The Austin Home Theater - Page 14 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #391 of 409 Old 12-17-2012, 03:57 PM
amb1s1's Avatar
Originally Posted by aaustin View Post
Hi rschuler,
Yes, I did run the LED strips the full length of the crown.
Here is what you would need.
RGB LED strips (30/meter):
http://www.ebay.com/itm/5M-30Leds-M-RGB-5050-Waterproof-SMD-LED-Lights-Flexible-Strip-/160688397549?pt=US_Car_Lighting&hash=item2569c65ced
I had to buy two strips for a total of 10 meters. They can be cut every few inches.
A remote and controller:
This one has two outputs to allow you to connect two separate stands.
http://www.ebay.com/itm/44-Key-IR-Remote-Control-Controller-For-5050-RGB-LED-Light-Strip-two-outputs-/160774070507?pt=US_Lighting_Parts_and_Accessories&hash=item256ee1a0eb
There is also this one that has five outputs.
http://www.ebay.com/itm/44-Key-IR-Remote-Controller-For-RGB-5050-LED-Light-Strip-Five-outputs-/251024970634?pt=US_Lighting_Parts_and_Accessories&hash=item3a7241138a
A power supply:
http://www.ebay.com/itm/LCD-AC-Power-Supply-Adapter-DC-12-Volt-6-Amp-12V-6A-/280869637229?pt=Laptop_Adapters_Chargers&hash=item4165228c6d
Each 5 meter length requires 3 amps of current. Since I ended up using about 8 meters, I bought a 6 amp power supply like the one that I linked to.
Mr. Tim also just posted some very good information on voltage drop with LEDs over in his thread. It can be found here.
http://www.avsforum.com/t/1426519/mr-tims-15x27-theater/120#post_22687289
Let me know if you have any other questions and I'll try to answer them as best I can.
I bought 4 of the strip that you link here, I want to buy the 5 ir controller, what type of power supply do I need?
amb1s1 is offline
post #392 of 409 Old 12-18-2012, 08:25 AM
amb1s1's Avatar
A power supply:
Correct me if I'm wrong 3amp is equal 360 watts and each strip use 36 watts, why do you need a 6amp power supply if with a 3amp power supply you had enough? I'm learning about watts and amps, so correct me if I'm wrong. Thanks
amb1s1 is offline
post #393 of 409 Old 12-18-2012, 09:47 AM - Thread Starter
aaustin's Avatar
Liked: 36
Hi amb1s1,
If remember my physics class correctly, Power= Voltage * Current. So that means that the Current =36W / 12V =3A.
Since the strips are connected in parallel to the controller, that means that the voltage in all of the strips is twelve volts. With a resistance of 4 ohms in each strip, the equivalent resistance of four of them would be 1 ohm. Since Current=Voltage / Resistance, that mean that the total current would be 12 amps.
I couldn't find a reasonable 12 amp power supply, so in your case I'd recommend trying all of them with either a 6 amp or an 8 amp (http://www.ebay.com/itm/8-Amp-12-Volt-Ac-Power-Adapter-with-3-Prong-Plug-with-5-Mm-Dc-Output-Jack-/390346437395). I "think" that using a lower amperage will just cause the maximum brightness to be lower, but this shouldn't be a problem for accent lighting in a theater. I keep mine on the lowest setting all of the time.
The worst case scenario would be that you'd have to run two sets of two strips with their own power supply and controller.
The Austin Home Theater:
aaustin is offline
post #394 of 409 Old 12-31-2012, 10:12 PM - Thread Starter
aaustin's Avatar
Liked: 36
Happy New Year to everyone on AVS!
aaustin is offline
post #395 of 409 Old 01-08-2013, 08:41 PM
azula's Avatar
Quoted: 20 Post(s)
Happy New Year brother!
Hope all is well, how is that theater of yours??
azula is offline
post #396 of 409 Old 01-08-2013, 09:18 PM - Thread Starter
aaustin's Avatar
Liked: 36
What's up azula? It's great to hear from you!
The theater has only gotten better with time. I've been watching movies almost every night while on vacation. smile.gif
Thanks for stopping in!
aaustin is offline
post #397 of 409 Old 01-09-2013, 05:52 AM
RTROSE's Avatar
Quoted: 192 Post(s)
Liked: 167
It is very nice to enjoy a vacation like that isn't it? I STILL go down to my basement and get a smile on my face thinking "I can't believe that I have a theater in my basement". Enjoy it my friend you deserve it!
RTROSE
RTROSE is offline
post #398 of 409 Old 01-09-2013, 09:30 AM - Thread Starter
aaustin's Avatar
Liked: 36
Thanks RTROSE!
You are absolutely right, I get a huge smile on my face every time a pop a movie in and see it come to life on the screen. It is awesome. biggrin.gif
I've been working on some finishing touches in the rest of the basement over my break. A little drop ceiling, molding, etc. It's good to get back into some DIY projects. I never thought I'd miss going to Home Depot all of the time! smile.gif
aaustin is offline
post #399 of 409 Old 02-19-2013, 12:27 PM - Thread Starter
aaustin's Avatar
Liked: 36
Its been awhile since this thread has been updated, but this weekend I actually did some work in the theater.
I came home for a three day weekend to find that half of my LED lights wouldn't turn green. It turns out that one of the connections came loose, but that's nothing that five minutes with a soldering iron couldn't fix. Still, I can officially say that I did something other than watch movies. biggrin.gif
Being away from my theater so much is both a blessing and a curse in my eyes. On one hand I miss watching movies, but the flip side of that is that when I do return home the splendor of the whole thing is still there. I realized that there wasn't a single thing I'd change about that room. It really is perfect.
I also checked the lock, because I don't want to experience an incident such as the one Vik and RTROSE had to go through. biggrin.gif
aaustin is offline
post #400 of 409 Old 02-19-2013, 04:32 PM
RTROSE's Avatar
Quoted: 192 Post(s)
Liked: 167
Good to hear that it was an easy fix! I completely understand about being away from the theater as a blessing and a curse. Sure makes you appreciate what you have. Does the rest of the family indulge in the theater while you are away? I would hate to think of that beautiful theater just sitting there idle.
RTROSE
RTROSE is offline
post #401 of 409 Old 02-19-2013, 09:05 PM - Thread Starter
aaustin's Avatar
Liked: 36
Hi RT!
Yes, the rest of the family does find time to enjoy the theater, though not as much as I would if I was home. It's always a good feeling when I talk to them and they tell me about the latest movie that they watched and how awesome it was. My siblings have also had some of their friends over for television series premiers. Our house has become THE best spot to watch something. biggrin.gif
Thanks for stopping by!
aaustin is offline
post #402 of 409 Old 09-25-2013, 10:52 AM
GWCR's Avatar
Quoted: 17 Post(s)
Liked: 39
Hey Austin. Just wanted to check in and see how the LED rope lights are holding up for you. Getting ready to order some and wanted to see if you had any issues other than the one loose connection. Thanks!
GWCR is offline
post #403 of 409 Old 10-03-2013, 09:24 AM - Thread Starter
aaustin's Avatar
Liked: 36
Where does the time go? It has been far too long since I've posted here!
The lights are still working great GWCR. No issues since the one loose connection.
As for the rest of the theater, it still gets used daily by my family. Last weekend I was home and had the chance to watch "Now You See Me" and "World War Z". Both were entertaining, especially "World War Z", which I enjoyed much more than I thought I would.
Now for what has been keeping me busy lately:
That's a total of four dual 18" subwoofers (EAW SB528), six dual 15" subwoofers (four EAW SB600 and two EAW SB250), EAW KF850 for the left and right channels, and EAW LA212 for the center and rear channels. This was set up in a large lecture hall for a movie screening of "Star Trek: Into Darkness". It was very cool!
Now, time to go check up on everyone's builds!
darthray likes this.
aaustin is offline
post #404 of 409 Old 10-04-2013, 08:27 PM
petew's Avatar
Quoted: 25 Post(s)
Liked: 68
I was wondering where you were hiding. Thanks for checking in.
Building Bass - Subs
Surrounds - Easy as Pi
Storage - unRAID unDELL
Mains - Another piece of Pi
petew is offline
post #405 of 409 Old 03-02-2014, 05:52 PM
LoudDad's Avatar
Quoted: 33 Post(s)
Liked: 27
I read and enjoyed your entire thread.
I know you're all done and at school, but I was wondering how successful was the 2 dead vent's with just that single fan.  Are you happy with the air circulation in the room?
LoudDad is offline
post #406 of 409 Old 01-04-2015, 12:38 AM
darthray's Avatar
Quoted: 939 Post(s)
Liked: 895
All I can say
Impressive as DarthVader would say
Quite impressive for someone at this early stage in life.
Have fun, when you own your own space and Keep enjoying this Hobby.
Ray
darthray is offline
post #407 of 409 Old 01-06-2015, 11:40 AM - Thread Starter
aaustin's Avatar
Liked: 36
I apologize that I missed this question earlier. I've been very busy and haven't checked the forum in awhile.
The two dead vents and fan have been performing very well since I installed them. I generally leave the fan on low all of the time and only rarely turn it up when the room is full.
aaustin is offline
post #408 of 409 Old 01-06-2015, 11:49 AM - Thread Starter
aaustin's Avatar
Liked: 36
Originally Posted by darthray View Post
All I can say
Ray
Thank you for resurrecting this old thread darthray! I'm glad to see that it is still getting a little traffic.
The theater is still being enjoyed daily by my family and I try to use it as much as possible when I am home. Lately the projector was having some color issues so I took it down yesterday and gave it a thorough cleaning. That seems to have fixed the problem so I am hoping that it stays that way.
I've been keeping very busy at school and am loving what I do. I spent last summer back home doing projects for people around town. A shed, a couple decks, and the removal of a wall to open up a kitchen were the biggest projects. I am currently working on applying to internships for next summer to begin building up some experience in my field.
In other news, I got a notification right before Christmas that my YouTube video documenting the build has over 10,000 views! It is pretty cool to think that something I did may be helping others with their own construction projects.
All the best in the new year!
dRwOOD73 likes this.
aaustin is offline
post #409 of 409 Old 12-25-2015, 07:29 PM
RTROSE's Avatar
Quoted: 192 Post(s)
Liked: 167
Nearly a year without any updates? A shameless thread bump to nudge some info out of you. Merry Christmas!
RTROSE
RTROSE is offline
Projectors , Onkyo Tx Nr609 7 2 Channel Network Thx Certified A V Receiver , Polk Audio Monitor 60 Am6022 A 2 Way Floorstanding Speaker Single Cherry , Polk Audio Monitor Series Cs2 Center Channel Speaker Single Cherry
