Redskinema - Nearing completion! - Page 18 - AVS Forum | Home Theater Discussions And Reviews
post #511 of 606 Old 08-01-2013, 07:46 PM
jedimastergrant's Avatar
Quoted: 411 Post(s)
Liked: 190
Yes I bought the porter cable us58.
The cheapest extra long handles I found are from Emtek. They are not cheap though at more than $100. I have thought about just buying the regular width and splicing it. I would think the metal should be easily sourced and then you just need to spot weld it together. My dad is a much better welder than me so I would ask him to do it. Still looking into it.
http://emtek.com
Sunflower State Cinema -Now with JTR 212 HT's
FS: JVC RS45 bought new from AVS (PM me)
jedimastergrant is online now
post #512 of 606 Old 08-02-2013, 07:30 AM - Thread Starter
SKINSnCANES's Avatar
Carpet is half in!! Now for the tricky parts. Looking great so far!
Ill post the 200 pics I've taken later....
SKINSnCANES is offline
post #513 of 606 Old 08-02-2013, 10:30 AM
NGiovas's Avatar
Liked: 43
I saw the first sentence and got all excited.  Then I logged in and saw the second sentence and was disappointed.   No pictures mad.gif.
NGiovas is offline
post #514 of 606 Old 08-02-2013, 10:31 AM
J_P_A's Avatar
Quoted: 569 Post(s)
Liked: 427
Great news on the carpet! Carpet has a huge visual impact!
The Plains Theater Has Begun
J_P_A is offline
post #515 of 606 Old 08-02-2013, 10:40 AM
ScAndal's Avatar
Liked: 27
WOW biggest tease ever! Congrats and can't wait to see this milestone.
ScAndal is offline
post #516 of 606 Old 08-02-2013, 11:12 AM - Thread Starter
I told the guy I need a crew for "the day" and they've been bitching it doesn't an hour lol
post #517 of 606 Old 08-02-2013, 11:18 AM - Thread Starter
I also told them to come look at the job first, or I'd send pictures... But he was confident in his price. His workers apparently don't agree! How do you tip when the workers said the job was bid 20% of what it should cost?!
post #518 of 606 Old 08-02-2013, 11:22 AM
wraunch's Avatar
Quoted: 119 Post(s)
Liked: 39
where are the pics!?!?!?
wraunch is offline
post #519 of 606 Old 08-02-2013, 12:12 PM - Thread Starter
Finished!
The pics are....on my phone lol. Ill post them soon I promise
post #520 of 606 Old 08-02-2013, 12:33 PM - Thread Starter
Finished!
Pictures are uploading! dont leave your computers!
not 200 though...
post #521 of 606 Old 08-02-2013, 12:57 PM - Thread Starter
Ok here are the pics!
First putting down the tac strip and pads
Prepping the carpet
and completed pad
post #522 of 606 Old 08-02-2013, 01:09 PM - Thread Starter
They put the middle piece down first, as you can see in the picture. They misaligned and cut a few things but it worked out in the end.
I originally put a few pieces of trim down in the beginning, it didnt present any issues. And it worked better that there was no trim for some of the other areas. Ill put all the trim later
I wanted them to to the stage first to make sure that was perfect
They then realized they did a horrible cut and the stage needed to have seams. So they moved onto the back steps. Because of the angle there is a lot of cuts on this and patches but it came out pretty good. You cant see the seams but if you look close you can see where you cant perfectly match. At this point were starting to go crazy looking at the pattern but when you stand back it all looks great
Heres their bad cut that would later need to be seamed on teh stage. Again, they just moved to the riser at this point.
The front was aligned and the seam put in
post #523 of 606 Old 08-02-2013, 01:17 PM - Thread Starter
And the final pics!
Because of that bad cut the left side of the stage is a 2 inch wide seams, made out of like 8 inch long pieces. So its like 5 pieces but it still came out fine. You cant really tell
The riser
The a$$holes thought you could lean against anything with their elbow! Now I have to fix my one completed column! It was the thing stick where the speaker points
Stage
From the door
This is stage corner column. If you remember I had 3/4inch wood under it to allow it to be removed. I painted them black last night and you cant even tell its there
post #524 of 606 Old 08-02-2013, 01:20 PM - Thread Starter
Here are pics with the front columns put back in. The room still needs to be vacuumed because they apparently dont do that... Some of these pics are blurry but you get the point! Im excited about todays progress. And were very motivated to keep going now!
post #525 of 606 Old 08-02-2013, 01:48 PM
ScAndal's Avatar
Liked: 27
ScAndal is offline
post #526 of 606 Old 08-02-2013, 06:02 PM - Thread Starter
Originally Posted by ScAndal View Post
Thanks! Its getting there. I had to vac the carpet up, it had so much debris and dust on it. Its crazy that I thought my paint was pure black and so dark, yet the carpet is a darker black. That or its just because its less flat.
On another note, we were motivated and kept going. We did four more columns and fixed the broken one. Pics uploading now smile.gif
post #527 of 606 Old 08-02-2013, 06:08 PM - Thread Starter
Here pics of the back with all the columns wrapped in fabric.
I fixed the column that carpet guy broke. Also, I wired in the two wide speakers. The only speakers that arent in right now are the second sub, and the left/right channel speakers. I have to build two boxes to elevate them ten inches (sunday!)
The other front column
post #528 of 606 Old 08-02-2013, 06:11 PM - Thread Starter
Final pics for day of the THEATER! with CARPET! and COLUMNS!
post #529 of 606 Old 08-02-2013, 06:22 PM
J_P_A's Avatar
Quoted: 569 Post(s)
Liked: 427
Carpet looks AMAZING! Awesome progress.
J_P_A is offline
post #530 of 606 Old 08-03-2013, 08:43 AM
ScAndal's Avatar
Liked: 27
Simply stunning. What a great looking room. I bet its crazy to look back earlier in the thread and remember the different stages and how far you've come.
This is one of the cool things about documenting a build, IMO.
ScAndal is offline
post #531 of 606 Old 08-03-2013, 08:57 AM
NYGIANTSFAN23's Avatar
Liked: 39
I know all about nearing the end. Just wrapped up my space yesterday. I few odds and ends left but the bulk is done. I love that carpet and the color scheme. The smell of new carpet puts me on cloud 9. Your space is nice and really elegant..
NYGIANTSFAN23 is offline
post #532 of 606 Old 08-03-2013, 12:32 PM - Thread Starter
Thanks! And yup every time I look through the thread, I'm amazed how far its come. Walking downstairs today and seeing carpet hasnt set in yet. Its very real now!
post #533 of 606 Old 08-03-2013, 12:33 PM - Thread Starter
Dont worry I'll have the Giants on twice a year wink.gif It didnt actually turn out to look like redskins colors but at this point its like the name stuck.
post #534 of 606 Old 08-03-2013, 12:40 PM - Thread Starter
I went to Home Depot this morning and explored my options for shelving. I wanted an equipment rack but I think this is one of the areas I could save money. In the end I found some steel shelves that just fit my closet. I had to take a break to read some manuals so heres some quick pics. The equipment is going in and getting setup!!
I left a big gap in the bottom because thats where I crawl through to get to the back. Its pretty easy and I still have room to mostly stand in the back.
Also, our wiring idea of putting all the wires on a board, and having them be in the order they are on the receiver was clutch! It took two seconds to put all the speaker wires in!
First, heres the two new toys. The Denon 4520 and DBT3313 blu ray player with the Denon Link connection smile.gif
And here is the first batch of things that got thrown on the shelves.
Ok, im going back in the hole, time to keep wiring up everything
post #535 of 606 Old 08-03-2013, 03:33 PM
tlogan6797's Avatar
Quoted: 99 Post(s)
Liked: 123
GREAT room! Congrats!
Tom Logan
Need motivation? Get LOGANED
tlogan6797 is online now
post #536 of 606 Old 08-03-2013, 04:56 PM - Thread Starter
Tonys on the way over!! That means its time to make big progress!
I got all the electronics hooked up today. I have a little learning curve on the Denon 4520 and how to hook up another receiver to power the 10th and 11th channel. I had blu rays and tv shinning on the black wall with sound though.
Tonight I fix the fabric around the center channel and add the foam back, from having had it horizontally originally.
Build two ten inches boxes with sand to elevate the left and right channel speaker.
and...
wait for it..
PUT THE SCREEN TOGETHER!!!
Then tomorrow the cineslide!
Then...well lets be real we'll probably put in the first row of chairs. At some point you just gotta sit back and enjoy what you built smile.gif
post #537 of 606 Old 08-03-2013, 07:47 PM
NGiovas's Avatar
Liked: 43
Your room looks fantastic. I really like your carpet choice. Looks like they did a great job.
You'll be watching movies in no time. You will love the cineslide.
NGiovas is offline
post #538 of 606 Old 08-03-2013, 08:41 PM - Thread Starter
Screen frame is together! Not sleeping until the fabric is in!
post #539 of 606 Old 08-03-2013, 08:42 PM - Thread Starter
Actually im debating also putting in the chairs and sleeping in the theater lol
post #540 of 606 Old 08-03-2013, 11:21 PM - Thread Starter
It's 2 AM and I just hit PLAY on Transformers! Screens is up, cineslide up, and front row of chairs in. A few issues, and pics tomorrow. But for now Tony and I are having our first beer and watching a movie in my THEATER. I can't even describe it. It's so awesome.
Runco
