AKKR Theater - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 47 Old 11-30-2013, 06:23 AM - Thread Starter
ktm250rider's Avatar
Quoted: 18 Post(s)
Thanks, the key is to build temporary staging. I had planks set up so there was no up and down a ladder.
ktm250rider is offline
post #32 of 47 Old 11-30-2013, 07:01 AM
Mike Garrett's Avatar
Quoted: 7063 Post(s)
Liked: 4772
mjgarrett100@gmail.com
Mike Garrett is offline
post #33 of 47 Old 01-11-2014, 06:40 AM - Thread Starter
Quoted: 18 Post(s)
I thought with all the cold weather the riding would be perfect this weekend. Got the ice tires put on the 300 and was ready to hit the trails until i saw the torrential rains out the window. Well, I guess i can aim to finish my paneling. Got one wall section and one column section of MDF to finish. Then i can sand all the joints and move to the base, cap and panel insert molding. Of course i didnt account for my electrical outlets and had to pull them out .75" to fit with the panel insert. The top rail will be about 2" wide with a rounded edge. Oh, and then i can clean up this mess
post #34 of 47 Old 03-31-2014, 03:08 PM - Thread Starter
Quoted: 18 Post(s)
Major construction and trim work is done. I gotta figure out how to finish off the bottoms of the front columns. My two subs are tucked in there so the front needs to be removeable. I was hoping to build out the bottom of the columns similar to the others by using chair rail and trim. However, I have just enough room to fit a 120" 2.35 screen between the two speaker columns (124.5" total spacing). If I use any sort of trim to wrap around the corner to the screen, id have to drop down to a 115". This is based on screen frame sizes listed on the internets. Not sure what im gonna do and I keep putting it off to work on other stuff.
Current front speakers are old DIYs that sound OK but I plan on replacing them with a set of Fusions. I can fit Fusion 12's in the columns and an Alchemy MTM for the center. Just need to trim the openings for the L&R and build a support for the center.
As far as the paneling, ive decided to end it at the front column as shown. The blank space between the column and speakers will get a full length acoustic panel. The walls above the paneling will get frames and fabric. Thinking of going with a dark blue on the flats of the ceiling and keeping the trim/molding and coffer beams black. Walls would be similar blue and bottom paneling would be all black. Gonna try to pick out colors soon and get some painting done soon.
Current plan is for two rows of seats but all our friends think we are nuts building a theater. They just don't get it. So with the 4 of us, I keep thinking of adding a bar for the back row.
post #35 of 47 Old 04-02-2014, 10:49 AM
cw5billwade's Avatar
Quoted: 328 Post(s)
Liked: 184
I did a DIY Seymour Center Stage XD screen 126" wide x 64: high 2.0:1 constant image area. It wrapped around the frame and the grommets and bands are in the back. It would just be floating in your space perfect if you went that route. If the sides of cabinets and ceiling above were black that would look nice. You could fill the entire are with goodness. The constant image area gives you a larger 16x9 and 2.40:1 than if you picked either of the other formats. All for less than $650 counting my frame and minimalist wall. He is carrying the UV4k in DYI now as well
cw5billwade is offline
post #36 of 47 Old 04-10-2015, 04:34 PM - Thread Starter
Quoted: 18 Post(s)
Got a little work done over the winter (its still winter here in the north east). I think my camera is a little dirty. Got some painting touch ups to do. Front speaker cutouts have been resized for the third and final time I hope. Decided to go with a front setup of 1099's if I can ever catch them in stock. I painted the inside of my coffers a sky blue color. I should have gone with the stars as my original plan now that I see how it would have looked as in the Whit Oaks theater. After I showed the wife, she said "well you could always tear it down".
Carpet measurement is tomorrow! Gonna go with a simple dark color, no pattern.
So as far as video, I can fit a Falcon FS115 in either a 2.35 or 16:9. I have 125" between the two front columns. The 115 is 122" overall width. Original plan was 2.35 but know im thinking of the 16:9 because we will probably watch a lot of TV programing as well as sports events. I thought I changed my mind on speakers more until I got here.
As far as a projector, im really leaning towards the AE8000. For the price its at now, I almost cant wait to buy it. I wasn't planning on finishing the theater this year but I just might have to if I purchase the projector.
post #37 of 47 Old 04-10-2015, 08:38 PM
Maklar's Avatar
Quoted: 42 Post(s)
Looks great, I like your color choices.
Maklar is offline
post #38 of 47 Old 11-16-2015, 03:03 PM - Thread Starter
Quoted: 18 Post(s)
Getting an earlier start this year, maybe the finish line is in site. Dare I say Pats in the Superbowl!
Got my 3 1099s finished. They fit snuggly in their new home, and that was not a fun task getting them in there. Currently in carpet mode. We picked out a few samples and just by chance asked if they had any black for the front stage. They mentioned I should check the outlet next door. Im thinking what are the chances they'd have a piece of black, maybe scraps. Low and behold, I picked up a 6'x 15' piece, perfect for the front stage!
Next up, my 4 Volt 10s are due this week. Oh and ive decided to go with 4 Atmos ceiling speakers. Not sure how im going to get them in and wired since the ceiling is already finished. But hey, why not change again.
post #39 of 47 Old 11-16-2015, 03:15 PM
jimim's Avatar
Quoted: 499 Post(s)
Liked: 145
I just found ur build. Nice job man. I really like how it's looking. Very cool!
jimim is offline
post #40 of 47 Old 11-16-2015, 03:27 PM - Thread Starter
Quoted: 18 Post(s)
Oh, in all the excitement I forgot about this little gem. Picked it up off Amazon with Sunday delivery no less. Its going to power my 2 18" subs for the theater. Im not sure how to hook it up, must use some kind of new connection system.
post #41 of 47 Old 11-29-2015, 04:46 PM - Thread Starter
Quoted: 18 Post(s)
Wow, after missing the Black Friday sale for Jet clamps, I just thought of checking on sales for other equipment. Don't know why I didn't look sooner. Just picked up our Panasonic ae8000 from projector people.
post #42 of 47 Old 11-29-2015, 09:16 PM
NODES's Avatar
Quoted: 653 Post(s)
Liked: 273
was that a drone delivery?
Who needs 4K?... just go see your optometrist.
NODES is offline
post #43 of 47 Old 12-03-2015, 12:44 PM - Thread Starter
Quoted: 18 Post(s)
Got a delivery today!
Name:	projector arrives.jpg
post #44 of 47 Old 12-06-2015, 03:05 PM - Thread Starter
Quoted: 18 Post(s)
Played with the projector a little. Kids are all excited. Wanted to verify my mounting location. Bolted a 3/4 in plywood, 20x24" lag screwed to the strapping and framing. Then bolted the projector mount to the plywood. No screen so it's just projecting on the linacoustic. If I fill the gap between my columns I end with about about a 130" 16x9 screen. We are probably 50-50 between movies and tv/sports. That 130" sure makes our living room 65" tv look small!
Wife shot me down on building my own screen so I think I may be giving Falcon Screens a call tomorrow.
post #45 of 47 Old 12-06-2015, 04:04 PM
Quoted: 3897 Post(s)
Liked: 3331
ask for the AVS discount
post #46 of 47 Old 12-06-2015, 04:12 PM
eng-399's Avatar
Quoted: 1740 Post(s)
Liked: 2988
eng-399 is online now
post #47 of 47 Old 12-08-2015, 06:35 AM - Thread Starter
Quoted: 18 Post(s)
Yup, did that. Thought i was all set with the HD material but the quote included a price for the Horizon material. For some reason i didnt think that was AT. Do some more reading and now i have to decide which material. ARgghh, i was almost ready to purchase and yet another possible change!
