New Theater Room Construction Help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 11-15-2011, 05:47 PM - Thread Starter
esabet's Avatar
Hi;
We are working on a New Home Construction and trying to layout the Cellar. One of the features that we are looking for is a Home Theater. So this is going to be a "new built" theater room which means we have some flexibility as there are currently no partition walls. But depending on what I discover here, there are some other restrictions (structural columns, for example) that may dictate a change, That said let me strat with what we would consider an "ideal" theater.
The basic features that we are looking for:
Seats 12-14 Adults
Three (3) rows of seating.
Two isles, one on either side of each row.
Each row to be stepped up from the other.
What we would like to know at this stage is:
1.Given the above criteria, what is the minimum room size (WxL) that is necessay?
2.How far apart should each row be from the other?
3.How high should each step be? Is a 6" step enough?
4.Any other details that is necessary for us to know at the plannig stage?
THANK YOU in advacne.
esabet is offline
post #2 of 13 Old 11-15-2011, 05:56 PM
Felgar's Avatar
At the planning stage you'll need to decide to what lengths you're going to go in the pursuit of soundproofing/sound isolation. If you're looking to soundproof, you'll want to keep HVAC ducts to the rest of the house from running through the ceiling of the room, and you'll want to plan on building dead vents for any vents and returns that supply the room.
6" step is probably a little on the shy side but it depends on the position of your screen, etc.
Felgar is offline
post #3 of 13 Old 11-15-2011, 06:18 PM
Brad Horstkotte's Avatar
Liked: 68
>>1.Given the above criteria, what is the minimum room size (WxL) that is necessary?
That depends on the answer to (2), and if you're using an acoustically transparent screen (which adds 2-3' depth). Assuming an AT screen with 2' deep false wall, three rows of recliners spaced 7' apart, and 11' first row seating to screen distance, it would be 27' or so long. My room with 4 across curved seats in the back is 17' wide, and that works pretty well, still enough room on both sides. So maybe 27'x17'. If you use barstools in the back row, you can deal with just one riser (bar stools sit higher than the recliners on the same level), and cut down on room depth a couple feet.
That depends on the type of seats - if recliners, figure about 7' between rows to allow for recline and ability to get to/from your seat. If not recliners (typical movie theater seats, or couches, etc.), will be less.
That depends on how high your screen is mounted. There is a riser height calculator that you can use to estimate; mine ended up being 12" high for the second row, which was just enough to be able to see the bottom of the screen from the second row, over the seats and heads in the first.
>>4.Any other details that is necessary for us to know at the planning stage?
It depends One thing that comes to mind is you may need multiple side surrounds to provide adequate coverage for the three rows.
Have you considered using the Pro Layout Service? Take a look at least. Although I am happy where I ended up with my build, my build would have been accelerated significantly if that service had been available at the time - a lot of time spent researching and waffling on decisions, vs. following a well thought out plan.
Also, take some time to browse through some of the more popular (# of posts, # of views) build threads here for ideas, you'll pick up a lot of ideas that you might not have considered, that you can integrate into your plan.
Brad Horstkotte is offline
post #4 of 13 Old 11-15-2011, 06:22 PM
Quoted: 3280 Post(s)
Liked: 2757
18x30x10 ft ceilings, each riser will probably need to be 12 inches tall.
If that is too big think about a sit at bar (facing the screen) for the third row and you could shave 4-5 ft off.
Door position is CRITICAL for an effective layout so where the room sits make a difference.
If you would post a measured diagram of the layout of the basement and location of columns you will get some suggestions of how to position a theater.
post #5 of 13 Old 11-15-2011, 06:25 PM
Ted White's Avatar
Quoted: 12 Post(s)
Liked: 44
Actually, as long as they're not contacting the final ceiling, and the ceiling is decoupled with damped mass, and you don't pack in the insulation around the ducts, they're generally OK to leave.
Certainly agree with your points about the ducts that actually supply the room.
__________________
Ted
The Soundproofing Company
Ted White is offline
post #6 of 13 Old 11-15-2011, 06:49 PM
SierraMikeBravo's Avatar
Quoted: 339 Post(s)
Liked: 215
The simple answer is, everything should be known at the planning stage!
Shawn Byrne
CEDIA Certified Professional EST II - HAA, THX.
Theater Design Information and Examples
skbyrne@sbcglobal.net
shawn@questai.com
SierraMikeBravo is offline
post #7 of 13 Old 11-15-2011, 06:56 PM
Dennis Erskine's Avatar
Quoted: 64 Post(s)
Liked: 101
12 to 14 people is 6000 to 7000 BTU's of cooling ... electrical, HVAC, sound isolation and full construction prints are needed for your contractor or architect at this stage or you're likely going to face compromises, or additional expense, later that could have been avoided by earlier planning.
Dennis Erskine CFI, CFII, MEI
Architectural Acoustics
Subject Matter Expert
CEDIA Board of Directors
www.erskine-group.com
Dennis Erskine is offline
post #8 of 13 Old 11-15-2011, 08:21 PM - Thread Starter
esabet's Avatar
First, thank you all for great feedbacks.
I understand how complex this could get and advanced planning would certainly be of GREAT value and that is why I am here. But the Cellar layout (including the Theater Room) is a project that we intend to complete a couple of years after the house construction has completed (unless we have sufficient budget left at the end of the house construction). If the intention was to do it right away I would have certainly invested the $600 and use the Pro Layout Service, no questions asked.
The reason that I am looking into this at this stage of the game is to make the necessary preparations. Perhaps I can eliminate a structural column should it prove necessary as almost anything is possible at this stage. I also intend to create the steps by pouring the foundation slab in a "stepped" manner at the location where the future theater room will be located!! The Cellar ceiling height is going to be between 10 to 9 feet, depending on if any soffit work (for mechanical an plumbing reasons) becomes necessary. So by stepping the slab I can avoid losing precious ceiling height in the Theater.
So, to say the least I can appreciate the complexity!!
esabet is offline
post #9 of 13 Old 11-15-2011, 08:25 PM
Liked: 68
Personally, I would really avoid that - you change your mind on seating style, requiring different riser depth(s), and you're stuck with it.
post #10 of 13 Old 11-15-2011, 08:56 PM - Thread Starter
esabet's Avatar
I did think about that but then assuming the ceiling height is 9 feet then with two steps, assuming each step is about 10", then we are at almost 7 feet only at the rear. Is that ok?
esabet is offline
post #11 of 13 Old 11-15-2011, 09:21 PM
Liked: 2757
I would only consider pouring a stepped down floor if I had a professionally designed plan that you liked and are willing to stick to it, There have been plenty of guys showing up in this forum with something they developed with the advice of their builder/architect and it was basically flat out wrong.
Dennis could help you.
The best solution is to just lower the entire floor in the theater space and build risers as part of the theater construction.
post #12 of 13 Old 11-15-2011, 09:27 PM
Mike Garrett's Avatar
Quoted: 5643 Post(s)
Liked: 3612
I agree with the others. You need a full plan before you barrel ahead. Give us a call if you want to talk about the pro Design Service. It would be money well spent.
mjgarrett100@gmail.com
Mike Garrett is online now
post #13 of 13 Old 11-15-2011, 09:42 PM - Thread Starter
esabet's Avatar
It seems that it would be wise!! What are the hours (Eatern Standard Time)?
esabet is offline
