Chinadog's Tennessee Theater! - Page 43 - AVS Forum | Home Theater Discussions And Reviews
 305Likes
post #1261 of 1329 Old 05-30-2017, 04:03 PM
Quoted: 3897 Post(s)
Liked: 3331
Originally Posted by chinadog View Post
Just got the call, carpet has not been delivered to the store, so we have to push until Tuesday of next week. It's now suppose to be in either Friday or Monday, hence the delay until Tuesday.
Are you sure your house isn't cursed, maybe built on ancient ceremonial grounds?
PTAaron and DougUSMC like this.
post #1262 of 1329 Old 05-30-2017, 04:13 PM
Liked: 3331
Also, in haste, I forgot to keep a small piece of linacoustic for the projector box ceiling and bottom. If anyone has about three feet (by 48") they want to sell, please let me know.
As a quick substitute, In the drop ceiling aisle your Home Depot may stock the the 2x4 compressed fiberglass ceiling panels. You can usually buy a single. It feels like OC703, it's yellow compressed fiberglass with a white vinyl face, put the face toward the wood. If you want thicker peel off the vinyl and stack them.
post #1263 of 1329 Old 05-30-2017, 04:19 PM
HopefulFred's Avatar
Quoted: 523 Post(s)
Liked: 484
I should be able to help you out with some ductliner. It's not name-brand linacoustic. Are you coming to Atlanta any time soon? (Feel free to PM me)
HopefulFred is online now
post #1264 of 1329 Old 05-30-2017, 07:49 PM - Thread Starter
chinadog's Avatar
Quoted: 77 Post(s)
Liked: 284
Ancient Carpet Burial Mound, I suppose.
Bud
chirpie likes this.
chinadog is offline
post #1265 of 1329 Old 05-30-2017, 07:51 PM - Thread Starter
chinadog's Avatar
Quoted: 77 Post(s)
Liked: 284
I'll take a look. I still have some 2" material from Dennis, not sure that'll work though. The projector is very quiet, it's the cool cube that makes a ton of noise.
Bud
chinadog is offline
post #1266 of 1329 Old 05-30-2017, 07:53 PM - Thread Starter
chinadog's Avatar
Quoted: 77 Post(s)
Liked: 284
Thanks, I think that would be fine considering what I'm using it for. Not sure at this point what the basketball schedule looks like. They're finalizing the schedule for next month soon, so I'll let you know. Appreciate it.
Bud
chinadog is offline
post #1267 of 1329 Old 05-30-2017, 07:56 PM - Thread Starter
chinadog's Avatar
Quoted: 77 Post(s)
Liked: 284
I did the "L" molding tonight and start the crown under the soffit. I don't have any pictures though. I'll post them when I'm done. My daughter helped some, then we watched "School of Rock". Had not seen it in a while. A buddy from work is sharing his Plex library with me, so we watched it and had some laughs.
Bud
chinadog is offline
post #1268 of 1329 Old 05-30-2017, 09:19 PM
Liked: 3331
Bud
This is the second instance I recall of that system being noisey. I had problems with it on my Ohio build project and the recommendation by the vendor was to get a fan speed control and run it slower. My recommendation to Dennis would be spec a different fan. The problem I was having is the fan moves too much air and you can hear buffeting/air turbulence
post #1269 of 1329 Old 05-31-2017, 05:53 AM - Thread Starter
chinadog's Avatar
Quoted: 77 Post(s)
Liked: 284
I think there are two settings are far as speed control, but have not really played with it you. Since I don't have the projector box done, no real need to have it running. The temp probe helps, so it only kicks on when it needs to. I'm hoping that have the fan running and the system pulling air from the box may be enough to keep it from going on at all, but sort of doubt it. We'll soon find out.
Bud
chinadog is offline
post #1270 of 1329 Old 05-31-2017, 03:12 PM
Quoted: 523 Post(s)
Liked: 484
Bud, do you have any other pictures of your hushbox? It looks from the pictures like you were pretty straightforward with construction - MDF, white wood, probably brads and glue, just butt joints and presumably wood-filler and paint. Is all that true? I see the cool cube mounted inside, and I see the duct leading out(?) - what about intake?
post #1271 of 1329 Old 05-31-2017, 04:53 PM - Thread Starter
chinadog's Avatar
Quoted: 77 Post(s)
Liked: 284
Yes, all of that is true. I still have to complete it, but will take some pictures. I haven't connected the duct to the return yet on the inside of the box, bit from the box to the return is completed in the soffit. It'll be pretty straightforward to finish it out and I don't am not traveling this weekend, so that's on my list get done.
As i recall, it was the last thing I finished for the last theater. I've got some tricks up my sleeve for this one as well if it all plays out correctly.
Bud
chinadog is offline
post #1272 of 1329 Old 06-05-2017, 07:02 AM - Thread Starter
chinadog's Avatar
Quoted: 77 Post(s)
Liked: 284
Quick update.
Spent a chunk of Saturday putting in the shoe molding around the new wood floor. I wanted to get that done and start putting furniture back and get organized. Still have holes to fill and touch up work there.
On the theater side, I finished out the 2"crown molding under the soffit. I caulked joints and filled holes yesterday, so I need to do a little sanding tonight and touch up paint. I finally added some hooks onto the lower part of the projector box to hold in in place and I'll work on the front of the box in the next day or so. I also added the fabric to the top part of the side room door, which came out good, but I also need to figure out how to tie out the corners nicely where the track doesn't continue.
Carpet tomorrow! Woohoo! (Did I just jinx myself?)
Bud
chinadog is offline
post #1273 of 1329 Old 06-05-2017, 07:11 PM - Thread Starter
chinadog's Avatar
Quoted: 77 Post(s)
Liked: 284
Couple of quick shots. Did some touch up work before the carpet is going in, wanted to make sure I didn't drop a bucket of paint on it or down the stairs like I did last time. I assume I'll have touchup work after the carpet install, but at least I got most of what I knew I had to do done, including the 2" crown and the "L" molding holes and joints around the soffit. One or two joints aren't great, but I can always redo them later if I'm not happy with them. Here's a shot of the front (er, back) of the rack with its blanks in. Still missing - one PS4 Pro. Still needing work - Crestron programming which should start soon. Still to do, front of projector box (and pictures for HopefulFred) and fabric. And screen wall fabric. And doorknobs.
Bud
ID:	2173210   Click image for larger version
dgage and texpilot like this.
chinadog is offline
post #1274 of 1329 Old 06-06-2017, 11:18 AM - Thread Starter
chinadog's Avatar
Quoted: 77 Post(s)
Liked: 284
Carpet installed! Looks a little lighter in the pictures. Seats setup (with and without removable armrests and dogs).
This is a better look at the carpet color, but still lighter than it is.
Bud
ID:	2174410   Click image for larger version
ID:	2174418   Click image for larger version
ID:	2174426   Click image for larger version
ID:	2174434   Click image for larger version
ID:	2174450   Click image for larger version
dgage, PTAaron, texpilot and 2 others like this.
chinadog is offline
post #1275 of 1329 Old 06-06-2017, 11:31 AM
Liked: 3331
Know you know how SpaceX felt when they landed the first rocket upright!
post #1276 of 1329 Old 06-06-2017, 11:38 AM
COACH2369's Avatar
Quoted: 958 Post(s)
Liked: 790
Looks great!
I like the contrast from dark to light going from your front stage back to the first row.
COACH2369 is online now
post #1277 of 1329 Old 06-06-2017, 11:43 AM
Deep Sea Sound
dgage's Avatar
Quoted: 1669 Post(s)
Liked: 1491
The space is coming along very nicely. I'm looking forward to getting an invite or inviting myself just to experience the couches since I've been considering some HT loveseats.
David Gage
Deep Sea Sound
"You don't listen to our subs, you EXPERIENCE them!"
dgage is offline
post #1278 of 1329 Old 06-06-2017, 08:17 PM - Thread Starter
chinadog's Avatar
Quoted: 77 Post(s)
Liked: 284
Sure feels like it!
Bud
chinadog is offline
post #1279 of 1329 Old 06-06-2017, 08:19 PM - Thread Starter
chinadog's Avatar
Quoted: 77 Post(s)
Liked: 284
Originally Posted by COACH2369 View Post
Looks great!
Thanks. When the black fabric around the screen is done, it'll really pop.
Bud
chinadog is offline
post #1280 of 1329 Old 06-06-2017, 08:20 PM - Thread Starter
chinadog's Avatar
Quoted: 77 Post(s)
Liked: 284
We'll have to plan an AVSer night.
Bud
dgage likes this.
chinadog is offline
post #1281 of 1329 Old 06-06-2017, 08:22 PM - Thread Starter
chinadog's Avatar
Quoted: 77 Post(s)
Liked: 284
Got the right wall done tonight and part of the left side done. Kids wanted to watch something, so I'll finish up the fabric tomorrow.
Bud
ID:	2176714   Click image for larger version
ID:	2176722   Click image for larger version
dgage, TMcG, texpilot and 1 others like this.
chinadog is offline
post #1282 of 1329 Old 06-06-2017, 08:36 PM
jason4vu's Avatar
Quoted: 55 Post(s)
Liked: 131
Congrats! Looks really nice
jason4vu is offline
post #1283 of 1329 Old 06-06-2017, 09:12 PM
Deep Sea Sound
dgage's Avatar
Liked: 1491
Really looking good and you've made a lot of progress in a short time.
chinadog likes this.
David Gage
Deep Sea Sound
dgage is offline
post #1284 of 1329 Old 06-06-2017, 09:43 PM
dc_pilgrim's Avatar
Really sharp Bud.
dc_pilgrim is offline
post #1285 of 1329 Old 06-07-2017, 04:13 AM
COACH2369's Avatar
Quoted: 958 Post(s)
Liked: 790
Bud
+2...I can bring the popcorn.
Not the whole machine,but I would pop some before coming over.
Name:	Popcorn Machine.jpg
post #1286 of 1329 Old 06-07-2017, 07:12 AM - Thread Starter
chinadog's Avatar
Quoted: 77 Post(s)
Liked: 284
Really sharp Bud.
Thanks Dave.
chinadog is offline
post #1287 of 1329 Old 06-07-2017, 07:13 AM - Thread Starter
chinadog's Avatar
Quoted: 77 Post(s)
Liked: 284
Thanks Jason!
chinadog is offline
post #1288 of 1329 Old 06-08-2017, 04:26 AM
mrpergo's Avatar
Quoted: 21 Post(s)
It looks beautiful.
How does the finished product perform, picture & sound ?
mrpergo is offline
post #1289 of 1329 Old 06-08-2017, 05:13 AM - Thread Starter
chinadog's Avatar
Quoted: 77 Post(s)
Liked: 284
Well, thank you. Appreciate it. Still not quite ready, but close.
From a performance standpoint, I'm extremely happy. Love the JVC, it's bright, crisp and worthy. I ordered a few 4K BDs and even though its on e-shift, it's impressive. The audio is amazing. I've watched Fury Road about 50+ times (always on HBO) before the theater was functional. There were so many things I missed - whispers, clarity, etc. Really happy with everything - the soundproofing (DDWGG, doors, etc) works great, I was somewhat skeptical, but with almost everything complete there, it's amazing how quiet things are with the door shut.
Shifting all my BDs to Plex now that I have the NAS and that is so convenient from a media organization standpoint. Works really well.
Extremely happy with the performance of things.
Bud
dgage and DougUSMC like this.
chinadog is offline
post #1290 of 1329 Old 06-10-2017, 07:34 AM - Thread Starter
chinadog's Avatar
Quoted: 77 Post(s)
Liked: 284
Did a little more fabric when I had a chance this week. It was a busy one. Not going to be able to do anything this weekend either. I have the bottom of the theater entrance doors to complete and the little piece above the other door. I can then get the knobs on. From there I'll go ahead and do the screen, thinking I'm just going to build panels since it'll be easy.
Bud
ID:	2182001   Click image for larger version
chinadog is offline
