The Once and Future Theater - Page 57 - AVS Forum | Home Theater Discussions And Reviews
 203Likes
Old 01-20-2017, 07:52 AM
cowger's Avatar
Quoted: 20 Post(s)
Liked: 75
I think they look great!! Sure, perhaps they differ a bit side-by-side, but in opposite corners of the room...
Plus, if someone even notices this, you thank them for picking up on that -- you worked very hard to mimic the variation from your wall boards...
cowger is offline
Old 01-20-2017, 08:10 AM
Quoted: 73 Post(s)
Liked: 57
I like it move on. When you are "done" you can circle back for a upgrade.
Do you have your sub locations picked out ?
AdvancedTheater is offline
Old 01-20-2017, 04:33 PM - Thread Starter
HopefulFred's Avatar
Quoted: 499 Post(s)
Liked: 433
Thanks guys. I'm okay with them. And I realize now that I have given you only a partial view to the situation - not to change anything - Just that I see that you all thought the "problem" was with one of the subs. They're the same, and they're both okay. I'll let them fly. I am going to lay some flat-out-flat poly on them and call them done. (yay!)
Based on the size limitation of my space, I had to decide early on that if I wanted seating for 6 (which I do) then I would have to limit the subs to the corners. So that's what I've got: four subs (Dayton Audio UM15-22 in 3cuft sealed boxes) in four corners. Not a lot of placement flexibility, but one of the best (statistically) arrangements for uniformity out of the gate. In theory, the stage subs could come off the stage out into the room by a few feet, if that proved significantly advantageous. I'd prefer to leave them behind the screen wall.
HopefulFred is online now
Old 01-20-2017, 04:48 PM
Waterboy77's Avatar
Quoted: 531 Post(s)
Liked: 260
Not sure what the over all dimensions for the cabinet are but I thought I would mention that the bracing (from what I can see through the opening) seams to be on the light side.
One day I will start the new theater....... one day..... THAT DAY HAS ARRIVED
"If the women don't find you handsome, they should at least find you handy." Red Green
Family Cave Theater
Automation Thoughts/ Questions
Waterboy77 is online now
Old 01-21-2017, 02:51 PM - Thread Starter
Quoted: 499 Post(s)
Liked: 433
Originally Posted by Waterboy77 View Post
Not sure what the over all dimensions for the cabinet are but I thought I would mention that the bracing (from what I can see through the opening) seems to be on the light side.
You're not wrong, per se, but there wasn't much else to do. The cab is about 18" wide and 16" deep - 3 cuft approx. The top half is pretty thoroughly braced, IMO, and it's built from 3/4" plywood with a double front. I feel okay about it. The driver motor takes up almost all the available space in the bottom.
Old 01-21-2017, 03:05 PM - Thread Starter
Quoted: 499 Post(s)
Liked: 433
My "speaker stand" becomes a Helmholtz Resonator (I hope). The modeled performance should be adequate, and represents a series of compromises, as all things. The design to which we built was the green line.
The insulation is R30.
It's hung with hanging strap (plumbers strap). From inside (first image) and outside (second image)
Some of the batts had to be cut to width, but it fit pretty well.
The we cut the front down to size, marked the holes, and started drilling. The new 1" forstner was key. Tear out from the back was minimal in 1/2" MDF IMO.
We cut some diagonal bracing and screwed it in. Then caulk.
Here it is as it stands now. I suppose it deserves some black paint.
Old 01-26-2017, 03:18 AM
gerchy's Avatar
Quoted: 55 Post(s)
Any measurements with the new absorber?
beerbujit likes this.
gerchy is offline
Old 01-26-2017, 12:22 PM - Thread Starter
Quoted: 499 Post(s)
Liked: 433
Not yet, and there won't be until I also have my front wall treatment up. I would like to be able to measure with only one treatment up, but there have just been too many moving pieces to get that done. Work now - measure later.
Old 02-18-2017, 04:17 PM - Thread Starter
Quoted: 499 Post(s)
Liked: 433
Back to working on the proscenium. It's not easy going; and if you look too closely you find lots of little problems. Don't look too closely and it's very pleasing to me. I'm sure I will be happy with it when it is done.
cowger, JCJetta and J_P_A like this.
Old 02-19-2017, 03:26 AM
Mr.Tim's Avatar
Quoted: 279 Post(s)
Liked: 182
Looks great to me.. On another note I think this may be a first. I don't ever recall somebody doing deep button upholstery on the forum.
Tim
HopefulFred and thrillcat like this.
Mr.Tim is offline
Old 02-21-2017, 07:20 AM
J_P_A's Avatar
Quoted: 593 Post(s)
Liked: 450
That, sir, looks SWEET!!!!
HopefulFred likes this.
The Plains Theater Has Begun
J_P_A is offline
Old 03-11-2017, 11:47 AM - Thread Starter
Quoted: 499 Post(s)
Liked: 433
Upholstery without help is beyond my skillset. After a week with the flu, I have gotten more help. We're not going to finish this weekend, but probably next. The test-fit went well.
J_P_A, popalock and TMcG like this.
Old 03-12-2017, 12:17 PM
RTROSE's Avatar
Quoted: 194 Post(s)
Liked: 169
That adds a super classy touch to the theater sir! Nicely done! Looks fantastic. I was successful in my build because I let people (professionals) do the things that I couldn't do and I did the rest. No shame (actually it's smart) to have others come in and provide their knowledge/expertise.
RTROSE
RTROSE is offline
Old 03-12-2017, 04:43 PM
Tedd's Avatar
Quoted: 1027 Post(s)
Liked: 382
Tim
BigMouthinDC
bpassman likes this.
Tedd is offline
Old 03-12-2017, 08:22 PM
ambesolman's Avatar
Quoted: 1083 Post(s)
Liked: 912
BigMouthinDC
@popalock too
Sent using Tapatalk cuz the mobile version is still
popalock likes this.
ambesolman is online now
Old 03-13-2017, 02:51 AM
Mr.Tim's Avatar
Quoted: 279 Post(s)
Liked: 182
BigMouthinDC
In my defense, Big's theater was before my time
Tim
Mr.Tim is offline
Old 03-14-2017, 06:39 AM
J_P_A's Avatar
Quoted: 593 Post(s)
Liked: 450
The upholstery looks great!!! I'm digging it!
J_P_A is offline
Old 03-30-2017, 03:22 PM - Thread Starter
Quoted: 499 Post(s)
Liked: 433
As follow-up, the proscenium is up. I don't have a good picture because it seems my flash stopped working. (I'll try again later)
Looking forward: Rich is preparing my new Falcon screen - FVS 130 with the new fancy AT material, Falcon Vision Horizon - for shipment as we speak. I am in talks with a small-time contractor type to handle the remainder of the lobby work. We're looking at some drywall and new electrical (a couple new lights and switches), new flooring, cabinetry, sink and counters... Spending the tax refund.
Old 04-01-2017, 11:11 AM - Thread Starter
Quoted: 499 Post(s)
Liked: 433
The flat topcoat is killing me. How can a premium topcoat be giving me such trouble? https://generalfinishes.com/retail-p...t#.WN_tAZ8pBnE
Old 04-04-2017, 09:55 AM
atlbenlee's Avatar
I can't believe you're so close! Everything looks amazing in your recent photos. Looking forward to seeing it in person!
atlbenlee is offline
Old 04-18-2017, 06:04 PM - Thread Starter
Quoted: 499 Post(s)
Liked: 433
I wonder if I should have gotten a screen one size bigger?
Medi0gre likes this.
Old 04-19-2017, 07:58 AM
cowger's Avatar
Quoted: 20 Post(s)
Liked: 75
Don't know if you're joking or not, but it seems pretty danged perfect to me!
cowger is offline
Old 04-19-2017, 03:03 PM - Thread Starter
Quoted: 499 Post(s)
Liked: 433
Bryan, there's a gap about three fingers wide on each end. I'm sure a bigger screen wouldn't fit.
Old 04-20-2017, 05:17 AM
J_P_A's Avatar
Quoted: 593 Post(s)
Liked: 450
I'm loving it! I see you used TMcGs screen sizing algorithm looks great!
TMcG likes this.
J_P_A is offline
Old 04-22-2017, 04:01 PM
J_P_A's Avatar
Quoted: 593 Post(s)
Liked: 450
Have you had a chance to measure the room again?
J_P_A is offline
Old 04-22-2017, 04:15 PM - Thread Starter
Quoted: 499 Post(s)
Liked: 433
I have not fired the measurement system back up. I'd like to, but it has taken a back seat for a couple reasons. I figured that I don't have a lot more useful to learn until I get four subs up and running simultaneously. I'm still struggling with getting a good clear top coat on the two remaining subs. I had to sand the clouded top coat back off, so I need to repaint one more coat... etc, etc...
Today I've been painting the door and casing. Hopefully I can get that finished and get the case molding up on the inside of the room tomorrow.
J_P_A likes this.
Old 05-06-2017, 12:25 PM - Thread Starter
Quoted: 499 Post(s)
Liked: 433
Test for of the screen is going okay. I've adjusted the brackets that I slapped together to hang the screen from so that the screen is better square to the room. I don't think a half-inch difference in distance from the projector for the left edge vs the right edge is going to make a focus or geometry problem, but the better square everything is, the better. I also don't want the stage edge to be visually askew from the screen. I'm preparing to assemble the fabric frames that will bridge the gap between screen and stage and ceiling.
Fabric frames will be built from generic "white wood" (3/4" thick) ripped down to about 1&3/4" wide, then glued and screwed and the edge eased; then painted black and wrapped in velvet. I think I will get away with only building two: one for above (generally upside-down "T" shaped to fit between the soffits) and one simple rectangle below the screen. Then I'll need two slim somethings (scrap wood) for each edge, left and right). A few strategic bits of Velcro and some spare blocks should assure everything stays square and snug and quiet.
This isn't much of a minimalist false wall image, but maybe it's as close as I'll get.
Old Today, 07:29 PM - Thread Starter
Quoted: 499 Post(s)
Liked: 433
Baby steps.
Pioneer Electronics , Sherbourn , Dayton Audio Um18 22 18 Ultimax Dvc Subwoofer 2 Ohms Per Coil
