Looking for passive speaker on off switch - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 12-05-2011, 11:53 AM - Thread Starter
kstyv's Avatar
I would like to install a switch in the middle of a run of 14 gauge speaker wire (passive) so that I can shut off the sound to one specific speaker (center). My receiver (RX-V663) does not have the ability to do this.
Anyone seen such a switch, would prefer something as small as possible.
kstyv is offline
post #2 of 12 Old 12-05-2011, 01:42 PM
HDvids4all's Avatar
What's the purpose?
Can't you use banana plugs or something at the receiver, and just unplug the speaker from there?
HDvids4all is offline
post #3 of 12 Old 12-05-2011, 01:57 PM
Suntan's Avatar
Quoted: 75 Post(s)
Liked: 107
1) Snip one of the two copper strands going to the speaker where you want to install the switch.
2) Install one of these where you made the cut.
Undo step 2 when you want to turn the speaker off.
http://www.homedepot.com/webapp/wcs/...74&R=202894274
-Suntan
Suntan is offline
post #4 of 12 Old 12-05-2011, 02:44 PM - Thread Starter
kstyv's Avatar
Purpose is to mute the commentators for sports while keeping all surround arena sounds.
Receiver is installed in a closet and the back is inaccessible.
@Suntan your wirenut comment belongs in the "general home theater" forum.
This is the "dedicated theater design and construction" where exposed wires and cheap shortcuts are banned
kstyv is offline
post #5 of 12 Old 12-05-2011, 02:56 PM
NJ Jackals's Avatar
There are plenty of speaker wall control options available. If you don't want the variable dial control, you could always use an A-B switch but only Hook up A and leave B empty which would mimic off.
http://www.smarthome.com/_/Speakers_....aspx?Ns=Price
NJ Jackals is offline
post #6 of 12 Old 12-05-2011, 03:03 PM - Thread Starter
kstyv's Avatar
Oh sorry, I forgot to say I am not looking for a wall switch. Just looking for a small toggle that I can basically mount semi-hidden inside the TV cabinet near the center speaker.
kstyv is offline
post #7 of 12 Old 12-05-2011, 03:06 PM
HDvids4all's Avatar
Just use Suntan's idea with a small toggle switch then. You can pick them up at Radio Shack or similar.
post #8 of 12 Old 12-05-2011, 03:13 PM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 777
Or an A/B speaker selector, with nothing hooked to "B"...
jautor is online now
post #9 of 12 Old 12-05-2011, 03:24 PM
NJ Jackals's Avatar
Yup. That's all you need then. I used the same exact switch under the driver side footwell to toggle my bmw twin turbo ecu map from boost mode to 'valet' mode.
Great idea!
post #10 of 12 Old 12-05-2011, 03:52 PM - Thread Starter
kstyv's Avatar
Looks like the toggle would work the best, think there would be much signal loss?
How would you wire one of these to a single speaker, it looks like there are 3 posts, would I need one switch for each wire or just one. If just one would it matter which wire I attached it to? (ex. red, black)
kstyv is offline
post #11 of 12 Old 12-05-2011, 06:17 PM
scl23enn4m3's Avatar
Just one switch. Pick either the red or black wire and stay consistant. Just connect both of the wires (1 from the amp and 1 to the speaker) to two adjacent poles on the switch. That means either use the middle and the left outside pole, or the middle and right outside pole.
scl23enn4m3 is offline
post #12 of 12 Old 01-16-2012, 10:21 PM - Thread Starter
kstyv's Avatar
I ended up using this switch
http://www.radioshack.com/product/in...rodsPerPage=60
just used some double sided foam tape to hold it out of sight up in a corner of the TV stand. Works awesome.
Goodbye Joe Buck!
kstyv is offline
