My "Out of Africa" theater is "FINISHED" - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 6Likes
post #91 of 482 Old 01-16-2012, 06:35 AM - Thread Starter
Bobbejaan's Avatar
Thanx RT. It sounds very loud but I hope it will quiet down when everything is covered in fabric and accustic panels is in place. Anyway it'll only work once at the beginning of the movie so it won't be too bad I think
The panels is only controlled with the remote for now. I'll put on the microswitches when the panels is covered with velvet.
I'm glad you like it RT!
Bobbejaan is offline
post #92 of 482 Old 01-16-2012, 06:48 AM
calimark's Avatar
Originally Posted by Bobbejaan View Post
You've asked for it, you got it!
http://youtu.be/128vITyKL-A
Please excuse the poor quality of the clip. I was so excited to see it work so I just snapped the vid with my phone ( will post a better video later) to show you guys!
Dude, That is PIMP! I definitly am curious to see more details.
calimark is offline
post #93 of 482 Old 01-16-2012, 07:02 AM - Thread Starter
Bobbejaan's Avatar
Thank you calimark.
I'll post more details as we go along.
post #94 of 482 Old 01-16-2012, 08:00 AM
stockmonkey2000's Avatar
Liked: 30
Very cool. Nice work on the masking.
stockmonkey2000 is offline
post #95 of 482 Old 01-16-2012, 08:20 AM - Thread Starter
Bobbejaan's Avatar
Thank you stockmonkey, much appreciated.
post #96 of 482 Old 01-17-2012, 03:33 AM - Thread Starter
Bobbejaan's Avatar
Here's a couple of pics to show how i've screwed a piece of wood to the back of the frame where the screen material will be stapled to.
Now that the masking system is working and all the big construction work is about finished for now, it feels like I'm going into a state of not knowing what to do next. Kind of an anti-climax perhaps.
post #97 of 482 Old 01-17-2012, 06:44 AM - Thread Starter
Bobbejaan's Avatar
I see there's something done that I have'nt posted the pics of yet. Here is the front left and right columns in place. You'll note that they are basically the same shape as the rest of the columns, but only a bit narrower as to not overpower the stage and screenwall. Also their grilles will be on a 45 deg angle angled towards the screen - something like this [/ \\] to "pull" the eyes toward the screen.
And here's a shot of the whole screenwall as it looks with columns.
post #98 of 482 Old 01-27-2012, 04:39 PM
RTROSE's Avatar
Quoted: 195 Post(s)
Liked: 169
I have heard of the pj being hung and the progress stops. Not the masking system though. Looking for some updates and more killer progress.
RTROSE
RTROSE is offline
post #99 of 482 Old 01-27-2012, 05:20 PM
Liked: 30
I think the photos may have now caught up with the actual build.
post #100 of 482 Old 01-30-2012, 02:26 AM - Thread Starter
Bobbejaan's Avatar
Hi Stockmonkey, the pics have caught up a long time ago with the build! I had to do some other stuff this past few days, but have done a few things since then in the HT - will post pics soon!
RT, it's weird but yes, I sometimes just sit in the HT on the riser and watch the masking opening and closing (just to make sure it still works! )
post #101 of 482 Old 01-30-2012, 02:55 AM - Thread Starter
Bobbejaan's Avatar
I got a nice surprize this morning when I arrived at work this morning. My LED downlights have arrived. There's 15 of them - 3w 220v dimmable 3 led. The sales lady said they were equivelent to 40W halogen lights in brightness. I opt for the warm white ones since I don't like the white light that LEDS usually cast. I'll check them out tonight as soon as I get home.
post #102 of 482 Old 01-30-2012, 03:30 AM - Thread Starter
Bobbejaan's Avatar
I've installed the step-lights on the steps. They are also LEDs. I devised a plan to easily retrieve the wires after the carpet is laid over the holes. I took a piece of black hard plastic pipe and screwed 2 deck screws next to each other at the one end and into the step. (The pics will explain better) The wire goes in between the 2 screws and the connector block prevents it from pulling back into the step. After the carpet is laid I'll just cut a hole into it and find the wires in the pipe
Here's one of the light connected to the wires with the connector block.
And finally installed, albeit temporarily till the carpet comes ONE DAY.
And it's WORKING!!
And with lights off:
post #103 of 482 Old 01-30-2012, 03:51 AM - Thread Starter
Bobbejaan's Avatar
Oh yesssss, and another thing, while we're on the subject of me doing NOTHING and being idle and work catching up to pics and .............
Just to proof you wrong, ..................some more pics!!
Here I put up the styrofoam ceiling panels to cover the ugly nutec ceiling between the soffit and where the star ceiling will go, and also, you've guessed it ....... styrofoam cornice. Yes you've read correctly STYROFOAM. It seems here in SA we don't care much about safety and combustable building materials. If there were a fire, God forbid, the ceiling will be gone in a FLASH but luckily my brick walls will still stand
And a close-up of the tiles and pattern on it.
I'm not sure if I should paint the woodgrain pattern or leave it as is. I think there must be a light colour for the strip lights to reflect of, not so? What do you guys think? I'm thinking of leaving it as is and keep the side of the soffit white as well. I don't think there will be much reflecting from the screen since it wil be in an "alcove".
post #104 of 482 Old 01-30-2012, 07:02 AM
Quoted: 3902 Post(s)
Liked: 3336
IMHO the only thing that should be white in a theater is your underwear.
post #105 of 482 Old 01-30-2012, 07:43 AM - Thread Starter
Bobbejaan's Avatar
BiG, what colour do you think will work good enough to show off the colours of the strip light but also look nice with my black and red theme?
post #106 of 482 Old 01-31-2012, 03:43 AM - Thread Starter
Bobbejaan's Avatar
The soffits is painted with wood primer and the screenwall with black paint.
Another thing done is the fixing of MDF strips to the walls to secure the columns to once they're covered with fabric. I just stuck them down with with liquid nails and drilled holes for anchor plugs, but the liquid nails is SO STRONG that I doubt that I'll use the anchor screws.
It is NOT nice to haul every column out of the room by oneself
I took them all to the garage to remove about 2cm from the top of each column to make it easier to put in place once the fabric in pulled over. I also used a sander to smooth over all the rough edges in prep for the "fabrication".
Here's one of all the MDF strips stuck to the walls. Sorry for out of focus pic.
Here's the fresh air inlet in the back corner ontop of the riser - there's another one in the opposite corner.
Finally, all columns back in their spaces and the room cleaned out. From now on all cutting, sanding and dirty jobs will be done in the garage and not in the room any more. Fabric and dust don't go well together (hope I can keep the place clean)
PS. I Love This Hobby
post #107 of 482 Old 01-31-2012, 05:58 AM
Liked: 3336
You are making great progress with some very interesting details. That masking system looks pretty slick. One item I'm not convinced is going to work well for you is the white on the soffits particularly over the screen. This month I seem to be on a stamp out white campaign telling other forum members that the only white in a theater should be their underwear.
post #108 of 482 Old 01-31-2012, 07:05 AM - Thread Starter
Bobbejaan's Avatar
Oh no , all that white paint is just an undercoat/woodprimer. The area under soffit above screen will be very truly BLACK as can be, as well as all the other undersides of the soffits.
post #109 of 482 Old 01-31-2012, 07:32 AM
Liked: 3336
Presented as evidence that I didn't make this up
post #110 of 482 Old 01-31-2012, 07:52 AM - Thread Starter
Bobbejaan's Avatar
To quote myself:
I was just thinking of the side of the soffit and the section of styrofoam tiles above it, to be white/lighter to reflect the light form the strip light in the crownmoulding that will be put around the perimmiter of the soffit. I don't really want it to be white but don't know what other colour wil show off the different colours of the strip light
Sorry if it caused any confusion
post #111 of 482 Old 01-31-2012, 01:24 PM
seigneur_rayden's Avatar
Big, that cracked me up so hard at work.
Bobbejaan, you are advancing very well and it is looking very promising. I love the masking gig. Keep it up!!!
seigneur_rayden is offline
post #112 of 482 Old 01-31-2012, 04:17 PM
RTROSE's Avatar
Quoted: 195 Post(s)
Liked: 169
Excellent progress. Glad to see you and Big worked it out. I can't say anything about white in the theater as I have white trim and chair rail. However my ceiling and screen wall are a very dark blue and I have darker colors on the walls. Just so you know it is "OK" to have some white in your theater besides your fruit of the looms. Just have to know where to put it!
Keep up the progress and pics. Nice to see that you finally tore yourself away from the motorized making to do some "real" work.
RTROSE
RTROSE is offline
post #113 of 482 Old 01-31-2012, 05:16 PM
Liked: 3336
I don't really want it to be white but don't know what other color will show off the different colours of the strip light
I was wondering about Milano Blue. A color that has been used by a lot of guys. There are a bunch of threads that talk about it. It goes from blue to gray as the lights dim. I'm looking for a picture.
found some here:http://www.cinemamurray.com/Cinema_M...e/Welcome.html
post #114 of 482 Old 01-31-2012, 11:57 PM - Thread Starter
Bobbejaan's Avatar
Thank you very much guys. This thread kinda works like a weight-watchers or weight-less program in the sense that it keeps me working 'cause there's folks checking up on my progress
Thanks Big, I'll see if I can find something simmilar in SA.
post #115 of 482 Old 02-03-2012, 12:08 AM - Thread Starter
Bobbejaan's Avatar
Some progess.
I've been busy with the downlights and their panels. Here's some pics of the downlights all wired up and ready for the panels.
And here they are working.
This is the downlight holders that I got. The 8 under the soffits is square and satin chrome, while the 4 under the proscenium is round and gun metal colour.
The pieces of the frames is cut form MDF and ready for assembly. There is 6 long ones and 2 smaller ones.
Here's the first two being clamped:
And here's the two mini-me's in a thight situation!
After whatching glue dry for a while, eventually all frames are ready for the next step.
All the frames will be covered with black velvet at a later time. For now I put the holders and the lights in - I'm very happy with the results
I've angled the lights towards to wall so that they'll light up the wall panels later.
And a closeup in the dark.
The lights illuminate the room quite nicely now, but I think it will look much darker when about everthing in the room is black and the only other colour will be the red panels. I hope it's not too dark. The reflection of the light from the proscenium downlights on the screen will also light up the place better I think.
post #116 of 482 Old 02-03-2012, 12:34 AM
Dingaling2004's Avatar
Quoted: 33 Post(s)
Liked: 39
Looking great Will,
Powering ahead! Lights look really good. You'll be on the home stretch before you know it!
Cheers
Greg.
Follow my thread here
Dingaling2004 is offline
post #117 of 482 Old 02-03-2012, 12:36 AM
Quoted: 33 Post(s)
Liked: 39
Originally Posted by Dingaling2004 View Post
Looking great Will,
Cheers
Greg.
PS am I mistaken or is your handle the Afrikaans word for monkey / baboon????
post #118 of 482 Old 02-03-2012, 12:56 AM - Thread Starter
Bobbejaan's Avatar
Thanx Greg,
Yep Bobbejaan = Baboon
That's me.
Do you know Afrikaans or Afrikaans people. MANY (more than 1 million) Afrikaans speaking white people has left the country in the last decade or two since the new government came to power. Most of those folks went to Aus or New Zealand so it's possible that you may know someone from here.
post #119 of 482 Old 02-03-2012, 01:20 AM
RensMond's Avatar
Will, where did you get the ceiling panels?
I have almost the same setup around the star ceiling, but I'm thinking of replacing the panels I used.
Johan
There's always something!!!
RensMond is offline
post #120 of 482 Old 02-03-2012, 01:22 AM
Quoted: 33 Post(s)
Liked: 39
Thanx Greg,
That's me.
Hi will,
I'm not Afrikaans but I did date a girl once in my shady past from South Africa. I do distinctly recall she called me Bobbeejaan on more than a few occasions. All in good humor however! We have a our share of South Africans here in Oz. Always handy around cricket and rugby seasons! Go the wallabies!
