Type of paint for painting in wall speaker panel/grill - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 01-17-2012, 07:26 PM - Thread Starter
tvuong's Avatar
Quoted: 1544 Post(s)
Liked: 874
Guys,
I would like to paint my in-wall speaker panel/grill to match with my theater wall color, is there a special typre of paint for this or can I just use the same paint I paint my wall with? Thanks.
tvuong is online now
post #2 of 10 Old 01-17-2012, 08:10 PM
Quoted: 3255 Post(s)
Liked: 2743
You will thank yourself if you can find a can of spray paint in a matching color. Trying to use a latex wall paint will be frustrating and may clog the holes.
post #3 of 10 Old 01-17-2012, 08:39 PM
secondhander's Avatar
I have to do the same thing this week, here are the instructions with my speakers.
2nd last paragraph on page 1 has instructions for painting:
http://www.htd.com/core/media/media....88576&_xt=.pdf
Basically suggests a cheap spray gun and if it's latex paint then thin the paint, one part water to one part paint so it won't clog the holes.
secondhander is offline
post #4 of 10 Old 01-17-2012, 10:13 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 911
If you do use latex, get the variety known as 'DTM' (Direct to Metal).
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #5 of 10 Old 01-18-2012, 06:12 AM - Thread Starter
tvuong's Avatar
Liked: 874
The more i think about this, it is best just to leave the grill off as my Polk inwall is kind of dark/black color. I read somewhere that those metal inwall speaker grill can negatively impact the sound. I just need to paint the 4 side egdes around the speaker which is much easy to do. Thanks all for helping.
post #6 of 10 Old 01-18-2012, 01:53 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
http://www.remotecentral.com/cgi-bin...eywords=26539&
That thread from remotecentral has some details on a disposable sprayer from Home Depot, the Preval Sprayer.
Looks pretty awesome, and I will try it if the time comes. I'm looking at some 'narrow bezel' speakers, so I may not paint.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #7 of 10 Old 01-18-2012, 07:12 PM
hoffmand34's Avatar
I used a Preval sprayer and some thinned down leftover wall paint to paint my grills. Do multiple thin coats and you won't clog the holes in the grill. Matches perfectly and looks great.
hoffmand34 is offline
post #8 of 10 Old 08-22-2012, 08:33 AM
scoopy's Avatar
I recently bought Polk Vanishing Series speakers and have been researching ways to paint the grills. There are a lot of great suggestions in AVS threads.
The guy at my local paint shop mentioned Preval but said to be very careful as the risk if sputtering & drips is high.
I am going to give these folks (below) a try as it feels like the easiest way to go for my Left, Right, Centers to be the same as our wall color. This outfit has a big database of the major vendor's colors so I was able to order an exact match for the Benjamin Moore color we are painting the room with. One can of spray paint on the way!
http://www.myperfectcolor.com/Custom-Color-Spray-Paint/33865.htm
scoopy is offline
post #9 of 10 Old 08-23-2012, 08:36 PM
BrittonYoder's Avatar
Liked: 36
I did this as well recently. The preval sprayer is less than $10. They turned out really well. I think I have some pictures posted on my build.
Check out my whole house build HERE
BrittonYoder is offline
post #10 of 10 Old 08-24-2012, 11:00 AM
audiovideoholic's Avatar
Quoted: 588 Post(s)
Liked: 185
An airbrush with thinned paint will also work. I chose to use mine instead of a my paint sprayer for faster clean up. Turned out just about perfect.
audiovideoholic is offline
