water can feed it. Any kind of propeller can do it.. Boats do it all the time. Boat props have anodes in them to help with the wear of water eating away the metal... so does your water heater. Unless you are Tankless.
post #570 of 1329 Old 02-21-2013, 05:28 PM
Quoted: 521 Post(s)
Liked: 484
