The Once and Future Theater - Page 41 - AVS Forum
Old 01-15-2015, 08:24 AM
Mfusick's Avatar
Quoted: 240 Post(s)
Liked: 1179
This just happened.
It's not much, but it happened. I also ordered the light sockets I will need from Lowe's to build my fixtures.
Still waiting for the EP4000 to go on better sale.
I hate to bring this up but perhaps these: http://www.parts-express.com/neutrik...mount--092-054
The round ones I find a lot easier to install. Not only do they have a lot more edge to make an air tight seal, it's a lot easier to cut circles than squares if you want to recess them.
Like I did here:AE TD15M + SEOS15 + DNA360 (active crossover) Need advice pls... :)
The square little ones are ok, so use em if you got em'
But if you had a choice, the circles I prefer.
"Too much is almost enough. Anything in life worth doing is worth overdoing. Moderation is for cowards."
Mfusick is offline
Old 01-15-2015, 08:48 AM
Mr.Tim's Avatar
Quoted: 54 Post(s)
Liked: 78
pfft..
Mr.Tim is offline
Old 01-15-2015, 09:01 AM - Thread Starter
HopefulFred's Avatar
Quoted: 229 Post(s)
Liked: 229
Yeah,I thought about that, but I'm not worried about the mounting. The "pretty" subs mount on bottom, between the legs, and the "ugly" subs don't matter.
The real reason I picked those is for the set screw wire connection on the back. I couldn't find a round design with that connection.
HopefulFred is online now
Old 01-15-2015, 09:08 AM
Mfusick's Avatar
Quoted: 240 Post(s)
Liked: 1179
That looks like more pain though...
I remember what a mess it was doing the cutouts for my braces:
Not as easy as just hitting it with a quick forstner bit.
Plus I find the circle ones seal up better. Without needing caulk or anything.
ID:	479898   Click image for larger version
Mfusick is offline
Old 01-15-2015, 09:12 AM
Mfusick's Avatar
Quoted: 240 Post(s)
Liked: 1179
Good point. Although the screw in ones really suck. I've had them fail or pull out a couple times, it's mega pain. They are not that secure, even if you tighten them with the hand of god. And it's hard to read which is which and figure it out, get a magnify glass!.
Solder is a pain for about 5 seconds, then it's reliable and done forever. I drill out the hole with a small drill bit, so I can wrap the copper speaker wire and run it through the terminal plate and twist it back into itself, then just cover it over with electrical solder. Result is awesome connection very unlikely to ever fail. The screw down clamp ones are PITA. I got a box of em... If you want some let me know. I think I got about 16 left.
Mfusick is offline
Old 01-15-2015, 11:02 AM - Thread Starter
Quoted: 229 Post(s)
Liked: 229
Probably unrelated, but I want to keep this.http://www.theguardian.com/science/a...harriss-spiral
Old 01-15-2015, 05:48 PM
doublewing11's Avatar
Quoted: 106 Post(s)
Liked: 351
+1
I used same exact speakon terminal..........prefer due to ease of sealing. No air leaks on all four cabs.
doublewing11 is offline
Old 01-15-2015, 05:58 PM - Thread Starter
Quoted: 229 Post(s)
Liked: 229
Here's a bit of trouble. When I placed the order, PE was like, "Here you GO! Everything is in stock and ready to ship!" and I was like "Great, here's my credit card." Then today they were like, "...um so remember when we said everything was in stock? About that..."
The whole reason I went ahead with the subwoofer order, to be honest, was because PE's price on the wire was a little bit less than monoprice's. I am trying to get a few more runs into the soffits so I can be Atmos-ready. I don't need to wait two more months for no reason. Now I have to cancel that part of the order and go to monoprice...
Old 01-15-2015, 06:29 PM
Mfusick's Avatar
Quoted: 240 Post(s)
Liked: 1179
I hate that about them. It's BS.
Mfusick is offline
Al Sherwood's Avatar
Quoted: 335 Post(s)
Liked: 126
I know that it may be different down there, but in Canada locally at Home Depot they used to sell spools of FT rated in wall speaker cable quite reasonable. In fact I bought a 1000 ft spool of 12/2 for my HT install.
Al
Al Sherwood is offline
Old 01-15-2015, 06:41 PM - Thread Starter
Quoted: 229 Post(s)
Liked: 229
Yeah, Al. They do have it. I went to the websites and priced what I needed from both Lowes and Home Depot just now before I ordered from Monoprice. Lowes didn't have the length I wanted (200ft - I should need about 120 for Atmos) in 14/2 CL2. Home Depot did, but was about twice the cost of Monoprice (about $0.50/ft vs $0.23/ft plus shipping). I could have saved some of the difference by going with regular 16/2, since I think the CL2 rating if a little useless in my application, but I'm trying to do this by the book as much as possible. I probably also could have saved by buying 1 100ft roll and a 25 or something, but I'm sure I'll find good use for any excess eventually. So in 3-5 business days (from tomorrow, I suppose), I should have 2 100ft rolls from Monoprice.
Old 01-15-2015, 06:46 PM - Thread Starter
Quoted: 229 Post(s)
Liked: 229
Actually, since I have the thread up and running tonight... let me ask the audience: For two rows in a 12x22 room, would you consider 7.1.6 or assume that 7.1.4 was going to be plenty. I think my 200ft of cable would get me either, but I didn't figure 7.1.6 was worth pursuing.
And what's the abbreviated nomenclature for the overheads (per Atmos): Lft, Rft, Lrt, Rrt, and what Lmt, Rmt? (gotta have labels for my cables )
Old 01-15-2015, 06:49 PM
Quoted: 335 Post(s)
Liked: 126
Ahh yes, that is where we loose out up here, the shipping for most things within the US is cheaper or even free, try and bring it across the border and look out!
As for the FT rating, I too am a DIY'er and will go by the book when it comes to installing things, even though it is class 2 wiring I want all of my work to be defensible if challenged. (yes just wee bit paranoid some would say.)
Al
Old 01-15-2015, 06:54 PM
Quoted: 335 Post(s)
Liked: 126
Fred, my room is 16 x 21 and 2 rows and I am going to provision for 6 overhead speakers as well as front a rear heights... I am looking for a minimum of 9.1.6 (actually 2 DTS-10's)
Al
Old Yesterday, 03:03 PM - Thread Starter
Quoted: 229 Post(s)
Liked: 229
PE delivered. Still waiting on Monoprice - estimated for Thursday.
Pioneer Electronics , Sherbourn , Dayton Audio Um18 22 18 Ultimax Dvc Subwoofer 2 Ohms Per Coil
