Frankenstein Theater Project - Page 5 - AVS Forum | Home Theater Discussions And Reviews
Old 04-01-2012, 11:30 AM - Thread Starter
Expat444's Avatar
Current state, can't believe how much it's progressed compares to the original photos I posted at the start of the thread
Expat444 is offline
Old 04-01-2012, 12:12 PM - Thread Starter
Expat444's Avatar
From the stage:
Expat444 is offline
Old 04-01-2012, 08:03 PM - Thread Starter
Expat444's Avatar
His name is......
Expat444 is offline
Old 04-03-2012, 11:22 PM - Thread Starter
Expat444's Avatar
Front row testing.
Expat444 is offline
Old 04-03-2012, 11:27 PM
Brad Horstkotte's Avatar
Liked: 68
Stereoscopic, chair mounted projector disguised as a cat?
Brad Horstkotte is offline
Old 04-04-2012, 12:03 AM - Thread Starter
Expat444's Avatar
That's the post that you choose to reply to, seriously?
Expat444 is offline
Old 04-04-2012, 09:11 PM - Thread Starter
Expat444's Avatar
Further front row testing, 9.5' from a 133" wide (153" diagonal) screen:
Expat444 is offline
Old 04-07-2012, 03:27 PM - Thread Starter
Expat444's Avatar
Not exactly HT but video related and it did involve a bunch of tools and swearing....
Expat444 is offline
Old 04-07-2012, 06:54 PM - Thread Starter
Expat444's Avatar
Well it's a bit of an improvement, at least it won't all fall over in the next earthquake.
Expat444 is offline
Old 04-08-2012, 09:08 PM - Thread Starter
Expat444's Avatar
All I achieved in the HT this weekend.......
Expat444 is offline
Old 04-08-2012, 09:12 PM
KtrainHurricane's Avatar
Quoted: 38 Post(s)
Lol
KtrainHurricane is offline
Old 04-09-2012, 01:45 PM - Thread Starter
Expat444's Avatar
Wider view.
Expat444 is offline
Old 04-10-2012, 01:08 PM - Thread Starter
Expat444's Avatar
So after measuring and re-measuring I went back to the projection calculator at Projector Central and I've realized what's happened, the throw range (15') is the limiting factor, the widest image I can project at that distance with the AE4000 is 133".
Given that the curtain wall that the projector is mounted on and the screen wall aren't moving, I guess I've built a CIW.
Anyone have any thoughts?
Expat444 is offline
Old 04-10-2012, 01:14 PM
NicksHitachi's Avatar
Quoted: 182 Post(s)
Liked: 189
Given that the curtain wall that the projector is mounted on and the screen wall aren't moving, I guess I've build a CIW.
dont go all the way to max, youll need a little extra zoom to play with to get the image right. Id recommend 6" buffer......
NicksHitachi is offline
Old 04-10-2012, 07:48 PM - Thread Starter
Expat444's Avatar
Darn it, I'm already kind of disappointed that I can't get a wider 2.39:1 image.......
Expat444 is offline
Old 04-11-2012, 12:16 PM - Thread Starter
Expat444's Avatar
Temporary screen & screen wall fabric v3:
Expat444 is offline
Old 04-12-2012, 03:43 PM - Thread Starter
Expat444's Avatar
Light control and curtains.
Here's the current state of the room, there are three openings back into the house, the main stairs window, the straight stairs opening (that connects to the riser) and the wavy stairs opening (at the back of the room that leads behind the bar).
Expat444 is offline
Old 04-12-2012, 03:56 PM - Thread Starter
Expat444's Avatar
So I think the next area I need to tackle is controlling the light into the room, as you can see from the above post there are three ares that light is mainly entering the room (the rear wall doors & windows are covered by blinds).
Does anyone have suggestions about material for curtains to cover them?
1) The main stair window:
This should be relatively straight forward (although it's an odd shape) as I can make a curtain (and fittings) to cover the opening).
2) The straight steps entrance:
This connects to the riser, I think the curtain should be at the top of the two remaining steps as then the light in the ceiling will fall within the HT but I'm debating building a fabric covered panel to cover at lease the first couple of feet as then I can install a fan in it if I need to improve the air circulation (the HT currently has two HVAC input registers but no return).
3) The wavy steps entrance:
This is similar in that there's a light above the steps again but I might just go for floor to ceiling curtains as trying to build an "s" shaped fabric panel at the top to match the shape of the stairs would be a real pain.
Any suggestions are welcome (although I'm not going to sheet rock any of the openings) as currently the light leaking into to room means we only use the HT in the evenings and with the days getting longer I want to address this next.
Expat444 is offline
Old 04-12-2012, 10:42 PM - Thread Starter
Expat444's Avatar
Thunderstorm is directly overhead, just unplugged all the HT stuff not connected to a UPS.......
Expat444 is offline
Old 04-13-2012, 09:41 AM
LeBon's Avatar
Quoted: 184 Post(s)
Liked: 86
Don't count on a UPS helping much with a lightning strike. I would disconnect everything.
LeBon is offline
Old 04-14-2012, 03:26 PM - Thread Starter
Expat444's Avatar
Front row installed, awaiting unicorns
Expat444 is offline
Old 04-15-2012, 03:04 PM - Thread Starter
Expat444's Avatar
More curtain related images, focusing on how long the blinds need to be and how to build an 'S' shaped curtain rail to match the contours of the wavy steps:
Expat444 is offline
Old 04-18-2012, 02:06 PM - Thread Starter
Expat444's Avatar
Needed more power outlets so decided to add another PDC, this time with lights:
Expat444 is offline
Old 04-30-2012, 05:36 PM - Thread Starter
Expat444's Avatar
Finished the blinds on the staircase window:
Expat444 is offline
Old 05-02-2012, 03:57 PM - Thread Starter
Expat444's Avatar
Straight steps curtains:
Expat444 is offline
Old 05-02-2012, 07:38 PM
petew's Avatar
Quoted: 25 Post(s)
Liked: 68
Is that light leakage killing your picture? Any stray light is very distracting in my HT (with my admittedly dim JVC RS2)
Building Bass - Subs
Surrounds - Easy as Pi
Storage - unRAID unDELL
Mains - Another piece of Pi
petew is offline
Old 05-02-2012, 07:45 PM - Thread Starter
Expat444's Avatar
It's getting better with each of the openings I block. and the Panasonic AE4K is a pretty bright projector. I know I need to go back and block the light at the top of the blinds/curtains but I'm just dealing with the big light issues.
Expat444 is offline
Old 05-02-2012, 08:06 PM
aaustin's Avatar
Liked: 36
If the light bleed through the material becomes a problem, then you might want to think about replacing those curtains with something thicker. I've done a lot of work with theater drapes for musicals, and those things are almost like a heavy quilt and have a velvety texture. Nothing gets through them.
Something like this might be a good option (though kind of expensive).
http://www.overstock.com/Home-Garden/Signature-Warm-Black-Velvet-96-inch-Blackout-Curtain-Panel/5740481/product.html?cid=202290&kid=9553000357392&track=pspla&adtype=pla&kw={keyword}
The Austin Home Theater:
aaustin is offline
Old 05-02-2012, 08:39 PM - Thread Starter
Expat444's Avatar
Thanks, the current ones are from Ikea, cost $35 a pair and are as much a proof of concept, if I keep them I might just go to JoAnne's fabrics and get material to line them to improve the light blocking but it's a moot point until I block the last opening - the curvy steps one.
Expat444 is offline
Old 06-26-2012, 08:26 PM - Thread Starter
Expat444's Avatar
Wow, I take some time off for back surgery and suddenly it's 7 weeks since I've done anything to my HT!
Expat444 is offline
