Frankenstein Theater Project - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 271 Old 11-23-2011, 12:30 AM - Thread Starter
Expat444's Avatar
Not sure I follow - do you mean 24" OC stud spacing, or 24" between false wall and back wall, or ?
One doesn't usually use OC703 for insulation (in the wall) - rather, for acoustic absorption (on the wall).
I meant 24" stud spacing, there'll be 1-2" between the screen wall and the wall behind it, should I plan on covering that hidden wall with OC703 as the window will be filled with either polystyrene or OC foamular panels?
Expat444 is offline
post #32 of 271 Old 11-23-2011, 07:36 AM
petew's Avatar
Quoted: 25 Post(s)
Liked: 68
Two points/questions on your material lists:
You call for fir framing material. I'd use "white wood" (spruce or pine) everywhere except for the joists that are only supported at the ends. Fir is more expensive and has a tendency to split. There is no advantage except on the joists where the stiffer material may be better. Even that is doubtful since the spans are so short. Personally, I'd use pine everywhere.
How do you plan to attach the cabinet grade oak decking to the stage? It may be easier and more economical to use structural plywood and overlay thinner oak with glue and finish nails.
Building Bass - Subs
Surrounds - Easy as Pi
Storage - unRAID unDELL
Mains - Another piece of Pi
petew is offline
post #33 of 271 Old 11-28-2011, 12:49 AM - Thread Starter
Expat444's Avatar
So I just had an interesting Thanksgiving (hope you all did too )
Net result is I've had the go-ahead to start construction and we have a 3-4 week window to complete it so (as long as it goes to plan - how often have we all heard that before!)
Looks like December's going to be an expensive (and hopefully rewarding) month
Expat444 is offline
post #34 of 271 Old 12-02-2011, 07:47 PM - Thread Starter
Expat444's Avatar
Ran through the plans again, following updates:
1) Riser will now be extended to replace the bottom step tread, this will make it even stiffer and remove the problem of what to do about the join/gap where it met the bottom step.
2) Screen wall is now 6" taller as I'd missed the 7" screen border when measuring for the screen.
3) Curtain wall will either be extended or I'll mount the projector off the bottom of it so that the lens is within the top edge of the screen.
Expat444 is offline
post #35 of 271 Old 12-03-2011, 05:21 PM - Thread Starter
Expat444's Avatar
So here's my initial rough plan on how to treat the room, in addition I have the curtain wall which will come down 3-3.5' from the ceiling above the bar which I need decide wether to fill with 2" or 4' OC 703.
My plan is to do behind the screen wall and the curtain wall during construction and then add the other afterwards as required.
Does anyone have any thoughts?
Expat444 is offline
post #36 of 271 Old 12-04-2011, 09:47 PM - Thread Starter
Expat444's Avatar
Originally Posted by Expat444 View Post
So I need to decide what to use to fill the window spaces that will be behind the screen wall (which will be lined with 1" OC703), I was thinking of using either thick polystyrene sheets from HD or I just found that they stock OC Foamular F-250 http://www.homedepot.com/webapp/wcs/...62&R=202085962
What does everyone think?
Any opinions on this as I'll be doing the install next weekend (all going well!)
Expat444 is offline
post #37 of 271 Old 12-09-2011, 03:42 PM - Thread Starter
Expat444's Avatar
So looks like I'm in for a fun weekend!
Expat444 is offline
post #38 of 271 Old 12-09-2011, 04:31 PM
Brad Horstkotte's Avatar
Liked: 68
Brad Horstkotte is offline
post #39 of 271 Old 12-09-2011, 04:40 PM - Thread Starter
Expat444's Avatar
Nice haul!
Thanks, in case you were wondering, this is what was underneath the Triads.
Expat444 is offline
post #40 of 271 Old 12-09-2011, 04:42 PM - Thread Starter
Expat444's Avatar
Expat444 is offline
post #41 of 271 Old 12-10-2011, 11:02 AM - Thread Starter
Expat444's Avatar
Screen wall and power.
Expat444 is offline
post #42 of 271 Old 12-10-2011, 03:10 PM - Thread Starter
Expat444's Avatar
Sub-panel finished.
Expat444 is offline
post #43 of 271 Old 12-11-2011, 01:20 PM - Thread Starter
Expat444's Avatar
Building Rack 2:
Expat444 is offline
post #44 of 271 Old 12-11-2011, 02:07 PM
petew's Avatar
Quoted: 25 Post(s)
Liked: 68
Holy Moly you've got some serious Apples there.
petew is offline
post #45 of 271 Old 12-11-2011, 03:20 PM - Thread Starter
Expat444's Avatar
Thanks, that's one of the reasons I'm running two separate racks as I don't want the HT sounding like a data center.
Expat444 is offline
post #46 of 271 Old 12-11-2011, 10:19 PM - Thread Starter
Expat444's Avatar
The perils of new technology, I was derailed by the new amps and speakers, good job the projector is still in its box.
Expat444 is offline
post #47 of 271 Old 12-13-2011, 08:23 PM - Thread Starter
Expat444's Avatar
Guess who found their stud finder
Expat444 is offline
post #48 of 271 Old 12-14-2011, 07:55 PM - Thread Starter
Expat444's Avatar
Anyone have any experience/opinion about this stuff, otherwise I'll install it tonight/tomorrow.
Expat444 is offline
post #49 of 271 Old 12-15-2011, 08:52 PM - Thread Starter
Expat444's Avatar
Decided to go with dual layers of 2" pink foam and 1" silver faced polystyrene.
Expat444 is offline
post #50 of 271 Old 12-15-2011, 08:54 PM - Thread Starter
Expat444's Avatar
Installation day 2, screen wall finalized and stage installed.
Expat444 is offline
post #51 of 271 Old 12-15-2011, 08:55 PM - Thread Starter
Expat444's Avatar
Curtain wall and ceiling reinforcing.
Expat444 is offline
post #52 of 271 Old 12-16-2011, 10:19 PM - Thread Starter
Expat444's Avatar
Day 3:
Curtain wall framed out.
Riser and bar installed.
Expat444 is offline
post #53 of 271 Old 12-17-2011, 09:39 AM
petew's Avatar
Quoted: 25 Post(s)
Liked: 68
You're making good progress. Is that Pizza in the second shot, on the bar?
I'l still bury the fireplace. Do you think you'd ever use it? Looks too close to combustible surfaces to be safe.
petew is offline
post #54 of 271 Old 12-17-2011, 01:00 PM - Thread Starter
Expat444's Avatar
Oops yes it was, all gone now
Still not sure what to do about the fireplace, we've just ignored it for the moment (we've never used it), depending on how it goes when I install the fabric panels I'll either leave it exposed or just panel over it.
Expat444 is offline
post #55 of 271 Old 12-17-2011, 01:01 PM - Thread Starter
Expat444's Avatar
Window plug finished.
Not sure what to do about the top windows yet.
Expat444 is offline
post #56 of 271 Old 12-18-2011, 06:38 PM - Thread Starter
Expat444's Avatar
Building rack #1.
Expat444 is offline
post #57 of 271 Old 12-24-2011, 07:53 PM - Thread Starter
Expat444's Avatar
Screen wall speaker install.
Expat444 is offline
post #58 of 271 Old 12-25-2011, 08:42 PM - Thread Starter
Expat444's Avatar
It's Alive!
Well rack #2 is anyway
Expat444 is offline
post #59 of 271 Old 12-26-2011, 06:57 PM - Thread Starter
Expat444's Avatar
Rack #1 up and running.
Expat444 is offline
post #60 of 271 Old 12-26-2011, 06:59 PM - Thread Starter
Expat444's Avatar
Running wiring for the screen wall.
Expat444 is offline
