VELVET CLOTH for screen side wall and front ceiling - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 12Likes
post #61 of 79 Old 09-26-2016, 08:00 AM
Quoted: 34 Post(s)
Liked: 1
looks like a birds eye view of the corner. stone floor and baseboards, the wall looks more like a plaster on concrete.
Lets review your options
1) glue fabric to the uneven wall
2) attach fabric to some kind of flexible panel backing and attach the panel to the wall. Might be easier to use several slim panels rather than one big one.
3) attach the fabric to rigid 8-10 inch wide panels and arrange them in the corner approximating the curve.
4) hang the fabric like draperies in curve
5) have draperies made for the curve.
Originally Posted by Renron View Post
Thanks Jeff,
Usually I can visualize things pretty well , experience as a contractor. This one puzzled me, it did a 3D flip and I just couldn't see it until you pointed out the baseboard. Got it.
I have seen a similar case where a custom curtain rod was bent to the corner radius and suspended from the ceiling. Many ways to attach the fabric to the rod. All of your suggestions are also logical.
I enjoy these threads and quite often learn / see things from a different angle. No pun intended.
Ron
thanks jeff for your suggestions
i feel like gluing the fabric would be the best option for me, but im not sure how. I found out that liquid starch migh be an option but im not sure.
the panels might be my second choice. not too sure about to draping because theres a split ac in the room and im afraid that it might move the draping from side to side while on. I will probably be doing this myself, and im looking for the least number of elements needed as well as the most professional looking.
@Renron , i forgot to send the second pic showing exactly what i was taking a picture of. But, i guess you learned something from it .
suggestions?
azizk5 is online now
post #62 of 79 Old 09-26-2016, 08:42 AM
Spyderturbo007's Avatar
Quoted: 133 Post(s)
Liked: 40
I was considering using the thinnest MDF I can and wrapping that in velvet for my side walls and ceiling. I'm wondering if it would be better to build frames, fill them with OC703 and the wrap them in velvet. Would that be worthless since the velvet isn't acoustically transparent? I remember reading where someone said it didn't matter, but I can't seem to find the post, nor do I know if it's true.
I was thinking of gluing the velvet to the wall, but I'm guessing it would be better to have something that helps with sound absorption if possible. It appears as though gluing is the easiest, but does the most damage if it ever needs to be removed. I'm guessing the question is if it would ever need to be removed? I suspect that if I wanted to do something different to the walls and ceiling, the velvet could just be covered up?
Spyderturbo007 is offline
post #63 of 79 Old 09-26-2016, 11:46 AM
Quoted: 3255 Post(s)
Liked: 2743
If velvet isn't acoustically transparent we could soundproof rooms by hanging it on the walls. It does exact a toll on the sound passing through but it does pass some sound. You wouldn't want it in front of speakers. All velvets are not created equal, Triple Velvet from Syfabrics IMHO is the worst as you can't breathe through it. But it is cheap if you have lots of walls to cover. There are velvets acoustically transparent enough to be used for screen masking and placed in front of speakers.
post #64 of 79 Old 10-04-2016, 06:04 AM
Liked: 0
Hello,
I am a litte bit overstrained in choosing the right cloth for my purpose.
I would like to use black velvet for curtains on the side walls and the ceiling to blacken out my home cinema room.
The curtains will not overlap any speakers - only absorbers.
So to sum it up I need a fabric which I can use for curtains to darken the room when watching a movie and which is not influencing the acoustic, i.e. deadening the high tones too much.
Which cloth do you recommend for that?
I read about the fidelio in this thread. Do you know a seller which is also shipping to germany?
Thanks and best regards,
justkidding
Justkidding is offline
post #65 of 79 Old 10-27-2016, 02:22 PM
COACH2369's Avatar
Quoted: 801 Post(s)
Liked: 673
I stumbled upon this thread when doing some researching on how to cover my walls with velvet.
My screen wall is covered by a very black velvet and looks great.
I have decided I want to have all my walls matching and create a clean look with velvet. My plan is to attach the velvet to a board at the top of the ceiling and create a "wall of curtains". What I didn't take into account is how it would effect my current room treatments, which are all absorber panels. I am planning on adding some diffusers, so that has me worried on what to do.
Originally I was going to buy a bunch of velvet curtains and hang them. Then a fellow forum member advised me that those would be too thick, so I started looking at bulk velvet material. Today I stopped into Joanns and picked up a sample of a stretch velvet that was on sale. I also had some leftover scrap material from the screen wall, so I hung both to compare. The material from screen wall is as black as night...
I have attached a few pictures to show the differences. The only thing is, the velvet that matches my screen wall is almost twice the price as the other. Since I need approximately 50 yards to finish the project, that is a huge difference.
After reading through the thread, I found the Sy Fabric triple velvet. It looks almost identical to the stuff I have on my screen wall from Joann's.
I am looking for a little guidance/opinions from those that have more experience with this.
ID:	1738945   Click image for larger version
ID:	1738953   Click image for larger version
COACH2369 is offline
post #66 of 79 Old 10-31-2016, 06:27 AM
Quoted: 133 Post(s)
Liked: 40
I might be able to help a little as I'm just getting started on wall treatments. I picked up 20 yards of the JoAnn Royal 3 Velvet for about $10/yard, so it wasn't terrible. I'm planning on doing the walls and ceilings from the screen wall to the first column. The plan is to build the fabric frames on the wall using 1" x 1.75" furring strips I ripped from a piece of 1" plywood. I can then stretch the fabric over the frames and hide the staples at the top and bottom with crown and base molding.
You might be able to do something like that and then sit your treatments on top of the fabric. You would just need to know where they go so you could put in a nailer. I'm going to try something similar to hand my movie poster treatments on top of the fabric wall.
Not sure if that helps or not...
post #67 of 79 Old 10-31-2016, 12:13 PM
COACH2369's Avatar
Quoted: 801 Post(s)
Liked: 673
Appreciate the information. By any chance do you have the style number on the velvet from JoAnn or a picture of it?
post #68 of 79 Old 10-31-2016, 06:01 PM
ArmyMan's Avatar
Quoted: 39 Post(s)
JoAnn's
Got a flyer this weekend with coupons for JoAnn's.
40% off 10/30 - 11/5
50% off 10/30 - 11/2
Both good in store and online.
Includes one cut of by-the-yard fabric.
Paul
ArmyMan is offline
post #69 of 79 Old 11-01-2016, 05:58 AM
Quoted: 133 Post(s)
Liked: 40
Here is what I purchased.
http://www.joann.com/royalty-3-velve...Velvet&start=1
I would recommend signing up for their mailing list. They send out coupons every morning for between 40 - 60% off. They honor them for one cut of an item. When I bought my 20 yards, even though it comes in 10 yard bolts, they considered the entire 20 yards one item for the coupon.
arcticbowman likes this.
post #70 of 79 Old 11-04-2016, 12:44 PM
Quoted: 156 Post(s)
I found black velvet at my local store here in Canada (for covering walls via velvet curtain) but it is a tad shinny. Would this in anyway be a problem for light reflection?
busybe is offline
post #71 of 79 Old 11-04-2016, 01:23 PM
COACH2369's Avatar
Quoted: 801 Post(s)
Liked: 673
Thank you!
A fellow AVS'er let me come by his place and see his room earlier this week. He used the same velvet in the link and it looked great. Then he gave me some samples to try out and it will work perfectly for what I want to do. I am still waiting on a sample from SyFabrics since there product is priced much lower without having to get a coupon....but if it isn't as nice as what JoAnn's has, I will get this stuff.
post #72 of 79 Old 11-07-2016, 06:24 AM
Quoted: 133 Post(s)
Liked: 40
Has anyone had any experience building frames and putting velvet on the ceiling? Does it sag after time?
My screen wall is under a soffit, giving me about 8" above the screen and about 12" below the screen. My plan was to wrap the side walls and ceiling in black velvet so I didn't have to worry about reflections from the screen. I can figure out how to do the walls and can build panels for the ceiling, but I was concerned about sag.
post #73 of 79 Old 11-07-2016, 08:11 AM
Liked: 2743
I have a big black GOM FR701 panel on the ceiling over my screen it hasn't sagged in 10 years, I suggest you pick one of the stretch velvets and start by making it taut.
This was the beast of a fabric frame I put on my ceiling. I stuffed all the sections with Linacoustic. It is fixed in place with two screws along the back edge and liquid nails.
post #74 of 79 Old 11-09-2016, 11:05 PM
Liked: 1
Hello all,
I tried the premier velvet from joanns as someone in the thread suggested. I went with a 2 yard sample. I wanted to use it on the screenwall.
so I just want to make sure I understand it its purpose. this fabric main goal is to absorb light.
I put it over my screen in an attempt just to see how much light it reflects or absorbs. I was under the impression I would see nothing no picture.. I could still see the projected image it was just dark. Is this velvet supposed to completely block out the picture from showing. Or the main reason is for like masking so that the black bars in movies
look real dark and to help light reflections across the room (ambient light)?
projector is an Epson 6020ub
runco anamorphic lens
138 in curved silver ticket screen 2:35.1
21 ft throw distance to screen.
nigwhyritos is offline
post #75 of 79 Old 11-10-2016, 04:36 AM
MysticalJet's Avatar
Quoted: 81 Post(s)
Liked: 151
Originally Posted by nigwhyritos View Post
Hello all,
Hey - I don't know of any fabric that will absorb 100% light, so yes if you have the main picture on the fabric (very bright scenes) you will see it (although not very well). Yes it will "absorb" the black bars and you won't see them, and reflections will be much, much, less than a painted black wall or plain wall, or any other color wall or fabric. It helps absorb ambient light as well. The biggest gain is perceived contrast of the picture.
MysticalJet is offline
post #76 of 79 Old 11-21-2016, 03:19 PM
COACH2369's Avatar
Quoted: 801 Post(s)
Liked: 673
I received my swatches from SYFabrics today for the Black Plush Triple Velvet.
When I compared it to the Royalty 3 Velvet from Jo-Ann's, it looks like it could be the same thing..
This is good because the cost of the velvet from SYFabrics is significantly lower than Jo-Ann's...and I don't have to hunt it or the coupons down.
I'm going to have my wife look at it and see if she thinks the same thing....then order accordingly.
EDIT: JoAnn's appears to have there Royalty 3 on sale for $9.99 per yard with another 30% off, but it isn't available online and the stock is limited in the stores..
post #77 of 79 Old 01-12-2017, 04:09 AM
DaveN's Avatar
Quoted: 66 Post(s)
I have used both and F is not worth the extra $ unless you are looking for some degree of accoustical transparancy and Triple Velvet is not as transparent.
Check back with me next week as I have been ordering samples from various online sources.
Also FYI, Joannes often has a 50% off one item coupons and I will pop into the store to see what velvets they have in stock, It does change and sometimes they have something that I really like at a good price, last week they did not.
I know that it has been more than a week but what is your current thinking regarding Fidelio/Syfabric/Triple Velvet cost no object vs value?
DaveN is offline
post #78 of 79 Old 01-29-2017, 08:59 PM
dmfreck's Avatar
I have been placing Joann's Premiere Velvet on the front wall of my home theater and it's been great. Absolutely pitch black. I added some extra "flair" by artificially creating vertical 2 inch folds every 5 inches of material. Tough to see in the picture, of course, because of how light-absorbent the material is.
Pardon the mess, btw. It's still a work in progress. I took my fixed frame screen down, too, so I could run the fabric slightly behind it before re-mounting.
dmfreck is offline
post #79 of 79 Old 02-07-2017, 10:28 AM
Liked: 8
Wow, those folds came out looking really nice!
I'm considering picking up some Premier Velvet from Joanne Fabrics, but I'm still not sure if it's going to be absorbent enough for my needs.
I have 124" 2.39:1 AT Spandex screen that's 114" wide. I'm doing a constant image height setup with a 48" tall screen. Most of my sources are set up such that they will automatically adjust 16:9 content down to the right height, but my Blu-Ray player will not. Now I can manually zoom the projector out (digitally, not optically, no motorized lens) but I would also like to be able to just project the 16:9 image and absorb the 8" above and below of extra image content.
My room is well light controlled with black felt on the ceiling and side walls for 2 feet or so. The sides of the screen are matte black milliskin AT spandex.
I guess the question is whether ANY velvet will be enough to absorb like I'm hoping for. I suppose that dictates: "Get the Fidelio", but I'll need about 3 yards and that $30/yd price tag hurts when I'm just buying fabric. Haha.
I could get a Harmony Hub for that price.
kodyaudette is offline
